M3L1H 1 Posted December 10, 2023 Posted December 10, 2023 Hi, I have activated hardware decoder on my rpi 4b aarch64 64bit bullseye. I normally do not see hardware codec symbol while watching something but today I saw it when I try to watch a new movie. It used hardware decoder but output was too bad. If i disable hardware decoder, video runs without any problem with software decoder. I also do not why I have only 1 hardware decoder/encoder.. can you help me on this? Thank you! ffmpeg-transcode-66ae9d5e-087b-4589-ba39-674dc255a421_1.txt ffmpeg-transcode-6dbc4e0e-5f3e-444f-bd81-1bfa61000e0f_1.txt embyserver.txt
Luke 42245 Posted December 17, 2023 Posted December 17, 2023 @M3L1Hare you able to try the 4.8 beta server and see how that compares?
M3L1H 1 Posted December 17, 2023 Author Posted December 17, 2023 Result is same. But what I did is I re-installed 32bit instead of 64bit. I choose mmal encoder/decoders this time. It worked without any problem. I do not have those options on 64bit, only v4l2 decoder available. I have installed latest ffmpeg from git but no new option appeared at menu. 64 bit os painful on emby, I have to use software encoder/decoder even I bought lifetime subscription..
Luke 42245 Posted December 17, 2023 Posted December 17, 2023 24 minutes ago, M3L1H said: Result is same. But what I did is I re-installed 32bit instead of 64bit. I choose mmal encoder/decoders this time. It worked without any problem. I do not have those options on 64bit, only v4l2 decoder available. I have installed latest ffmpeg from git but no new option appeared at menu. 64 bit os painful on emby, I have to use software encoder/decoder even I bought lifetime subscription.. Can you please attach log file examples from that? Thanks.
M3L1H 1 Posted December 18, 2023 Author Posted December 18, 2023 Unfortunately, I can't. I gave up and installed 64bit, I use software decoder only.
