wyhghost 0 Posted December 13, 2023 Posted December 13, 2023 When I was playing some 1080p videos, I encountered this delay. Do you know what's going on? I have encountered this issue on both Windows and Docker. I am currently using the latest official version of Docker on unriad. This issue occurs when playing in Edge, Google Chrome, Android, and iOS's emby apps. If there is anything else you need to provide, please let me know. This issue has been bothering me for a long time. THANKS! demo.mp4 embyserver.txt hardware_detection-63838121778.txt embyserver-63838121770.txt
Luke 42244 Posted December 13, 2023 Posted December 13, 2023 So in this log you're direct playing with Microsoft Edge on the local network?
wyhghost 0 Posted December 14, 2023 Author Posted December 14, 2023 Yes, but this problem can occur both on the local network and external network, unless hardware decoding is used to 720p
wyhghost 0 Posted December 18, 2023 Author Posted December 18, 2023 No, it appears on many files. I haven't found any commonalities among these files yet. Do you have any idea? This issue has occurred on multiple devices of mine and my friend, and I believe it is caused by an issue with the decoding of such video files by the EMBY player. Because playing the same video using a local player or Infuse does not cause any lag,I won't experience any lag when transcoding videos using transcoding software.
Luke 42244 Posted December 18, 2023 Posted December 18, 2023 Is this an mp4. Try dragging the mp4 file into an open chrome browser tab. What happens then?
wyhghost 0 Posted December 18, 2023 Author Posted December 18, 2023 Dragging the video directly to the browser and playing it also lags
Solution Luke 42244 Posted December 19, 2023 Solution Posted December 19, 2023 2 hours ago, wyhghost said: hello,May I ask what caused it? this means it is a problem with the browser video player and not an Emby problem. You could try using Emby's convert media feature to re-encode the file: Convert Media
Luke 42244 Posted December 20, 2023 Posted December 20, 2023 For a more robust video player, why not use Emby Theater for Windows? https://emby.media/emby-theater.html
wyhghost 0 Posted December 20, 2023 Author Posted December 20, 2023 But I have this issue using both and the emby app on iOS and Android
Luke 42244 Posted December 26, 2023 Posted December 26, 2023 On 12/20/2023 at 12:11 AM, wyhghost said: But I have this issue using both and the emby app on iOS and Android Hi, on Windows, can you still give that a try and let us know how that compares? Thanks.
wyhghost 0 Posted February 4, 2024 Author Posted February 4, 2024 On 12/26/2023 at 11:30 AM, Luke said: 嗨,在 Windows 上,您还能尝试一下并让我们知道它如何比较吗?谢谢。 Sorry, may I ask what I need to do? I don't understand the meaning of this sentence
wyhghost 0 Posted February 4, 2024 Author Posted February 4, 2024 Also, everything is normal in folder mode as before This has caused me to search for a movie now, but there is no metadata and cover in the "Popular Results" section, and there is metadata and cover in the "Movie" section
wyhghost 0 Posted February 4, 2024 Author Posted February 4, 2024 1 hour ago, wyhghost said: 此外,文件夹模式下一切正常,和以前一样 这导致我现在搜索电影,但是在"热门结果"部分没有元数据和封面,在"电影"部分有元数据和封面 Sorry, I sent the wrong message
