sward 28 Posted February 6, 2024 Author Posted February 6, 2024 5 hours ago, denz said: Unfortunately, I couldn't roll back I did the whole install again. In my case it's not that hard the only hard part was to recreate all the series recordings again. I did run into an issue it was automatically updating so I posted a question in the server section how to stop auto update. Family is once again happy. You don't need to recreate the series recordings, just backup & restore the two files under "Emby-server\programdata\data\livetv". In fact, when reinstalling there's no need to delete the "programdata" folder at all, as this contains all your libraries, series recordings etc... Just delete the "Emby-server\system" folder which contains the actual Emby program. You can then reinstall Emby using the portable installation files which extract everything to a new "system" folder.
sward 28 Posted February 7, 2024 Author Posted February 7, 2024 So I downloaded 4.8.1.0 just now and tried live streaming a channel, but it's now saying "Tuner not found" (see attached log) even though the tuner is still defined. Also, as a sanity check I'm able to open a live network stream of the same channel in the VLC player using the following URL: http://192.168.1.4:5004/auto/v603 Tuner not found.txt
Luke 42241 Posted February 7, 2024 Posted February 7, 2024 16 minutes ago, sward said: So I downloaded 4.8.1.0 just now and tried live streaming a channel, but it's now saying "Tuner not found" (see attached log) even though the tuner is still defined. Also, as a sanity check I'm able to open a live network stream of the same channel in the VLC player using the following URL: http://192.168.1.4:5004/auto/v603 Tuner not found.txt 57.79 kB · 0 downloads I would try running your refresh guide scheduled task and see if that helps.
sward 28 Posted February 7, 2024 Author Posted February 7, 2024 16 minutes ago, Luke said: I would try running your refresh guide scheduled task and see if that helps. After refreshing the guide data my EPG is now empty. If I look at my channels they are all listed as not mapped to guide data.
sward 28 Posted February 8, 2024 Author Posted February 8, 2024 I was able to restore the EPG by running the cetonproxy GUI and adding back the channels (see attached image file), which I have to do a couple times a year. I then scheduled a recording of Chris Hayes to start at 8PM with a 4 minute buffer, which failed with error message "Error probing live tv stream." I was, however, able to launch a live stream of this same show a couple of minutes later by selecting it in the EPG, but any subsequent attempts to launch a live stream failed. It's almost like the one stream I opened never closed, so that when I try to open it again it fails. Details in the attached log. At least I have my EPG back, and I'm no longer getting "Tuner not found" messages. That's progress I guess, but we're back to where I was when I was upgraded to 4.8.0.80. Chris Hayes.txt
iiiJoe 62 Posted February 8, 2024 Posted February 8, 2024 I really wish I could help but I use an m3u
pwhodges 2033 Posted February 8, 2024 Posted February 8, 2024 You are not the only one to report a problem with a Ceton tuner: Paul
Ronstang 294 Posted February 8, 2024 Posted February 8, 2024 @swardGo to your TV and see if you can tune to a channel on LiveTV. This is how it works for me with a Ceton card. The proxy is working and the tuner is actually working and on my TWO servers I can tune a channel from the TV app but not from the web app on either system. So the issue seems to be with the web app. Strangely, if I set a program to record from within the web app it fails and just creates an empy directory. If I set a program to record from one of my TVs then it records fine....so this the web app is definitely the problem. A note about the latest 2 upgrades....4.8.1.0 stable and 4.9.0.1 beta....I tried them both and each one had the same behavior. After starting the server and going to the web app for the first time I could tune to a channel within the web app. Then as a test I tried a different channel and it would not tune, so I went back and tried the first channel again and this time it would not tune and after that no channels will tune on either server until a restart. It's the web app but I keep getting told it's me. I don't know what more info they want. I have provided many logs as the behavior has been the same since beta 4.8.075 and stable 4.8.0.80 but it all falls on deaf ears. I feel like I am talking to the cable company who thinks because I have my own equipment all signal issues are due to that and they ignore me.
sward 28 Posted February 8, 2024 Author Posted February 8, 2024 (edited) 5 hours ago, Ronstang said: @swardGo to your TV and see if you can tune to a channel on LiveTV. This is how it works for me with a Ceton card. The proxy is working and the tuner is actually working and on my TWO servers I can tune a channel from the TV app but not from the web app on either system. So the issue seems to be with the web app. Strangely, if I set a program to record from within the web app it fails and just creates an empy directory. If I set a program to record from one of my TVs then it records fine....so this the web app is definitely the problem. A note about the latest 2 upgrades....4.8.1.0 stable and 4.9.0.1 beta....I tried them both and each one had the same behavior. After starting the server and going to the web app for the first time I could tune to a channel within the web app. Then as a test I tried a different channel and it would not tune, so I went back and tried the first channel again and this time it would not tune and after that no channels will tune on either server until a restart. It's the web app but I keep getting told it's me. I don't know what more info they want. I have provided many logs as the behavior has been the same since beta 4.8.075 and stable 4.8.0.80 but it all falls on deaf ears. I feel like I am talking to the cable company who thinks because I have my own equipment all signal issues are due to that and they ignore me. The Emby app on my Sony TV isn't working for me, meaning I can't start a live stream that way or any other way for that matter. Edited February 8, 2024 by sward
sward 28 Posted February 8, 2024 Author Posted February 8, 2024 Is there any interest in getting 4.8.1.0 working with Ceton/cetonproxy? Just wondering b/c it's the best CableCARD tuner out there in that certain models like the InfiniTV 6 ETH can record 6 simultaneous TV channels vs the 4 that HDHomerun supports. In fact it would be great if you could incorporate cetonproxy directly into Emby, or better yet support Ceton CableCARD tuners natively, at least the Ethernet-based ones. The cetonproxy source code is up on GitHub so I would imagine it's open source (https://github.com/craigmox/cetonproxy). It hasn't been updated in 4 or 5 years, so I'm just dreading the moment when some Windows update will break it, but so far it still works great. If there's no interest, please let me know so I and other Ceton users can move on. I've already got it working with "Channels DVR" since I cannot record anything with Emby currently.
Luke 42241 Posted February 8, 2024 Posted February 8, 2024 CetonProxy is intended to mimic the HDHR api and as long as it's doing that then it should work just fine. The error in your log suggests that the channel you're trying to play doesn't exist in the CetonProxy response anymore. That could also be why you saw loss of guide data after refreshing the guide. if you put these urls in a browser: http://192.168.1.4:5004/discover.json http://192.168.1.4:5004/lineup.json What are the responses?
sward 28 Posted February 8, 2024 Author Posted February 8, 2024 Here's the output for each URL. As far as I can tell, everything is working correctly. http://192.168.1.4:5004/discover.json: =============================== {"FriendlyName":"HDHomeRun PRIME","ModelNumber":"HDHR3-CC","FirmwareName":"hdhomerun3_cablecard","FirmwareVersion":"20160630atest2","DeviceID":"13107550","DeviceAuth":"abcdefg","TunerCount":6,"BaseURL":"http:\/\/192.168.1.4:5004","LineupURL":"http:\/\/192.168.1.4:5004\/lineup.json"} http://192.168.1.4:5004/lineup.json: ============================= [{"GuideNumber":"2","GuideName":"WMDE ShopHQ","URL":"http:\/\/192.168.1.4:5004\/auto\/v2"},{"GuideNumber":"3","GuideName":"CW-WDCW","URL":"http:\/\/192.168.1.4:5004\/auto\/v3"},{"GuideNumber":"4","GuideName":"WRC","URL":"http:\/\/192.168.1.4:5004\/auto\/v4"},{"GuideNumber":"5","GuideName":"WTTG","URL":"http:\/\/192.168.1.4:5004\/auto\/v5"},{"GuideNumber":"6","GuideName":"WDCA Fox 5 Plus","URL":"http:\/\/192.168.1.4:5004\/auto\/v6"},{"GuideNumber":"7","GuideName":"WJLA","URL":"http:\/\/192.168.1.4:5004\/auto\/v7"},{"GuideNumber":"8","GuideName":"News Channel 8_1001","URL":"http:\/\/192.168.1.4:5004\/auto\/v8"},{"GuideNumber":"9","GuideName":"WUSA","URL":"http:\/\/192.168.1.4:5004\/auto\/v9"},{"GuideNumber":"10","GuideName":"local_PEG_10","URL":"http:\/\/192.168.1.4:5004\/auto\/v10"},{"GuideNumber":"11","GuideName":"local_PEG_11","URL":"http:\/\/192.168.1.4:5004\/auto\/v11"},{"GuideNumber":"12","GuideName":"local_PEG_12","URL":"http:\/\/192.168.1.4:5004\/auto\/v12"},{"GuideNumber":"13","GuideName":"WPXW","URL":"http:\/\/192.168.1.4:5004\/auto\/v13"},{"GuideNumber":"14","GuideName":"WFDC","URL":"http:\/\/192.168.1.4:5004\/auto\/v14"},{"GuideNumber":"15","GuideName":"WDCA Heroes & Icons","URL":"http:\/\/192.168.1.4:5004\/auto\/v15"},{"GuideNumber":"16","GuideName":"local_PEG_16","URL":"http:\/\/192.168.1.4:5004\/auto\/v16"},{"GuideNumber":"17","GuideName":"WFDC UniMas SD","URL":"http:\/\/192.168.1.4:5004\/auto\/v17"},{"GuideNumber":"18","GuideName":"local_PEG_18","URL":"http:\/\/192.168.1.4:5004\/auto\/v18"},{"GuideNumber":"19","GuideName":"local_PEG_19","URL":"http:\/\/192.168.1.4:5004\/auto\/v19"},{"GuideNumber":"20","GuideName":"WZDC","URL":"http:\/\/192.168.1.4:5004\/auto\/v20"},{"GuideNumber":"21","GuideName":"local_PEG_21","URL":"http:\/\/192.168.1.4:5004\/auto\/v21"},{"GuideNumber":"22","GuideName":"MPT 2","URL":"http:\/\/192.168.1.4:5004\/auto\/v22"},{"GuideNumber":"23","GuideName":"WDME MeTV SD","URL":"http:\/\/192.168.1.4:5004\/auto\/v23"},{"GuideNumber":"25","GuideName":"local_PEG_25","URL":"http:\/\/192.168.1.4:5004\/auto\/v25"},{"GuideNumber":"26","GuideName":"WETA","URL":"http:\/\/192.168.1.4:5004\/auto\/v26"},{"GuideNumber":"27","GuideName":"WQAW Azteca","URL":"http:\/\/192.168.1.4:5004\/auto\/v27"},{"GuideNumber":"28","GuideName":"local_PEG_28","URL":"http:\/\/192.168.1.4:5004\/auto\/v28"},{"GuideNumber":"29","GuideName":"WASA Estrella TV","URL":"http:\/\/192.168.1.4:5004\/auto\/v29"},{"GuideNumber":"30","GuideName":"local_PEG_30","URL":"http:\/\/192.168.1.4:5004\/auto\/v30"},{"GuideNumber":"31","GuideName":"WDVM TV","URL":"http:\/\/192.168.1.4:5004\/auto\/v31"},{"GuideNumber":"32","GuideName":"WHUT","URL":"http:\/\/192.168.1.4:5004\/auto\/v32"},{"GuideNumber":"33","GuideName":"WJAL SonLife","URL":"http:\/\/192.168.1.4:5004\/auto\/v33"},{"GuideNumber":"35","GuideName":"local_PEG_35","URL":"http:\/\/192.168.1.4:5004\/auto\/v35"},{"GuideNumber":"36","GuideName":"local_PEG_36","URL":"http:\/\/192.168.1.4:5004\/auto\/v36"},{"GuideNumber":"37","GuideName":"local_PEG_37","URL":"http:\/\/192.168.1.4:5004\/auto\/v37"},{"GuideNumber":"38","GuideName":"local_PEG_38","URL":"http:\/\/192.168.1.4:5004\/auto\/v38"},{"GuideNumber":"39","GuideName":"local_PEG_39","URL":"http:\/\/192.168.1.4:5004\/auto\/v39"},{"GuideNumber":"40","GuideName":"local_PEG_40","URL":"http:\/\/192.168.1.4:5004\/auto\/v40"},{"GuideNumber":"41","GuideName":"local_PEG_41","URL":"http:\/\/192.168.1.4:5004\/auto\/v41"},{"GuideNumber":"42","GuideName":"local_PEG_42","URL":"http:\/\/192.168.1.4:5004\/auto\/v42"},{"GuideNumber":"43","GuideName":"local_PEG_43","URL":"http:\/\/192.168.1.4:5004\/auto\/v43"},{"GuideNumber":"44","GuideName":"local_PEG_44","URL":"http:\/\/192.168.1.4:5004\/auto\/v44"},{"GuideNumber":"50","GuideName":"USA (East)","URL":"http:\/\/192.168.1.4:5004\/auto\/v50"},{"GuideNumber":"51","GuideName":"TNT (East)","URL":"http:\/\/192.168.1.4:5004\/auto\/v51"},{"GuideNumber":"52","GuideName":"TBS (East)","URL":"http:\/\/192.168.1.4:5004\/auto\/v52"},{"GuideNumber":"54","GuideName":"Paramount Network","URL":"http:\/\/192.168.1.4:5004\/auto\/v54"},{"GuideNumber":"61","GuideName":"Rogue One Live Red Carpet Event","URL":"http:\/\/192.168.1.4:5004\/auto\/v61"},{"GuideNumber":"68","GuideName":"NewsNation","URL":"http:\/\/192.168.1.4:5004\/auto\/v68"},{"GuideNumber":"70","GuideName":"ESPN","URL":"http:\/\/192.168.1.4:5004\/auto\/v70"},{"GuideNumber":"71","GuideName":"ACC Network","URL":"http:\/\/192.168.1.4:5004\/auto\/v71"},{"GuideNumber":"72","GuideName":"ESPNews","URL":"http:\/\/192.168.1.4:5004\/auto\/v72"},{"GuideNumber":"73","GuideName":"ESPNU","URL":"http:\/\/192.168.1.4:5004\/auto\/v73"},{"GuideNumber":"74","GuideName":"ESPN 2","URL":"http:\/\/192.168.1.4:5004\/auto\/v74"},{"GuideNumber":"75","GuideName":"SEC Network National","URL":"http:\/\/192.168.1.4:5004\/auto\/v75"},{"GuideNumber":"76","GuideName":"Monumental SN-Was","URL":"http:\/\/192.168.1.4:5004\/auto\/v76"},{"GuideNumber":"77","GuideName":"MASN","URL":"http:\/\/192.168.1.4:5004\/auto\/v77"},{"GuideNumber":"78","GuideName":"Monumental SN 2","URL":"http:\/\/192.168.1.4:5004\/auto\/v78"},{"GuideNumber":"79","GuideName":"MASN 2","URL":"http:\/\/192.168.1.4:5004\/auto\/v79"},{"GuideNumber":"83","GuideName":"Fox Sports 1","URL":"http:\/\/192.168.1.4:5004\/auto\/v83"},{"GuideNumber":"84","GuideName":"Fox Sports 2","URL":"http:\/\/192.168.1.4:5004\/auto\/v84"},{"GuideNumber":"85","GuideName":"BTN","URL":"http:\/\/192.168.1.4:5004\/auto\/v85"},{"GuideNumber":"86","GuideName":"MLB Network SD","URL":"http:\/\/192.168.1.4:5004\/auto\/v86"},{"GuideNumber":"87","GuideName":"NHL Network","URL":"http:\/\/192.168.1.4:5004\/auto\/v87"},{"GuideNumber":"88","GuideName":"NFL Network","URL":"http:\/\/192.168.1.4:5004\/auto\/v88"},{"GuideNumber":"89","GuideName":"NBA TV","URL":"http:\/\/192.168.1.4:5004\/auto\/v89"},{"GuideNumber":"90","GuideName":"NBC Sports Network","URL":"http:\/\/192.168.1.4:5004\/auto\/v90"},{"GuideNumber":"91","GuideName":"Olympic Channel SD","URL":"http:\/\/192.168.1.4:5004\/auto\/v91"},{"GuideNumber":"92","GuideName":"Tennis Channel","URL":"http:\/\/192.168.1.4:5004\/auto\/v92"},{"GuideNumber":"93","GuideName":"Golf Channel","URL":"http:\/\/192.168.1.4:5004\/auto\/v93"},{"GuideNumber":"94","GuideName":"CBS Sports Network","URL":"http:\/\/192.168.1.4:5004\/auto\/v94"},{"GuideNumber":"96","GuideName":"SportsNet NY (OOM)","URL":"http:\/\/192.168.1.4:5004\/auto\/v96"},{"GuideNumber":"97","GuideName":"NESN National","URL":"http:\/\/192.168.1.4:5004\/auto\/v97"},{"GuideNumber":"100","GuideName":"CNN","URL":"http:\/\/192.168.1.4:5004\/auto\/v100"},{"GuideNumber":"101","GuideName":"CNN Headline News","URL":"http:\/\/192.168.1.4:5004\/auto\/v101"},{"GuideNumber":"102","GuideName":"CNBC","URL":"http:\/\/192.168.1.4:5004\/auto\/v102"},{"GuideNumber":"103","GuideName":"MSNBC","URL":"http:\/\/192.168.1.4:5004\/auto\/v103"},{"GuideNumber":"104","GuideName":"Bloomburg TV","URL":"http:\/\/192.168.1.4:5004\/auto\/v104"},{"GuideNumber":"105","GuideName":"CNN International","URL":"http:\/\/192.168.1.4:5004\/auto\/v105"},{"GuideNumber":"106","GuideName":"CNBC World","URL":"http:\/\/192.168.1.4:5004\/auto\/v106"},{"GuideNumber":"107","GuideName":"BBC News","URL":"http:\/\/192.168.1.4:5004\/auto\/v107"},{"GuideNumber":"108","GuideName":"Fusion","URL":"http:\/\/192.168.1.4:5004\/auto\/v108"},{"GuideNumber":"109","GuideName":"C-SPAN","URL":"http:\/\/192.168.1.4:5004\/auto\/v109"},{"GuideNumber":"110","GuideName":"C-SPAN 2","URL":"http:\/\/192.168.1.4:5004\/auto\/v110"},{"GuideNumber":"111","GuideName":"C-SPAN 3","URL":"http:\/\/192.168.1.4:5004\/auto\/v111"},{"GuideNumber":"112","GuideName":"The Blaze TV","URL":"http:\/\/192.168.1.4:5004\/auto\/v112"},{"GuideNumber":"113","GuideName":"Fox Weather","URL":"http:\/\/192.168.1.4:5004\/auto\/v113"},{"GuideNumber":"114","GuideName":"Al Jazeera America","URL":"http:\/\/192.168.1.4:5004\/auto\/v114"},{"GuideNumber":"115","GuideName":"Newsmax TV Slate","URL":"http:\/\/192.168.1.4:5004\/auto\/v115"},{"GuideNumber":"116","GuideName":"Newsmax TV","URL":"http:\/\/192.168.1.4:5004\/auto\/v116"},{"GuideNumber":"117","GuideName":"Fox Business Channel","URL":"http:\/\/192.168.1.4:5004\/auto\/v117"},{"GuideNumber":"118","GuideName":"Fox News","URL":"http:\/\/192.168.1.4:5004\/auto\/v118"},{"GuideNumber":"119","GuideName":"AccuWeather DC MD VA","URL":"http:\/\/192.168.1.4:5004\/auto\/v119"},{"GuideNumber":"120","GuideName":"Discovery East","URL":"http:\/\/192.168.1.4:5004\/auto\/v120"},{"GuideNumber":"122","GuideName":"Science Channel","URL":"http:\/\/192.168.1.4:5004\/auto\/v122"},{"GuideNumber":"123","GuideName":"Investigation Discovery","URL":"http:\/\/192.168.1.4:5004\/auto\/v123"},{"GuideNumber":"125","GuideName":"American Heroes Channel","URL":"http:\/\/192.168.1.4:5004\/auto\/v125"},{"GuideNumber":"126","GuideName":"Military History Channel","URL":"http:\/\/192.168.1.4:5004\/auto\/v126"},{"GuideNumber":"127","GuideName":"VICE","URL":"http:\/\/192.168.1.4:5004\/auto\/v127"},{"GuideNumber":"128","GuideName":"History Channel","URL":"http:\/\/192.168.1.4:5004\/auto\/v128"},{"GuideNumber":"129","GuideName":"FYI","URL":"http:\/\/192.168.1.4:5004\/auto\/v129"},{"GuideNumber":"130","GuideName":"Animal Planet","URL":"http:\/\/192.168.1.4:5004\/auto\/v130"},{"GuideNumber":"131","GuideName":"Barker 3 - FIOS TV Info-Mercury","URL":"http:\/\/192.168.1.4:5004\/auto\/v131"},{"GuideNumber":"134","GuideName":"Smithsonian Channel SD","URL":"http:\/\/192.168.1.4:5004\/auto\/v134"},{"GuideNumber":"139","GuideName":"TLC (East)","URL":"http:\/\/192.168.1.4:5004\/auto\/v139"},{"GuideNumber":"140","GuideName":"Lifetime East","URL":"http:\/\/192.168.1.4:5004\/auto\/v140"},{"GuideNumber":"141","GuideName":"LMN","URL":"http:\/\/192.168.1.4:5004\/auto\/v141"},{"GuideNumber":"142","GuideName":"Lifetime Real Women","URL":"http:\/\/192.168.1.4:5004\/auto\/v142"},{"GuideNumber":"144","GuideName":"Oxygen East","URL":"http:\/\/192.168.1.4:5004\/auto\/v144"},{"GuideNumber":"145","GuideName":"OWN SD","URL":"http:\/\/192.168.1.4:5004\/auto\/v145"},{"GuideNumber":"149","GuideName":"Women's Entertainment TV","URL":"http:\/\/192.168.1.4:5004\/auto\/v149"},{"GuideNumber":"150","GuideName":"QVC","URL":"http:\/\/192.168.1.4:5004\/auto\/v150"},{"GuideNumber":"151","GuideName":"HSN","URL":"http:\/\/192.168.1.4:5004\/auto\/v151"},{"GuideNumber":"152","GuideName":"Jewelry","URL":"http:\/\/192.168.1.4:5004\/auto\/v152"},{"GuideNumber":"153","GuideName":"QVC 2","URL":"http:\/\/192.168.1.4:5004\/auto\/v153"},{"GuideNumber":"154","GuideName":"HSN2","URL":"http:\/\/192.168.1.4:5004\/auto\/v154"},{"GuideNumber":"155","GuideName":"FETV","URL":"http:\/\/192.168.1.4:5004\/auto\/v155"},{"GuideNumber":"156","GuideName":"ShopHQ Health","URL":"http:\/\/192.168.1.4:5004\/auto\/v156"},{"GuideNumber":"157","GuideName":"ShopHQ","URL":"http:\/\/192.168.1.4:5004\/auto\/v157"},{"GuideNumber":"158","GuideName":"WOW OnTV4U","URL":"http:\/\/192.168.1.4:5004\/auto\/v158"},{"GuideNumber":"159","GuideName":"ShopLC","URL":"http:\/\/192.168.1.4:5004\/auto\/v159"},{"GuideNumber":"160","GuideName":"Great American Country","URL":"http:\/\/192.168.1.4:5004\/auto\/v160"},{"GuideNumber":"161","GuideName":"Discovery Life","URL":"http:\/\/192.168.1.4:5004\/auto\/v161"},{"GuideNumber":"162","GuideName":"Z Living","URL":"http:\/\/192.168.1.4:5004\/auto\/v162"},{"GuideNumber":"163","GuideName":"Cooking Channel","URL":"http:\/\/192.168.1.4:5004\/auto\/v163"},{"GuideNumber":"164","GuideName":"Food Network East","URL":"http:\/\/192.168.1.4:5004\/auto\/v164"},{"GuideNumber":"165","GuideName":"Home & Garden TV","URL":"http:\/\/192.168.1.4:5004\/auto\/v165"},{"GuideNumber":"167","GuideName":"Magnolia Network","URL":"http:\/\/192.168.1.4:5004\/auto\/v167"},{"GuideNumber":"168","GuideName":"Destination America SD","URL":"http:\/\/192.168.1.4:5004\/auto\/v168"},{"GuideNumber":"169","GuideName":"AWE","URL":"http:\/\/192.168.1.4:5004\/auto\/v169"},{"GuideNumber":"170","GuideName":"Travel Channel","URL":"http:\/\/192.168.1.4:5004\/auto\/v170"},{"GuideNumber":"172","GuideName":"Deals TV","URL":"http:\/\/192.168.1.4:5004\/auto\/v172"},{"GuideNumber":"173","GuideName":"Lifehak","URL":"http:\/\/192.168.1.4:5004\/auto\/v173"},{"GuideNumber":"174","GuideName":"Lifehak2","URL":"http:\/\/192.168.1.4:5004\/auto\/v174"},{"GuideNumber":"175","GuideName":"Lifehak3","URL":"http:\/\/192.168.1.4:5004\/auto\/v175"},{"GuideNumber":"176","GuideName":"Lifehak4","URL":"http:\/\/192.168.1.4:5004\/auto\/v176"},{"GuideNumber":"177","GuideName":"Xtra","URL":"http:\/\/192.168.1.4:5004\/auto\/v177"},{"GuideNumber":"178","GuideName":"Mall","URL":"http:\/\/192.168.1.4:5004\/auto\/v178"},{"GuideNumber":"179","GuideName":"TODAY","URL":"http:\/\/192.168.1.4:5004\/auto\/v179"},{"GuideNumber":"180","GuideName":"SYFY (East)","URL":"http:\/\/192.168.1.4:5004\/auto\/v180"},{"GuideNumber":"181","GuideName":"A&E East","URL":"http:\/\/192.168.1.4:5004\/auto\/v181"},{"GuideNumber":"182","GuideName":"Crime & Investigation","URL":"http:\/\/192.168.1.4:5004\/auto\/v182"},{"GuideNumber":"183","GuideName":"tru TV