dustbro 5 Posted December 11, 2023 Posted December 11, 2023 I've recently been getting an error when trying to watch Live TV on channels that need transcoding. *** Error Report *** Version: 4.7.14.0 Command line: /app/emby/EmbyServer.dll -programdata /config -ffdetect /app/emby/ffdetect -ffmpeg /app/emby/ffmpeg -ffprobe /app/emby/ffprobe -restartexitcode 3 Operating system: Linux version 5.15.79+truenas (root@tnsbuilds01.tn.ixsystems.net) (gcc (Debian 10.2.1-6) 10.2.1 20210110, GNU ld (GNU Binutils for Debian) 2.35.2) #1 Framework: .NET 6.0.20 OS/Process: x64/x64 Runtime: app/emby/System.Private.CoreLib.dll Processor count: 4 Data path: /config Application path: /app/emby System.Exception: System.Exception: Error starting ffmpeg at Emby.Server.MediaEncoding.Api.BaseStreamingService.StartFfMpeg(StreamState state, String outputPath, CancellationToken cancellationToken, Boolean acquireResources) at Emby.Server.MediaEncoding.Api.Hls.BaseHlsService.ProcessRequest(StreamRequest request) at Emby.Server.Implementations.Services.ServiceController.GetTaskResult(Task task) at Emby.Server.Implementations.Services.ServiceHandler.ProcessRequestAsync(HttpListenerHost httpHost, IServerApplicationHost appHost, IRequest httpReq, IResponse httpRes, RestPath restPath, String responseContentType, CancellationToken cancellationToken) at Emby.Server.Implementations.HttpServer.HttpListenerHost.RequestHandler(IRequest httpReq, ReadOnlyMemory`1 urlString, ReadOnlyMemory`1 localPath, CancellationToken cancellationToken) Source: Emby.Server.MediaEncoding TargetSite: Void MoveNext() 2023-12-11 09:59:28.773 Info App: ProcessRun 'StreamTranscode c32eb2': Stopping ffmpeg process with q command for /mnt/transcoding-temp/047A76/047A76_0.ts 2023-12-11 09:59:28.862 Info App: ProcessRun 'StreamTranscode c32eb2': Stopping ffmpeg process with q command for /mnt/transcoding-temp/047A76/047A76_0.ts 2023-12-11 09:59:28.921 Info App: AppendExtraLogData - Read graph file: /config/logs/ffmpeg-transcode-c32eb23a-9bec-4670-88d3-ab6214859a24_1graph.txt 2023-12-11 09:59:28.922 Warn App: AppendExtraLogData: Unable read graph output file: /config/logs/ffmpeg-transcode-c32eb23a-9bec-4670-88d3-ab6214859a24_1graph.txt 2023-12-11 09:59:28.924 Info App: ProcessRun 'StreamTranscode c32eb2' Process exited with code 137 - Failed What's the starting point to debug this issue?
Luke 42245 Posted December 11, 2023 Posted December 11, 2023 Hi there, please attach the complete emby server log file. Thanks.
dustbro 5 Posted December 12, 2023 Author Posted December 12, 2023 Server Log attached. embyserver.txt
Luke 42245 Posted December 30, 2023 Posted December 30, 2023 Hi @dustbrohow did you install Emby Server?
