sward 28 Posted February 17, 2024 Author Posted February 17, 2024 On 2/14/2024 at 4:57 PM, Luke said: OK I did find an issue where if a stream takes more than a few seconds to open, the server will end up closing it instead of waiting. So that's resolved in 4.8.2. Do we have an ETA for 4.8.2? I currently have to use a different product to record my shows, but the interface is terrible, so I would much rather get back to using Emby. 1
Ronstang 294 Posted February 17, 2024 Posted February 17, 2024 That's good news Luke, but my question is it seems the issue of the web app for me not wanting to tune has been resolved in the latest beta so it appears you found the issue there also and is that going to make it into 4.8.2? 1
sward 28 Posted February 24, 2024 Author Posted February 24, 2024 So another week has passed with no release of a bug fix. Since you've identified the issue "where if a stream takes more than a few seconds to open, the server will end up closing it instead of waiting", how difficult would it be to release a quick fix?
Ronstang 294 Posted February 24, 2024 Posted February 24, 2024 4 hours ago, sward said: So another week has passed with no release of a bug fix. Since you've identified the issue "where if a stream takes more than a few seconds to open, the server will end up closing it instead of waiting", how difficult would it be to release a quick fix? You have to get in the mindset that "emby time" is kind of like "God time"......a year to us could be a minute the to them
sward 28 Posted March 4, 2024 Author Posted March 4, 2024 Good news - 4.8.3 fixed the recording issues with Ceton/cetonproxy, so I no longer have to use Channels DVR! 1 1 1
Ronstang 294 Posted March 4, 2024 Posted March 4, 2024 3 hours ago, sward said: Good news - 4.8.3 fixed the recording issues with Ceton/cetonproxy, so I no longer have to use Channels DVR! That's good to hear, I haven't had time to start using the stable again for recordings. I will when I return from California. I did test it quickly and the tuners are working again in the web app so that's a positive. I sure hope you're right because I stopped complaining about this issue years ago because they kept telling me it was a problem with my tuner card....but I have 5 and switching in a brand new one never changed the issue so I knew that was baloney.
sward 28 Posted March 5, 2024 Author Posted March 5, 2024 20 hours ago, Ronstang said: That's good to hear, I haven't had time to start using the stable again for recordings. I will when I return from California. I did test it quickly and the tuners are working again in the web app so that's a positive. I sure hope you're right because I stopped complaining about this issue years ago because they kept telling me it was a problem with my tuner card....but I have 5 and switching in a brand new one never changed the issue so I knew that was baloney. To test your Ceton cards separately from Emby you can use VLC. Just open a network stream and type in the url http://192.168.1.4:5004/auto/v1234 but replace the IP with that of your PC running cetonproxy, and replace 1234 with the channel you want to test. If you're able to get a live stream this way, then you've proven your cards are fine!
Ronstang 294 Posted March 6, 2024 Posted March 6, 2024 20 hours ago, sward said: If you're able to get a live stream this way, then you've proven your cards are fine! Thanks for the info, but I was always sure my cards are fine. The truncated recordings NEVER happened in WMC and having 5 cards I was able to open a brand new one and replace the other, and the exact same issue persisted so it was kind of hard to claim it's a problem with the card when no matter which card I tried it repeated. Now, having something to do with the proxy, that is totally believable and I suspect that the fix Luke implemented just works around a flaw that comes from using the proxy. They could just release NextTV and solve all these issues since it is supposedly complete and running....but that is another issue I won't hold my breath over.
iiiJoe 62 Posted March 6, 2024 Posted March 6, 2024 14 hours ago, Ronstang said: They could just release NextTV and solve all these issues since it is supposedly complete and running Keep seeing things about NextTV. Just wondering what it is? Better platform?
pwhodges 2033 Posted March 6, 2024 Posted March 6, 2024 New implementation of the entire LiveTV subsystem, including native support for a much wider range of hardware, and many other improvements over the existing implementation. It was in a usable beta state over a year ago, but it has not yet been taken forward as a definitive replacement for the old. This is frustrating, but we have been told that a decision will be made shortly - yes or no without any remaining maybe option. There has been no hint of why they would want to shelve it. More here: Paul
iiiJoe 62 Posted March 6, 2024 Posted March 6, 2024 Sounds really exciting. Would the new system still use ffmpeg or something different?
Carlo 4561 Posted March 19, 2025 Posted March 19, 2025 On 3/6/2024 at 6:35 PM, iiiJoe said: Sounds really exciting. Would the new system still use ffmpeg or something different? For transcoding, yes it would be used as normal. ffmpeg/ffprobe won't be used for stream acquisition, as it is currently used. TVNext, bypasses the use of ffmpeg for stream acquisition by handling this functionality directly. In rare cases, if some combination of protocol/codec/package wasn't directly supported, TVNext could fallback to using ffmpeg for compatibility (wouldn't be common). Carlo 1
iiiJoe 62 Posted March 20, 2025 Posted March 20, 2025 (edited) 21 hours ago, Carlo said: For transcoding, yes it would be used as normal. ffmpeg/ffprobe won't be used for stream acquisition, as it is currently used. TVNext, bypasses the use of ffmpeg for stream acquisition by handling this functionality directly. In rare cases, if some combination of protocol/codec/package wasn't directly supported, TVNext could fallback to using ffmpeg for compatibility (wouldn't be common). Carlo Hi, Carlo! So, would TVNext be more stable on handling m3u streams that are not perfect? I’m specifically wondering about failed recordings due to an interruption in the stream for whatever reason. Currently Emby marks a recording as completed when this happens which requires the user to catch the failure and manually restart the recording. Edited March 20, 2025 by iiiJoe
Carlo 4561 Posted March 21, 2025 Posted March 21, 2025 TVNext should be more stable handling streams in general, perfect or not. TVNext development and testing has been focused on live use of streams (hardware tuner to iptv) and of course channel management, but not on recording functionality per say. Carlo
iiiJoe 62 Posted March 21, 2025 Posted March 21, 2025 59 minutes ago, Carlo said: TVNext should be more stable handling streams in general, perfect or not. TVNext development and testing has been focused on live use of streams (hardware tuner to iptv) and of course channel management, but not on recording functionality per say. Carlo Look forward to seeing it in action. Any idea on when it will be available?
Carlo 4561 Posted March 21, 2025 Posted March 21, 2025 20 hours ago, iiiJoe said: Look forward to seeing it in action. Any idea on when it will be available? In the next beta, after 4.9 is released. 1