East","URL":"http:\/\/192.168.1.4:5004\/auto\/v183"},{"GuideNumber":"184","GuideName":"Game Show Network","URL":"http:\/\/192.168.1.4:5004\/auto\/v184"},{"GuideNumber":"185","GuideName":"Bravo","URL":"http:\/\/192.168.1.4:5004\/auto\/v185"},{"GuideNumber":"186","GuideName":"Justice Central.TV","URL":"http:\/\/192.168.1.4:5004\/auto\/v186"},{"GuideNumber":"187","GuideName":"Logo","URL":"http:\/\/192.168.1.4:5004\/auto\/v187"},{"GuideNumber":"188","GuideName":"Ovation","URL":"http:\/\/192.168.1.4:5004\/auto\/v188"},{"GuideNumber":"189","GuideName":"BBC America","URL":"http:\/\/192.168.1.4:5004\/auto\/v189"},{"GuideNumber":"190","GuideName":"Comedy Central East","URL":"http:\/\/192.168.1.4:5004\/auto\/v190"},{"GuideNumber":"192","GuideName":"Pivot","URL":"http:\/\/192.168.1.4:5004\/auto\/v192"},{"GuideNumber":"193","GuideName":"Chiller","URL":"http:\/\/192.168.1.4:5004\/auto\/v193"},{"GuideNumber":"194","GuideName":"POP East","URL":"http:\/\/192.168.1.4:5004\/auto\/v194"},{"GuideNumber":"196","GuideName":"E! TV East","URL":"http:\/\/192.168.1.4:5004\/auto\/v196"},{"GuideNumber":"198","GuideName":"El Rey","URL":"http:\/\/192.168.1.4:5004\/auto\/v198"},{"GuideNumber":"199","GuideName":"Freeform East","URL":"http:\/\/192.168.1.4:5004\/auto\/v199"},{"GuideNumber":"210","GuideName":"MTV East","URL":"http:\/\/192.168.1.4:5004\/auto\/v210"},{"GuideNumber":"211","GuideName":"MTV 2","URL":"http:\/\/192.168.1.4:5004\/auto\/v211"},{"GuideNumber":"212","GuideName":"MTV U","URL":"http:\/\/192.168.1.4:5004\/auto\/v212"},{"GuideNumber":"213","GuideName":"BET Jams","URL":"http:\/\/192.168.1.4:5004\/auto\/v213"},{"GuideNumber":"214","GuideName":"nickmusic","URL":"http:\/\/192.168.1.4:5004\/auto\/v214"},{"GuideNumber":"215","GuideName":"AXS tv","URL":"http:\/\/192.168.1.4:5004\/auto\/v215"},{"GuideNumber":"216","GuideName":"FUSE","URL":"http:\/\/192.168.1.4:5004\/auto\/v216"},{"GuideNumber":"217","GuideName":"VH1 (East)","URL":"http:\/\/192.168.1.4:5004\/auto\/v217"},{"GuideNumber":"218","GuideName":"MTV Classics","URL":"http:\/\/192.168.1.4:5004\/auto\/v218"},{"GuideNumber":"219","GuideName":"BET Soul","URL":"http:\/\/192.168.1.4:5004\/auto\/v219"},{"GuideNumber":"220","GuideName":"BET Her","URL":"http:\/\/192.168.1.4:5004\/auto\/v220"},{"GuideNumber":"221","GuideName":"CMT East","URL":"http:\/\/192.168.1.4:5004\/auto\/v221"},{"GuideNumber":"222","GuideName":"CMT Music","URL":"http:\/\/192.168.1.4:5004\/auto\/v222"},{"GuideNumber":"223","GuideName":"Great American Country","URL":"http:\/\/192.168.1.4:5004\/auto\/v223"},{"GuideNumber":"225","GuideName":"BET Gospel","URL":"http:\/\/192.168.1.4:5004\/auto\/v225"},{"GuideNumber":"228","GuideName":"FM","URL":"http:\/\/192.168.1.4:5004\/auto\/v228"},{"GuideNumber":"229","GuideName":"Mnet","URL":"http:\/\/192.168.1.4:5004\/auto\/v229"},{"GuideNumber":"230","GuideName":"Turner Classic Movies","URL":"http:\/\/192.168.1.4:5004\/auto\/v230"},{"GuideNumber":"231","GuideName":"AMC East","URL":"http:\/\/192.168.1.4:5004\/auto\/v231"},{"GuideNumber":"232","GuideName":"Fox Movie Channel","URL":"http:\/\/192.168.1.4:5004\/auto\/v232"},{"GuideNumber":"233","GuideName":"Reelz Channel","URL":"http:\/\/192.168.1.4:5004\/auto\/v233"},{"GuideNumber":"234","GuideName":"IFC","URL":"http:\/\/192.168.1.4:5004\/auto\/v234"},{"GuideNumber":"235","GuideName":"Sundance TV East","URL":"http:\/\/192.168.1.4:5004\/auto\/v235"},{"GuideNumber":"236","GuideName":"Cinemoi","URL":"http:\/\/192.168.1.4:5004\/auto\/v236"},{"GuideNumber":"238","GuideName":"UP TV","URL":"http:\/\/192.168.1.4:5004\/auto\/v238"},{"GuideNumber":"239","GuideName":"Hallmark Movies and Mysteries SD","URL":"http:\/\/192.168.1.4:5004\/auto\/v239"},{"GuideNumber":"240","GuideName":"Hallmark Channel East","URL":"http:\/\/192.168.1.4:5004\/auto\/v240"},{"GuideNumber":"241","GuideName":"TV Land (East)","URL":"http:\/\/192.168.1.4:5004\/auto\/v241"},{"GuideNumber":"245","GuideName":"FETV","URL":"http:\/\/192.168.1.4:5004\/auto\/v245"},{"GuideNumber":"246","GuideName":"Cowboy Channel","URL":"http:\/\/192.168.1.4:5004\/auto\/v246"},{"GuideNumber":"247","GuideName":"Blue Highways TV","URL":"http:\/\/192.168.1.4:5004\/auto\/v247"},{"GuideNumber":"250","GuideName":"Disney East","URL":"http:\/\/192.168.1.4:5004\/auto\/v250"},{"GuideNumber":"251","GuideName":"Disney XD East","URL":"http:\/\/192.168.1.4:5004\/auto\/v251"},{"GuideNumber":"252","GuideName":"Nickelodeon East","URL":"http:\/\/192.168.1.4:5004\/auto\/v252"},{"GuideNumber":"253","GuideName":"Nick 2","URL":"http:\/\/192.168.1.4:5004\/auto\/v253"},{"GuideNumber":"254","GuideName":"Nick Toons","URL":"http:\/\/192.168.1.4:5004\/auto\/v254"},{"GuideNumber":"255","GuideName":"Teen Nick","URL":"http:\/\/192.168.1.4:5004\/auto\/v255"},{"GuideNumber":"256","GuideName":"Nick Jr.","URL":"http:\/\/192.168.1.4:5004\/auto\/v256"},{"GuideNumber":"257","GuideName":"Cartoon Network East","URL":"http:\/\/192.168.1.4:5004\/auto\/v257"},{"GuideNumber":"258","GuideName":"Boomerang","URL":"http:\/\/192.168.1.4:5004\/auto\/v258"},{"GuideNumber":"259","GuideName":"Discovery Family Channel","URL":"http:\/\/192.168.1.4:5004\/auto\/v259"},{"GuideNumber":"260","GuideName":"Disney Junior (East)","URL":"http:\/\/192.168.1.4:5004\/auto\/v260"},{"GuideNumber":"263","GuideName":"Universal Kids","URL":"http:\/\/192.168.1.4:5004\/auto\/v263"},{"GuideNumber":"269","GuideName":"Noire TV","URL":"http:\/\/192.168.1.4:5004\/auto\/v269"},{"GuideNumber":"270","GuideName":"BET East","URL":"http:\/\/192.168.1.4:5004\/auto\/v270"},{"GuideNumber":"271","GuideName":"TV One","URL":"http:\/\/192.168.1.4:5004\/auto\/v271"},{"GuideNumber":"272","GuideName":"ASPiRE","URL":"http:\/\/192.168.1.4:5004\/auto\/v272"},{"GuideNumber":"273","GuideName":"MTV tr3s","URL":"http:\/\/192.168.1.4:5004\/auto\/v273"},{"GuideNumber":"274","GuideName":"Galavision East","URL":"http:\/\/192.168.1.4:5004\/auto\/v274"},{"GuideNumber":"275","GuideName":"NBC Universo East","URL":"http:\/\/192.168.1.4:5004\/auto\/v275"},{"GuideNumber":"276","GuideName":"FM","URL":"http:\/\/192.168.1.4:5004\/auto\/v276"},{"GuideNumber":"277","GuideName":"CGTN","URL":"http:\/\/192.168.1.4:5004\/auto\/v277"},{"GuideNumber":"279","GuideName":"HITN","URL":"http:\/\/192.168.1.4:5004\/auto\/v279"},{"GuideNumber":"281","GuideName":"Sino TV","URL":"http:\/\/192.168.1.4:5004\/auto\/v281"},{"GuideNumber":"285","GuideName":"EWTN","URL":"http:\/\/192.168.1.4:5004\/auto\/v285"},{"GuideNumber":"286","GuideName":"INSP","URL":"http:\/\/192.168.1.4:5004\/auto\/v286"},{"GuideNumber":"287","GuideName":"Impact Network","URL":"http:\/\/192.168.1.4:5004\/auto\/v287"},{"GuideNumber":"288","GuideName":"The Hillsong Channel","URL":"http:\/\/192.168.1.4:5004\/auto\/v288"},{"GuideNumber":"290","GuideName":"BYU","URL":"http:\/\/192.168.1.4:5004\/auto\/v290"},{"GuideNumber":"291","GuideName":"3ABN","URL":"http:\/\/192.168.1.4:5004\/auto\/v291"},{"GuideNumber":"292","GuideName":"The Word Network","URL":"http:\/\/192.168.1.4:5004\/auto\/v292"},{"GuideNumber":"293","GuideName":"Daystar","URL":"http:\/\/192.168.1.4:5004\/auto\/v293"},{"GuideNumber":"294","GuideName":"Smile of a Child","URL":"http:\/\/192.168.1.4:5004\/auto\/v294"},{"GuideNumber":"295","GuideName":"TBN","URL":"http:\/\/192.168.1.4:5004\/auto\/v295"},{"GuideNumber":"297","GuideName":"SonLife","URL":"http:\/\/192.168.1.4:5004\/auto\/v297"},{"GuideNumber":"300","GuideName":"Fox College Sports Atlantic","URL":"http:\/\/192.168.1.4:5004\/auto\/v300"},{"GuideNumber":"301","GuideName":"Fox College Sports Central","URL":"http:\/\/192.168.1.4:5004\/auto\/v301"},{"GuideNumber":"302","GuideName":"Fox College Sports Pacific","URL":"http:\/\/192.168.1.4:5004\/auto\/v302"},{"GuideNumber":"303","GuideName":"Tennis Channel","URL":"http:\/\/192.168.1.4:5004\/auto\/v303"},{"GuideNumber":"307","GuideName":"Outdoor Channel","URL":"http:\/\/192.168.1.4:5004\/auto\/v307"},{"GuideNumber":"308","GuideName":"SW VII","URL":"http:\/\/192.168.1.4:5004\/auto\/v308"},{"GuideNumber":"309","GuideName":"One World Sports","URL":"http:\/\/192.168.1.4:5004\/auto\/v309"},{"GuideNumber":"310","GuideName":"ESPN Classic","URL":"http:\/\/192.168.1.4:5004\/auto\/v310"},{"GuideNumber":"311","GuideName":"Fox Deportes (Spanish)","URL":"http:\/\/192.168.1.4:5004\/auto\/v311"},{"GuideNumber":"313","GuideName":"GOL TV","URL":"http:\/\/192.168.1.4:5004\/auto\/v313"},{"GuideNumber":"315","GuideName":"FanDuel TV","URL":"http:\/\/192.168.1.4:5004\/auto\/v315"},{"GuideNumber":"316","GuideName":"FanDuel Racing","URL":"http:\/\/192.168.1.4:5004\/auto\/v316"},{"GuideNumber":"317","GuideName":"World Fishing Network","URL":"http:\/\/192.168.1.4:5004\/auto\/v317"},{"GuideNumber":"320","GuideName":"Longhorn Network SD (National)","URL":"http:\/\/192.168.1.4:5004\/auto\/v320"},{"GuideNumber":"321","GuideName":"ESPN College Extra 1 HD","URL":"http:\/\/192.168.1.4:5004\/auto\/v321"},{"GuideNumber":"322","GuideName":"ESPN College Extra 2 HD","URL":"http:\/\/192.168.1.4:5004\/auto\/v322"},{"GuideNumber":"323","GuideName":"ESPN College Extra 3 HD","URL":"http:\/\/192.168.1.4:5004\/auto\/v323"},{"GuideNumber":"324","GuideName":"ESPN College Extra 4 HD","URL":"http:\/\/192.168.1.4:5004\/auto\/v324"},{"GuideNumber":"325","GuideName":"ESPN College Extra 5 HD","URL":"http:\/\/192.168.1.4:5004\/auto\/v325"},{"GuideNumber":"326","GuideName":"ESPN College Extra 6 HD","URL":"http:\/\/192.168.1.4:5004\/auto\/v326"},{"GuideNumber":"327","GuideName":"ESPN College Extra 7 HD","URL":"http:\/\/192.168.1.4:5004\/auto\/v327"},{"GuideNumber":"328","GuideName":"ESPN College Extra 8 HD","URL":"http:\/\/192.168.1.4:5004\/auto\/v328"},{"GuideNumber":"330","GuideName":"BTN 1","URL":"http:\/\/192.168.1.4:5004\/auto\/v330"},{"GuideNumber":"331","GuideName":"BTN 2","URL":"http:\/\/192.168.1.4:5004\/auto\/v331"},{"GuideNumber":"332","GuideName":"SEC Network Alt 1","URL":"http:\/\/192.168.1.4:5004\/auto\/v332"},{"GuideNumber":"335","GuideName":"NFL Red Zone SD","URL":"http:\/\/192.168.1.4:5004\/auto\/v335"},{"GuideNumber":"339","GuideName":"Barker 4 - Mercury VOD","URL":"http:\/\/192.168.1.4:5004\/auto\/v339"},{"GuideNumber":"340","GuideName":"Starz!","URL":"http:\/\/192.168.1.4:5004\/auto\/v340"},{"GuideNumber":"341","GuideName":"Starz! West","URL":"http:\/\/192.168.1.4:5004\/auto\/v341"},{"GuideNumber":"342","GuideName":"Starz! Edge","URL":"http:\/\/192.168.1.4:5004\/auto\/v342"},{"GuideNumber":"343","GuideName":"Starz! Edge West","URL":"http:\/\/192.168.1.4:5004\/auto\/v343"},{"GuideNumber":"344","GuideName":"Starz! in Black","URL":"http:\/\/192.168.1.4:5004\/auto\/v344"},{"GuideNumber":"345","GuideName":"Starz! Kids & Family","URL":"http:\/\/192.168.1.4:5004\/auto\/v345"},{"GuideNumber":"346","GuideName":"Starz! Cinema","URL":"http:\/\/192.168.1.4:5004\/auto\/v346"},{"GuideNumber":"347","GuideName":"Starz! Comedy","URL":"http:\/\/192.168.1.4:5004\/auto\/v347"},{"GuideNumber":"348","GuideName":"IndiePlex","URL":"http:\/\/192.168.1.4:5004\/auto\/v348"},{"GuideNumber":"349","GuideName":"RetroPlex","URL":"http:\/\/192.168.1.4:5004\/auto\/v349"},{"GuideNumber":"350","GuideName":"Starz Encore","URL":"http:\/\/192.168.1.4:5004\/auto\/v350"},{"GuideNumber":"351","GuideName":"Starz Encore West","URL":"http:\/\/192.168.1.4:5004\/auto\/v351"},{"GuideNumber":"352","GuideName":"Starz Encore Classic","URL":"http:\/\/192.168.1.4:5004\/auto\/v352"},{"GuideNumber":"353","GuideName":"Starz Encore Classic West","URL":"http:\/\/192.168.1.4:5004\/auto\/v353"},{"GuideNumber":"354","GuideName":"Starz Encore Westerns","URL":"http:\/\/192.168.1.4:5004\/auto\/v354"},{"GuideNumber":"355","GuideName":"Starz Encore Westerns West","URL":"http:\/\/192.168.1.4:5004\/auto\/v355"},{"GuideNumber":"356","GuideName":"Starz Encore Suspense","URL":"http:\/\/192.168.1.4:5004\/auto\/v356"},{"GuideNumber":"357","GuideName":"Starz Encore Suspense West","URL":"http:\/\/192.168.1.4:5004\/auto\/v357"},{"GuideNumber":"358","GuideName":"Starz Encore Black","URL":"http:\/\/192.168.1.4:5004\/auto\/v358"},{"GuideNumber":"359","GuideName":"Starz Encore Black West","URL":"http:\/\/192.168.1.4:5004\/auto\/v359"},{"GuideNumber":"360","GuideName":"Starz Encore Action","URL":"http:\/\/192.168.1.4:5004\/auto\/v360"},{"GuideNumber":"361","GuideName":"Starz Encore Action West","URL":"http:\/\/192.168.1.4:5004\/auto\/v361"},{"GuideNumber":"362","GuideName":"Starz Encore Family","URL":"http:\/\/192.168.1.4:5004\/auto\/v362"},{"GuideNumber":"363","GuideName":"Starz Encore Espanol","URL":"http:\/\/192.168.1.4:5004\/auto\/v363"},{"GuideNumber":"365","GuideName":"Paramount+ with SHOWTIME","URL":"http:\/\/192.168.1.4:5004\/auto\/v365"},{"GuideNumber":"366","GuideName":"Paramount+ with SHOWTIME (West)","URL":"http:\/\/192.168.1.4:5004\/auto\/v366"},{"GuideNumber":"367","GuideName":"Showtime Showcase","URL":"http:\/\/192.168.1.4:5004\/auto\/v367"},{"GuideNumber":"368","GuideName":"Showtime Showcase W","URL":"http:\/\/192.168.1.4:5004\/auto\/v368"},{"GuideNumber":"369","GuideName":"Showtime 2","URL":"http:\/\/192.168.1.4:5004\/auto\/v369"},{"GuideNumber":"370","GuideName":"Showtime 2 W","URL":"http:\/\/192.168.1.4:5004\/auto\/v370"},{"GuideNumber":"371","GuideName":"Showtime Beyond","URL":"http:\/\/192.168.1.4:5004\/auto\/v371"},{"GuideNumber":"372","GuideName":"Showtime Beyond W","URL":"http:\/\/192.168.1.4:5004\/auto\/v372"},{"GuideNumber":"373","GuideName":"Showtime Extreme","URL":"http:\/\/192.168.1.4:5004\/auto\/v373"},{"GuideNumber":"374","GuideName":"Showtime Extreme W","URL":"http:\/\/192.168.1.4:5004\/auto\/v374"},{"GuideNumber":"375","GuideName":"Showtime Women","URL":"http:\/\/192.168.1.4:5004\/auto\/v375"},{"GuideNumber":"376","GuideName":"Showtime Women W","URL":"http:\/\/192.168.1.4:5004\/auto\/v376"},{"GuideNumber":"377","GuideName":"Showtime Next","URL":"http:\/\/192.168.1.4:5004\/auto\/v377"},{"GuideNumber":"378","GuideName":"Showtime Next W","URL":"http:\/\/192.168.1.4:5004\/auto\/v378"},{"GuideNumber":"379","GuideName":"Showtime Family Zone","URL":"http:\/\/192.168.1.4:5004\/auto\/v379"},{"GuideNumber":"380","GuideName":"Showtime Family Zone W","URL":"http:\/\/192.168.1.4:5004\/auto\/v380"},{"GuideNumber":"385","GuideName":"TMC","URL":"http:\/\/192.168.1.4:5004\/auto\/v385"},{"GuideNumber":"386","GuideName":"TMC W","URL":"http:\/\/192.168.1.4:5004\/auto\/v386"},{"GuideNumber":"387","GuideName":"TMC Xtra","URL":"http:\/\/192.168.1.4:5004\/auto\/v387"},{"GuideNumber":"388","GuideName":"TMC Xtra W","URL":"http:\/\/192.168.1.4:5004\/auto\/v388"},{"GuideNumber":"390","GuideName":"Flix","URL":"http:\/\/192.168.1.4:5004\/auto\/v390"},{"GuideNumber":"391","GuideName":"Flix West","URL":"http:\/\/192.168.1.4:5004\/auto\/v391"},{"GuideNumber":"395","GuideName":"MGM+","URL":"http:\/\/192.168.1.4:5004\/auto\/v395"},{"GuideNumber":"445","GuideName":"Here! TV HD","URL":"http:\/\/192.168.1.4:5004\/auto\/v445"},{"GuideNumber":"451","GuideName":"MHZ 1 World View","URL":"http:\/\/192.168.1.4:5004\/auto\/v451"},{"GuideNumber":"452","GuideName":"MHZ CCTV Documentary","URL":"http:\/\/192.168.1.4:5004\/auto\/v452"},{"GuideNumber":"453","GuideName":"MHZ 3 France","URL":"http:\/\/192.168.1.4:5004\/auto\/v453"},{"GuideNumber":"454","GuideName":"WNVT China News","URL":"http:\/\/192.168.1.4:5004\/auto\/v454"},{"GuideNumber":"455","GuideName":"MHZ 5 RTTV","URL":"http:\/\/192.168.1.4:5004\/auto\/v455"},{"GuideNumber":"456","GuideName":"WNVC TRT World","URL":"http:\/\/192.168.1.4:5004\/auto\/v456"},{"GuideNumber":"457","GuideName":"WNVC Africa Today","URL":"http:\/\/192.168.1.4:5004\/auto\/v457"},{"GuideNumber":"458","GuideName":"MHZ CCTV News","URL":"http:\/\/192.168.1.4:5004\/auto\/v458"},{"GuideNumber":"459","GuideName":"WPXW Bounce","URL":"http:\/\/192.168.1.4:5004\/auto\/v459"},{"GuideNumber":"460","GuideName":"WRC Cozi TV","URL":"http:\/\/192.168.1.4:5004\/auto\/v460"},{"GuideNumber":"461","GuideName":"WUSA True Crime Network","URL":"http:\/\/192.168.1.4:5004\/auto\/v461"},{"GuideNumber":"462","GuideName":"WJLA Charge TV","URL":"http:\/\/192.168.1.4:5004\/auto\/v462"},{"GuideNumber":"463","GuideName":"WDCW This TV","URL":"http:\/\/192.168.1.4:5004\/auto\/v463"},{"GuideNumber":"464","GuideName":"WFDC GetTV","URL":"http:\/\/192.168.1.4:5004\/auto\/v464"},{"GuideNumber":"467","GuideName":"WJLA Comet TV","URL":"http:\/\/192.168.1.4:5004\/auto\/v467"},{"GuideNumber":"469","GuideName":"WDCA Movies!","URL":"http:\/\/192.168.1.4:5004\/auto\/v469"},{"GuideNumber":"470","GuideName":"WETA METRO HD","URL":"http:\/\/192.168.1.4:5004\/auto\/v470"},{"GuideNumber":"472","GuideName":"WETA Family","URL":"http:\/\/192.168.1.4:5004\/auto\/v472"},{"GuideNumber":"473","GuideName":"WJLA TBD TV","URL":"http:\/\/192.168.1.4:5004\/auto\/v473"},{"GuideNumber":"474","GuideName":"WETA UK HD","URL":"http:\/\/192.168.1.4:5004\/auto\/v474"},{"GuideNumber":"475","GuideName":"WETA World","URL":"http:\/\/192.168.1.4:5004\/auto\/v475"},{"GuideNumber":"476","GuideName":"WJLA TBD TV","URL":"http:\/\/192.168.1.4:5004\/auto\/v476"},{"GuideNumber":"477","GuideName":"WRC LX","URL":"http:\/\/192.168.1.4:5004\/auto\/v477"},{"GuideNumber":"478","GuideName":"WMPT Create HD","URL":"http:\/\/192.168.1.4:5004\/auto\/v478"},{"GuideNumber":"480","GuideName":"WMPT Create","URL":"http:\/\/192.168.1.4:5004\/auto\/v480"},{"GuideNumber":"481","GuideName":"WMPT V-me","URL":"http:\/\/192.168.1.4:5004\/auto\/v481"},{"GuideNumber":"482","GuideName":"WDCW ATV","URL":"http:\/\/192.168.1.4:5004\/auto\/v482"},{"GuideNumber":"484","GuideName":"WTTG Buzzr","URL":"http:\/\/192.168.1.4:5004\/auto\/v484"},{"GuideNumber":"485","GuideName":"WFDC Grit TV","URL":"http:\/\/192.168.1.4:5004\/auto\/v485"},{"GuideNumber":"486","GuideName":"WDVM ION Mystery","URL":"http:\/\/192.168.1.4:5004\/auto\/v486"},{"GuideNumber":"487","GuideName":"WDVM Rewind","URL":"http:\/\/192.168.1.4:5004\/auto\/v487"},{"GuideNumber":"488","GuideName":"WDVM ShopLC","URL":"http:\/\/192.168.1.4:5004\/auto\/v488"},{"GuideNumber":"489","GuideName":"WTTG StartTV","URL":"http:\/\/192.168.1.4:5004\/auto\/v489"},{"GuideNumber":"490","GuideName":"WHUT PBS Kids","URL":"http:\/\/192.168.1.4:5004\/auto\/v490"},{"GuideNumber":"491","GuideName":"ION QUBO","URL":"http:\/\/192.168.1.4:5004\/auto\/v491"},{"GuideNumber":"492","GuideName":"ION Plus","URL":"http:\/\/192.168.1.4:5004\/auto\/v492"},{"GuideNumber":"493","GuideName":"WZDC TeleXitos","URL":"http:\/\/192.168.1.4:5004\/auto\/v493"},{"GuideNumber":"500","GuideName":"Barker 6 - Quantum","URL":"http:\/\/192.168.1.4:5004\/auto\/v500"},{"GuideNumber":"502","GuideName":"WMDE ShopHQ HD","URL":"http:\/\/192.168.1.4:5004\/auto\/v502"},{"GuideNumber":"503","GuideName":"CW-WCCW-DTV","URL":"http:\/\/192.168.1.4:5004\/auto\/v503"},{"GuideNumber":"504","GuideName":"WRC-DTV","URL":"http:\/\/192.168.1.4:5004\/auto\/v504"},{"GuideNumber":"505","GuideName":"WTTG-DTV","URL":"http:\/\/192.168.1.4:5004\/auto\/v505"},{"GuideNumber":"506","GuideName":"WDCA Fox 5 Plus HD","URL":"http:\/\/192.168.1.4:5004\/auto\/v506"},{"GuideNumber":"507","GuideName":"WJLA-DTV","URL":"http:\/\/192.168.1.4:5004\/auto\/v507"},{"GuideNumber":"508","GuideName":"News 8 HD (MD)","URL":"http:\/\/192.168.1.4:5004\/auto\/v508"},{"GuideNumber":"509","GuideName":"WUSA-DTV","URL":"http:\/\/192.168.1.4:5004\/auto\/v509"},{"GuideNumber":"513","GuideName":"WPXV ION HD","URL":"http:\/\/192.168.1.4:5004\/auto\/v513"},{"GuideNumber":"514","GuideName":"WFDC TV14 (HD)","URL":"http:\/\/192.168.1.4:5004\/auto\/v514"},{"GuideNumber":"517","GuideName":"WFDC UniMas HD","URL":"http:\/\/192.168.1.4:5004\/auto\/v517"},{"GuideNumber":"520","GuideName":"WZDC HD","URL":"http:\/\/192.168.1.4:5004\/auto\/v520"},{"GuideNumber":"522","GuideName":"WMPT-DTV","URL":"http:\/\/192.168.1.4:5004\/auto\/v522"},{"GuideNumber":"523","GuideName":"WDME MeTV HD","URL":"http:\/\/192.168.1.4:5004\/auto\/v523"},{"GuideNumber":"526","GuideName":"WETA-DTV","URL":"http:\/\/192.168.1.4:5004\/auto\/v526"},{"GuideNumber":"529","GuideName":"Estrella TV HD","URL":"http:\/\/192.168.1.4:5004\/auto\/v529"},{"GuideNumber":"531","GuideName":"WDVM TV HD","URL":"http:\/\/192.168.1.4:5004\/auto\/v531"},{"GuideNumber":"532","GuideName":"WHUT-DT","URL":"http:\/\/192.168.1.4:5004\/auto\/v532"},{"GuideNumber":"533","GuideName":"WJAL SonLife HD","URL":"http:\/\/192.168.1.4:5004\/auto\/v533"},{"GuideNumber":"550","GuideName":"USA HD","URL":"http:\/\/192.168.1.4:5004\/auto\/v550"},{"GuideNumber":"551","GuideName":"TNT HD","URL":"http:\/\/192.168.1.4:5004\/auto\/v551"},{"GuideNumber":"552","GuideName":"TBS HD","URL":"http:\/\/192.168.1.4:5004\/auto\/v552"},{"GuideNumber":"554","GuideName":"Paramount Network HD","URL":"http:\/\/192.168.1.4:5004\/auto\/v554"},{"GuideNumber":"558","GuideName":"ES.TV HD","URL":"http:\/\/192.168.1.4:5004\/auto\/v558"},{"GuideNumber":"567","GuideName":"Universal HDTV","URL":"http:\/\/192.168.1.4:5004\/auto\/v567"},{"GuideNumber":"568","GuideName":"NewsNation HD","URL":"http:\/\/192.168.1.4:5004\/auto\/v568"},{"GuideNumber":"569","GuideName":"AXS tv HD","URL":"http:\/\/192.168.1.4:5004\/auto\/v569"},{"GuideNumber":"570","GuideName":"ESPN HD","URL":"http:\/\/192.168.1.4:5004\/auto\/v570"},{"GuideNumber":"571","GuideName":"ACC Network HD","URL":"http:\/\/192.168.1.4:5004\/auto\/v571"},{"GuideNumber":"572","GuideName":"ESPNews HD","URL":"http:\/\/192.168.1.4:5004\/auto\/v572"},{"GuideNumber":"573","GuideName":"ESPNU HD","URL":"http:\/\/192.168.1.4:5004\/auto\/v573"},{"GuideNumber":"574","GuideName":"ESPN 2 HD","URL":"http:\/\/192.168.1.4:5004\/auto\/v574"},{"GuideNumber":"575","GuideName":"SEC