Orionas21 4 Posted December 13, 2023 Posted December 13, 2023 Hi team, I tried yesterday to convert a movie but the conversion after 11 hours failed... Attached are also the logs from server and ffmpeg. It seems that it is calling the h246_mediacodecndk for the conversion and while it is started successfully when it reaches at the end it fails with: [h264_mediacodecndk @ 0xf4e29700] NdkEnc: Cannot get input pixdesc! Below my transcoding configuration: emby_trans_log.txt emby_server_log.txt
Luke 42237 Posted December 13, 2023 Posted December 13, 2023 Hi, are you able to try the 4.8 beta server and see how that compares?
Orionas21 4 Posted December 14, 2023 Author Posted December 14, 2023 13 hours ago, Luke said: Hi, are you able to try the 4.8 beta server and see how that compares? Hi Luke, Thank you for your suggestion. I will try it within this weekend and report back to you. 1
Orionas21 4 Posted December 20, 2023 Author Posted December 20, 2023 Hi Luke, Unfortunately it is failing now instantly with the below error: WARNING: linker: /data/data/com.emby.embyserver/files/ffmpeg/ffmpeg: unused DT entry: type 0x1d arg 0x14b9 WARNING: linker: /data/data/com.emby.embyserver/files/ffmpeg/ffmpeg: unsupported flags DT_FLAGS_1=0x8000001 CANNOT LINK EXECUTABLE: library "libcamera2ndk.so" not found 2023-12-20 12:27:36.464 Info FfmpegManager: ProcessRun 'ffmpeg -hide_banner -filters' Execute: /data/data/com.emby.embyserver/files/ffmpeg/ffmpeg -hide_banner -filters 2023-12-20 12:27:36.510 Info FfmpegManager: ProcessRun 'ffmpeg -hide_banner -filters' Process exited with code 1 - Failed 2023-12-20 12:27:36.510 Error FfmpegManager: ProcessRun 'ffmpeg -hide_banner -filters' Output: 2023-12-20 12:27:36.510 Error FfmpegManager: ProcessRun 'ffmpeg -hide_banner -filters' Error Output: WARNING: linker: /data/data/com.emby.embyserver/files/ffmpeg/ffmpeg: unused DT entry: type 0x1d arg 0x14b9 WARNING: linker: /data/data/com.emby.embyserver/files/ffmpeg/ffmpeg: unsupported flags DT_FLAGS_1=0x8000001 CANNOT LINK EXECUTABLE: library "libcamera2ndk.so" not found attached also the logs. emby_server_log_20122023.txt emby_trans_log_20122023.txt
Luke 42237 Posted December 20, 2023 Posted December 20, 2023 Ouch, I'm so sorry. Are you able to update this device to a newer version of android?
Orionas21 4 Posted December 20, 2023 Author Posted December 20, 2023 No unfortunately. The support for this device has stopped 2 years ago. So I have the last version of it. Also Realtek chip is out of support for updated drivers. I will search a workaround to download the missing library but do you have anything else to suggest?
Luke 42237 Posted December 21, 2023 Posted December 21, 2023 I'm sorry I should have checked your android version before asking you to install the beta. I apologize. We have bumped up our targeting for android 9 and up.
Orionas21 4 Posted December 22, 2023 Author Posted December 22, 2023 Ok i have uninstall the beta and install the previous one 4.7.14.0. I'm now restoring my server from backup. I had some issues though with that, but managed to overcome them. So the new releases of Emby server for Android will be from Android 9 and up. I was thinking of change my server as i also have some issues in the hdmi (some times the HDR is not working). I was thinking to change it to nvidia shield pro or a Gigabyte Brix Pro BSi3-1115G4. So i kindly ask your opinion on which from the above will be better to run the server(android in Tegra or windows/linux in Core i3-1115G43) for trans-coding up to 2 4k streams with usually 45 Mbps bitrate and EA-C 5.1.2 Atmos audio to 1080p 8 Mbps bitrate with AC3 DD 5.1. I have read many articles about it but i still haven't made up my mind. More specific i want something to be more power efficiency because it will run also as torrent server and it will be running 24/7/365 also for cloud storage and devices backup. I do not prefer NAS because they are very expensive and i have different type of storage for each purpose.
Luke 42237 Posted December 30, 2023 Posted December 30, 2023 Quote android in Tegra or windows/linux in Core i3-1115G43 @Orionas21between these two it sounds to me like the windows machine will be more powerful and will perform better. 1
Orionas21 4 Posted December 30, 2023 Author Posted December 30, 2023 One of my colleagues lend me his laptop with core i5 -1135G7 8G of ram and I was pretty amazed with the transcoding capabilities of this CPU with Xr graphics. It managed successfully to transcode 2 4K 65Mbit streams to 1080p 6Mbit and from DAtmos to AC3. This is pretty much what I need so I'm focusing now to buy a NUC with this CPU or even i7-1165G7 witch is having the same GPU but 96 Cuda rather than 80 of i5. 1
