Xreal AIr2 & Beam succesfully sideloaded Emby on Beam Device
In case anyone looking for the same I downloaded the ARM64 version, literally just done and although early days all appears to be working well, just downloading a couple of episodes for offline testing as that will be my normal usage, take from far from the drudgery that is commuting into London .
Hi, that's great. Thanks for sharing.
  • 3 months later...
  • 1 year later...
bobaldis
On 12/03/2024 at 09:45, chinswain said:
How's it been so far @bobaldis?
@chinswainApologies I'm a little late to respond 🙄
But although loads and plays, you lose all controls and have to reboot the device to exit, shame would love to watch my content on my glasses.
Bob
Edited by bobaldis
  • Thanks 1
chinswain
I've reverted to using the android app, works well except the phone screen must stay on, I use a wireless charger at home and I found a device that allows you to have the charger and glasses plugged in at the same time.
  • Thanks 1