Network National HD","URL":"http:\/\/192.168.1.4:5004\/auto\/v575"},{"GuideNumber":"576","GuideName":"Monumental SN HD-Was","URL":"http:\/\/192.168.1.4:5004\/auto\/v576"},{"GuideNumber":"577","GuideName":"MASN HD","URL":"http:\/\/192.168.1.4:5004\/auto\/v577"},{"GuideNumber":"578","GuideName":"Monumental SN 2 HD","URL":"http:\/\/192.168.1.4:5004\/auto\/v578"},{"GuideNumber":"579","GuideName":"MASN 2 HD","URL":"http:\/\/192.168.1.4:5004\/auto\/v579"},{"GuideNumber":"583","GuideName":"Fox Sports 1 HD","URL":"http:\/\/192.168.1.4:5004\/auto\/v583"},{"GuideNumber":"584","GuideName":"Fox Sports 2 HD","URL":"http:\/\/192.168.1.4:5004\/auto\/v584"},{"GuideNumber":"585","GuideName":"BTN HD","URL":"http:\/\/192.168.1.4:5004\/auto\/v585"},{"GuideNumber":"586","GuideName":"MLB Network HD","URL":"http:\/\/192.168.1.4:5004\/auto\/v586"},{"GuideNumber":"587","GuideName":"NHL Network HD","URL":"http:\/\/192.168.1.4:5004\/auto\/v587"},{"GuideNumber":"588","GuideName":"NFL Network HD","URL":"http:\/\/192.168.1.4:5004\/auto\/v588"},{"GuideNumber":"589","GuideName":"NBA TV HD","URL":"http:\/\/192.168.1.4:5004\/auto\/v589"},{"GuideNumber":"590","GuideName":"NBC Sports Network HD","URL":"http:\/\/192.168.1.4:5004\/auto\/v590"},{"GuideNumber":"591","GuideName":"Olympic Channel HD","URL":"http:\/\/192.168.1.4:5004\/auto\/v591"},{"GuideNumber":"592","GuideName":"Tennis Channel HD","URL":"http:\/\/192.168.1.4:5004\/auto\/v592"},{"GuideNumber":"593","GuideName":"Golf HD","URL":"http:\/\/192.168.1.4:5004\/auto\/v593"},{"GuideNumber":"594","GuideName":"CBS Sports Network HD","URL":"http:\/\/192.168.1.4:5004\/auto\/v594"},{"GuideNumber":"595","GuideName":"YES HD (National)","URL":"http:\/\/192.168.1.4:5004\/auto\/v595"},{"GuideNumber":"596","GuideName":"BeIN Sports HD","URL":"http:\/\/192.168.1.4:5004\/auto\/v596"},{"GuideNumber":"597","GuideName":"Next Level Sports HD","URL":"http:\/\/192.168.1.4:5004\/auto\/v597"},{"GuideNumber":"598","GuideName":"Rio Olympics Soccer HD","URL":"http:\/\/192.168.1.4:5004\/auto\/v598"},{"GuideNumber":"599","GuideName":"Cars.TV HD","URL":"http:\/\/192.168.1.4:5004\/auto\/v599"},{"GuideNumber":"600","GuideName":"CNN HD","URL":"http:\/\/192.168.1.4:5004\/auto\/v600"},{"GuideNumber":"601","GuideName":"Rogue One Live Red Carpet Event HD","URL":"http:\/\/192.168.1.4:5004\/auto\/v601"},{"GuideNumber":"602","GuideName":"CNBC HD","URL":"http:\/\/192.168.1.4:5004\/auto\/v602"},{"GuideNumber":"603","GuideName":"MSNBC HD","URL":"http:\/\/192.168.1.4:5004\/auto\/v603"},{"GuideNumber":"604","GuideName":"Yahoo Finance HD","URL":"http:\/\/192.168.1.4:5004\/auto\/v604"},{"GuideNumber":"605","GuideName":"Bloomberg TV HD","URL":"http:\/\/192.168.1.4:5004\/auto\/v605"},{"GuideNumber":"606","GuideName":"C-SPAN HD","URL":"http:\/\/192.168.1.4:5004\/auto\/v606"},{"GuideNumber":"607","GuideName":"C-SPAN 2 HD","URL":"http:\/\/192.168.1.4:5004\/auto\/v607"},{"GuideNumber":"608","GuideName":"C-SPAN 3 HD","URL":"http:\/\/192.168.1.4:5004\/auto\/v608"},{"GuideNumber":"609","GuideName":"BBC News HD","URL":"http:\/\/192.168.1.4:5004\/auto\/v609"},{"GuideNumber":"610","GuideName":"i24NEWS HD","URL":"http:\/\/192.168.1.4:5004\/auto\/v610"},{"GuideNumber":"611","GuideName":"The Weather Chan HD","URL":"http:\/\/192.168.1.4:5004\/auto\/v611"},{"GuideNumber":"612","GuideName":"Pattrn HD","URL":"http:\/\/192.168.1.4:5004\/auto\/v612"},{"GuideNumber":"613","GuideName":"Fox Weather HD","URL":"http:\/\/192.168.1.4:5004\/auto\/v613"},{"GuideNumber":"614","GuideName":"Cheddar News HD","URL":"http:\/\/192.168.1.4:5004\/auto\/v614"},{"GuideNumber":"615","GuideName":"Newsmax TV HD Slate","URL":"http:\/\/192.168.1.4:5004\/auto\/v615"},{"GuideNumber":"616","GuideName":"Newsmax TV HD","URL":"http:\/\/192.168.1.4:5004\/auto\/v616"},{"GuideNumber":"617","GuideName":"Fox Business Network HD","URL":"http:\/\/192.168.1.4:5004\/auto\/v617"},{"GuideNumber":"618","GuideName":"Fox News HD","URL":"http:\/\/192.168.1.4:5004\/auto\/v618"},{"GuideNumber":"619","GuideName":"AccuWeather HD DC MD VA","URL":"http:\/\/192.168.1.4:5004\/auto\/v619"},{"GuideNumber":"620","GuideName":"Discovery HD","URL":"http:\/\/192.168.1.4:5004\/auto\/v620"},{"GuideNumber":"622","GuideName":"Science Channel HD","URL":"http:\/\/192.168.1.4:5004\/auto\/v622"},{"GuideNumber":"623","GuideName":"Investigation Discovery HD","URL":"http:\/\/192.168.1.4:5004\/auto\/v623"},{"GuideNumber":"624","GuideName":"Discovery Life HD","URL":"http:\/\/192.168.1.4:5004\/auto\/v624"},{"GuideNumber":"625","GuideName":"American Heroes HD","URL":"http:\/\/192.168.1.4:5004\/auto\/v625"},{"GuideNumber":"628","GuideName":"History HD","URL":"http:\/\/192.168.1.4:5004\/auto\/v628"},{"GuideNumber":"629","GuideName":"FYI HD","URL":"http:\/\/192.168.1.4:5004\/auto\/v629"},{"GuideNumber":"630","GuideName":"Animal Planet HD","URL":"http:\/\/192.168.1.4:5004\/auto\/v630"},{"GuideNumber":"631","GuideName":"MotorTrend HD","URL":"http:\/\/192.168.1.4:5004\/auto\/v631"},{"GuideNumber":"633","GuideName":"Pets.TV HD","URL":"http:\/\/192.168.1.4:5004\/auto\/v633"},{"GuideNumber":"634","GuideName":"Smithsonian Channel HD","URL":"http:\/\/192.168.1.4:5004\/auto\/v634"},{"GuideNumber":"635","GuideName":"Great American Faith and Living HD","URL":"http:\/\/192.168.1.4:5004\/auto\/v635"},{"GuideNumber":"639","GuideName":"TLC HD","URL":"http:\/\/192.168.1.4:5004\/auto\/v639"},{"GuideNumber":"640","GuideName":"Lifetime HD","URL":"http:\/\/192.168.1.4:5004\/auto\/v640"},{"GuideNumber":"641","GuideName":"LMN HD","URL":"http:\/\/192.168.1.4:5004\/auto\/v641"},{"GuideNumber":"644","GuideName":"Oxygen HD (East)","URL":"http:\/\/192.168.1.4:5004\/auto\/v644"},{"GuideNumber":"645","GuideName":"OWN HD","URL":"http:\/\/192.168.1.4:5004\/auto\/v645"},{"GuideNumber":"649","GuideName":"WE TV (HD)","URL":"http:\/\/192.168.1.4:5004\/auto\/v649"},{"GuideNumber":"650","GuideName":"QVC HD","URL":"http:\/\/192.168.1.4:5004\/auto\/v650"},{"GuideNumber":"651","GuideName":"HSN HD","URL":"http:\/\/192.168.1.4:5004\/auto\/v651"},{"GuideNumber":"652","GuideName":"Jewelry HD","URL":"http:\/\/192.168.1.4:5004\/auto\/v652"},{"GuideNumber":"653","GuideName":"QVC 2 HD","URL":"http:\/\/192.168.1.4:5004\/auto\/v653"},{"GuideNumber":"654","GuideName":"HSN 2 HD","URL":"http:\/\/192.168.1.4:5004\/auto\/v654"},{"GuideNumber":"656","GuideName":"QVC3 HD","URL":"http:\/\/192.168.1.4:5004\/auto\/v656"},{"GuideNumber":"657","GuideName":"ShopHQ HD","URL":"http:\/\/192.168.1.4:5004\/auto\/v657"},{"GuideNumber":"658","GuideName":"GEM Shopping Net HD","URL":"http:\/\/192.168.1.4:5004\/auto\/v658"},{"GuideNumber":"659","GuideName":"Enrich HD","URL":"http:\/\/192.168.1.4:5004\/auto\/v659"},{"GuideNumber":"660","GuideName":"GAC HD","URL":"http:\/\/192.168.1.4:5004\/auto\/v660"},{"GuideNumber":"662","GuideName":"Z Living HD","URL":"http:\/\/192.168.1.4:5004\/auto\/v662"},{"GuideNumber":"663","GuideName":"Cooking Channel HD","URL":"http:\/\/192.168.1.4:5004\/auto\/v663"},{"GuideNumber":"664","GuideName":"Food Network HD","URL":"http:\/\/192.168.1.4:5004\/auto\/v664"},{"GuideNumber":"665","GuideName":"Home & Garden TV HD","URL":"http:\/\/192.168.1.4:5004\/auto\/v665"},{"GuideNumber":"667","GuideName":"Magnolia Network HD","URL":"http:\/\/192.168.1.4:5004\/auto\/v667"},{"GuideNumber":"668","GuideName":"Destination America HD","URL":"http:\/\/192.168.1.4:5004\/auto\/v668"},{"GuideNumber":"669","GuideName":"AWE HD","URL":"http:\/\/192.168.1.4:5004\/auto\/v669"},{"GuideNumber":"670","GuideName":"Travel Channel HD","URL":"http:\/\/192.168.1.4:5004\/auto\/v670"},{"GuideNumber":"674","GuideName":"My Destination.TV HD","URL":"http:\/\/192.168.1.4:5004\/auto\/v674"},{"GuideNumber":"676","GuideName":"Recipe.TV HD","URL":"http:\/\/192.168.1.4:5004\/auto\/v676"},{"GuideNumber":"677","GuideName":"Justice Central HD","URL":"http:\/\/192.168.1.4:5004\/auto\/v677"},{"GuideNumber":"678","GuideName":"Law & Crime Net HD","URL":"http:\/\/192.168.1.4:5004\/auto\/v678"},{"GuideNumber":"679","GuideName":"Crime & Investig HD","URL":"http:\/\/192.168.1.4:5004\/auto\/v679"},{"GuideNumber":"680","GuideName":"SYFY HD","URL":"http:\/\/192.168.1.4:5004\/auto\/v680"},{"GuideNumber":"681","GuideName":"A&E HD","URL":"http:\/\/192.168.1.4:5004\/auto\/v681"},{"GuideNumber":"683","GuideName":"tru TV HD","URL":"http:\/\/192.168.1.4:5004\/auto\/v683"},{"GuideNumber":"684","GuideName":"Game Show Network HD","URL":"http:\/\/192.168.1.4:5004\/auto\/v684"},{"GuideNumber":"685","GuideName":"Bravo HD","URL":"http:\/\/192.168.1.4:5004\/auto\/v685"},{"GuideNumber":"687","GuideName":"Logo HD (East)","URL":"http:\/\/192.168.1.4:5004\/auto\/v687"},{"GuideNumber":"688","GuideName":"Ovation HD","URL":"http:\/\/192.168.1.4:5004\/auto\/v688"},{"GuideNumber":"689","GuideName":"BBC America HD","URL":"http:\/\/192.168.1.4:5004\/auto\/v689"},{"GuideNumber":"690","GuideName":"Comedy Central HD (East)","URL":"http:\/\/192.168.1.4:5004\/auto\/v690"},{"GuideNumber":"692","GuideName":"Reelz Channel HD","URL":"http:\/\/192.168.1.4:5004\/auto\/v692"},{"GuideNumber":"694","GuideName":"POP HD East","URL":"http:\/\/192.168.1.4:5004\/auto\/v694"},{"GuideNumber":"695","GuideName":"Comedy.TV HD","URL":"http:\/\/192.168.1.4:5004\/auto\/v695"},{"GuideNumber":"696","GuideName":"E! TV HD","URL":"http:\/\/192.168.1.4:5004\/auto\/v696"},{"GuideNumber":"697","GuideName":"VICE HD","URL":"http:\/\/192.168.1.4:5004\/auto\/v697"},{"GuideNumber":"699","GuideName":"Freeform HD","URL":"http:\/\/192.168.1.4:5004\/auto\/v699"},{"GuideNumber":"710","GuideName":"MTV HD (East)","URL":"http:\/\/192.168.1.4:5004\/auto\/v710"},{"GuideNumber":"711","GuideName":"MTV2 HD (East)","URL":"http:\/\/192.168.1.4:5004\/auto\/v711"},{"GuideNumber":"715","GuideName":"MTV Live HD","URL":"http:\/\/192.168.1.4:5004\/auto\/v715"},{"GuideNumber":"716","GuideName":"FUSE (HD)","URL":"http:\/\/192.168.1.4:5004\/auto\/v716"},{"GuideNumber":"717","GuideName":"VH1 HD (East)","URL":"http:\/\/192.168.1.4:5004\/auto\/v717"},{"GuideNumber":"720","GuideName":"BET Her HD","URL":"http:\/\/192.168.1.4:5004\/auto\/v720"},{"GuideNumber":"721","GuideName":"CMT HD (East)","URL":"http:\/\/192.168.1.4:5004\/auto\/v721"},{"GuideNumber":"723","GuideName":"Great American Country HD","URL":"http:\/\/192.168.1.4:5004\/auto\/v723"},{"GuideNumber":"726","GuideName":"Revolt TV HD","URL":"http:\/\/192.168.1.4:5004\/auto\/v726"},{"GuideNumber":"730","GuideName":"Turner Classics HD","URL":"http:\/\/192.168.1.4:5004\/auto\/v730"},{"GuideNumber":"731","GuideName":"AMC HD","URL":"http:\/\/192.168.1.4:5004\/auto\/v731"},{"GuideNumber":"732","GuideName":"FXM HD","URL":"http:\/\/192.168.1.4:5004\/auto\/v732"},{"GuideNumber":"734","GuideName":"IFC HD","URL":"http:\/\/192.168.1.4:5004\/auto\/v734"},{"GuideNumber":"735","GuideName":"Sundance HD","URL":"http:\/\/192.168.1.4:5004\/auto\/v735"},{"GuideNumber":"737","GuideName":"Hallmark Drama HD","URL":"http:\/\/192.168.1.4:5004\/auto\/v737"},{"GuideNumber":"738","GuideName":"UP HD (East)","URL":"http:\/\/192.168.1.4:5004\/auto\/v738"},{"GuideNumber":"739","GuideName":"Hallmark Movies and Mysteries HD","URL":"http:\/\/192.168.1.4:5004\/auto\/v739"},{"GuideNumber":"740","GuideName":"Hallmark Channel HD","URL":"http:\/\/192.168.1.4:5004\/auto\/v740"},{"GuideNumber":"741","GuideName":"TV Land HD (East)","URL":"http:\/\/192.168.1.4:5004\/auto\/v741"},{"GuideNumber":"743","GuideName":"Great American Family HD","URL":"http:\/\/192.168.1.4:5004\/auto\/v743"},{"GuideNumber":"744","GuideName":"thisTV HD","URL":"http:\/\/192.168.1.4:5004\/auto\/v744"},{"GuideNumber":"746","GuideName":"HD Net Movies","URL":"http:\/\/192.168.1.4:5004\/auto\/v746"},{"GuideNumber":"752","GuideName":"Nick HD (East)","URL":"http:\/\/192.168.1.4:5004\/auto\/v752"},{"GuideNumber":"754","GuideName":"Nick Toons HD","URL":"http:\/\/192.168.1.4:5004\/auto\/v754"},{"GuideNumber":"755","GuideName":"TeenNick HD","URL":"http:\/\/192.168.1.4:5004\/auto\/v755"},{"GuideNumber":"756","GuideName":"Nick Jr. HD","URL":"http:\/\/192.168.1.4:5004\/auto\/v756"},{"GuideNumber":"757","GuideName":"Cartoon Network HD (East)","URL":"http:\/\/192.168.1.4:5004\/auto\/v757"},{"GuideNumber":"763","GuideName":"Universal Kids HD","URL":"http:\/\/192.168.1.4:5004\/auto\/v763"},{"GuideNumber":"765","GuideName":"BabyFirst HD","URL":"http:\/\/192.168.1.4:5004\/auto\/v765"},{"GuideNumber":"770","GuideName":"BET HD","URL":"http:\/\/192.168.1.4:5004\/auto\/v770"},{"GuideNumber":"771","GuideName":"TV One HD","URL":"http:\/\/192.168.1.4:5004\/auto\/v771"},{"GuideNumber":"772","GuideName":"ASPiRE HD","URL":"http:\/\/192.168.1.4:5004\/auto\/v772"},{"GuideNumber":"773","GuideName":"Cleo TV HD","URL":"http:\/\/192.168.1.4:5004\/auto\/v773"},{"GuideNumber":"774","GuideName":"HBCU GO HD","URL":"http:\/\/192.168.1.4:5004\/auto\/v774"},{"GuideNumber":"775","GuideName":"NBC Universo HD","URL":"http:\/\/192.168.1.4:5004\/auto\/v775"},{"GuideNumber":"776","GuideName":"stellarTV HD","URL":"http:\/\/192.168.1.4:5004\/auto\/v776"},{"GuideNumber":"777","GuideName":"TheGrio HD","URL":"http:\/\/192.168.1.4:5004\/auto\/v777"},{"GuideNumber":"780","GuideName":"Disney Channel HD","URL":"http:\/\/192.168.1.4:5004\/auto\/v780"},{"GuideNumber":"781","GuideName":"Disney XD HD","URL":"http:\/\/192.168.1.4:5004\/auto\/v781"},{"GuideNumber":"786","GuideName":"INSP HD","URL":"http:\/\/192.168.1.4:5004\/auto\/v786"},{"GuideNumber":"787","GuideName":"Impact Network HD","URL":"http:\/\/192.168.1.4:5004\/auto\/v787"},{"GuideNumber":"789","GuideName":"Discovery Family Channel HD","URL":"http:\/\/192.168.1.4:5004\/auto\/v789"},{"GuideNumber":"793","GuideName":"Daystar HD","URL":"http:\/\/192.168.1.4:5004\/auto\/v793"},{"GuideNumber":"795","GuideName":"PTL TV HD","URL":"http:\/\/192.168.1.4:5004\/auto\/v795"},{"GuideNumber":"797","GuideName":"SonLife HD","URL":"http:\/\/192.168.1.4:5004\/auto\/v797"},{"GuideNumber":"798","GuideName":"JBS HD","URL":"http:\/\/192.168.1.4:5004\/auto\/v798"},{"GuideNumber":"800","GuideName":"Mobile+Home Promo Ch","URL":"http:\/\/192.168.1.4:5004\/auto\/v800"},{"GuideNumber":"803","GuideName":"Tennis Channel HD","URL":"http:\/\/192.168.1.4:5004\/auto\/v803"},{"GuideNumber":"804","GuideName":"G4 HD","URL":"http:\/\/192.168.1.4:5004\/auto\/v804"},{"GuideNumber":"805","GuideName":"BeIN Sport HD","URL":"http:\/\/192.168.1.4:5004\/auto\/v805"},{"GuideNumber":"806","GuideName":"Willow Cricket HD","URL":"http:\/\/192.168.1.4:5004\/auto\/v806"},{"GuideNumber":"807","GuideName":"ESPN IPL 1","URL":"http:\/\/192.168.1.4:5004\/auto\/v807"},{"GuideNumber":"808","GuideName":"ESPN IPL 2","URL":"http:\/\/192.168.1.4:5004\/auto\/v808"},{"GuideNumber":"810","GuideName":"MAV TV HD","URL":"http:\/\/192.168.1.4:5004\/auto\/v810"},{"GuideNumber":"811","GuideName":"Fox Deportes HD","URL":"http:\/\/192.168.1.4:5004\/auto\/v811"},{"GuideNumber":"812","GuideName":"Stad Coll Spt Atl HD","URL":"http:\/\/192.168.1.4:5004\/auto\/v812"},{"GuideNumber":"813","GuideName":"Stad Coll Spt Cen HD","URL":"http:\/\/192.168.1.4:5004\/auto\/v813"},{"GuideNumber":"814","GuideName":"Stad Coll Spt Pac HD","URL":"http:\/\/192.168.1.4:5004\/auto\/v814"},{"GuideNumber":"815","GuideName":"FanDuel TV HD","URL":"http:\/\/192.168.1.4:5004\/auto\/v815"},{"GuideNumber":"817","GuideName":"World Fishing Network HD","URL":"http:\/\/192.168.1.4:5004\/auto\/v817"},{"GuideNumber":"818","GuideName":"Pursuit Channel HD","URL":"http:\/\/192.168.1.4:5004\/auto\/v818"},{"GuideNumber":"820","GuideName":"Unknown","URL":"http:\/\/192.168.1.4:5004\/auto\/v820"},{"GuideNumber":"821","GuideName":"ESPN College Extra 1 HD","URL":"http:\/\/192.168.1.4:5004\/auto\/v821"},{"GuideNumber":"822","GuideName":"ESPN College Extra 2 HD","URL":"http:\/\/192.168.1.4:5004\/auto\/v822"},{"GuideNumber":"823","GuideName":"ESPN College Extra 3 HD","URL":"http:\/\/192.168.1.4:5004\/auto\/v823"},{"GuideNumber":"824","GuideName":"ESPN College Extra 4 HD","URL":"http:\/\/192.168.1.4:5004\/auto\/v824"},{"GuideNumber":"825","GuideName":"ESPN College Extra 5 HD","URL":"http:\/\/192.168.1.4:5004\/auto\/v825"},{"GuideNumber":"826","GuideName":"ESPN College Extra 6 HD","URL":"http:\/\/192.168.1.4:5004\/auto\/v826"},{"GuideNumber":"827","GuideName":"ESPN College Extra 7 HD","URL":"http:\/\/192.168.1.4:5004\/auto\/v827"},{"GuideNumber":"828","GuideName":"ESPN College Extra 8 HD","URL":"http:\/\/192.168.1.4:5004\/auto\/v828"},{"GuideNumber":"830","GuideName":"BTN 1 HD","URL":"http:\/\/192.168.1.4:5004\/auto\/v830"},{"GuideNumber":"831","GuideName":"BTN 2 HD","URL":"http:\/\/192.168.1.4:5004\/auto\/v831"},{"GuideNumber":"833","GuideName":"BTN 3 HD","URL":"http:\/\/192.168.1.4:5004\/auto\/v833"},{"GuideNumber":"834","GuideName":"MLB Strike Zone HD","URL":"http:\/\/192.168.1.4:5004\/auto\/v834"},{"GuideNumber":"835","GuideName":"NFL Red Zone HD","URL":"http:\/\/192.168.1.4:5004\/auto\/v835"},{"GuideNumber":"840","GuideName":"Starz! HD (East)","URL":"http:\/\/192.168.1.4:5004\/auto\/v840"},{"GuideNumber":"842","GuideName":"Starz! Edge HD","URL":"http:\/\/192.168.1.4:5004\/auto\/v842"},{"GuideNumber":"844","GuideName":"Starz in Black HD","URL":"http:\/\/192.168.1.4:5004\/auto\/v844"},{"GuideNumber":"845","GuideName":"Starz Kids & Fam HD","URL":"http:\/\/192.168.1.4:5004\/auto\/v845"},{"GuideNumber":"846","GuideName":"Starz Cinema HD","URL":"http:\/\/192.168.1.4:5004\/auto\/v846"},{"GuideNumber":"847","GuideName":"Starz! Comedy HD","URL":"http:\/\/192.168.1.4:5004\/auto\/v847"},{"GuideNumber":"848","GuideName":"IndiePlex HD","URL":"http:\/\/192.168.1.4:5004\/auto\/v848"},{"GuideNumber":"849","GuideName":"RetroPlex HD","URL":"http:\/\/192.168.1.4:5004\/auto\/v849"},{"GuideNumber":"850","GuideName":"Starz Encore HD","URL":"http:\/\/192.168.1.4:5004\/auto\/v850"},{"GuideNumber":"852","GuideName":"Starz Encore Class HD","URL":"http:\/\/192.168.1.4:5004\/auto\/v852"},{"GuideNumber":"854","GuideName":"Starz Enc Western HD","URL":"http:\/\/192.168.1.4:5004\/auto\/v854"},{"GuideNumber":"856","GuideName":"Starz Encore Susp HD","URL":"http:\/\/192.168.1.4:5004\/auto\/v856"},{"GuideNumber":"858","GuideName":"Starz Encore Black HD","URL":"http:\/\/192.168.1.4:5004\/auto\/v858"},{"GuideNumber":"860","GuideName":"Barker 1 - Premier Promo Channel","URL":"http:\/\/192.168.1.4:5004\/auto\/v860"},{"GuideNumber":"861","GuideName":"Starz Encore Act HD","URL":"http:\/\/192.168.1.4:5004\/auto\/v861"},{"GuideNumber":"862","GuideName":"Starz Encore Fam HD","URL":"http:\/\/192.168.1.4:5004\/auto\/v862"},{"GuideNumber":"863","GuideName":"Starz Encore Esp HD","URL":"http:\/\/192.168.1.4:5004\/auto\/v863"},{"GuideNumber":"865","GuideName":"Paramount+ with SHOWTIME HD","URL":"http:\/\/192.168.1.4:5004\/auto\/v865"},{"GuideNumber":"866","GuideName":"Paramount+ with SHOWTIME HD (West)","URL":"http:\/\/192.168.1.4:5004\/auto\/v866"},{"GuideNumber":"867","GuideName":"Showcase HD","URL":"http:\/\/192.168.1.4:5004\/auto\/v867"},{"GuideNumber":"868","GuideName":"SHO BET HD","URL":"http:\/\/192.168.1.4:5004\/auto\/v868"},{"GuideNumber":"869","GuideName":"Showtime 2 HD","URL":"http:\/\/192.168.1.4:5004\/auto\/v869"},{"GuideNumber":"870","GuideName":"Showtime 2 HD (West)","URL":"http:\/\/192.168.1.4:5004\/auto\/v870"},{"GuideNumber":"873","GuideName":"Showtime Extreme HD","URL":"http:\/\/192.168.1.4:5004\/auto\/v873"},{"GuideNumber":"874","GuideName":"Showtime Extreme HD (West)","URL":"http:\/\/192.168.1.4:5004\/auto\/v874"},{"GuideNumber":"885","GuideName":"TMC HD","URL":"http:\/\/192.168.1.4:5004\/auto\/v885"},{"GuideNumber":"887","GuideName":"TMC Xtra HD","URL":"http:\/\/192.168.1.4:5004\/auto\/v887"},{"GuideNumber":"895","GuideName":"MGM+ HD","URL":"http:\/\/192.168.1.4:5004\/auto\/v895"},{"GuideNumber":"896","GuideName":"MGM+ Hits HD","URL":"http:\/\/192.168.1.4:5004\/auto\/v896"},{"GuideNumber":"950","GuideName":"Playboy TV HD","URL":"http:\/\/192.168.1.4:5004\/auto\/v950"},{"GuideNumber":"951","GuideName":"Brazzers","URL":"http:\/\/192.168.1.4:5004\/auto\/v951"},{"GuideNumber":"952","GuideName":"Reality Kings","URL":"http:\/\/192.168.1.4:5004\/auto\/v952"},{"GuideNumber":"970","GuideName":"local_PEG_970","URL":"http:\/\/192.168.1.4:5004\/auto\/v970"},{"GuideNumber":"971","GuideName":"local_PEG_971","URL":"http:\/\/192.168.1.4:5004\/auto\/v971"},{"GuideNumber":"997","GuideName":"Barker 5 - Mercury Market Place","URL":"http:\/\/192.168.1.4:5004\/auto\/v997"},{"GuideNumber":"998","GuideName":"Barker 4 - Mercury VOD","URL":"http:\/\/192.168.1.4:5004\/auto\/v998"},{"GuideNumber":"1000","GuideName":"TVN1 PPV","URL":"http:\/\/192.168.1.4:5004\/auto\/v1000"},{"GuideNumber":"1001","GuideName":"HD PPV Events","URL":"http:\/\/192.168.1.4:5004\/auto\/v1001"},{"GuideNumber":"1002","GuideName":"HD PPV Events 2","URL":"http:\/\/192.168.1.4:5004\/auto\/v1002"},{"GuideNumber":"1005","GuideName":"Hustler HD","URL":"http:\/\/192.168.1.4:5004\/auto\/v1005"},{"GuideNumber":"1009","GuideName":"Fox Soccer Plus","URL":"http:\/\/192.168.1.4:5004\/auto\/v1009"},{"GuideNumber":"1010","GuideName":"Fox Soccer Plus HD","URL":"http:\/\/192.168.1.4:5004\/auto\/v1010"},{"GuideNumber":"1450","GuideName":"TEAM HD (NBA)","URL":"http:\/\/192.168.1.4:5004\/auto\/v1450"},{"GuideNumber":"1451","GuideName":"TEAM HD 2 (NBA)","URL":"http:\/\/192.168.1.4:5004\/auto\/v1451"},{"GuideNumber":"1452","GuideName":"TEAM HD 3 (NBA)","URL":"http:\/\/192.168.1.4:5004\/auto\/v1452"},{"GuideNumber":"1453","GuideName":"TEAM HD 4 (NBA)","URL":"http:\/\/192.168.1.4:5004\/auto\/v1453"},{"GuideNumber":"1454","GuideName":"TEAM