WW_Emby 2 Posted December 15, 2023 Posted December 15, 2023 This is a snippet from my Emby Server Log, looks like an issue with TheMovieDB... any one else having this issue? Thursday night ~6pm CST. 2023-12-14 18:09:42.696 Error App: Error in TheMovieDb *** Error Report *** Version: 4.7.14.0 Command line: /system/EmbyServer.dll -programdata /config -ffdetect /bin/ffdetect -ffmpeg /bin/ffmpeg -ffprobe /bin/ffprobe -restartexitcode 3 Operating system: Linux version 6.1.64-Unraid (root@Develop-612) (gcc (GCC) 12.2.0, GNU ld version 2.40-slack151) #1 SMP PREEMPT_DYNAMIC Wed Nov 29 12:48:16 PST 2023 Framework: .NET 6.0.20 OS/Process: x64/x64 Runtime: system/System.Private.CoreLib.dll Processor count: 24 Data path: /config Application path: /system MediaBrowser.Model.Net.HttpException: MediaBrowser.Model.Net.HttpException: Cancelling connection to https://api.themoviedb.org/3/configuration/primary_translations?api_key=x_secret1_x due to a previous timeout. Thanks in advance...
Luke 42185 Posted December 15, 2023 Posted December 15, 2023 Hi, your server is unable to reach moviedb. You could have something blocking that connection such as firewall, security software or vpn. Can you look into those and let us know what you find? But even with that. it’s not stuck. just taking longer due to those timeouts. If you be patient and allow it to finish, it will.
WW_Emby 2 Posted December 15, 2023 Author Posted December 15, 2023 There are no issues from a network security side, issued a traffic rule for the domain just to be safe. Will watch it overnight and see what transpires. Thanks for the input will post if things get scarier - LOL
smoon 10 Posted December 15, 2023 Posted December 15, 2023 It´s an IPv6 Issue. You need to diable IPv6 Network support on your Host which runs the emby server. Had to do that also to get that plugin working properly.
WW_Emby 2 Posted December 15, 2023 Author Posted December 15, 2023 Nothing positive overnight, looked at my server logs and have a networking issue, running that down now. Will let you know how it turns out. Thanks... 1
WW_Emby 2 Posted December 15, 2023 Author Posted December 15, 2023 Put in a new NIC and had to adjust routing table. First time doing on an unRaid server, took be a bit to figure out. Seems to be ok for now. Thanks All 1