HD 5 (NBA)","URL":"http:\/\/192.168.1.4:5004\/auto\/v1454"},{"GuideNumber":"1455","GuideName":"TEAM HD 6 (NBA)","URL":"http:\/\/192.168.1.4:5004\/auto\/v1455"},{"GuideNumber":"1456","GuideName":"TEAM HD 7 (NBA)","URL":"http:\/\/192.168.1.4:5004\/auto\/v1456"},{"GuideNumber":"1457","GuideName":"TEAM HD 8 (NBA)","URL":"http:\/\/192.168.1.4:5004\/auto\/v1457"},{"GuideNumber":"1458","GuideName":"TEAM HD 9 (NBA)","URL":"http:\/\/192.168.1.4:5004\/auto\/v1458"},{"GuideNumber":"1459","GuideName":"TEAM HD 10 (NBA)","URL":"http:\/\/192.168.1.4:5004\/auto\/v1459"},{"GuideNumber":"1461","GuideName":"Game HD","URL":"http:\/\/192.168.1.4:5004\/auto\/v1461"},{"GuideNumber":"1462","GuideName":"Game HD 2","URL":"http:\/\/192.168.1.4:5004\/auto\/v1462"},{"GuideNumber":"1463","GuideName":"Game HD 3","URL":"http:\/\/192.168.1.4:5004\/auto\/v1463"},{"GuideNumber":"1464","GuideName":"Game HD 4","URL":"http:\/\/192.168.1.4:5004\/auto\/v1464"},{"GuideNumber":"1465","GuideName":"Game HD 5","URL":"http:\/\/192.168.1.4:5004\/auto\/v1465"},{"GuideNumber":"1466","GuideName":"Game HD 6","URL":"http:\/\/192.168.1.4:5004\/auto\/v1466"},{"GuideNumber":"1467","GuideName":"Game HD 7","URL":"http:\/\/192.168.1.4:5004\/auto\/v1467"},{"GuideNumber":"1468","GuideName":"Game HD 8","URL":"http:\/\/192.168.1.4:5004\/auto\/v1468"},{"GuideNumber":"1469","GuideName":"Game HD 9","URL":"http:\/\/192.168.1.4:5004\/auto\/v1469"},{"GuideNumber":"1470","GuideName":"Game HD 10","URL":"http:\/\/192.168.1.4:5004\/auto\/v1470"},{"GuideNumber":"1471","GuideName":"Game HD 11","URL":"http:\/\/192.168.1.4:5004\/auto\/v1471"},{"GuideNumber":"1472","GuideName":"Game HD 12","URL":"http:\/\/192.168.1.4:5004\/auto\/v1472"},{"GuideNumber":"1473","GuideName":"Game HD 13","URL":"http:\/\/192.168.1.4:5004\/auto\/v1473"},{"GuideNumber":"1474","GuideName":"Game HD 14","URL":"http:\/\/192.168.1.4:5004\/auto\/v1474"},{"GuideNumber":"1475","GuideName":"MLB \/ NHL 01","URL":"http:\/\/192.168.1.4:5004\/auto\/v1475"},{"GuideNumber":"1476","GuideName":"MLB \/ NHL 02","URL":"http:\/\/192.168.1.4:5004\/auto\/v1476"},{"GuideNumber":"1477","GuideName":"MLB \/ NHL 03","URL":"http:\/\/192.168.1.4:5004\/auto\/v1477"},{"GuideNumber":"1478","GuideName":"MLB \/ NHL 04","URL":"http:\/\/192.168.1.4:5004\/auto\/v1478"},{"GuideNumber":"1479","GuideName":"MLB \/ NHL 05","URL":"http:\/\/192.168.1.4:5004\/auto\/v1479"},{"GuideNumber":"1480","GuideName":"MLB \/ NHL 06","URL":"http:\/\/192.168.1.4:5004\/auto\/v1480"},{"GuideNumber":"1481","GuideName":"MLB \/ NHL 07","URL":"http:\/\/192.168.1.4:5004\/auto\/v1481"},{"GuideNumber":"1482","GuideName":"MLB \/ NHL 08","URL":"http:\/\/192.168.1.4:5004\/auto\/v1482"},{"GuideNumber":"1483","GuideName":"MLB \/ NHL 09","URL":"http:\/\/192.168.1.4:5004\/auto\/v1483"},{"GuideNumber":"1484","GuideName":"MLB \/ NHL 10","URL":"http:\/\/192.168.1.4:5004\/auto\/v1484"},{"GuideNumber":"1485","GuideName":"MLB \/ NHL 11","URL":"http:\/\/192.168.1.4:5004\/auto\/v1485"},{"GuideNumber":"1486","GuideName":"MLB \/ NHL 12","URL":"http:\/\/192.168.1.4:5004\/auto\/v1486"},{"GuideNumber":"1487","GuideName":"MLB \/ NHL 13","URL":"http:\/\/192.168.1.4:5004\/auto\/v1487"},{"GuideNumber":"1488","GuideName":"MLB \/ NHL 14","URL":"http:\/\/192.168.1.4:5004\/auto\/v1488"},{"GuideNumber":"1490","GuideName":"NBA \/ MLS 01","URL":"http:\/\/192.168.1.4:5004\/auto\/v1490"},{"GuideNumber":"1491","GuideName":"Fios 4K1-WRC","URL":"http:\/\/192.168.1.4:5004\/auto\/v1491"},{"GuideNumber":"1492","GuideName":"Fios 4K2-National","URL":"http:\/\/192.168.1.4:5004\/auto\/v1492"},{"GuideNumber":"1493","GuideName":"NBA \/ MLS 04","URL":"http:\/\/192.168.1.4:5004\/auto\/v1493"},{"GuideNumber":"1494","GuideName":"NBA \/ MLS 05","URL":"http:\/\/192.168.1.4:5004\/auto\/v1494"},{"GuideNumber":"1495","GuideName":"Fios 4K5","URL":"http:\/\/192.168.1.4:5004\/auto\/v1495"},{"GuideNumber":"1496","GuideName":"Fios 4K6","URL":"http:\/\/192.168.1.4:5004\/auto\/v1496"},{"GuideNumber":"1497","GuideName":"Fios 4K7","URL":"http:\/\/192.168.1.4:5004\/auto\/v1497"},{"GuideNumber":"1498","GuideName":"Fios 4K8","URL":"http:\/\/192.168.1.4:5004\/auto\/v1498"},{"GuideNumber":"1499","GuideName":"Fios 4K9","URL":"http:\/\/192.168.1.4:5004\/auto\/v1499"},{"GuideNumber":"1500","GuideName":"USA (East)","URL":"http:\/\/192.168.1.4:5004\/auto\/v1500"},{"GuideNumber":"1501","GuideName":"TNT (East)","URL":"http:\/\/192.168.1.4:5004\/auto\/v1501"},{"GuideNumber":"1502","GuideName":"TBS (East)","URL":"http:\/\/192.168.1.4:5004\/auto\/v1502"},{"GuideNumber":"1503","GuideName":"Galavision East","URL":"http:\/\/192.168.1.4:5004\/auto\/v1503"},{"GuideNumber":"1505","GuideName":"Paramount Network","URL":"http:\/\/192.168.1.4:5004\/auto\/v1505"},{"GuideNumber":"1506","GuideName":"TV Dominica","URL":"http:\/\/192.168.1.4:5004\/auto\/v1506"},{"GuideNumber":"1507","GuideName":"Supercanal HD","URL":"http:\/\/192.168.1.4:5004\/auto\/v1507"},{"GuideNumber":"1508","GuideName":"WAPA TV","URL":"http:\/\/192.168.1.4:5004\/auto\/v1508"},{"GuideNumber":"1509","GuideName":"Tele El Salvador HD","URL":"http:\/\/192.168.1.4:5004\/auto\/v1509"},{"GuideNumber":"1510","GuideName":"SUR Peru","URL":"http:\/\/192.168.1.4:5004\/auto\/v1510"},{"GuideNumber":"1511","GuideName":"Multimedios TV","URL":"http:\/\/192.168.1.4:5004\/auto\/v1511"},{"GuideNumber":"1512","GuideName":"Ecuavisa Internacional","URL":"http:\/\/192.168.1.4:5004\/auto\/v1512"},{"GuideNumber":"1513","GuideName":"Telemicro Intern HD","URL":"http:\/\/192.168.1.4:5004\/auto\/v1513"},{"GuideNumber":"1515","GuideName":"Antena 3 Internacional HD","URL":"http:\/\/192.168.1.4:5004\/auto\/v1515"},{"GuideNumber":"1516","GuideName":"Multimedios HD","URL":"http:\/\/192.168.1.4:5004\/auto\/v1516"},{"GuideNumber":"1517","GuideName":"TV Venezuela HD","URL":"http:\/\/192.168.1.4:5004\/auto\/v1517"},{"GuideNumber":"1520","GuideName":"ESPN Deportes","URL":"http:\/\/192.168.1.4:5004\/auto\/v1520"},{"GuideNumber":"1521","GuideName":"Fox Deportes (Spanish)","URL":"http:\/\/192.168.1.4:5004\/auto\/v1521"},{"GuideNumber":"1523","GuideName":"GOL TV","URL":"http:\/\/192.168.1.4:5004\/auto\/v1523"},{"GuideNumber":"1524","GuideName":"TUDN","URL":"http:\/\/192.168.1.4:5004\/auto\/v1524"},{"GuideNumber":"1525","GuideName":"Monumental SN-Was","URL":"http:\/\/192.168.1.4:5004\/auto\/v1525"},{"GuideNumber":"1526","GuideName":"MASN","URL":"http:\/\/192.168.1.4:5004\/auto\/v1526"},{"GuideNumber":"1530","GuideName":"MLB Network SD","URL":"http:\/\/192.168.1.4:5004\/auto\/v1530"},{"GuideNumber":"1533","GuideName":"ZonaFutbol HD","URL":"http:\/\/192.168.1.4:5004\/auto\/v1533"},{"GuideNumber":"1534","GuideName":"Fox Deportes HD","URL":"http:\/\/192.168.1.4:5004\/auto\/v1534"},{"GuideNumber":"1535","GuideName":"AyM Sports","URL":"http:\/\/192.168.1.4:5004\/auto\/v1535"},{"GuideNumber":"1536","GuideName":"TyC Sports","URL":"http:\/\/192.168.1.4:5004\/auto\/v1536"},{"GuideNumber":"1537","GuideName":"ESPN Deportes HD","URL":"http:\/\/192.168.1.4:5004\/auto\/v1537"},{"GuideNumber":"1538","GuideName":"BeIN Sports en Espanol HD","URL":"http:\/\/192.168.1.4:5004\/auto\/v1538"},{"GuideNumber":"1539","GuideName":"TUDN HD","URL":"http:\/\/192.168.1.4:5004\/auto\/v1539"},{"GuideNumber":"1540","GuideName":"CNN Espanol","URL":"http:\/\/192.168.1.4:5004\/auto\/v1540"},{"GuideNumber":"1541","GuideName":"CNN","URL":"http:\/\/192.168.1.4:5004\/auto\/v1541"},{"GuideNumber":"1542","GuideName":"CNN Headline News","URL":"http:\/\/192.168.1.4:5004\/auto\/v1542"},{"GuideNumber":"1543","GuideName":"Fox News","URL":"http:\/\/192.168.1.4:5004\/auto\/v1543"},{"GuideNumber":"1544","GuideName":"CNBC","URL":"http:\/\/192.168.1.4:5004\/auto\/v1544"},{"GuideNumber":"1545","GuideName":"MSNBC","URL":"http:\/\/192.168.1.4:5004\/auto\/v1545"},{"GuideNumber":"1546","GuideName":"C-SPAN","URL":"http:\/\/192.168.1.4:5004\/auto\/v1546"},{"GuideNumber":"1547","GuideName":"Fox Business Channel","URL":"http:\/\/192.168.1.4:5004\/auto\/v1547"},{"GuideNumber":"1548","GuideName":"Dominican View HD","URL":"http:\/\/192.168.1.4:5004\/auto\/v1548"},{"GuideNumber":"1549","GuideName":"Canal SUR","URL":"http:\/\/192.168.1.4:5004\/auto\/v1549"},{"GuideNumber":"1550","GuideName":"Milenio TV","URL":"http:\/\/192.168.1.4:5004\/auto\/v1550"},{"GuideNumber":"1551","GuideName":"FOROtv","URL":"http:\/\/192.168.1.4:5004\/auto\/v1551"},{"GuideNumber":"1552","GuideName":"TWCE HD","URL":"http:\/\/192.168.1.4:5004\/auto\/v1552"},{"GuideNumber":"1558","GuideName":"Discovery En Espanol HD","URL":"http:\/\/192.168.1.4:5004\/auto\/v1558"},{"GuideNumber":"1559","GuideName":"Discovery en Espanol HD","URL":"http:\/\/192.168.1.4:5004\/auto\/v1559"},{"GuideNumber":"1560","GuideName":"TVE International","URL":"http:\/\/192.168.1.4:5004\/auto\/v1560"},{"GuideNumber":"1561","GuideName":"History Channel Espanol","URL":"http:\/\/192.168.1.4:5004\/auto\/v1561"},{"GuideNumber":"1562","GuideName":"Discovery East","URL":"http:\/\/192.168.1.4:5004\/auto\/v1562"},{"GuideNumber":"1563","GuideName":"Discovery Espanol","URL":"http:\/\/192.168.1.4:5004\/auto\/v1563"},{"GuideNumber":"1564","GuideName":"Nat Geo Mundo","URL":"http:\/\/192.168.1.4:5004\/auto\/v1564"},{"GuideNumber":"1565","GuideName":"Animal Planet","URL":"http:\/\/192.168.1.4:5004\/auto\/v1565"},{"GuideNumber":"1566","GuideName":"TLC (East)","URL":"http:\/\/192.168.1.4:5004\/auto\/v1566"},{"GuideNumber":"1567","GuideName":"Once","URL":"http:\/\/192.168.1.4:5004\/auto\/v1567"},{"GuideNumber":"1570","GuideName":"Ultra Docu HD","URL":"http:\/\/192.168.1.4:5004\/auto\/v1570"},{"GuideNumber":"1579","GuideName":"Hola! TV HD","URL":"http:\/\/192.168.1.4:5004\/auto\/v1579"},{"GuideNumber":"1580","GuideName":"Lifetime East","URL":"http:\/\/192.168.1.4:5004\/auto\/v1580"},{"GuideNumber":"1581","GuideName":"LMN","URL":"http:\/\/192.168.1.4:5004\/auto\/v1581"},{"GuideNumber":"1582","GuideName":"Fox Life","URL":"http:\/\/192.168.1.4:5004\/auto\/v1582"},{"GuideNumber":"1583","GuideName":"Pasiones","URL":"http:\/\/192.168.1.4:5004\/auto\/v1583"},{"GuideNumber":"1584","GuideName":"Univision tlNovelas","URL":"http:\/\/192.168.1.4:5004\/auto\/v1584"},{"GuideNumber":"1585","GuideName":"Ultra Luna HD","URL":"http:\/\/192.168.1.4:5004\/auto\/v1585"},{"GuideNumber":"1586","GuideName":"Kanal D Drama HD","URL":"http:\/\/192.168.1.4:5004\/auto\/v1586"},{"GuideNumber":"1587","GuideName":"TVE Star HD","URL":"http:\/\/192.168.1.4:5004\/auto\/v1587"},{"GuideNumber":"1588","GuideName":"Atreseries HD","URL":"http:\/\/192.168.1.4:5004\/auto\/v1588"},{"GuideNumber":"1590","GuideName":"TeleN","URL":"http:\/\/192.168.1.4:5004\/auto\/v1590"},{"GuideNumber":"1600","GuideName":"QVC","URL":"http:\/\/192.168.1.4:5004\/auto\/v1600"},{"GuideNumber":"1601","GuideName":"HSN","URL":"http:\/\/192.168.1.4:5004\/auto\/v1601"},{"GuideNumber":"1602","GuideName":"Jewelry","URL":"http:\/\/192.168.1.4:5004\/auto\/v1602"},{"GuideNumber":"1603","GuideName":"ShopHQ","URL":"http:\/\/192.168.1.4:5004\/auto\/v1603"},{"GuideNumber":"1604","GuideName":"QVC 2","URL":"http:\/\/192.168.1.4:5004\/auto\/v1604"},{"GuideNumber":"1605","GuideName":"HSN2","URL":"http:\/\/192.168.1.4:5004\/auto\/v1605"},{"GuideNumber":"1620","GuideName":"Infinito","URL":"http:\/\/192.168.1.4:5004\/auto\/v1620"},{"GuideNumber":"1621","GuideName":"Food Network East","URL":"http:\/\/192.168.1.4:5004\/auto\/v1621"},{"GuideNumber":"1622","GuideName":"Home & Garden TV","URL":"http:\/\/192.168.1.4:5004\/auto\/v1622"},{"GuideNumber":"1623","GuideName":"Travel Channel","URL":"http:\/\/192.168.1.4:5004\/auto\/v1623"},{"GuideNumber":"1624","GuideName":"Hogar de HGTV HD","URL":"http:\/\/192.168.1.4:5004\/auto\/v1624"},{"GuideNumber":"1625","GuideName":"OWN SD","URL":"http:\/\/192.168.1.4:5004\/auto\/v1625"},{"GuideNumber":"1640","GuideName":"E! TV East","URL":"http:\/\/192.168.1.4:5004\/auto\/v1640"},{"GuideNumber":"1641","GuideName":"A&E East","URL":"http:\/\/192.168.1.4:5004\/auto\/v1641"},{"GuideNumber":"1642","GuideName":"FUSE","URL":"http:\/\/192.168.1.4:5004\/auto\/v1642"},{"GuideNumber":"1643","GuideName":"NBC Universo East","URL":"http:\/\/192.168.1.4:5004\/auto\/v1643"},{"GuideNumber":"1644","GuideName":"Comedy Central East","URL":"http:\/\/192.168.1.4:5004\/auto\/v1644"},{"GuideNumber":"1645","GuideName":"SYFY (East)","URL":"http:\/\/192.168.1.4:5004\/auto\/v1645"},{"GuideNumber":"1646","GuideName":"Canal 22","URL":"http:\/\/192.168.1.4:5004\/auto\/v1646"},{"GuideNumber":"1648","GuideName":"HITN","URL":"http:\/\/192.168.1.4:5004\/auto\/v1648"},{"GuideNumber":"1650","GuideName":"Ultra Macho HD","URL":"http:\/\/192.168.1.4:5004\/auto\/v1650"},{"GuideNumber":"1660","GuideName":"MTV tr3s","URL":"http:\/\/192.168.1.4:5004\/auto\/v1660"},{"GuideNumber":"1661","GuideName":"MTV 2","URL":"http:\/\/192.168.1.4:5004\/auto\/v1661"},{"GuideNumber":"1662","GuideName":"Telehit","URL":"http:\/\/192.168.1.4:5004\/auto\/v1662"},{"GuideNumber":"1663","GuideName":"Bandamax Estados Unidos","URL":"http:\/\/192.168.1.4:5004\/auto\/v1663"},{"GuideNumber":"1664","GuideName":"Telehit Musica","URL":"http:\/\/192.168.1.4:5004\/auto\/v1664"},{"GuideNumber":"1665","GuideName":"CMT East","URL":"http:\/\/192.168.1.4:5004\/auto\/v1665"},{"GuideNumber":"1666","GuideName":"Teleritmo TV","URL":"http:\/\/192.168.1.4:5004\/auto\/v1666"},{"GuideNumber":"1670","GuideName":"Ultra Fiesta","URL":"http:\/\/192.168.1.4:5004\/auto\/v1670"},{"GuideNumber":"1680","GuideName":"De Pelicula","URL":"http:\/\/192.168.1.4:5004\/auto\/v1680"},{"GuideNumber":"1681","GuideName":"De Pelicula Clasico","URL":"http:\/\/192.168.1.4:5004\/auto\/v1681"},{"GuideNumber":"1682","GuideName":"Viendo Movies","URL":"http:\/\/192.168.1.4:5004\/auto\/v1682"},{"GuideNumber":"1683","GuideName":"Gran Cine","URL":"http:\/\/192.168.1.4:5004\/auto\/v1683"},{"GuideNumber":"1685","GuideName":"Cine Latino","URL":"http:\/\/192.168.1.4:5004\/auto\/v1685"},{"GuideNumber":"1686","GuideName":"Cine Mexicano","URL":"http:\/\/192.168.1.4:5004\/auto\/v1686"},{"GuideNumber":"1687","GuideName":"Cine Nostalgia","URL":"http:\/\/192.168.1.4:5004\/auto\/v1687"},{"GuideNumber":"1688","GuideName":"Cine Estelar","URL":"http:\/\/192.168.1.4:5004\/auto\/v1688"},{"GuideNumber":"1689","GuideName":"Viendo Movies HD","URL":"http:\/\/192.168.1.4:5004\/auto\/v1689"},{"GuideNumber":"1690","GuideName":"Ultra Cine","URL":"http:\/\/192.168.1.4:5004\/auto\/v1690"},{"GuideNumber":"1691","GuideName":"Ultra Film HD","URL":"http:\/\/192.168.1.4:5004\/auto\/v1691"},{"GuideNumber":"1692","GuideName":"Ultra MEX","URL":"http:\/\/192.168.1.4:5004\/auto\/v1692"},{"GuideNumber":"1693","GuideName":"Ultra Clasico HD","URL":"http:\/\/192.168.1.4:5004\/auto\/v1693"},{"GuideNumber":"1700","GuideName":"Freeform East","URL":"http:\/\/192.168.1.4:5004\/auto\/v1700"},{"GuideNumber":"1701","GuideName":"Discovery Familia HD","URL":"http:\/\/192.168.1.4:5004\/auto\/v1701"},{"GuideNumber":"1702","GuideName":"Discovery Familia","URL":"http:\/\/192.168.1.4:5004\/auto\/v1702"},{"GuideNumber":"1703","GuideName":"CentroAmerica TV","URL":"http:\/\/192.168.1.4:5004\/auto\/v1703"},{"GuideNumber":"1704","GuideName":"TV Chile","URL":"http:\/\/192.168.1.4:5004\/auto\/v1704"},{"GuideNumber":"1705","GuideName":"Nuestra Tele","URL":"http:\/\/192.168.1.4:5004\/auto\/v1705"},{"GuideNumber":"1707","GuideName":"TV Land (East)","URL":"http:\/\/192.168.1.4:5004\/auto\/v1707"},{"GuideNumber":"1710","GuideName":"INTI TV HD","URL":"http:\/\/192.168.1.4:5004\/auto\/v1710"},{"GuideNumber":"1711","GuideName":"Caracol TV HD","URL":"http:\/\/192.168.1.4:5004\/auto\/v1711"},{"GuideNumber":"1719","GuideName":"BabyFirst HD","URL":"http:\/\/192.168.1.4:5004\/auto\/v1719"},{"GuideNumber":"1720","GuideName":"Sorpresa","URL":"http:\/\/192.168.1.4:5004\/auto\/v1720"},{"GuideNumber":"1721","GuideName":"Semillitas HD","URL":"http:\/\/192.168.1.4:5004\/auto\/v1721"},{"GuideNumber":"1722","GuideName":"Disney XD East","URL":"http:\/\/192.168.1.4:5004\/auto\/v1722"},{"GuideNumber":"1723","GuideName":"Semillitas","URL":"http:\/\/192.168.1.4:5004\/auto\/v1723"},{"GuideNumber":"1724","GuideName":"Clan HD","URL":"http:\/\/192.168.1.4:5004\/auto\/v1724"},{"GuideNumber":"1725","GuideName":"Boomerang","URL":"http:\/\/192.168.1.4:5004\/auto\/v1725"},{"GuideNumber":"1726","GuideName":"Cartoon Network East","URL":"http:\/\/192.168.1.4:5004\/auto\/v1726"},{"GuideNumber":"1727","GuideName":"BBC CBEEBIES","URL":"http:\/\/192.168.1.4:5004\/auto\/v1727"},{"GuideNumber":"1728","GuideName":"Nickelodeon East","URL":"http:\/\/192.168.1.4:5004\/auto\/v1728"},{"GuideNumber":"1729","GuideName":"Disney East","URL":"http:\/\/192.168.1.4:5004\/auto\/v1729"},{"GuideNumber":"1730","GuideName":"Ultra Kidz","URL":"http:\/\/192.168.1.4:5004\/auto\/v1730"},{"GuideNumber":"1740","GuideName":"TBN Enclace USA","URL":"http:\/\/192.168.1.4:5004\/auto\/v1740"},{"GuideNumber":"1741","GuideName":"EWTN Espanol","URL":"http:\/\/192.168.1.4:5004\/auto\/v1741"},{"GuideNumber":"1750","GuideName":"Aapka Colors","URL":"http:\/\/192.168.1.4:5004\/auto\/v1750"},{"GuideNumber":"1751","GuideName":"Zee News","URL":"http:\/\/192.168.1.4:5004\/auto\/v1751"},{"GuideNumber":"1752","GuideName":"TV Asia","URL":"http:\/\/192.168.1.4:5004\/auto\/v1752"},{"GuideNumber":"1753","GuideName":"Zee TV","URL":"http:\/\/192.168.1.4:5004\/auto\/v1753"},{"GuideNumber":"1754","GuideName":"SET","URL":"http:\/\/192.168.1.4:5004\/auto\/v1754"},{"GuideNumber":"1755","GuideName":"Filipino Channel","URL":"http:\/\/192.168.1.4:5004\/auto\/v1755"},{"GuideNumber":"1756","GuideName":"GMA Pinoy","URL":"http:\/\/192.168.1.4:5004\/auto\/v1756"},{"GuideNumber":"1757","GuideName":"Jus Punjabi","URL":"http:\/\/192.168.1.4:5004\/auto\/v1757"},{"GuideNumber":"1758","GuideName":"KBS America HD","URL":"http:\/\/192.168.1.4:5004\/auto\/v1758"},{"GuideNumber":"1759","GuideName":"MBC Drama HD","URL":"http:\/\/192.168.1.4:5004\/auto\/v1759"},{"GuideNumber":"1760","GuideName":"MBC (Korean)","URL":"http:\/\/192.168.1.4:5004\/auto\/v1760"},{"GuideNumber":"1761","GuideName":"YTN","URL":"http:\/\/192.168.1.4:5004\/auto\/v1761"},{"GuideNumber":"1762","GuideName":"SBS","URL":"http:\/\/192.168.1.4:5004\/auto\/v1762"},{"GuideNumber":"1763","GuideName":"SIC Internacional HD","URL":"http:\/\/192.168.1.4:5004\/auto\/v1763"},{"GuideNumber":"1764","GuideName":"RTPi","URL":"http:\/\/192.168.1.4:5004\/auto\/v1764"},{"GuideNumber":"1765","GuideName":"SBTN (Viet)","URL":"http:\/\/192.168.1.4:5004\/auto\/v1765"},{"GuideNumber":"1766","GuideName":"CTN","URL":"http:\/\/192.168.1.4:5004\/auto\/v1766"},{"GuideNumber":"1767","GuideName":"TVK","URL":"http:\/\/192.168.1.4:5004\/auto\/v1767"},{"GuideNumber":"1768","GuideName":"TV Globo","URL":"http:\/\/192.168.1.4:5004\/auto\/v1768"},{"GuideNumber":"1769","GuideName":"TV Japan HD","URL":"http:\/\/192.168.1.4:5004\/auto\/v1769"},{"GuideNumber":"1770","GuideName":"TV Japan","URL":"http:\/\/192.168.1.4:5004\/auto\/v1770"},{"GuideNumber":"1771","GuideName":"TV5 Monde HD","URL":"http:\/\/192.168.1.4:5004\/auto\/v1771"},{"GuideNumber":"1773","GuideName":"Channel 1 Russian","URL":"http:\/\/192.168.1.4:5004\/auto\/v1773"},{"GuideNumber":"1774","GuideName":"RTN (Russian)","URL":"http:\/\/192.168.1.4:5004\/auto\/v1774"},{"GuideNumber":"1775","GuideName":"RTR Planeta","URL":"http:\/\/192.168.1.4:5004\/auto\/v1775"},{"GuideNumber":"1776","GuideName":"RTVI HD","URL":"http:\/\/192.168.1.4:5004\/auto\/v1776"},{"GuideNumber":"1777","GuideName":"BN","URL":"http:\/\/192.168.1.4:5004\/auto\/v1777"},{"GuideNumber":"1778","GuideName":"O Kanal","URL":"http:\/\/192.168.1.4:5004\/auto\/v1778"},{"GuideNumber":"1779","GuideName":"Public TV of Armenia","URL":"http:\/\/192.168.1.4:5004\/auto\/v1779"},{"GuideNumber":"1780","GuideName":"ART (Arabic)","URL":"http:\/\/192.168.1.4:5004\/auto\/v1780"},{"GuideNumber":"1781","GuideName":"Kuwait TV","URL":"http:\/\/192.168.1.4:5004\/auto\/v1781"},{"GuideNumber":"1782","GuideName":"Israeli Network","URL":"http:\/\/192.168.1.4:5004\/auto\/v1782"},{"GuideNumber":"1783","GuideName":"Pro TV (RSC-3)","URL":"http:\/\/192.168.1.4:5004\/auto\/v1783"},{"GuideNumber":"1784","GuideName":"TVRi","URL":"http:\/\/192.168.1.4:5004\/auto\/v1784"},{"GuideNumber":"1785","GuideName":"Rang A Rang (Farsi)","URL":"http:\/\/192.168.1.4:5004\/auto\/v1785"},{"GuideNumber":"1787","GuideName":"DW Amerika","URL":"http:\/\/192.168.1.4:5004\/auto\/v1787"},{"GuideNumber":"1788","GuideName":"ProSiebenSAT.1Welt","URL":"http:\/\/192.168.1.4:5004\/auto\/v1788"},{"GuideNumber":"1789","GuideName":"Antenna","URL":"http:\/\/192.168.1.4:5004\/auto\/v1789"},{"GuideNumber":"1790","GuideName":"RAI (Italian)","URL":"http:\/\/192.168.1.4:5004\/auto\/v1790"},{"GuideNumber":"1791","GuideName":"MediaSet Italia","URL":"http:\/\/192.168.1.4:5004\/auto\/v1791"},{"GuideNumber":"1792","GuideName":"TVB1","URL":"http:\/\/192.168.1.4:5004\/auto\/v1792"},{"GuideNumber":"1793","GuideName":"TVB Drama","URL":"http:\/\/192.168.1.4:5004\/auto\/v1793"},{"GuideNumber":"1794","GuideName":"TVBe","URL":"http:\/\/192.168.1.4:5004\/auto\/v1794"},{"GuideNumber":"1795","GuideName":"CCTV-4 (Mandarin)","URL":"http:\/\/192.168.1.4:5004\/auto\/v1795"},{"GuideNumber":"1796","GuideName":"CTI-Zhong Tian","URL":"http:\/\/192.168.1.4:5004\/auto\/v1796"},{"GuideNumber":"1797","GuideName":"Phoenix","URL":"http:\/\/192.168.1.4:5004\/auto\/v1797"}]
Luke 42241 Posted February 8, 2024 Posted February 8, 2024 What you could do is try removing all tuner sources from live tv setup, complete the subsequent guide refresh, and then add them back.
sward 28 Posted February 9, 2024 Author Posted February 9, 2024 So after deleting the Ceton and adding it back I was able to launch a live stream, but after stopping this initial live stream, any subsequent attempts failed. Full log is attached, but relevant section is here: 2024-02-08 20:21:31.889 Info SessionManager: Playback start reported by app Emby Web 4.8.1.0 playing MSNBC HD. Started at 0 ms 2024-02-08 20:21:31.890 Info Server: http/1.1 Response 204 to 192.168.1.4. Time: 2ms. POST http://192.168.1.4:8096/emby/Sessions/Playing?X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome Windows&X-Emby-Device-Id=ece699cb-abe6-4ffa-98f1-7b81b4c0de40&X-Emby-Client-Version=4.8.1.0&X-Emby-Token=x_secret2_x&X-Emby-Language=en-us&reqformat=json 2024-02-08 20:21:31.964 Info Server: http/1.1 POST http://192.168.1.4:8096/emby/Sessions/Playing/Progress?X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome Windows&X-Emby-Device-Id=ece699cb-abe6-4ffa-98f1-7b81b4c0de40&X-Emby-Client-Version=4.8.1.0&X-Emby-Token=x_secret2_x&X-Emby-Language=en-us&reqformat=json. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/121.0.0.0 Safari/537.36 2024-02-08 20:21:31.966 Info Server: http/1.1 Response 204 to 192.168.1.4. Time: 1ms. POST http://192.168.1.4:8096/emby/Sessions/Playing/Progress?X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome Windows&X-Emby-Device-Id=ece699cb-abe6-4ffa-98f1-7b81b4c0de40&X-Emby-Client-Version=4.8.1.0&X-Emby-Token=x_secret2_x&X-Emby-Language=en-us&reqformat=json 2024-02-08 20:21:34.507 Info Server: http/1.1 GET http://192.168.1.4:8096/emby/videos/17804845/live.m3u8?DeviceId=ece699cb-abe6-4ffa-98f1-7b81b4c0de40&MediaSourceId=native_e35bc8df39ab263c2c7ed7966836cabd_f8f181232418314d1bc8239f1eabc416&PlaySessionId=5bf719e1d7db4352a138caa0e57ccf41&api_key=x_secret2_x&LiveStreamId=06044cf0e6f93cdae5f285c9ecfaaeb4_01413a525b3a9622ce6fdf19f7dde354_native_e35bc8df39ab263c2c7ed7966836cabd_f8f181232418314d1bc8239f1eabc416&VideoCodec=h264,h265,hevc,av1&AudioCodec=mp3,aac&VideoBitrate=159616000&AudioBitrate=384000&MaxWidth=3840&AudioStreamIndex=1&VideoSideDataSubs=100&TranscodingMaxAudioChannels=2&SegmentContainer=m4s,ts&MinSegments=1&BreakOnNonKeyFrames=True&SubtitleStreamIndexes=-1&ManifestSubtitles=vtt&h264-profile=high,main,baseline,constrainedbaseline,high10&h264-level=62&hevc-codectag=hvc1,hev1,hevc,hdmv&TranscodeReasons=ContainerNotSupported. Accept=*/*, Connection=keep-alive, Host=host4, User-Agent=Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/121.0.0.0 Safari/537.36, Accept-Encoding=gzip, deflate, Accept-Language=en-US,en;q=0.9,fr;q=0.8, Referer=http://192.168.1.4:8096/web/index.html 2024-02-08 20:21:34.508 Info Server: http/1.1 Response 200 to 192.168.1.4. Time: 1ms. GET http://192.168.1.4:8096/emby/videos/17804845/live.m3u8?DeviceId=ece699cb-abe6-4ffa-98f1-7b81b4c0de40&MediaSourceId=native_e35bc8df39ab263c2c7ed7966836cabd_f8f181232418314d1bc8239f1eabc416&PlaySessionId=5bf719e1d7db4352a138caa0e57ccf41&api_key=x_secret2_x&LiveStreamId=06044cf0e6f93cdae5f285c9ecfaaeb4_01413a525b3a9622ce6fdf19f7dde354_native_e35bc8df39ab263c2c7ed7966836cabd_f8f181232418314d1bc8239f1eabc416&VideoCodec=h264,h265,hevc,av1&AudioCodec=mp3,aac&VideoBitrate=159616000&AudioBitrate=384000&MaxWidth=3840&AudioStreamIndex=1&VideoSideDataSubs=100&TranscodingMaxAudioChannels=2&SegmentContainer=m4s,ts&MinSegments=1&BreakOnNonKeyFrames=True&SubtitleStreamIndexes=-1&ManifestSubtitles=vtt&h264-profile=high,main,baseline,constrainedbaseline,high10&h264-level=62&hevc-codectag=hvc1,hev1,hevc,hdmv&TranscodeReasons=ContainerNotSupported 2024-02-08 20:21:34.511 Info Server: http/1.1 GET http://192.168.1.4:8096/emby/videos/17804845/hls/2EB688/2EB688_1.ts?PlaySessionId=5bf719e1d7db4352a138caa0e57ccf41. Accept=*/*, Connection=keep-alive, Host=host4, User-Agent=Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/121.0.0.0 Safari/537.36, Accept-Encoding=gzip, deflate, Accept-Language=en-US,en;q=0.9,fr;q=0.8, Referer=http://192.168.1.4:8096/web/index.html 2024-02-08 20:21:34.515 Info Server: http/1.1 Response 200 to 192.168.1.4. Time: 3ms. GET http://192.168.1.4:8096/emby/videos/17804845/hls/2EB688/2EB688_1.ts?PlaySessionId=5bf719e1d7db4352a138caa0e57ccf41 2024-02-08 20:21:34.540 Info Server: http/1.1 GET http://192.168.1.4:8096/emby/videos/17804845/hls/2EB688/2EB688_2.ts?PlaySessionId=5bf719e1d7db4352a138caa0e57ccf41. Accept=*/*, Connection=keep-alive, Host=host4, User-Agent=Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/121.0.0.0 Safari/537.36, Accept-Encoding=gzip, deflate, Accept-Language=en-US,en;q=0.9,fr;q=0.8, Referer=http://192.168.1.4:8096/web/index.html 2024-02-08 20:21:34.541 Info Server: http/1.1 Response 200 to 192.168.1.4. Time: 2ms. GET http://192.168.1.4:8096/emby/videos/17804845/hls/2EB688/2EB688_2.ts?PlaySessionId=5bf719e1d7db4352a138caa0e57ccf41 2024-02-08 20:21:37.511 Info Server: http/1.1 GET http://192.168.1.4:8096/emby/videos/17804845/live.m3u8?DeviceId=ece699cb-abe6-4ffa-98f1-7b81b4c0de40&MediaSourceId=native_e35bc8df39ab263c2c7ed7966836cabd_f8f181232418314d1bc8239f1eabc416&PlaySessionId=5bf719e1d7db4352a138caa0e57ccf41&api_key=x_secret2_x&LiveStreamId=06044cf0e6f93cdae5f285c9ecfaaeb4_01413a525b3a9622ce6fdf19f7dde354_native_e35bc8df39ab263c2c7ed7966836cabd_f8f181232418314d1bc8239f1eabc416&VideoCodec=h264,h265,hevc,av1&AudioCodec=mp3,aac&VideoBitrate=159616000&AudioBitrate=384000&MaxWidth=3840&AudioStreamIndex=1&VideoSideDataSubs=100&TranscodingMaxAudioChannels=2&SegmentContainer=m4s,ts&MinSegments=1&BreakOnNonKeyFrames=True&SubtitleStreamIndexes=-1&ManifestSubtitles=vtt&h264-profile=high,main,baseline,constrainedbaseline,high10&h264-level=62&hevc-codectag=hvc1,hev1,hevc,hdmv&TranscodeReasons=ContainerNotSupported. Accept=*/*, Connection=keep-alive, Host=host4, User-Agent=Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/121.0.0.0 Safari/537.36, Accept-Encoding=gzip, deflate, Accept-Language=en-US,en;q=0.9,fr;q=0.8, Referer=http://192.168.1.4:8096/web/index.html 2024-02-08 20:21:37.512 Info Server: http/1.1 Response 200 to 192.168.1.4. Time: 1ms. GET http://192.168.1.4:8096/emby/videos/17804845/live.m3u8?DeviceId=ece699cb-abe6-4ffa-98f1-7b81b4c0de40&MediaSourceId=native_e35bc8df39ab263c2c7ed7966836cabd_f8f181232418314d1bc8239f1eabc416&PlaySessionId=5bf719e1d7db4352a138caa0e57ccf41&api_key=x_secret2_x&LiveStreamId=06044cf0e6f93cdae5f285c9ecfaaeb4_01413a525b3a9622ce6fdf19f7dde354_native_e35bc8df39ab263c2c7ed7966836cabd_f8f181232418314d1bc8239f1eabc416&VideoCodec=h264,h265,hevc,av1&AudioCodec=mp3,aac&VideoBitrate=159616000&AudioBitrate=384000&MaxWidth=3840&AudioStreamIndex=1&VideoSideDataSubs=100&TranscodingMaxAudioChannels=2&SegmentContainer=m4s,ts&MinSegments=1&BreakOnNonKeyFrames=True&SubtitleStreamIndexes=-1&ManifestSubtitles=vtt&h264-profile=high,main,baseline,constrainedbaseline,high10&h264-level=62&hevc-codectag=hvc1,hev1,hevc,hdmv&TranscodeReasons=ContainerNotSupported 2024-02-08 20:21:37.514 Info Server: http/1.1 GET http://192.168.1.4:8096/emby/videos/17804845/hls/2EB688/2EB688_3.ts?PlaySessionId=5bf719e1d7db4352a138caa0e57ccf41. Accept=*/*, Connection=keep-alive, Host=host4, User-Agent=Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/121.0.0.0 Safari/537.36, Accept-Encoding=gzip, deflate, Accept-Language=en-US,en;q=0.9,fr;q=0.8, Referer=http://192.168.1.4:8096/web/index.html 2024-02-08 20:21:37.531 Info Server: http/1.1 Response 200 to 192.168.1.4. Time: 17ms. GET http://192.168.1.4:8096/emby/videos/17804845/hls/2EB688/2EB688_3.ts?PlaySessionId=5bf719e1d7db4352a138caa0e57ccf41 2024-02-08 20:21:40.513 Info Server: http/1.1 GET http://192.168.1.4:8096/emby/videos/17804845/live.m3u8?DeviceId=ece699cb-abe6-4ffa-98f1-7b81b4c0de40&MediaSourceId=native_e35bc8df39ab263c2c7ed7966836cabd_f8f181232418314d1bc8239f1eabc416&PlaySessionId=5bf719e1d7db4352a138caa0e57ccf41&api_key=x_secret2_x&LiveStreamId=06044cf0e6f93cdae5f285c9ecfaaeb4_01413a525b3a9622ce6fdf19f7dde354_native_e35bc8df39ab263c2c7ed7966836cabd_f8f181232418314d1bc8239f1eabc416&VideoCodec=h264,h265,hevc,av1&AudioCodec=mp3,aac&VideoBitrate=159616000&AudioBitrate=384000&MaxWidth=3840&AudioStreamIndex=1&VideoSideDataSubs=100&TranscodingMaxAudioChannels=2&SegmentContainer=m4s,ts&MinSegments=1&BreakOnNonKeyFrames=True&SubtitleStreamIndexes=-1&ManifestSubtitles=vtt&h264-profile=high,main,baseline,constrainedbaseline,high10&h264-level=62&hevc-codectag=hvc1,hev1,hevc,hdmv&TranscodeReasons=ContainerNotSupported. Accept=*/*, Connection=keep-alive, Host=host4, User-Agent=Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/121.0.0.0 Safari/537.36, Accept-Encoding=gzip, deflate, Accept-Language=en-US,en;q=0.9,fr;q=0.8, Referer=http://192.168.1.4:8096/web/index.html 2024-02-08 20:21:40.515 Info Server: http/1.1 Response 200 to 192.168.1.4. Time: 2ms. GET http://192.168.1.4:8096/emby/videos/17804845/live.m3u8?DeviceId=ece699cb-abe6-4ffa-98f1-7b81b4c0de40&MediaSourceId=native_e35bc8df39ab263c2c7ed7966836cabd_f8f181232418314d1bc8239f1eabc416&PlaySessionId=5bf719e1d7db4352a138caa0e57ccf41&api_key=x_secret2_x&LiveStreamId=06044cf0e6f93cdae5f285c9ecfaaeb4_01413a525b3a9622ce6fdf19f7dde354_native_e35bc8df39ab263c2c7ed7966836cabd_f8f181232418314d1bc8239f1eabc416&VideoCodec=h264,h265,hevc,av1&AudioCodec=mp3,aac&VideoBitrate=159616000&AudioBitrate=384000&MaxWidth=3840&AudioStreamIndex=1&VideoSideDataSubs=100&TranscodingMaxAudioChannels=2&SegmentContainer=m4s,ts&MinSegments=1&BreakOnNonKeyFrames=True&SubtitleStreamIndexes=-1&ManifestSubtitles=vtt&h264-profile=high,main,baseline,constrainedbaseline,high10&h264-level=62&hevc-codectag=hvc1,hev1,hevc,hdmv&TranscodeReasons=ContainerNotSupported 2024-02-08 20:21:40.518 Info Server: http/1.1 GET http://192.168.1.4:8096/emby/videos/17804845/hls/2EB688/2EB688_4.ts?PlaySessionId=5bf719e1d7db4352a138caa0e57ccf41. Accept=*/*, Connection=keep-alive, Host=host4, User-Agent=Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/121.0.0.0 Safari/537.36, Accept-Encoding=gzip, deflate, Accept-Language=en-US,en;q=0.9,fr;q=0.8, Referer=http://192.168.1.4:8096/web/index.html 2024-02-08 20:21:40.520 Info Server: http/1.1 Response 200 to 192.168.1.4. Time: 3ms. GET http://192.168.1.4:8096/emby/videos/17804845/hls/2EB688/2EB688_4.ts?PlaySessionId=5bf719e1d7db4352a138caa0e57ccf41 2024-02-08 20:21:42.075 Info Server: http/1.1 POST http://192.168.1.4:8096/emby/Sessions/Playing/Progress?X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome Windows&X-Emby-Device-Id=ece699cb-abe6-4ffa-98f1-7b81b4c0de40&X-Emby-Client-Version=4.8.1.0&X-Emby-Token=x_secret2_x&X-Emby-Language=en-us&reqformat=json. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/121.0.0.0 Safari/537.36 2024-02-08 20:21:42.076 Info Server: http/1.1 Response 204 to 192.168.1.4. Time: 1ms. POST http://192.168.1.4:8096/emby/Sessions/Playing/Progress?X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome Windows&X-Emby-Device-Id=ece699cb-abe6-4ffa-98f1-7b81b4c0de40&X-Emby-Client-Version=4.8.1.0&X-Emby-Token=x_secret2_x&X-Emby-Language=en-us&reqformat=json 2024-02-08 20:21:43.521 Info Server: http/1.1 GET http://192.168.1.4:8096/emby/videos/17804845/live.m3u8?DeviceId=ece699cb-abe6-4ffa-98f1-7b81b4c0de40&MediaSourceId=native_e35bc8df39ab263c2c7ed7966836cabd_f8f181232418314d1bc8239f1eabc416&PlaySessionId=5bf719e1d7db4352a138caa0e57ccf41&api_key=x_secret2_x&LiveStreamId=06044cf0e6f93cdae5f285c9ecfaaeb4_01413a525b3a9622ce6fdf19f7dde354_native_e35bc8df39ab263c2c7ed7966836cabd_f8f181232418314d1bc8239f1eabc416&VideoCodec=h264,h265,hevc,av1&AudioCodec=mp3,aac&VideoBitrate=159616000&AudioBitrate=384000&MaxWidth=3840&AudioStreamIndex=1&VideoSideDataSubs=100&TranscodingMaxAudioChannels=2&SegmentContainer=m4s,ts&MinSegments=1&BreakOnNonKeyFrames=True&SubtitleStreamIndexes=-1&ManifestSubtitles=vtt&h264-profile=high,main,baseline,constrainedbaseline,high10&h264-level=62&hevc-codectag=hvc1,hev1,hevc,hdmv&TranscodeReasons=ContainerNotSupported. Accept=*/*, Connection=keep-alive, Host=host4, User-Agent=Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/121.0.0.0 Safari/537.36, Accept-Encoding=gzip, deflate, Accept-Language=en-US,en;q=0.9,fr;q=0.8, Referer=http://192.168.1.4:8096/web/index.html 2024-02-08 20:21:43.522 Info Server: http/1.1 Response 200 to 192.168.1.4. Time: 1ms. GET http://192.168.1.4:8096/emby/videos/17804845/live.m3u8?DeviceId=ece699cb-abe6-4ffa-98f1-7b81b4c0de40&MediaSourceId=native_e35bc8df39ab263c2c7ed7966836cabd_f8f181232418314d1bc8239f1eabc416&PlaySessionId=5bf719e1d7db4352a138caa0e57ccf41&api_key=x_secret2_x&LiveStreamId=06044cf0e6f93cdae5f285c9ecfaaeb4_01413a525b3a9622ce6fdf19f7dde354_native_e35bc8df39ab263c2c7ed7966836cabd_f8f181232418314d1bc8239f1eabc416&VideoCodec=h264,h265,hevc,av1&AudioCodec=mp3,aac&VideoBitrate=159616000&AudioBitrate=384000&MaxWidth=3840&AudioStreamIndex=1&VideoSideDataSubs=100&TranscodingMaxAudioChannels=2&SegmentContainer=m4s,ts&MinSegments=1&BreakOnNonKeyFrames=True&SubtitleStreamIndexes=-1&ManifestSubtitles=vtt&h264-profile=high,main,baseline,constrainedbaseline,high10&h264-level=62&hevc-codectag=hvc1,hev1,hevc,hdmv&TranscodeReasons=ContainerNotSupported 2024-02-08 20:21:43.524 Info Server: http/1.1 GET http://192.168.1.4:8096/emby/videos/17804845/hls/2EB688/2EB688_5.ts?PlaySessionId=5bf719e1d7db4352a138caa0e57ccf41. Accept=*/*, Connection=keep-alive, Host=host4, User-Agent=Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/121.0.0.0 Safari/537.36, Accept-Encoding=gzip, deflate, Accept-Language=en-US,en;q=0.9,fr;q=0.8, Referer=http://192.168.1.4:8096/web/index.html 2024-02-08 20:21:43.526 Info Server: http/1.1 Response 200 to 192.168.1.4. Time: 2ms. GET http://192.168.1.4:8096/emby/videos/17804845/hls/2EB688/2EB688_5.ts?PlaySessionId=5bf719e1d7db4352a138caa0e57ccf41 2024-02-08 20:21:46.523 Info Server: http/1.1 GET http://192.168.1.4:8096/emby/videos/17804845/live.m3u8?DeviceId=ece699cb-abe6-4ffa-98f1-7b81b4c0de40&MediaSourceId=native_e35bc8df39ab263c2c7ed7966836cabd_f8f181232418314d1bc8239f1eabc416&PlaySessionId=5bf719e1d7db4352a138caa0e57ccf41&api_key=x_secret2_x&LiveStreamId=06044cf0e6f93cdae5f285c9ecfaaeb4_01413a525b3a9622ce6fdf19f7dde354_native_e35bc8df39ab263c2c7ed7966836cabd_f8f181232418314d1bc8239f1eabc416&VideoCodec=h264,h265,hevc,av1&AudioCodec=mp3,aac&VideoBitrate=159616000&AudioBitrate=384000&MaxWidth=3840&AudioStreamIndex=1&VideoSideDataSubs=100&TranscodingMaxAudioChannels=2&SegmentContainer=m4s,ts&MinSegments=1&BreakOnNonKeyFrames=True&SubtitleStreamIndexes=-1&ManifestSubtitles=vtt&h264-profile=high,main,baseline,constrainedbaseline,high10&h264-level=62&hevc-codectag=hvc1,hev1,hevc,hdmv&TranscodeReasons=ContainerNotSupported. Accept=*/*, Connection=keep-alive, Host=host4, User-Agent=Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/121.0.0.0 Safari/537.36, Accept-Encoding=gzip, deflate, Accept-Language=en-US,en;q=0.9,fr;q=0.8, Referer=http://192.168.1.4:8096/web/index.html 2024-02-08 20:21:46.524 Info Server: http/1.1 Response 200 to 192.168.1.4. Time: 1ms. GET http://192.168.1.4:8096/emby/videos/17804845/live.m3u8?DeviceId=ece699cb-abe6-4ffa-98f1-7b81b4c0de40&MediaSourceId=native_e35bc8df39ab263c2c7ed7966836cabd_f8f181232418314d1bc8239f1eabc416&PlaySessionId=5bf719e1d7db4352a138caa0e57ccf41&api_key=x_secret2_x&LiveStreamId=06044cf0e6f93cdae5f285c9ecfaaeb4_01413a525b3a9622ce6fdf19f7dde354_native_e35bc8df39ab263c2c7ed7966836cabd_f8f181232418314d1bc8239f1eabc416&VideoCodec=h264,h265,hevc,av1&AudioCodec=mp3,aac&VideoBitrate=159616000&AudioBitrate=384000&MaxWidth=3840&AudioStreamIndex=1&VideoSideDataSubs=100&TranscodingMaxAudioChannels=2&SegmentContainer=m4s,ts&MinSegments=1&BreakOnNonKeyFrames=True&SubtitleStreamIndexes=-1&ManifestSubtitles=vtt&h264-profile=high,main,baseline,constrainedbaseline,high10&h264-level=62&hevc-codectag=hvc1,hev1,hevc,hdmv&TranscodeReasons=ContainerNotSupported 2024-02-08 20:21:46.526 Info Server: http/1.1 GET http://192.168.1.4:8096/emby/videos/17804845/hls/2EB688/2EB688_6.ts?PlaySessionId=5bf719e1d7db4352a138caa0e57ccf41. Accept=*/*, Connection=keep-alive, Host=host4, User-Agent=Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/121.0.0.0 Safari/537.36, Accept-Encoding=gzip, deflate, Accept-Language=en-US,en;q=0.9,fr;q=0.8, Referer=http://192.168.1.4:8096/web/index.html 2024-02-08 20:21:46.530 Info Server: http/1.1 Response 200 to 192.168.1.4. Time: 3ms. GET http://192.168.1.4:8096/emby/videos/17804845/hls/2EB688/2EB688_6.ts?PlaySessionId=5bf719e1d7db4352a138caa0e57ccf41 2024-02-08 20:21:49.513 Info Server: http/1.1 GET http://192.168.1.4:8096/emby/videos/17804845/live.m3u8?DeviceId=ece699cb-abe6-4ffa-98f1-7b81b4c0de40&MediaSourceId=native_e35bc8df39ab263c2c7ed7966836cabd_f8f181232418314d1bc8239f1eabc416&PlaySessionId=5bf719e1d7db4352a138caa0e57ccf41&api_key=x_secret2_x&LiveStreamId=06044cf0e6f93cdae5f285c9ecfaaeb4_01413a525b3a9622ce6fdf19f7dde354_native_e35bc8df39ab263c2c7ed7966836cabd_f8f181232418314d1bc8239f1eabc416&VideoCodec=h264,h265,hevc,av1&AudioCodec=mp3,aac&VideoBitrate=159616000&AudioBitrate=384000&MaxWidth=3840&AudioStreamIndex=1&VideoSideDataSubs=100&TranscodingMaxAudioChannels=2&SegmentContainer=m4s,ts&MinSegments=1&BreakOnNonKeyFrames=True&SubtitleStreamIndexes=-1&ManifestSubtitles=vtt&h264-profile=high,main,baseline,constrainedbaseline,high10&h264-level=62&hevc-codectag=hvc1,hev1,hevc,hdmv&TranscodeReasons=ContainerNotSupported. Accept=*/*, Connection=keep-alive, Host=host4, User-Agent=Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/121.0.0.0 Safari/537.36, Accept-Encoding=gzip, deflate, Accept-Language=en-US,en;q=0.9,fr;q=0.8, Referer=http://192.168.1.4:8096/web/index.html 2024-02-08 20:21:49.515 Info Server: http/1.1 Response 200 to 192.168.1.4. Time: 1ms. GET http://192.168.1.4:8096/emby/videos/17804845/live.m3u8?DeviceId=ece699cb-abe6-4ffa-98f1-7b81b4c0de40&MediaSourceId=native_e35bc8df39ab263c2c7ed7966836cabd_f8f181232418314d1bc8239f1eabc416&PlaySessionId=5bf719e1d7db4352a138caa0e57ccf41&api_key=x_secret2_x&LiveStreamId=06044cf0e6f93cdae5f285c9ecfaaeb4_01413a525b3a9622ce6fdf19f7dde354_native_e35bc8df39ab263c2c7ed7966836cabd_f8f181232418314d1bc8239f1eabc416&VideoCodec=h264,h265,hevc,av1&AudioCodec=mp3,aac&VideoBitrate=159616000&AudioBitrate=384000&MaxWidth=3840&AudioStreamIndex=1&VideoSideDataSubs=100&TranscodingMaxAudioChannels=2&SegmentContainer=m4s,ts&MinSegments=1&BreakOnNonKeyFrames=True&SubtitleStreamIndexes=-1&ManifestSubtitles=vtt&h264-profile=high,main,baseline,constrainedbaseline,high10&h264-level=62&hevc-codectag=hvc1,hev1,hevc,hdmv&TranscodeReasons=ContainerNotSupported 2024-02-08 20:21:49.517 Info Server: http/1.1 GET http://192.168.1.4:8096/emby/videos/17804845/hls/2EB688/2EB688_7.ts?PlaySessionId=5bf719e1d7db4352a138caa0e57ccf41. Accept=*/*, Connection=keep-alive, Host=host4, User-Agent=Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/121.0.0.0 Safari/537.36, Accept-Encoding=gzip, deflate, Accept-Language=en-US,en;q=0.9,fr;q=0.8, Referer=http://192.168.1.4:8096/web/index.html 2024-02-08 20:21:49.524 Info Server: http/1.1 Response 200 to 192.168.1.4. Time: 7ms. GET http://192.168.1.4:8096/emby/videos/17804845/hls/2EB688/2EB688_7.ts?PlaySessionId=5bf719e1d7db4352a138caa0e57ccf41 2024-02-08 20:21:52.167 Info Server: http/1.1 POST http://192.168.1.4:8096/emby/Sessions/Playing/Progress?X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome Windows&X-Emby-Device-Id=ece699cb-abe6-4ffa-98f1-7b81b4c0de40&X-Emby-Client-Version=4.8.1.0&X-Emby-Token=x_secret2_x&X-Emby-Language=en-us&reqformat=json. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/121.0.0.0 Safari/537.36 2024-02-08 20:21:52.168 Info Server: http/1.1 Response 204 to 192.168.1.4. Time: 1ms. POST http://192.168.1.4:8096/emby/Sessions/Playing/Progress?X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome Windows&X-Emby-Device-Id=ece699cb-abe6-4ffa-98f1-7b81b4c0de40&X-Emby-Client-Version=4.8.1.0&X-Emby-Token=x_secret2_x&X-Emby-Language=en-us&reqformat=json 2024-02-08 20:21:52.520 Info Server: http/1.1 GET http://192.168.1.4:8096/emby/videos/17804845/live.m3u8?DeviceId=ece699cb-abe6-4ffa-98f1-7b81b4c0de40&MediaSourceId=native_e35bc8df39ab263c2c7ed7966836cabd_f8f181232418314d1bc8239f1eabc416&PlaySessionId=5bf719e1d7db4352a138caa0e57ccf41&api_key=x_secret2_x&LiveStreamId=06044cf0e6f93cdae5f285c9ecfaaeb4_01413a525b3a9622ce6fdf19f7dde354_native_e35bc8df39ab263c2c7ed7966836cabd_f8f181232418314d1bc8239f1eabc416&VideoCodec=h264,h265,hevc,av1&AudioCodec=mp3,aac&VideoBitrate=159616000&AudioBitrate=384000&MaxWidth=3840&AudioStreamIndex=1&VideoSideDataSubs=100&TranscodingMaxAudioChannels=2&SegmentContainer=m4s,ts&MinSegments=1&BreakOnNonKeyFrames=True&SubtitleStreamIndexes=-1&ManifestSubtitles=vtt&h264-profile=high,main,baseline,constrainedbaseline,high10&h264-level=62&hevc-codectag=hvc1,hev1,hevc,hdmv&TranscodeReasons=ContainerNotSupported. Accept=*/*, Connection=keep-alive, Host=host4, User-Agent=Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/121.0.0.0 Safari/537.36, Accept-Encoding=gzip, deflate, Accept-Language=en-US,en;q=0.9,fr;q=0.8, Referer=http://192.168.1.4:8096/web/index.html 2024-02-08 20:21:52.521 Info Server: http/1.1 Response 200 to 192.168.1.4. Time: 1ms. GET http://192.168.1.4:8096/emby/videos/17804845/live.m3u8?DeviceId=ece699cb-abe6-4ffa-98f1-7b81b4c0de40&MediaSourceId=native_e35bc8df39ab263c2c7ed7966836cabd_f8f181232418314d1bc8239f1eabc416&PlaySessionId=5bf719e1d7db4352a138caa0e57ccf41&api_key=x_secret2_x&LiveStreamId=06044cf0e6f93cdae5f285c9ecfaaeb4_01413a525b3a9622ce6fdf19f7dde354_native_e35bc8df39ab263c2c7ed7966836cabd_f8f181232418314d1bc8239f1eabc416&VideoCodec=h264,h265,hevc,av1&AudioCodec=mp3,aac&VideoBitrate=159616000&AudioBitrate=384000&MaxWidth=3840&AudioStreamIndex=1&VideoSideDataSubs=100&TranscodingMaxAudioChannels=2&SegmentContainer=m4s,ts&MinSegments=1&BreakOnNonKeyFrames=True&SubtitleStreamIndexes=-1&ManifestSubtitles=vtt&h264-profile=high,main,baseline,constrainedbaseline,high10&h264-level=62&hevc-codectag=hvc1,hev1,hevc,hdmv&TranscodeReasons=ContainerNotSupported 2024-02-08 20:21:52.523 Info Server: http/1.1 GET http://192.168.1.4:8096/emby/videos/17804845/hls/2EB688/2EB688_8.ts?PlaySessionId=5bf719e1d7db4352a138caa0e57ccf41. Accept=*/*, Connection=keep-alive, Host=host4, User-Agent=Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/121.0.0.0 Safari/537.36, Accept-Encoding=gzip, deflate, Accept-Language=en-US,en;q=0.9,fr;q=0.8, Referer=http://192.168.1.4:8096/web/index.html 2024-02-08 20:21:52.525 Info Server: http/1.1 Response 200 to 192.168.1.4. Time: 2ms. GET http://192.168.1.4:8096/emby/videos/17804845/hls/2EB688/2EB688_8.ts?PlaySessionId=5bf719e1d7db4352a138caa0e57ccf41 2024-02-08 20:21:55.533 Info Server: http/1.1 GET http://192.168.1.4:8096/emby/videos/17804845/live.m3u8?DeviceId=ece699cb-abe6-4ffa-98f1-7b81b4c0de40&MediaSourceId=native_e35bc8df39ab263c2c7ed7966836cabd_f8f181232418314d1bc8239f1eabc416&PlaySessionId=5bf719e1d7db4352a138caa0e57ccf41&api_key=x_secret2_x&LiveStreamId=06044cf0e6f93cdae5f285c9ecfaaeb4_01413a525b3a9622ce6fdf19f7dde354_native_e35bc8df39ab263c2c7ed7966836cabd_f8f181232418314d1bc8239f1eabc416&VideoCodec=h264,h265,hevc,av1&AudioCodec=mp3,aac&VideoBitrate=159616000&AudioBitrate=384000&MaxWidth=3840&AudioStreamIndex=1&VideoSideDataSubs=100&TranscodingMaxAudioChannels=2&SegmentContainer=m4s,ts&MinSegments=1&BreakOnNonKeyFrames=True&SubtitleStreamIndexes=-1&ManifestSubtitles=vtt&h264-profile=high,main,baseline,constrainedbaseline,high10&h264-level=62&hevc-codectag=hvc1,hev1,hevc,hdmv&TranscodeReasons=ContainerNotSupported. Accept=*/*, Connection=keep-alive, Host=host4, User-Agent=Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/121.0.0.0 Safari/537.36, Accept-Encoding=gzip, deflate, Accept-Language=en-US,en;q=0.9,fr;q=0.8, Referer=http://192.168.1.4:8096/web/index.html 2024-02-08 20:21:55.534 Info Server: http/1.1 Response 200 to 192.168.1.4. Time: 1ms. GET http://192.168.1.4:8096/emby/videos/17804845/live.m3u8?DeviceId=ece699cb-abe6-4ffa-98f1-7b81b4c0de40&MediaSourceId=native_e35bc8df39ab263c2c7ed7966836cabd_f8f181232418314d1bc8239f1eabc416&PlaySessionId=5bf719e1d7db4352a138caa0e57ccf41&api_key=x_secret2_x&LiveStreamId=06044cf0e6f93cdae5f285c9ecfaaeb4_01413a525b3a9622ce6fdf19f7dde354_native_e35bc8df39ab263c2c7ed7966836cabd_f8f181232418314d1bc8239f1eabc416&VideoCodec=h264,h265,hevc,av1&AudioCodec=mp3,aac&VideoBitrate=159616000&AudioBitrate=384000&MaxWidth=3840&AudioStreamIndex=1&VideoSideDataSubs=100&TranscodingMaxAudioChannels=2&SegmentContainer=m4s,ts&MinSegments=1&BreakOnNonKeyFrames=True&SubtitleStreamIndexes=-1&ManifestSubtitles=vtt&h264-profile=high,main,baseline,constrainedbaseline,high10&h264-level=62&hevc-codectag=hvc1,hev1,hevc,hdmv&TranscodeReasons=ContainerNotSupported 2024-02-08 20:21:55.536 Info Server: http/1.1 GET http://192.168.1.4:8096/emby/videos/17804845/hls/2EB688/2EB688_9.ts?PlaySessionId=5bf719e1d7db4352a138caa0e57ccf41. Accept=*/*, Connection=keep-alive, Host=host4, User-Agent=Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/121.0.0.0 Safari/537.36, Accept-Encoding=gzip, deflate, Accept-Language=en-US,en;q=0.9,fr;q=0.8, Referer=http://192.168.1.4:8096/web/index.html 2024-02-08 20:21:55.538 Info Server: http/1.1 Response 200 to 192.168.1.4. Time: 2ms. GET http://192.168.1.4:8096/emby/videos/17804845/hls/2EB688/2EB688_9.ts?PlaySessionId=5bf719e1d7db4352a138caa0e57ccf41 2024-02-08 20:21:58.524 Info Server: http/1.1 GET http://192.168.1.4:8096/emby/videos/17804845/live.m3u8?DeviceId=ece699cb-abe6-4ffa-98f1-7b81b4c0de40&MediaSourceId=native_e35bc8df39ab263c2c7ed7966836cabd_f8f181232418314d1bc8239f1eabc416&PlaySessionId=5bf719e1d7db4352a138caa0e57ccf41&api_key=x_secret2_x&LiveStreamId=06044cf0e6f93cdae5f285c9ecfaaeb4_01413a525b3a9622ce6fdf19f7dde354_native_e35bc8df39ab263c2c7ed7966836cabd_f8f181232418314d1bc8239f1eabc416&VideoCodec=h264,h265,hevc,av1&AudioCodec=mp3,aac&VideoBitrate=159616000&AudioBitrate=384000&MaxWidth=3840&AudioStreamIndex=1&VideoSideDataSubs=100&TranscodingMaxAudioChannels=2&SegmentContainer=m4s,ts&MinSegments=1&BreakOnNonKeyFrames=True&SubtitleStreamIndexes=-1&ManifestSubtitles=vtt&h264-profile=high,main,baseline,constrainedbaseline,high10&h264-level=62&hevc-codectag=hvc1,hev1,hevc,hdmv&TranscodeReasons=ContainerNotSupported. Accept=*/*, Connection=keep-alive, Host=host4, User-Agent=Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/121.0.0.0 Safari/537.36, Accept-Encoding=gzip, deflate, Accept-Language=en-US,en;q=0.9,fr;q=0.8, Referer=http://192.168.1.4:8096/web/index.html 2024-02-08 20:21:58.525 Info Server: http/1.1 Response 200 to 192.168.1.4. Time: 1ms. GET http://192.168.1.4:8096/emby/videos/17804845/live.m3u8?DeviceId=ece699cb-abe6-4ffa-98f1-7b81b4c0de40&MediaSourceId=native_e35bc8df39ab263c2c7ed7966836cabd_f8f181232418314d1bc8239f1eabc416&PlaySessionId=5bf719e1d7db4352a138caa0e57ccf41&api_key=x_secret2_x&LiveStreamId=06044cf0e6f93cdae5f285c9ecfaaeb4_01413a525b3a9622ce6fdf19f7dde354_native_e35bc8df39ab263c2c7ed7966836cabd_f8f181232418314d1bc8239f1eabc416&VideoCodec=h264,h265,hevc,av1&AudioCodec=mp3,aac&VideoBitrate=159616000&AudioBitrate=384000&MaxWidth=3840&AudioStreamIndex=1&VideoSideDataSubs=100&TranscodingMaxAudioChannels=2&SegmentContainer=m4s,ts&MinSegments=1&BreakOnNonKeyFrames=True&SubtitleStreamIndexes=-1&ManifestSubtitles=vtt&h264-profile=high,main,baseline,constrainedbaseline,high10&h264-level=62&hevc-codectag=hvc1,hev1,hevc,hdmv&TranscodeReasons=ContainerNotSupported 2024-02-08 20:21:58.527 Info Server: http/1.1 GET http://192.168.1.4:8096/emby/videos/17804845/hls/2EB688/2EB688_10.ts?PlaySessionId=5bf719e1d7db4352a138caa0e57ccf41. Accept=*/*, Connection=keep-alive, Host=host4, User-Agent=Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/121.0.0.0 Safari/537.36, Accept-Encoding=gzip, deflate, Accept-Language=en-US,en;q=0.9,fr;q=0.8, Referer=http://192.168.1.4:8096/web/index.html 2024-02-08 20:21:58.530 Info Server: http/1.1 Response 200 to 192.168.1.4. Time: 3ms. GET http://192.168.1.4:8096/emby/videos/17804845/hls/2EB688/2EB688_10.ts?PlaySessionId=5bf719e1d7db4352a138caa0e57ccf41 2024-02-08 20:22:01.524 Info Server: http/1.1 GET http://192.168.1.4:8096/emby/videos/17804845/live.m3u8?DeviceId=ece699cb-abe6-4ffa-98f1-7b81b4c0de40&MediaSourceId=native_e35bc8df39ab263c2c7ed7966836cabd_f8f181232418314d1bc8239f1eabc416&PlaySessionId=5bf719e1d7db4352a138caa0e57ccf41&api_key=x_secret2_x&LiveStreamId=06044cf0e6f93cdae5f285c9ecfaaeb4_01413a525b3a9622ce6fdf19f7dde354_native_e35bc8df39ab263c2c7ed7966836cabd_f8f181232418314d1bc8239f1eabc416&VideoCodec=h264,h265,hevc,av1&AudioCodec=mp3,aac&VideoBitrate=159616000&AudioBitrate=384000&MaxWidth=3840&AudioStreamIndex=1&VideoSideDataSubs=100&TranscodingMaxAudioChannels=2&SegmentContainer=m4s,ts&MinSegments=1&BreakOnNonKeyFrames=True&SubtitleStreamIndexes=-1&ManifestSubtitles=vtt&h264-profile=high,main,baseline,constrainedbaseline,high10&h264-level=62&hevc-codectag=hvc1,hev1,hevc,hdmv&TranscodeReasons=ContainerNotSupported. Accept=*/*, Connection=keep-alive, Host=host4, User-Agent=Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/121.0.0.0 Safari/537.36, Accept-Encoding=gzip, deflate, Accept-Language=en-US,en;q=0.9,fr;q=0.8, Referer=http://192.168.1.4:8096/web/index.html 2024-02-08 20:22:01.526 Info Server: http/1.1 Response 200 to 192.168.1.4. Time: 2ms. GET http://192.168.1.4:8096/emby/videos/17804845/live.m3u8?DeviceId=ece699cb-abe6-4ffa-98f1-7b81b4c0de40&MediaSourceId=native_e35bc8df39ab263c2c7ed7966836cabd_f8f181232418314d1bc8239f1eabc416&PlaySessionId=5bf719e1d7db4352a138caa0e57ccf41&api_key=x_secret2_x&LiveStreamId=06044cf0e6f93cdae5f285c9ecfaaeb4_01413a525b3a9622ce6fdf19f7dde354_native_e35bc8df39ab263c2c7ed7966836cabd_f8f181232418314d1bc8239f1eabc416&VideoCodec=h264,h265,hevc,av1&AudioCodec=mp3,aac&VideoBitrate=159616000&AudioBitrate=384000&MaxWidth=3840&AudioStreamIndex=1&VideoSideDataSubs=100&TranscodingMaxAudioChannels=2&SegmentContainer=m4s,ts&MinSegments=1&BreakOnNonKeyFrames=True&SubtitleStreamIndexes=-1&ManifestSubtitles=vtt&h264-profile=high,main,baseline,constrainedbaseline,high10&h264-level=62&hevc-codectag=hvc1,hev1,hevc,hdmv&TranscodeReasons=ContainerNotSupported 2024-02-08 20:22:01.529 Info Server: http/1.1 GET http://192.168.1.4:8096/emby/videos/17804845/hls/2EB688/2EB688_11.ts?PlaySessionId=5bf719e1d7db4352a138caa0e57ccf41. Accept=*/*, Connection=keep-alive, Host=host4, User-Agent=Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/121.0.0.0 Safari/537.36, Accept-Encoding=gzip, deflate, Accept-Language=en-US,en;q=0.9,fr;q=0.8, Referer=http://192.168.1.4:8096/web/index.html 2024-02-08 20:22:01.531 Info Server: http/1.1 Response 200 to 192.168.1.4. Time: 2ms. GET http://192.168.1.4:8096/emby/videos/17804845/hls/2EB688/2EB688_11.ts?PlaySessionId=5bf719e1d7db4352a138caa0e57ccf41 2024-02-08 20:22:02.261 Info Server: http/1.1 POST http://192.168.1.4:8096/emby/Sessions/Playing/Progress?X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome Windows&X-Emby-Device-Id=ece699cb-abe6-4ffa-98f1-7b81b4c0de40&X-Emby-Client-Version=4.8.1.0&X-Emby-Token=x_secret2_x&X-Emby-Language=en-us&reqformat=json. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/121.0.0.0 Safari/537.36 2024-02-08 20:22:02.261 Info Server: http/1.1 Response 204 to 192.168.1.4. Time: 1ms. POST http://192.168.1.4:8096/emby/Sessions/Playing/Progress?X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome Windows&X-Emby-Device-Id=ece699cb-abe6-4ffa-98f1-7b81b4c0de40&X-Emby-Client-Version=4.8.1.0&X-Emby-Token=x_secret2_x&X-Emby-Language=en-us&reqformat=json 2024-02-08 20:22:04.536 Info Server: http/1.1 GET http://192.168.1.4:8096/emby/videos/17804845/live.m3u8?DeviceId=ece699cb-abe6-4ffa-98f1-7b81b4c0de40&MediaSourceId=native_e35bc8df39ab263c2c7ed7966836cabd_f8f181232418314d1bc8239f1eabc416&PlaySessionId=5bf719e1d7db4352a138caa0e57ccf41&api_key=x_secret2_x&LiveStreamId=06044cf0e6f93cdae5f285c9ecfaaeb4_01413a525b3a9622ce6fdf19f7dde354_native_e35bc8df39ab263c2c7ed7966836cabd_f8f181232418314d1bc8239f1eabc416&VideoCodec=h264,h265,hevc,av1&AudioCodec=mp3,aac&VideoBitrate=159616000&AudioBitrate=384000&MaxWidth=3840&AudioStreamIndex=1&VideoSideDataSubs=100&TranscodingMaxAudioChannels=2&SegmentContainer=m4s,ts&MinSegments=1&BreakOnNonKeyFrames=True&SubtitleStreamIndexes=-1&ManifestSubtitles=vtt&h264-profile=high,main,baseline,constrainedbaseline,high10&h264-level=62&hevc-codectag=hvc1,hev1,hevc,hdmv&TranscodeReasons=ContainerNotSupported. Accept=*/*, Connection=keep-alive, Host=host4, User-Agent=Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/121.0.0.0 Safari/537.36, Accept-Encoding=gzip, deflate, Accept-Language=en-US,en;q=0.9,fr;q=0.8, Referer=http://192.168.1.4:8096/web/index.html 2024-02-08 20:22:04.537 Info Server: http/1.1 Response 200 to 192.168.1.4. Time: 1ms. GET http://192.168.1.4:8096/emby/videos/17804845/live.m3u8?DeviceId=ece699cb-abe6-4ffa-98f1-7b81b4c0de40&MediaSourceId=native_e35bc8df39ab263c2c7ed7966836cabd_f8f181232418314d1bc8239f1eabc416&PlaySessionId=5bf719e1d7db4352a138caa0e57ccf41&api_key=x_secret2_x&LiveStreamId=06044cf0e6f93cdae5f285c9ecfaaeb4_01413a525b3a9622ce6fdf19f7dde354_native_e35bc8df39ab263c2c7ed7966836cabd_f8f181232418314d1bc8239f1eabc416&VideoCodec=h264,h265,hevc,av1&AudioCodec=mp3,aac&VideoBitrate=159616000&AudioBitrate=384000&MaxWidth=3840&AudioStreamIndex=1&VideoSideDataSubs=100&TranscodingMaxAudioChannels=2&SegmentContainer=m4s,ts&MinSegments=1&BreakOnNonKeyFrames=True&SubtitleStreamIndexes=-1&ManifestSubtitles=vtt&h264-profile=high,main,baseline,constrainedbaseline,high10&h264-level=62&hevc-codectag=hvc1,hev1,hevc,hdmv&TranscodeReasons=ContainerNotSupported 2024-02-08 20:22:04.540 Info Server: http/1.1 GET http://192.168.1.4:8096/emby/videos/17804845/hls/2EB688/2EB688_12.ts?PlaySessionId=5bf719e1d7db4352a138caa0e57ccf41. Accept=*/*, Connection=keep-alive, Host=host4, User-Agent=Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/121.0.0.0 Safari/537.36, Accept-Encoding=gzip, deflate, Accept-Language=en-US,en;q=0.9,fr;q=0.8, Referer=http://192.168.1.4:8096/web/index.html 2024-02-08 20:22:04.541 Info Server: http/1.1 Response 200 to 192.168.1.4. Time: 2ms. GET http://192.168.1.4:8096/emby/videos/17804845/hls/2EB688/2EB688_12.ts?PlaySessionId=5bf719e1d7db4352a138caa0e57ccf41 2024-02-08 20:22:07.534 Info Server: http/1.1 GET http://192.168.1.4:8096/emby/videos/17804845/live.m3u8?DeviceId=ece699cb-abe6-4ffa-98f1-7b81b4c0de40&MediaSourceId=native_e35bc8df39ab263c2c7ed7966836cabd_f8f181232418314d1bc8239f1eabc416&PlaySessionId=5bf719e1d7db4352a138caa0e57ccf41&api_key=x_secret2_x&LiveStreamId=06044cf0e6f93cdae5f285c9ecfaaeb4_01413a525b3a9622ce6fdf19f7dde354_native_e35bc8df39ab263c2c7ed7966836cabd_f8f181232418314d1bc8239f1eabc416&VideoCodec=h264,h265,hevc,av1&AudioCodec=mp3,aac&VideoBitrate=159616000&AudioBitrate=384000&MaxWidth=3840&AudioStreamIndex=1&VideoSideDataSubs=100&TranscodingMaxAudioChannels=2&SegmentContainer=m4s,ts&MinSegments=1&BreakOnNonKeyFrames=True&SubtitleStreamIndexes=-1&ManifestSubtitles=vtt&h264-profile=high,main,baseline,constrainedbaseline,high10&h264-level=62&hevc-codectag=hvc1,hev1,hevc,hdmv&TranscodeReasons=ContainerNotSupported. Accept=*/*, Connection=keep-alive, Host=host4, User-Agent=Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/121.0.0.0 Safari/537.36, Accept-Encoding=gzip, deflate, Accept-Language=en-US,en;q=0.9,fr;q=0.8, Referer=http://192.168.1.4:8096/web/index.html 2024-02-08 20:22:07.534 Info Server: http/1.1 Response 200 to 192.168.1.4. Time: 1ms. GET http://192.168.1.4:8096/emby/videos/17804845/live.m3u8?DeviceId=ece699cb-abe6-4ffa-98f1-7b81b4c0de40&MediaSourceId=native_e35bc8df39ab263c2c7ed7966836cabd_f8f181232418314d1bc8239f1eabc416&PlaySessionId=5bf719e1d7db4352a138caa0e57ccf41&api_key=x_secret2_x&LiveStreamId=06044cf0e6f93cdae5f285c9ecfaaeb4_01413a525b3a9622ce6fdf19f7dde354_native_e35bc8df39ab263c2c7ed7966836cabd_f8f181232418314d1bc8239f1eabc416&VideoCodec=h264,h265,hevc,av1&AudioCodec=mp3,aac&VideoBitrate=159616000&AudioBitrate=384000&MaxWidth=3840&AudioStreamIndex=1&VideoSideDataSubs=100&TranscodingMaxAudioChannels=2&SegmentContainer=m4s,ts&MinSegments=1&BreakOnNonKeyFrames=True&SubtitleStreamIndexes=-1&ManifestSubtitles=vtt&h264-profile=high,main,baseline,constrainedbaseline,high10&h264-level=62&hevc-codectag=hvc1,hev1,hevc,hdmv&TranscodeReasons=ContainerNotSupported 2024-02-08 20:22:07.536 Info Server: http/1.1 GET http://192.168.1.4:8096/emby/videos/17804845/hls/2EB688/2EB688_13.ts?PlaySessionId=5bf719e1d7db4352a138caa0e57ccf41. Accept=*/*, Connection=keep-alive, Host=host4, User-Agent=Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/121.0.0.0 Safari/537.36, Accept-Encoding=gzip, deflate, Accept-Language=en-US,en;q=0.9,fr;q=0.8, Referer=http://192.168.1.4:8096/web/index.html 2024-02-08 20:22:07.538 Info Server: http/1.1 Response 200 to 192.168.1.4. Time: 2ms. GET http://192.168.1.4:8096/emby/videos/17804845/hls/2EB688/2EB688_13.ts?PlaySessionId=5bf719e1d7db4352a138caa0e57ccf41 2024-02-08 20:22:10.533 Info Server: http/1.1 GET http://192.168.1.4:8096/emby/videos/17804845/live.m3u8?DeviceId=ece699cb-abe6-4ffa-98f1-7b81b4c0de40&MediaSourceId=native_e35bc8df39ab263c2c7ed7966836cabd_f8f181232418314d1bc8239f1eabc416&PlaySessionId=5bf719e1d7db4352a138caa0e57ccf41&api_key=x_secret2_x&LiveStreamId=06044cf0e6f93cdae5f285c9ecfaaeb4_01413a525b3a9622ce6fdf19f7dde354_native_e35bc8df39ab263c2c7ed7966836cabd_f8f181232418314d1bc8239f1eabc416&VideoCodec=h264,h265,hevc,av1&AudioCodec=mp3,aac&VideoBitrate=159616000&AudioBitrate=384000&MaxWidth=3840&AudioStreamIndex=1&VideoSideDataSubs=100&TranscodingMaxAudioChannels=2&SegmentContainer=m4s,ts&MinSegments=1&BreakOnNonKeyFrames=True&SubtitleStreamIndexes=-1&ManifestSubtitles=vtt&h264-profile=high,main,baseline,constrainedbaseline,high10&h264-level=62&hevc-codectag=hvc1,hev1,hevc,hdmv&TranscodeReasons=ContainerNotSupported. Accept=*/*, Connection=keep-alive, Host=host4, User-Agent=Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/121.0.0.0 Safari/537.36, Accept-Encoding=gzip, deflate, Accept-Language=en-US,en;q=0.9,fr;q=0.8, Referer=http://192.168.1.4:8096/web/index.html 2024-02-08 20:22:10.534 Info Server: http/1.1 Response 200 to 192.168.1.4. Time: 1ms. GET http://192.168.1.4:8096/emby/videos/17804845/live.m3u8?DeviceId=ece699cb-abe6-4ffa-98f1-7b81b4c0de40&MediaSourceId=native_e35bc8df39ab263c2c7ed7966836cabd_f8f181232418314d1bc8239f1eabc416&PlaySessionId=5bf719e1d7db4352a138caa0e57ccf41&api_key=x_secret2_x&LiveStreamId=06044cf0e6f93cdae5f285c9ecfaaeb4_01413a525b3a9622ce6fdf19f7dde354_native_e35bc8df39ab263c2c7ed7966836cabd_f8f181232418314d1bc8239f1eabc416&VideoCodec=h264,h265,hevc,av1&AudioCodec=mp3,aac&VideoBitrate=159616000&AudioBitrate=384000&MaxWidth=3840&AudioStreamIndex=1&VideoSideDataSubs=100&TranscodingMaxAudioChannels=2&SegmentContainer=m4s,ts&MinSegments=1&BreakOnNonKeyFrames=True&SubtitleStreamIndexes=-1&ManifestSubtitles=vtt&h264-profile=high,main,baseline,constrainedbaseline,high10&h264-level=62&hevc-codectag=hvc1,hev1,hevc,hdmv&TranscodeReasons=ContainerNotSupported 2024-02-08 20:22:10.536 Info Server: http/1.1 GET http://192.168.1.4:8096/emby/videos/17804845/hls/2EB688/2EB688_14.ts?PlaySessionId=5bf719e1d7db4352a138caa0e57ccf41. Accept=*/*, Connection=keep-alive, Host=host4, User-Agent=Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/121.0.0.0 Safari/537.36, Accept-Encoding=gzip, deflate, Accept-Language=en-US,en;q=0.9,fr;q=0.8, Referer=http://192.168.1.4:8096/web/index.html 2024-02-08 20:22:10.538 Info Server: http/1.1 Response 200 to 192.168.1.4. Time: 2ms. GET http://192.168.1.4:8096/emby/videos/17804845/hls/2EB688/2EB688_14.ts?PlaySessionId=5bf719e1d7db4352a138caa0e57ccf41 2024-02-08 20:22:12.373 Info Server: http/1.1 POST http://192.168.1.4:8096/emby/Sessions/Playing/Progress?X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome Windows&X-Emby-Device-Id=ece699cb-abe6-4ffa-98f1-7b81b4c0de40&X-Emby-Client-Version=4.8.1.0&X-Emby-Token=x_secret2_x&X-Emby-Language=en-us&reqformat=json. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/121.0.0.0 Safari/537.36 2024-02-08 20:22:12.374 Info Server: http/1.1 Response 204 to 192.168.1.4. Time: 1ms. POST http://192.168.1.4:8096/emby/Sessions/Playing/Progress?X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome Windows&X-Emby-Device-Id=ece699cb-abe6-4ffa-98f1-7b81b4c0de40&X-Emby-Client-Version=4.8.1.0&X-Emby-Token=x_secret2_x&X-Emby-Language=en-us&reqformat=json 2024-02-08 20:22:13.541 Info Server: http/1.1 GET http://192.168.1.4:8096/emby/videos/17804845/live.m3u8?DeviceId=ece699cb-abe6-4ffa-98f1-7b81b4c0de40&MediaSourceId=native_e35bc8df39ab263c2c7ed7966836cabd_f8f181232418314d1bc8239f1eabc416&PlaySessionId=5bf719e1d7db4352a138caa0e57ccf41&api_key=x_secret2_x&LiveStreamId=06044cf0e6f93cdae5f285c9ecfaaeb4_01413a525b3a9622ce6fdf19f7dde354_native_e35bc8df39ab263c2c7ed7966836cabd_f8f181232418314d1bc8239f1eabc416&VideoCodec=h264,h265,hevc,av1&AudioCodec=mp3,aac&VideoBitrate=159616000&AudioBitrate=384000&MaxWidth=3840&AudioStreamIndex=1&VideoSideDataSubs=100&TranscodingMaxAudioChannels=2&SegmentContainer=m4s,ts&MinSegments=1&BreakOnNonKeyFrames=True&SubtitleStreamIndexes=-1&ManifestSubtitles=vtt&h264-profile=high,main,baseline,constrainedbaseline,high10&h264-level=62&hevc-codectag=hvc1,hev1,hevc,hdmv&TranscodeReasons=ContainerNotSupported. Accept=*/*, Connection=keep-alive, Host=host4, User-Agent=Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/121.0.0.0 Safari/537.36, Accept-Encoding=gzip, deflate, Accept-Language=en-US,en;q=0.9,fr;q=0.8, Referer=http://192.168.1.4:8096/web/index.html 2024-02-08 20:22:13.542 Info Server: http/1.1 Response 200 to 192.168.1.4. Time: 1ms. GET http://192.168.1.4:8096/emby/videos/17804845/live.m3u8?DeviceId=ece699cb-abe6-4ffa-98f1-7b81b4c0de40&MediaSourceId=native_e35bc8df39ab263c2c7ed7966836cabd_f8f181232418314d1bc8239f1eabc416&PlaySessionId=5bf719e1d7db4352a138caa0e57ccf41&api_key=x_secret2_x&LiveStreamId=06044cf0e6f93cdae5f285c9ecfaaeb4_01413a525b3a9622ce6fdf19f7dde354_native_e35bc8df39ab263c2c7ed7966836cabd_f8f181232418314d1bc8239f1eabc416&VideoCodec=h264,h265,hevc,av1&AudioCodec=mp3,aac&VideoBitrate=159616000&AudioBitrate=384000&MaxWidth=3840&AudioStreamIndex=1&VideoSideDataSubs=100&TranscodingMaxAudioChannels=2&SegmentContainer=m4s,ts&MinSegments=1&BreakOnNonKeyFrames=True&SubtitleStreamIndexes=-1&ManifestSubtitles=vtt&h264-profile=high,main,baseline,constrainedbaseline,high10&h264-level=62&hevc-codectag=hvc1,hev1,hevc,hdmv&TranscodeReasons=ContainerNotSupported 2024-02-08 20:22:13.545 Info Server: http/1.1 GET http://192.168.1.4:8096/emby/videos/17804845/hls/2EB688/2EB688_15.ts?PlaySessionId=5bf719e1d7db4352a138caa0e57ccf41. Accept=*/*, Connection=keep-alive, Host=host4, User-Agent=Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/121.0.0.0 Safari/537.36, Accept-Encoding=gzip, deflate, Accept-Language=en-US,en;q=0.9,fr;q=0.8, Referer=http://192.168.1.4:8096/web/index.html 2024-02-08 20:22:13.546 Info Server: http/1.1 Response 200 to 192.168.1.4. Time: 2ms. GET http://192.168.1.4:8096/emby/videos/17804845/hls/2EB688/2EB688_15.ts?PlaySessionId=5bf719e1d7db4352a138caa0e57ccf41 2024-02-08 20:22:16.540 Info Server: http/1.1 GET http://192.168.1.4:8096/emby/videos/17804845/live.m3u8?DeviceId=ece699cb-abe6-4ffa-98f1-7b81b4c0de40&MediaSourceId=native_e35bc8df39ab263c2c7ed7966836cabd_f8f181232418314d1bc8239f1eabc416&PlaySessionId=5bf719e1d7db4352a138caa0e57ccf41&api_key=x_secret2_x&LiveStreamId=06044cf0e6f93cdae5f285c9ecfaaeb4_01413a525b3a9622ce6fdf19f7dde354_native_e35bc8df39ab263c2c7ed7966836cabd_f8f181232418314d1bc8239f1eabc416&VideoCodec=h264,h265,hevc,av1&AudioCodec=mp3,aac&VideoBitrate=159616000&AudioBitrate=384000&MaxWidth=3840&AudioStreamIndex=1&VideoSideDataSubs=100&TranscodingMaxAudioChannels=2&SegmentContainer=m4s,ts&MinSegments=1&BreakOnNonKeyFrames=True&SubtitleStreamIndexes=-1&ManifestSubtitles=vtt&h264-profile=high,main,baseline,constrainedbaseline,high10&h264-level=62&hevc-codectag=hvc1,hev1,hevc,hdmv&TranscodeReasons=ContainerNotSupported. Accept=*/*, Connection=keep-alive, Host=host4, User-Agent=Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/121.0.0.0 Safari/537.36, Accept-Encoding=gzip, deflate, Accept-Language=en-US,en;q=0.9,fr;q=0.8, Referer=http://192.168.1.4:8096/web/index.html 2024-02-08 20:22:16.541 Info Server: http/1.1 Response 200 to 192.168.1.4. Time: 1ms. GET http://192.168.1.4:8096/emby/videos/17804845/live.m3u8?DeviceId=ece699cb-abe6-4ffa-98f1-7b81b4c0de40&MediaSourceId=native_e35bc8df39ab263c2c7ed7966836cabd_f8f181232418314d1bc8239f1eabc416&PlaySessionId=5bf719e1d7db4352a138caa0e57ccf41&api_key=x_secret2_x&LiveStreamId=06044cf0e6f93cdae5f285c9ecfaaeb4_01413a525b3a9622ce6fdf19f7dde354_native_e35bc8df39ab263c2c7ed7966836cabd_f8f181232418314d1bc8239f1eabc416&VideoCodec=h264,h265,hevc,av1&AudioCodec=mp3,aac&VideoBitrate=159616000&AudioBitrate=384000&MaxWidth=3840&AudioStreamIndex=1&VideoSideDataSubs=100&TranscodingMaxAudioChannels=2&SegmentContainer=m4s,ts&MinSegments=1&BreakOnNonKeyFrames=True&SubtitleStreamIndexes=-1&ManifestSubtitles=vtt&h264-profile=high,main,baseline,constrainedbaseline,high10&h264-level=62&hevc-codectag=hvc1,hev1,hevc,hdmv&TranscodeReasons=ContainerNotSupported 2024-02-08 20:22:16.544 Info Server: http/1.1 GET http://192.168.1.4:8096/emby/videos/17804845/hls/2EB688/2EB688_16.ts?PlaySessionId=5bf719e1d7db4352a138caa0e57ccf41. Accept=*/*, Connection=keep-alive, Host=host4, User-Agent=Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/121.0.0.0 Safari/537.36, Accept-Encoding=gzip, deflate, Accept-Language=en-US,en;q=0.9,fr;q=0.8, Referer=http://192.168.1.4:8096/web/index.html 2024-02-08 20:22:16.546 Info Server: http/1.1 Response 200 to 192.168.1.4. Time: 2ms. GET http://192.168.1.4:8096/emby/videos/17804845/hls/2EB688/2EB688_16.ts?PlaySessionId=5bf719e1d7db4352a138caa0e57ccf41 2024-02-08 20:22:19.553 Info Server: http/1.1 GET http://192.168.1.4:8096/emby/videos/17804845/live.m3u8?DeviceId=ece699cb-abe6-4ffa-98f1-7b81b4c0de40&MediaSourceId=native_e35bc8df39ab263c2c7ed7966836cabd_f8f181232418314d1bc8239f1eabc416&PlaySessionId=5bf719e1d7db4352a138caa0e57ccf41&api_key=x_secret2_x&LiveStreamId=06044cf0e6f93cdae5f285c9ecfaaeb4_01413a525b3a9622ce6fdf19f7dde354_native_e35bc8df39ab263c2c7ed7966836cabd_f8f181232418314d1bc8239f1eabc416&VideoCodec=h264,h265,hevc,av1&AudioCodec=mp3,aac&VideoBitrate=159616000&AudioBitrate=384000&MaxWidth=3840&AudioStreamIndex=1&VideoSideDataSubs=100&TranscodingMaxAudioChannels=2&SegmentContainer=m4s,ts&MinSegments=1&BreakOnNonKeyFrames=True&SubtitleStreamIndexes=-1&ManifestSubtitles=vtt&h264-profile=high,main,baseline,constrainedbaseline,high10&h264-level=62&hevc-codectag=hvc1,hev1,hevc,hdmv&TranscodeReasons=ContainerNotSupported. Accept=*/*, Connection=keep-alive, Host=host4, User-Agent=Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/121.0.0.0 Safari/537.36, Accept-Encoding=gzip, deflate, Accept-Language=en-US,en;q=0.9,fr;q=0.8, Referer=http://192.168.1.4:8096/web/index.html 2024-02-08 20:22:19.554 Info Server: http/1.1 Response 200 to 192.168.1.4. Time: 1ms. GET http://192.168.1.4:8096/emby/videos/17804845/live.m3u8?DeviceId=ece699cb-abe6-4ffa-98f1-7b81b4c0de40&MediaSourceId=native_e35bc8df39ab263c2c7ed7966836cabd_f8f181232418314d1bc8239f1eabc416&PlaySessionId=5bf719e1d7db4352a138caa0e57ccf41&api_key=x_secret2_x&LiveStreamId=06044cf0e6f93cdae5f285c9ecfaaeb4_01413a525b3a9622ce6fdf19f7dde354_native_e35bc8df39ab263c2c7ed7966836cabd_f8f181232418314d1bc8239f1eabc416&VideoCodec=h264,h265,hevc,av1&AudioCodec=mp3,aac&VideoBitrate=159616000&AudioBitrate=384000&MaxWidth=3840&AudioStreamIndex=1&VideoSideDataSubs=100&TranscodingMaxAudioChannels=2&SegmentContainer=m4s,ts&MinSegments=1&BreakOnNonKeyFrames=True&SubtitleStreamIndexes=-1&ManifestSubtitles=vtt&h264-profile=high,main,baseline,constrainedbaseline,high10&h264-level=62&hevc-codectag=hvc1,hev1,hevc,hdmv&TranscodeReasons=ContainerNotSupported 2024-02-08 20:22:19.556 Info Server: http/1.1 GET http://192.168.1.4:8096/emby/videos/17804845/hls/2EB688/2EB688_17.ts?PlaySessionId=5bf719e1d7db4352a138caa0e57ccf41. Accept=*/*, Connection=keep-alive, Host=host4, User-Agent=Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/121.0.0.0 Safari/537.36, Accept-Encoding=gzip, deflate, Accept-Language=en-US,en;q=0.9,fr;q=0.8, Referer=http://192.168.1.4:8096/web/index.html 2024-02-08 20:22:19.558 Info Server: http/1.1 Response 200 to 192.168.1.4. Time: 2ms. GET http://192.168.1.4:8096/emby/videos/17804845/hls/2EB688/2EB688_17.ts?PlaySessionId=5bf719e1d7db4352a138caa0e57ccf41 2024-02-08 20:22:22.465 Info Server: http/1.1 POST http://192.168.1.4:8096/emby/Sessions/Playing/Progress?X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome Windows&X-Emby-Device-Id=ece699cb-abe6-4ffa-98f1-7b81b4c0de40&X-Emby-Client-Version=4.8.1.0&X-Emby-Token=x_secret2_x&X-Emby-Language=en-us&reqformat=json. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/121.0.0.0 Safari/537.36 2024-02-08 20:22:22.466 Info Server: http/1.1 Response 204 to 192.168.1.4. Time: 1ms. POST http://192.168.1.4:8096/emby/Sessions/Playing/Progress?X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome Windows&X-Emby-Device-Id=ece699cb-abe6-4ffa-98f1-7b81b4c0de40&X-Emby-Client-Version=4.8.1.0&X-Emby-Token=x_secret2_x&X-Emby-Language=en-us&reqformat=json 2024-02-08 20:22:22.558 Info Server: http/1.1 GET http://192.168.1.4:8096/emby/videos/17804845/live.m3u8?DeviceId=ece699cb-abe6-4ffa-98f1-7b81b4c0de40&MediaSourceId=native_e35bc8df39ab263c2c7ed7966836cabd_f8f181232418314d1bc8239f1eabc416&PlaySessionId=5bf719e1d7db4352a138caa0e57ccf41&api_key=x_secret2_x&LiveStreamId=06044cf0e6f93cdae5f285c9ecfaaeb4_01413a525b3a9622ce6fdf19f7dde354_native_e35bc8df39ab263c2c7ed7966836cabd_f8f181232418314d1bc8239f1eabc416&VideoCodec=h264,h265,hevc,av1&AudioCodec=mp3,aac&VideoBitrate=159616000&AudioBitrate=384000&MaxWidth=3840&AudioStreamIndex=1&VideoSideDataSubs=100&TranscodingMaxAudioChannels=2&SegmentContainer=m4s,ts&MinSegments=1&BreakOnNonKeyFrames=True&SubtitleStreamIndexes=-1&ManifestSubtitles=vtt&h264-profile=high,main,baseline,constrainedbaseline,high10&h264-level=62&hevc-codectag=hvc1,hev1,hevc,hdmv&TranscodeReasons=ContainerNotSupported. Accept=*/*, Connection=keep-alive, Host=host4, User-Agent=Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/121.0.0.0 Safari/537.36, Accept-Encoding=gzip, deflate, Accept-Language=en-US,en;q=0.9,fr;q=0.8, Referer=http://192.168.1.4:8096/web/index.html 2024-02-08 20:22:22.559 Info Server: http/1.1 Response 200 to 192.168.1.4. Time: 1ms. GET http://192.168.1.4:8096/emby/videos/17804845/live.m3u8?DeviceId=ece699cb-abe6-4ffa-98f1-7b81b4c0de40&MediaSourceId=native_e35bc8df39ab263c2c7ed7966836cabd_f8f181232418314d1bc8239f1eabc416&PlaySessionId=5bf719e1d7db4352a138caa0e57ccf41&api_key=x_secret2_x&LiveStreamId=06044cf0e6f93cdae5f285c9ecfaaeb4_01413a525b3a9622ce6fdf19f7dde354_native_e35bc8df39ab263c2c7ed7966836cabd_f8f181232418314d1bc8239f1eabc416&VideoCodec=h264,h265,hevc,av1&AudioCodec=mp3,aac&VideoBitrate=159616000&AudioBitrate=384000&MaxWidth=3840&AudioStreamIndex=1&VideoSideDataSubs=100&TranscodingMaxAudioChannels=2&SegmentContainer=m4s,ts&MinSegments=1&BreakOnNonKeyFrames=True&SubtitleStreamIndexes=-1&ManifestSubtitles=vtt&h264-profile=high,main,baseline,constrainedbaseline,high10&h264-level=62&hevc-codectag=hvc1,hev1,hevc,hdmv&TranscodeReasons=ContainerNotSupported 2024-02-08 20:22:22.561 Info Server: http/1.1 GET http://192.168.1.4:8096/emby/videos/17804845/hls/2EB688/2EB688_18.ts?PlaySessionId=5bf719e1d7db4352a138caa0e57ccf41. Accept=*/*, Connection=keep-alive, Host=host4, User-Agent=Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/121.0.0.0 Safari/537.36, Accept-Encoding=gzip, deflate, Accept-Language=en-US,en;q=0.9,fr;q=0.8, Referer=http://192.168.1.4:8096/web/index.html 2024-02-08 20:22:22.562 Info Server: http/1.1 Response 200 to 192.168.1.4. Time: 2ms. GET http://192.168.1.4:8096/emby/videos/17804845/hls/2EB688/2EB688_18.ts?PlaySessionId=5bf719e1d7db4352a138caa0e57ccf41 2024-02-08 20:22:25.555 Info Server: http/1.1 GET http://192.168.1.4:8096/emby/videos/17804845/live.m3u8?DeviceId=ece699cb-abe6-4ffa-98f1-7b81b4c0de40&MediaSourceId=native_e35bc8df39ab263c2c7ed7966836cabd_f8f181232418314d1bc8239f1eabc416&PlaySessionId=5bf719e1d7db4352a138caa0e57ccf41&api_key=x_secret2_x&LiveStreamId=06044cf0e6f93cdae5f285c9ecfaaeb4_01413a525b3a9622ce6fdf19f7dde354_native_e35bc8df39ab263c2c7ed7966836cabd_f8f181232418314d1bc8239f1eabc416&VideoCodec=h264,h265,hevc,av1&AudioCodec=mp3,aac&VideoBitrate=159616000&AudioBitrate=384000&MaxWidth=3840&AudioStreamIndex=1&VideoSideDataSubs=100&TranscodingMaxAudioChannels=2&SegmentContainer=m4s,ts&MinSegments=1&BreakOnNonKeyFrames=True&SubtitleStreamIndexes=-1&ManifestSubtitles=vtt&h264-profile=high,main,baseline,constrainedbaseline,high10&h264-level=62&hevc-codectag=hvc1,hev1,hevc,hdmv&TranscodeReasons=ContainerNotSupported. Accept=*/*, Connection=keep-alive, Host=host4, User-Agent=Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/121.0.0.0 Safari/537.36, Accept-Encoding=gzip, deflate, Accept-Language=en-US,en;q=0.9,fr;q=0.8, Referer=http://192.168.1.4:8096/web/index.html 2024-02-08 20:22:25.556 Info Server: http/1.1 Response 200 to 192.168.1.4. Time: 1ms. GET http://192.168.1.4:8096/emby/videos/17804845/live.m3u8?DeviceId=ece699cb-abe6-4ffa-98f1-7b81b4c0de40&MediaSourceId=native_e35bc8df39ab263c2c7ed7966836cabd_f8f181232418314d1bc8239f1eabc416&PlaySessionId=5bf719e1d7db4352a138caa0e57ccf41&api_key=x_secret2_x&LiveStreamId=06044cf0e6f93cdae5f285c9ecfaaeb4_01413a525b3a9622ce6fdf19f7dde354_native_e35bc8df39ab263c2c7ed7966836cabd_f8f181232418314d1bc8239f1eabc416&VideoCodec=h264,h265,hevc,av1&AudioCodec=mp3,aac&VideoBitrate=159616000&AudioBitrate=384000&MaxWidth=3840&AudioStreamIndex=1&VideoSideDataSubs=100&TranscodingMaxAudioChannels=2&SegmentContainer=m4s,ts&MinSegments=1&BreakOnNonKeyFrames=True&SubtitleStreamIndexes=-1&ManifestSubtitles=vtt&h264-profile=high,main,baseline,constrainedbaseline,high10&h264-level=62&hevc-codectag=hvc1,hev1,hevc,hdmv&TranscodeReasons=ContainerNotSupported 2024-02-08 20:22:25.558 Info Server: http/1.1 GET http://192.168.1.4:8096/emby/videos/17804845/hls/2EB688/2EB688_19.ts?PlaySessionId=5bf719e1d7db4352a138caa0e57ccf41. Accept=*/*, Connection=keep-alive, Host=host4, User-Agent=Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/121.0.0.0 Safari/537.36, Accept-Encoding=gzip, deflate, Accept-Language=en-US,en;q=0.9,fr;q=0.8, Referer=http://192.168.1.4:8096/web/index.html 2024-02-08 20:22:25.560 Info Server: http/1.1 Response 200 to 192.168.1.4. Time: 2ms. GET http://192.168.1.4:8096/emby/videos/17804845/hls/2EB688/2EB688_19.ts?PlaySessionId=5bf719e1d7db4352a138caa0e57ccf41 2024-02-08 20:22:28.562 Info Server: http/1.1 GET http://192.168.1.4:8096/emby/videos/17804845/live.m3u8?DeviceId=ece699cb-abe6-4ffa-98f1-7b81b4c0de40&MediaSourceId=native_e35bc8df39ab263c2c7ed7966836cabd_f8f181232418314d1bc8239f1eabc416&PlaySessionId=5bf719e1d7db4352a138caa0e57ccf41&api_key=x_secret2_x&LiveStreamId=06044cf0e6f93cdae5f285c9ecfaaeb4_01413a525b3a9622ce6fdf19f7dde354_native_e35bc8df39ab263c2c7ed7966836cabd_f8f181232418314d1bc8239f1eabc416&VideoCodec=h264,h265,hevc,av1&AudioCodec=mp3,aac&VideoBitrate=159616000&AudioBitrate=384000&MaxWidth=3840&AudioStreamIndex=1&VideoSideDataSubs=100&TranscodingMaxAudioChannels=2&SegmentContainer=m4s,ts&MinSegments=1&BreakOnNonKeyFrames=True&SubtitleStreamIndexes=-1&ManifestSubtitles=vtt&h264-profile=high,main,baseline,constrainedbaseline,high10&h264-level=62&hevc-codectag=hvc1,hev1,hevc,hdmv&TranscodeReasons=ContainerNotSupported. Accept=*/*, Connection=keep-alive, Host=host4, User-Agent=Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/121.0.0.0 Safari/537.36, Accept-Encoding=gzip, deflate, Accept-Language=en-US,en;q=0.9,fr;q=0.8, Referer=http://192.168.1.4:8096/web/index.html 2024-02-08 20:22:28.563 Info Server: http/1.1 Response 200 to 192.168.1.4. Time: 1ms. GET http://192.168.1.4:8096/emby/videos/17804845/live.m3u8?DeviceId=ece699cb-abe6-4ffa-98f1-7b81b4c0de40&MediaSourceId=native_e35bc8df39ab263c2c7ed7966836cabd_f8f181232418314d1bc8239f1eabc416&PlaySessionId=5bf719e1d7db4352a138caa0e57ccf41&api_key=x_secret2_x&LiveStreamId=06044cf0e6f93cdae5f285c9ecfaaeb4_01413a525b3a9622ce6fdf19f7dde354_native_e35bc8df39ab263c2c7ed7966836cabd_f8f181232418314d1bc8239f1eabc416&VideoCodec=h264,h265,hevc,av1&AudioCodec=mp3,aac&VideoBitrate=159616000&AudioBitrate=384000&MaxWidth=3840&AudioStreamIndex=1&VideoSideDataSubs=100&TranscodingMaxAudioChannels=2&SegmentContainer=m4s,ts&MinSegments=1&BreakOnNonKeyFrames=True&SubtitleStreamIndexes=-1&ManifestSubtitles=vtt&h264-profile=high,main,baseline,constrainedbaseline,high10&h264-level=62&hevc-codectag=hvc1,hev1,hevc,hdmv&TranscodeReasons=ContainerNotSupported 2024-02-08 20:22:28.565 Info Server: http/1.1 GET http://192.168.1.4:8096/emby/videos/17804845/hls/2EB688/2EB688_20.ts?PlaySessionId=5bf719e1d7db4352a138caa0e57ccf41. Accept=*/*, Connection=keep-alive, Host=host4, User-Agent=Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/121.0.0.0 Safari/537.36, Accept-Encoding=gzip, deflate, Accept-Language=en-US,en;q=0.9,fr;q=0.8, Referer=http://192.168.1.4:8096/web/index.html 2024-02-08 20:22:28.568 Info Server: http/1.1 Response 200 to 192.168.1.4. Time: 2ms. GET http://192.168.1.4:8096/emby/videos/17804845/hls/2EB688/2EB688_20.ts?PlaySessionId=5bf719e1d7db4352a138caa0e57ccf41 2024-02-08 20:22:31.561 Info Server: http/1.1 GET http://192.168.1.4:8096/emby/videos/17804845/live.m3u8?DeviceId=ece699cb-abe6-4ffa-98f1-7b81b4c0de40&MediaSourceId=native_e35bc8df39ab263c2c7ed7966836cabd_f8f181232418314d1bc8239f1eabc416&PlaySessionId=5bf719e1d7db4352a138caa0e57ccf41&api_key=x_secret2_x&LiveStreamId=06044cf0e6f93cdae5f285c9ecfaaeb4_01413a525b3a9622ce6fdf19f7dde354_native_e35bc8df39ab263c2c7ed7966836cabd_f8f181232418314d1bc8239f1eabc416&VideoCodec=h264,h265,hevc,av1&AudioCodec=mp3,aac&VideoBitrate=159616000&AudioBitrate=384000&MaxWidth=3840&AudioStreamIndex=1&VideoSideDataSubs=100&TranscodingMaxAudioChannels=2&SegmentContainer=m4s,ts&MinSegments=1&BreakOnNonKeyFrames=True&SubtitleStreamIndexes=-1&ManifestSubtitles=vtt&h264-profile=high,main,baseline,constrainedbaseline,high10&h264-level=62&hevc-codectag=hvc1,hev1,hevc,hdmv&TranscodeReasons=ContainerNotSupported. Accept=*/*, Connection=keep-alive, Host=host4, User-Agent=Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/121.0.0.0 Safari/537.36, Accept-Encoding=gzip, deflate, Accept-Language=en-US,en;q=0.9,fr;q=0.8, Referer=http://192.168.1.4:8096/web/index.html 2024-02-08 20:22:31.562 Info Server: http/1.1 Response 200 to 192.168.1.4. Time: 1ms. GET http://192.168.1.4:8096/emby/videos/17804845/live.m3u8?DeviceId=ece699cb-abe6-4ffa-98f1-7b81b4c0de40&MediaSourceId=native_e35bc8df39ab263c2c7ed7966836cabd_f8f181232418314d1bc8239f1eabc416&PlaySessionId=5bf719e1d7db4352a138caa0e57ccf41&api_key=x_secret2_x&LiveStreamId=06044cf0e6f93cdae5f285c9ecfaaeb4_01413a525b3a9622ce6fdf19f7dde354_native_e35bc8df39ab263c2c7ed7966836cabd_f8f181232418314d1bc8239f1eabc416&VideoCodec=h264,h265,hevc,av1&AudioCodec=mp3,aac&VideoBitrate=159616000&AudioBitrate=384000&MaxWidth=3840&AudioStreamIndex=1&VideoSideDataSubs=100&TranscodingMaxAudioChannels=2&SegmentContainer=m4s,ts&MinSegments=1&BreakOnNonKeyFrames=True&SubtitleStreamIndexes=-1&ManifestSubtitles=vtt&h264-profile=high,main,baseline,constrainedbaseline,high10&h264-level=62&hevc-codectag=hvc1,hev1,hevc,hdmv&TranscodeReasons=ContainerNotSupported 2024-02-08 20:22:31.565 Info Server: http/1.1 GET http://192.168.1.4:8096/emby/videos/17804845/hls/2EB688/2EB688_21.ts?PlaySessionId=5bf719e1d7db4352a138caa0e57ccf41. Accept=*/*, Connection=keep-alive, Host=host4, User-Agent=Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/121.0.0.0 Safari/537.36, Accept-Encoding=gzip, deflate, Accept-Language=en-US,en;q=0.9,fr;q=0.8, Referer=http://192.168.1.4:8096/web/index.html 2024-02-08 20:22:31.569 Info Server: http/1.1 Response 200 to 192.168.1.4. Time: 4ms. GET http://192.168.1.4:8096/emby/videos/17804845/hls/2EB688/2EB688_21.ts?PlaySessionId=5bf719e1d7db4352a138caa0e57ccf41 2024-02-08 20:22:32.563 Info Server: http/1.1 POST http://192.168.1.4:8096/emby/Sessions/Playing/Progress?X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome Windows&X-Emby-Device-Id=ece699cb-abe6-4ffa-98f1-7b81b4c0de40&X-Emby-Client-Version=4.8.1.0&X-Emby-Token=x_secret2_x&X-Emby-Language=en-us&reqformat=json. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/121.0.0.0 Safari/537.36 2024-02-08 20:22:32.564 Info Server: http/1.1 Response 204 to 192.168.1.4. Time: 1ms. POST http://192.168.1.4:8096/emby/Sessions/Playing/Progress?X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome Windows&X-Emby-Device-Id=ece699cb-abe6-4ffa-98f1-7b81b4c0de40&X-Emby-Client-Version=4.8.1.0&X-Emby-Token=x_secret2_x&X-Emby-Language=en-us&reqformat=json 2024-02-08 20:22:34.559 Info Server: http/1.1 GET http://192.168.1.4:8096/emby/videos/17804845/live.m3u8?DeviceId=ece699cb-abe6-4ffa-98f1-7b81b4c0de40&MediaSourceId=native_e35bc8df39ab263c2c7ed7966836cabd_f8f181232418314d1bc8239f1eabc416&PlaySessionId=5bf719e1d7db4352a138caa0e57ccf41&api_key=x_secret2_x&LiveStreamId=06044cf0e6f93cdae5f285c9ecfaaeb4_01413a525b3a9622ce6fdf19f7dde354_native_e35bc8df39ab263c2c7ed7966836cabd_f8f181232418314d1bc8239f1eabc416&VideoCodec=h264,h265,hevc,av1&AudioCodec=mp3,aac&VideoBitrate=159616000&AudioBitrate=384000&MaxWidth=3840&AudioStreamIndex=1&VideoSideDataSubs=100&TranscodingMaxAudioChannels=2&SegmentContainer=m4s,ts&MinSegments=1&BreakOnNonKeyFrames=True&SubtitleStreamIndexes=-1&ManifestSubtitles=vtt&h264-profile=high,main,baseline,constrainedbaseline,high10&h264-level=62&hevc-codectag=hvc1,hev1,hevc,hdmv&TranscodeReasons=ContainerNotSupported. Accept=*/*, Connection=keep-alive, Host=host4, User-Agent=Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/121.0.0.0 Safari/537.36, Accept-Encoding=gzip, deflate, Accept-Language=en-US,en;q=0.9,fr;q=0.8, Referer=http://192.168.1.4:8096/web/index.html 2024-02-08 20:22:34.560 Info Server: http/1.1 Response 200 to 192.168.1.4. Time: 1ms. GET http://192.168.1.4:8096/emby/videos/17804845/live.m3u8?DeviceId=ece699cb-abe6-4ffa-98f1-7b81b4c0de40&MediaSourceId=native_e35bc8df39ab263c2c7ed7966836cabd_f8f181232418314d1bc8239f1eabc416&PlaySessionId=5bf719e1d7db4352a138caa0e57ccf41&api_key=x_secret2_x&LiveStreamId=06044cf0e6f93cdae5f285c9ecfaaeb4_01413a525b3a9622ce6fdf19f7dde354_native_e35bc8df39ab263c2c7ed7966836cabd_f8f181232418314d1bc8239f1eabc416&VideoCodec=h264,h265,hevc,av1&AudioCodec=mp3,aac&VideoBitrate=159616000&AudioBitrate=384000&MaxWidth=3840&AudioStreamIndex=1&VideoSideDataSubs=100&TranscodingMaxAudioChannels=2&SegmentContainer=m4s,ts&MinSegments=1&BreakOnNonKeyFrames=True&SubtitleStreamIndexes=-1&ManifestSubtitles=vtt&h264-profile=high,main,baseline,constrainedbaseline,high10&h264-level=62&hevc-codectag=hvc1,hev1,hevc,hdmv&TranscodeReasons=ContainerNotSupported 2024-02-08 20:22:34.563 Info Server: http/1.1 GET http://192.168.1.4:8096/emby/videos/17804845/hls/2EB688/2EB688_22.ts?PlaySessionId=5bf719e1d7db4352a138caa0e57ccf41. Accept=*/*, Connection=keep-alive, Host=host4, User-Agent=Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/121.0.0.0 Safari/537.36, Accept-Encoding=gzip, deflate, Accept-Language=en-US,en;q=0.9,fr;q=0.8, Referer=http://192.168.1.4:8096/web/index.html 2024-02-08 20:22:34.565 Info Server: http/1.1 Response 200 to 192.168.1.4. Time: 2ms. GET http://192.168.1.4:8096/emby/videos/17804845/hls/2EB688/2EB688_22.ts?PlaySessionId=5bf719e1d7db4352a138caa0e57ccf41 2024-02-08 20:22:37.560 Info Server: http/1.1 GET http://192.168.1.4:8096/emby/videos/17804845/live.m3u8?DeviceId=ece699cb-abe6-4ffa-98f1-7b81b4c0de40&MediaSourceId=native_e35bc8df39ab263c2c7ed7966836cabd_f8f181232418314d1bc8239f1eabc416&PlaySessionId=5bf719e1d7db4352a138caa0e57ccf41&api_key=x_secret2_x&LiveStreamId=06044cf0e6f93cdae5f285c9ecfaaeb4_01413a525b3a9622ce6fdf19f7dde354_native_e35bc8df39ab263c2c7ed7966836cabd_f8f181232418314d1bc8239f1eabc416&VideoCodec=h264,h265,hevc,av1&AudioCodec=mp3,aac&VideoBitrate=159616000&AudioBitrate=384000&MaxWidth=3840&AudioStreamIndex=1&VideoSideDataSubs=100&TranscodingMaxAudioChannels=2&SegmentContainer=m4s,ts&MinSegments=1&BreakOnNonKeyFrames=True&SubtitleStreamIndexes=-1&ManifestSubtitles=vtt&h264-profile=high,main,baseline,constrainedbaseline,high10&h264-level=62&hevc-codectag=hvc1,hev1,hevc,hdmv&TranscodeReasons=ContainerNotSupported. Accept=*/*, Connection=keep-alive, Host=host4, User-Agent=Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/121.0.0.0 Safari/537.36, Accept-Encoding=gzip, deflate, Accept-Language=en-US,en;q=0.9,fr;q=0.8, Referer=http://192.168.1.4:8096/web/index.html 2024-02-08 20:22:37.561 Info Server: http/1.1 Response 200 to 192.168.1.4. Time: 1ms. GET http://192.168.1.4:8096/emby/videos/17804845/live.m3u8?DeviceId=ece699cb-abe6-4ffa-98f1-7b81b4c0de40&MediaSourceId=native_e35bc8df39ab263c2c7ed7966836cabd_f8f181232418314d1bc8239f1eabc416&PlaySessionId=5bf719e1d7db4352a138caa0e57ccf41&api_key=x_secret2_x&LiveStreamId=06044cf0e6f93cdae5f285c9ecfaaeb4_01413a525b3a9622ce6fdf19f7dde354_native_e35bc8df39ab263c2c7ed7966836cabd_f8f181232418314d1bc8239f1eabc416&VideoCodec=h264,h265,hevc,av1&AudioCodec=mp3,aac&VideoBitrate=159616000&AudioBitrate=384000&MaxWidth=3840&AudioStreamIndex=1&VideoSideDataSubs=100&TranscodingMaxAudioChannels=2&SegmentContainer=m4s,ts&MinSegments=1&BreakOnNonKeyFrames=True&SubtitleStreamIndexes=-1&ManifestSubtitles=vtt&h264-profile=high,main,baseline,constrainedbaseline,high10&h264-level=62&hevc-codectag=hvc1,hev1,hevc,hdmv&TranscodeReasons=ContainerNotSupported 2024-02-08 20:22:37.563 Info Server: http/1.1 GET http://192.168.1.4:8096/emby/videos/17804845/hls/2EB688/2EB688_23.ts?PlaySessionId=5bf719e1d7db4352a138caa0e57ccf41. Accept=*/*, Connection=keep-alive, Host=host4, User-Agent=Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/121.0.0.0 Safari/537.36, Accept-Encoding=gzip, deflate, Accept-Language=en-US,en;q=0.9,fr;q=0.8, Referer=http://192.168.1.4:8096/web/index.html 2024-02-08 20:22:37.566 Info Server: http/1.1 Response 200 to 192.168.1.4. Time: 2ms. GET http://192.168.1.4:8096/emby/videos/17804845/hls/2EB688/2EB688_23.ts?PlaySessionId=5bf719e1d7db4352a138caa0e57ccf41 2024-02-08 20:22:40.567 Info Server: http/1.1 GET http://192.168.1.4:8096/emby/videos/17804845/live.m3u8?DeviceId=ece699cb-abe6-4ffa-98f1-7b81b4c0de40&MediaSourceId=native_e35bc8df39ab263c2c7ed7966836cabd_f8f181232418314d1bc8239f1eabc416&PlaySessionId=5bf719e1d7db4352a138caa0e57ccf41&api_key=x_secret2_x&LiveStreamId=06044cf0e6f93cdae5f285c9ecfaaeb4_01413a525b3a9622ce6fdf19f7dde354_native_e35bc8df39ab263c2c7ed7966836cabd_f8f181232418314d1bc8239f1eabc416&VideoCodec=h264,h265,hevc,av1&AudioCodec=mp3,aac&VideoBitrate=159616000&AudioBitrate=384000&MaxWidth=3840&AudioStreamIndex=1&VideoSideDataSubs=100&TranscodingMaxAudioChannels=2&SegmentContainer=m4s,ts&MinSegments=1&BreakOnNonKeyFrames=True&SubtitleStreamIndexes=-1&ManifestSubtitles=vtt&h264-profile=high,main,baseline,constrainedbaseline,high10&h264-level=62&hevc-codectag=hvc1,hev1,hevc,hdmv&TranscodeReasons=ContainerNotSupported. Accept=*/*, Connection=keep-alive, Host=host4, User-Agent=Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/121.0.0.0 Safari/537.36, Accept-Encoding=gzip, deflate, Accept-Language=en-US,en;q=0.9,fr;q=0.8, Referer=http://192.168.1.4:8096/web/index.html 2024-02-08 20:22:40.567 Info Server: http/1.1 Response 200 to 192.168.1.4. Time: 1ms. GET http://192.168.1.4:8096/emby/videos/17804845/live.m3u8?DeviceId=ece699cb-abe6-4ffa-98f1-7b81b4c0de40&MediaSourceId=native_e35bc8df39ab263c2c7ed7966836cabd_f8f181232418314d1bc8239f1eabc416&PlaySessionId=5bf719e1d7db4352a138caa0e57ccf41&api_key=x_secret2_x&LiveStreamId=06044cf0e6f93cdae5f285c9ecfaaeb4_01413a525b3a9622ce6fdf19f7dde354_native_e35bc8df39ab263c2c7ed7966836cabd_f8f181232418314d1bc8239f1eabc416&VideoCodec=h264,h265,hevc,av1&AudioCodec=mp3,aac&VideoBitrate=159616000&AudioBitrate=384000&MaxWidth=3840&AudioStreamIndex=1&VideoSideDataSubs=100&TranscodingMaxAudioChannels=2&SegmentContainer=m4s,ts&MinSegments=1&BreakOnNonKeyFrames=True&SubtitleStreamIndexes=-1&ManifestSubtitles=vtt&h264-profile=high,main,baseline,constrainedbaseline,high10&h264-level=62&hevc-codectag=hvc1,hev1,hevc,hdmv&TranscodeReasons=ContainerNotSupported 2024-02-08 20:22:40.570 Info Server: http/1.1 GET http://192.168.1.4:8096/emby/videos/17804845/hls/2EB688/2EB688_24.ts?PlaySessionId=5bf719e1d7db4352a138caa0e57ccf41. Accept=*/*, Connection=keep-alive, Host=host4, User-Agent=Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/121.0.0.0 Safari/537.36, Accept-Encoding=gzip, deflate, Accept-Language=en-US,en;q=0.9,fr;q=0.8, Referer=http://192.168.1.4:8096/web/index.html 2024-02-08 20:22:40.571 Info Server: http/1.1 Response 200 to 192.168.1.4. Time: 2ms. GET http://192.168.1.4:8096/emby/videos/17804845/hls/2EB688/2EB688_24.ts?PlaySessionId=5bf719e1d7db4352a138caa0e57ccf41 2024-02-08 20:22:42.653 Info Server: http/1.1 POST http://192.168.1.4:8096/emby/Sessions/Playing/Progress?X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome Windows&X-Emby-Device-Id=ece699cb-abe6-4ffa-98f1-7b81b4c0de40&X-Emby-Client-Version=4.8.1.0&X-Emby-Token=x_secret2_x&X-Emby-Language=en-us&reqformat=json. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/121.0.0.0 Safari/537.36 2024-02-08 20:22:42.653 Info Server: http/1.1 Response 204 to 192.168.1.4. Time: 1ms. POST http://192.168.1.4:8096/emby/Sessions/Playing/Progress?X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome Windows&X-Emby-Device-Id=ece699cb-abe6-4ffa-98f1-7b81b4c0de40&X-Emby-Client-Version=4.8.1.0&X-Emby-Token=x_secret2_x&X-Emby-Language=en-us&reqformat=json 2024-02-08 20:22:43.570 Info Server: http/1.1 GET http://192.168.1.4:8096/emby/videos/17804845/live.m3u8?DeviceId=ece699cb-abe6-4ffa-98f1-7b81b4c0de40&MediaSourceId=native_e35bc8df39ab263c2c7ed7966836cabd_f8f181232418314d1bc8239f1eabc416&PlaySessionId=5bf719e1d7db4352a138caa0e57ccf41&api_key=x_secret2_x&LiveStreamId=06044cf0e6f93cdae5f285c9ecfaaeb4_01413a525b3a9622ce6fdf19f7dde354_native_e35bc8df39ab263c2c7ed7966836cabd_f8f181232418314d1bc8239f1eabc416&VideoCodec=h264,h265,hevc,av1&AudioCodec=mp3,aac&VideoBitrate=159616000&AudioBitrate=384000&MaxWidth=3840&AudioStreamIndex=1&VideoSideDataSubs=100&TranscodingMaxAudioChannels=2&SegmentContainer=m4s,ts&MinSegments=1&BreakOnNonKeyFrames=True&SubtitleStreamIndexes=-1&ManifestSubtitles=vtt&h264-profile=high,main,baseline,constrainedbaseline,high10&h264-level=62&hevc-codectag=hvc1,hev1,hevc,hdmv&TranscodeReasons=ContainerNotSupported. Accept=*/*, Connection=keep-alive, Host=host4, User-Agent=Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/121.0.0.0 Safari/537.36, Accept-Encoding=gzip, deflate, Accept-Language=en-US,en;q=0.9,fr;q=0.8, Referer=http://192.168.1.4:8096/web/index.html 2024-02-08 20:22:43.570 Info Server: http/1.1 Response 200 to 192.168.1.4. Time: 1ms. GET http://192.168.1.4:8096/emby/videos/17804845/live.m3u8?DeviceId=ece699cb-abe6-4ffa-98f1-7b81b4c0de40&MediaSourceId=native_e35bc8df39ab263c2c7ed7966836cabd_f8f181232418314d1bc8239f1eabc416&PlaySessionId=5bf719e1d7db4352a138caa0e57ccf41&api_key=x_secret2_x&LiveStreamId=06044cf0e6f93cdae5f285c9ecfaaeb4_01413a525b3a9622ce6fdf19f7dde354_native_e35bc8df39ab263c2c7ed7966836cabd_f8f181232418314d1bc8239f1eabc416&VideoCodec=h264,h265,hevc,av1&AudioCodec=mp3,aac&VideoBitrate=159616000&AudioBitrate=384000&MaxWidth=3840&AudioStreamIndex=1&VideoSideDataSubs=100&TranscodingMaxAudioChannels=2&SegmentContainer=m4s,ts&MinSegments=1&BreakOnNonKeyFrames=True&SubtitleStreamIndexes=-1&ManifestSubtitles=vtt&h264-profile=high,main,baseline,constrainedbaseline,high10&h264-level=62&hevc-codectag=hvc1,hev1,hevc,hdmv&TranscodeReasons=ContainerNotSupported 2024-02-08 20:22:43.573 Info Server: http/1.1 GET http://192.168.1.4:8096/emby/videos/17804845/hls/2EB688/2EB688_25.ts?PlaySessionId=5bf719e1d7db4352a138caa0e57ccf41. Accept=*/*, Connection=keep-alive, Host=host4, User-Agent=Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/121.0.0.0 Safari/537.36, Accept-Encoding=gzip, deflate, Accept-Language=en-US,en;q=0.9,fr;q=0.8, Referer=http://192.168.1.4:8096/web/index.html 2024-02-08 20:22:43.575 Info Server: http/1.1 Response 200 to 192.168.1.4. Time: 2ms. GET http://192.168.1.4:8096/emby/videos/17804845/hls/2EB688/2EB688_25.ts?PlaySessionId=5bf719e1d7db4352a138caa0e57ccf41 2024-02-08 20:22:46.569 Info Server: http/1.1 GET http://192.168.1.4:8096/emby/videos/17804845/live.m3u8?DeviceId=ece699cb-abe6-4ffa-98f1-7b81b4c0de40&MediaSourceId=native_e35bc8df39ab263c2c7ed7966836cabd_f8f181232418314d1bc8239f1eabc416&PlaySessionId=5bf719e1d7db4352a138caa0e57ccf41&api_key=x_secret2_x&LiveStreamId=06044cf0e6f93cdae5f285c9ecfaaeb4_01413a525b3a9622ce6fdf19f7dde354_native_e35bc8df39ab263c2c7ed7966836cabd_f8f181232418314d1bc8239f1eabc416&VideoCodec=h264,h265,hevc,av1&AudioCodec=mp3,aac&VideoBitrate=159616000&AudioBitrate=384000&MaxWidth=3840&AudioStreamIndex=1&VideoSideDataSubs=100&TranscodingMaxAudioChannels=2&SegmentContainer=m4s,ts&MinSegments=1&BreakOnNonKeyFrames=True&SubtitleStreamIndexes=-1&ManifestSubtitles=vtt&h264-profile=high,main,baseline,constrainedbaseline,high10&h264-level=62&hevc-codectag=hvc1,hev1,hevc,hdmv&TranscodeReasons=ContainerNotSupported. Accept=*/*, Connection=keep-alive, Host=host4, User-Agent=Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/121.0.0.0 Safari/537.36, Accept-Encoding=gzip, deflate, Accept-Language=en-US,en;q=0.9,fr;q=0.8, Referer=http://192.168.1.4:8096/web/index.html 2024-02-08 20:22:46.570 Info Server: http/1.1 Response 200 to 192.168.1.4. Time: 1ms. GET http://192.168.1.4:8096/emby/videos/17804845/live.m3u8?DeviceId=ece699cb-abe6-4ffa-98f1-7b81b4c0de40&MediaSourceId=native_e35bc8df39ab263c2c7ed7966836cabd_f8f181232418314d1bc8239f1eabc416&PlaySessionId=5bf719e1d7db4352a138caa0e57ccf41&api_key=x_secret2_x&LiveStreamId=06044cf0e6f93cdae5f285c9ecfaaeb4_01413a525b3a9622ce6fdf19f7dde354_native_e35bc8df39ab263c2c7ed7966836cabd_f8f181232418314d1bc8239f1eabc416&VideoCodec=h264,h265,hevc,av1&AudioCodec=mp3,aac&VideoBitrate=159616000&AudioBitrate=384000&MaxWidth=3840&AudioStreamIndex=1&VideoSideDataSubs=100&TranscodingMaxAudioChannels=2&SegmentContainer=m4s,ts&MinSegments=1&BreakOnNonKeyFrames=True&SubtitleStreamIndexes=-1&ManifestSubtitles=vtt&h264-profile=high,main,baseline,constrainedbaseline,high10&h264-level=62&hevc-codectag=hvc1,hev1,hevc,hdmv&TranscodeReasons=ContainerNotSupported 2024-02-08 20:22:46.572 Info Server: http/1.1 GET http://192.168.1.4:8096/emby/videos/17804845/hls/2EB688/2EB688_26.ts?PlaySessionId=5bf719e1d7db4352a138caa0e57ccf41. Accept=*/*, Connection=keep-alive, Host=host4, User-Agent=Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/121.0.0.0 Safari/537.36, Accept-Encoding=gzip, deflate, Accept-Language=en-US,en;q=0.9,fr;q=0.8, Referer=http://192.168.1.4:8096/web/index.html 2024-02-08 20:22:46.576 Info Server: http/1.1 Response 200 to 192.168.1.4. Time: 3ms. GET http://192.168.1.4:8096/emby/videos/17804845/hls/2EB688/2EB688_26.ts?PlaySessionId=5bf719e1d7db4352a138caa0e57ccf41 2024-02-08 20:22:48.741 Info Server: http/1.1 POST http://192.168.1.4:8096/emby/Sessions/Playing/Stopped?X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome Windows&X-Emby-Device-Id=ece699cb-abe6-4ffa-98f1-7b81b4c0de40&X-Emby-Client-Version=4.8.1.0&X-Emby-Token=x_secret2_x&X-Emby-Language=en-us&reqformat=json. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/121.0.0.0 Safari/537.36 2024-02-08 20:22:48.742 Info SessionManager: Playback stopped reported by app Emby Web 4.8.1.0 on Chrome Windows playing MSNBC HD. Stopped at 76558 ms 2024-02-08 20:22:48.742 Info MediaSourceManager: Live stream native_e35bc8df39ab263c2c7ed7966836cabd_f8f181232418314d1bc8239f1eabc416 consumer count is now 0 2024-02-08 20:22:48.742 Info MediaSourceManager: Closing live stream 06044cf0e6f93cdae5f285c9ecfaaeb4_01413a525b3a9622ce6fdf19f7dde354_native_e35bc8df39ab263c2c7ed7966836cabd_f8f181232418314d1bc8239f1eabc416 2024-02-08 20:22:48.742 Info SharedHttpPipelineSource: Closing SharedHttpPipelineSource 2024-02-08 20:22:48.743 Info Server: http/1.1 Response 200 to 127.0.0.1. Time: 77801ms. GET http://127.0.0.1:8096/LiveTv/LiveStreamFiles/ba572900ac514691938f6396db8971b4/stream.ts 2024-02-08 20:22:48.743 Info SharedHttpPipelineSource: Deleting temp files D:\Recorded TV\TempRec\transcoding-temp\ba572900ac514691938f6396db8971b4\0000000.ts, D:\Recorded TV\TempRec\transcoding-temp\ba572900ac514691938f6396db8971b4\0000001.ts 2024-02-08 20:22:48.744 Info SharedHttpPipelineSource: SharedHttpPipelineSource is done streaming. 2024-02-08 20:22:48.762 Info MediaSourceManager: Live stream 06044cf0e6f93cdae5f285c9ecfaaeb4_01413a525b3a9622ce6fdf19f7dde354_native_e35bc8df39ab263c2c7ed7966836cabd_f8f181232418314d1bc8239f1eabc416 closed successfully 2024-02-08 20:22:48.762 Info SessionManager: Removing playSession 5bf719e1d7db4352a138caa0e57ccf41 from session c21560fc005e5b7fca081b1a8d99b88d 2024-02-08 20:22:48.762 Info Server: http/1.1 Response 204 to 192.168.1.4. Time: 21ms. POST http://192.168.1.4:8096/emby/Sessions/Playing/Stopped?X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome Windows&X-Emby-Device-Id=ece699cb-abe6-4ffa-98f1-7b81b4c0de40&X-Emby-Client-Version=4.8.1.0&X-Emby-Token=x_secret2_x&X-Emby-Language=en-us&reqformat=json 2024-02-08 20:22:48.762 Info App: ProcessRun 'StreamTranscode 21394f': Stopping ffmpeg process with q command for D:\Recorded TV\TempRec\transcoding-temp\2EB688\2EB688_0.ts 2024-02-08 20:22:48.842 Info App: AppendExtraLogData - Read graph file: C:\Emby-server\programdata\logs\ffmpeg-transcode-21394fc4-1528-4342-a35d-261f02656204_1graph.txt 2024-02-08 20:22:48.843 Info App: AppendExtraLogData - Deserialized GraphData fileStream: 12,100.000 bytes Graph Count: 2 2024-02-08 20:22:48.843 Info App: AppendExtraLogData - File Deleted 2024-02-08 20:22:48.846 Info App: ProcessRun 'StreamTranscode 21394f' Process exited with code 0 - Succeeded 2024-02-08 20:22:52.794 Info HttpClient: GET https://emby.tmsimg.com/assets/p26695576_b_v11_aa.jpg?w=480&h=720 2024-02-08 20:22:52.840 Info HttpClient: GET https://emby.tmsimg.com/assets/p21080988_b_v12_aa.jpg?w=480&h=720 2024-02-08 20:22:52.840 Info HttpClient: GET https://emby.tmsimg.com/assets/p26695578_b_v12_aa.jpg?w=480&h=720 2024-02-08 20:22:52.840 Info HttpClient: GET https://emby.tmsimg.com/assets/p10746425_b_v8_aa.jpg?w=480&h=720 2024-02-08 20:22:52.840 Info HttpClient: GET https://emby.tmsimg.com/assets/p24732155_st_v8_aa.jpg?w=480&h=720 2024-02-08 20:22:52.840 Info HttpClient: GET https://emby.tmsimg.com/assets/p26505035_b_v12_aa.jpg?w=480&h=720 2024-02-08 20:22:52.873 Info HttpClient: GET https://emby.tmsimg.com/assets/p451918_st_v8_aa.jpg?w=480&h=720 2024-02-08 20:22:52.931 Info HttpClient: GET https://emby.tmsimg.com/assets/p8358694_b_v8_aa.jpg?w=480&h=720 2024-02-08 20:22:54.247 Info Server: http/1.1 POST http://192.168.1.4:8096/emby/Items/17804842/PlaybackInfo?UserId=c187086aa78d48339215740cc3bf1cde&StartTimeTicks=0&IsPlayback=true&AutoOpenLiveStream=true&MaxStreamingBitrate=160000000&X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome Windows&X-Emby-Device-Id=ece699cb-abe6-4ffa-98f1-7b81b4c0de40&X-Emby-Client-Version=4.8.1.0&X-Emby-Token=x_secret2_x&X-Emby-Language=en-us&reqformat=json. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/121.0.0.0 Safari/537.36 2024-02-08 20:22:54.248 Info App: User policy for sward. EnablePlaybackRemuxing: True EnableVideoPlaybackTranscoding: True EnableAudioPlaybackTranscoding: True 2024-02-08 20:22:54.248 Info LiveTvManager: Opening channel stream, external channel Id: hdhr_600 2024-02-08 20:22:54.248 Info LiveTV: Streaming Channel hdhr_600, with streamId: native_57c9a92498ecd5858f960120f6e8a572_f8f181232418314d1bc8239f1eabc416 2024-02-08 20:22:54.248 Info HdHomerunHost: GetChannelStream: channel id: 600. stream id: native_57c9a92498ecd5858f960120f6e8a572_f8f181232418314d1bc8239f1eabc416 profile: native 2024-02-08 20:22:54.248 Info SharedHttpPipelineSource: Opening SharedHttpPipelineSource Live stream from Http-http://192.168.1.4:5004/x_path1_x/x_path3_x 2024-02-08 20:22:54.248 Info HttpClient: GET http://192.168.1.4:5004/x_path1_x/x_path3_x 2024-02-08 20:22:54.250 Info HttpClient: Http response 200 from http://192.168.1.4:5004/x_path1_x/x_path3_x after 2ms. Headers Connection=close, Date=Fri, 09 Feb 2024 01:22:54 GMT, Transfer-Encoding=chunked 2024-02-08 20:22:54.250 Info SharedHttpPipelineSource: Live stream buffer limit is unlimited. 2024-02-08 20:22:54.250 Info SharedHttpPipelineSource: Start waiting for the live stream buffer to fill 2024-02-08 20:22:54.251 Info SharedHttpPipelineSource: Beginning SharedHttpPipelineSource stream to D:\Recorded TV\TempRec\transcoding-temp\c285b4599ba54c8192d77278fd354b8a\{0:0000000}.ts 2024-02-08 20:22:54.251 Info SharedHttpPipelineSource: Start copying from response stream: Http-http://192.168.1.4:5004/x_path1_x/x_path3_x 2024-02-08 20:22:57.754 Info SharedHttpPipelineSource: Done waiting for segments after 3503ms 2024-02-08 20:22:57.754 Info MediaProbeManager: ProcessRun 'ffprobe' Execute: C:\Emby-server\system\ffprobe.exe -analyzeduration 3000000 -i "http://127.0.0.1:8096/LiveTv/LiveStreamFiles/c285b4599ba54c8192d77278fd354b8a/stream.ts" -threads 0 -v info -print_format json -show_streams -show_format -show_data 2024-02-08 20:22:57.820 Info Server: http/1.1 GET http://127.0.0.1:8096/LiveTv/LiveStreamFiles/c285b4599ba54c8192d77278fd354b8a/stream.ts. Accept=*/*, Connection=close, Host=host3, User-Agent=Lavf/59.27.100, Range=bytes=0-, Icy-MetaData=1 2024-02-08 20:22:57.820 Info SharedHttpPipelineSource: Live Stream ended. 2024-02-08 20:22:57.820 Info Server: http/1.1 Response 200 to 127.0.0.1. Time: 0ms. GET http://127.0.0.1:8096/LiveTv/LiveStreamFiles/c285b4599ba54c8192d77278fd354b8a/stream.ts 2024-02-08 20:22:57.825 Info MediaProbeManager: ProcessRun 'ffprobe' Process exited with code 0 - Succeeded 2024-02-08 20:22:57.826 Error MediaSourceManager: Error probing live tv stream *** Error Report *** Version: 4.8.1.0 Command line: C:\Emby-server\system\EmbyServer.dll Operating system: Microsoft Windows 10.0.22631 Framework: .NET 6.0.26 OS/Process: x64/x64 Runtime: C:/Emby-server/system/System.Private.CoreLib.dll Processor count: 24 Data path: C:\Emby-server\programdata Application path: C:\Emby-server\system Emby.Server.MediaEncoding.Unified.Ffmpeg.FfRunException: Emby.Server.MediaEncoding.Unified.Ffmpeg.FfRunException: ffprobe failed - streams and format are both null: -analyzeduration 3000000 -i "http://127.0.0.1:8096/LiveTv/LiveStreamFiles/c285b4599ba54c8192d77278fd354b8a/stream.ts" -threads 0 -v info -print_format json -show_streams -show_format -show_data ffprobe version 5.1-emby_2023_06_25 Copyright (c) 2007-2022 the FFmpeg developers and softworkz for Emby LLC built with gcc 12.2.0 (Rev10, Built by MSYS2 project) http://127.0.0.1:8096/LiveTv/LiveStreamFiles/c285b4599ba54c8192d77278fd354b8a/stream.ts: Invalid data found when processing input { } at Emby.Server.MediaEncoding.Probing.MediaProbeManager.GetMediaInfoInternal(String inputPath, String primaryPath, MediaProtocol protocol, String userAgent, Boolean extractChapters, String probeSizeArgument, Boolean isAudio, Boolean hasMixedProtocols, CancellationToken cancellationToken) at Emby.Server.Implementations.Library.MediaSourceManager.AddMediaInfoWithProbe(MediaSourceInfo mediaSource, Boolean isAudio, Boolean addProbeDelay, CancellationToken cancellationToken) at Emby.Server.Implementations.Library.MediaSourceManager.AddMediaInfoWithProbeSafe(MediaSourceInfo mediaSource, Boolean isAudio, Boolean addProbeDelay, CancellationToken cancellationToken) Source: Emby.Server.MediaEncoding TargetSite: Void MoveNext() 2024-02-08 20:22:57.826 Info HdHomerunHost: Live stream opened after 3577.6993ms 2024-02-08 20:22:57.826 Info LiveTV: Returning mediasource streamId native_57c9a92498ecd5858f960120f6e8a572_f8f181232418314d1bc8239f1eabc416, mediaSource.Id native_57c9a92498ecd5858f960120f6e8a572_f8f181232418314d1bc8239f1eabc416, mediaSource.LiveStreamId 2024-02-08 20:22:57.826 Info MediaSourceManager: Live stream opened: {"Protocol":"Http","Id":"native_57c9a92498ecd5858f960120f6e8a572_f8f181232418314d1bc8239f1eabc416","Path":"http://127.0.0.1:8096/LiveTv/LiveStreamFiles/c285b4599ba54c8192d77278fd354b8a/stream.ts","Type":"Default","ProbePath":"","ProbeProtocol":"File","Container":"mpegts","IsRemote":false,"HasMixedProtocols":false,"SupportsTranscoding":true,"SupportsDirectStream":true,"SupportsDirectPlay":false,"IsInfiniteStream":true,"RequiresOpening":true,"RequiresClosing":true,"LiveStreamId":"06044cf0e6f93cdae5f285c9ecfaaeb4_01413a525b3a9622ce6fdf19f7dde354_native_57c9a92498ecd5858f960120f6e8a572_f8f181232418314d1bc8239f1eabc416","RequiresLooping":false,"SupportsProbing":false,"MediaStreams":[{"VideoRange":"SDR","IsInterlaced":true,"BitRate":2000000,"IsDefault":false,"IsForced":false,"IsHearingImpaired":false,"Type":"Video","Index":-1,"IsExternal":false,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"Protocol":"File","ExtendedVideoType":"None","ExtendedVideoSubType":"None","ExtendedVideoSubTypeDescription":"None"},{"IsInterlaced":false,"BitRate":192000,"IsDefault":false,"IsForced":false,"IsHearingImpaired":false,"Type":"Audio","Index":-1,"IsExternal":false,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"Protocol":"File","ExtendedVideoType":"None","ExtendedVideoSubType":"None","ExtendedVideoSubTypeDescription":"None"}],"Formats":[],"Bitrate":2192000,"RequiredHttpHeaders":{},"AddApiKeyToDirectStreamUrl":false,"ReadAtNativeFramerate":false} 2024-02-08 20:22:57.826 Info App: User policy for sward. EnablePlaybackRemuxing: True EnableVideoPlaybackTranscoding: True EnableAudioPlaybackTranscoding: True 2024-02-08 20:22:57.826 Info SessionManager: Adding playSession 913ce158d9304b17813f44be87752631 to session c21560fc005e5b7fca081b1a8d99b88d 2024-02-08 20:22:57.826 Info Server: http/1.1 Response 200 to 192.168.1.4. Time: 3579ms. POST http://192.168.1.4:8096/emby/Items/17804842/PlaybackInfo?UserId=c187086aa78d48339215740cc3bf1cde&StartTimeTicks=0&IsPlayback=true&AutoOpenLiveStream=true&MaxStreamingBitrate=160000000&X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome Windows&X-Emby-Device-Id=ece699cb-abe6-4ffa-98f1-7b81b4c0de40&X-Emby-Client-Version=4.8.1.0&X-Emby-Token=x_secret2_x&X-Emby-Language=en-us&reqformat=json 2024-02-08 20:22:57.858 Info Server: http/1.1 GET http://192.168.1.4:8096/emby/videos/17804842/master.m3u8?DeviceId=ece699cb-abe6-4ffa-98f1-7b81b4c0de40&MediaSourceId=native_57c9a92498ecd5858f960120f6e8a572_f8f181232418314d1bc8239f1eabc416&PlaySessionId=913ce158d9304b17813f44be87752631&api_key=x_secret2_x&LiveStreamId=06044cf0e6f93cdae5f285c9ecfaaeb4_01413a525b3a9622ce6fdf19f7dde354_native_57c9a92498ecd5858f960120f6e8a572_f8f181232418314d1bc8239f1eabc416&VideoCodec=h264,h265,hevc,av1&AudioCodec=mp3,aac&VideoBitrate=159808000&AudioBitrate=192000&MaxWidth=3840&TranscodingMaxAudioChannels=2&SegmentContainer=m4s,ts&MinSegments=1&BreakOnNonKeyFrames=True&SubtitleStreamIndexes=-1&ManifestSubtitles=vtt&h264-profile=high,main,baseline,constrainedbaseline,high10&h264-level=62&hevc-codectag=hvc1,hev1,hevc,hdmv&TranscodeReasons=ContainerNotSupported. Accept=*/*, Connection=keep-alive, Host=host4, User-Agent=Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/121.0.0.0 Safari/537.36, Accept-Encoding=gzip, deflate, Accept-Language=en-US,en;q=0.9,fr;q=0.8, Referer=http://192.168.1.4:8096/web/index.html 2024-02-08 20:22:57.859 Info Server: http/1.1 Response 200 to 192.168.1.4. Time: 1ms. GET http://192.168.1.4:8096/emby/videos/17804842/master.m3u8?DeviceId=ece699cb-abe6-4ffa-98f1-7b81b4c0de40&MediaSourceId=native_57c9a92498ecd5858f960120f6e8a572_f8f181232418314d1bc8239f1eabc416&PlaySessionId=913ce158d9304b17813f44be87752631&api_key=x_secret2_x&LiveStreamId=06044cf0e6f93cdae5f285c9ecfaaeb4_01413a525b3a9622ce6fdf19f7dde354_native_57c9a92498ecd5858f960120f6e8a572_f8f181232418314d1bc8239f1eabc416&VideoCodec=h264,h265,hevc,av1&AudioCodec=mp3,aac&VideoBitrate=159808000&AudioBitrate=192000&MaxWidth=3840&TranscodingMaxAudioChannels=2&SegmentContainer=m4s,ts&MinSegments=1&BreakOnNonKeyFrames=True&SubtitleStreamIndexes=-1&ManifestSubtitles=vtt&h264-profile=high,main,baseline,constrainedbaseline,high10&h264-level=62&hevc-codectag=hvc1,hev1,hevc,hdmv&TranscodeReasons=ContainerNotSupported 2024-02-08 20:22:57.869 Info Server: http/1.1 GET http://192.168.1.4:8096/emby/videos/17804842/live.m3u8?DeviceId=ece699cb-abe6-4ffa-98f1-7b81b4c0de40&MediaSourceId=native_57c9a92498ecd5858f960120f6e8a572_f8f181232418314d1bc8239f1eabc416&PlaySessionId=913ce158d9304b17813f44be87752631&api_key=x_secret2_x&LiveStreamId=06044cf0e6f93cdae5f285c9ecfaaeb4_01413a525b3a9622ce6fdf19f7dde354_native_57c9a92498ecd5858f960120f6e8a572_f8f181232418314d1bc8239f1eabc416&VideoCodec=h264,h265,hevc,av1&AudioCodec=mp3,aac&VideoBitrate=159808000&AudioBitrate=192000&MaxWidth=3840&TranscodingMaxAudioChannels=2&SegmentContainer=m4s,ts&MinSegments=1&BreakOnNonKeyFrames=True&SubtitleStreamIndexes=-1&ManifestSubtitles=vtt&h264-profile=high,main,baseline,constrainedbaseline,high10&h264-level=62&hevc-codectag=hvc1,hev1,hevc,hdmv&TranscodeReasons=ContainerNotSupported. Accept=*/*, Connection=keep-alive, Host=host4, User-Agent=Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/121.0.0.0 Safari/537.36, Accept-Encoding=gzip, deflate, Accept-Language=en-US,en;q=0.9,fr;q=0.8, Referer=http://192.168.1.4:8096/web/index.html 2024-02-08 20:22:57.885 Info App: ProcessRun 'StreamTranscode 9d8b71' Execute: C:\Emby-server\system\ffmpeg.exe -loglevel +timing -y -print_graphs_file "C:\Emby-server\programdata\logs\ffmpeg-transcode-9d8b71b2-d575-44fc-8707-20e8335309d1_1graph.txt" -copyts -start_at_zero -analyzeduration 3000000 -f mpegts -noautorotate -i "http://127.0.0.1:8096/LiveTv/LiveStreamFiles/c285b4599ba54c8192d77278fd354b8a/stream.ts" -filter_complex "[v:0]yadif@f1=mode=send_frame:parity=auto:deint=all,scale@f2=width='trunc(min(max(iw,ih*dar),3840)/2)*2':height=trunc(ow/dar/2)*2,format@f3=pix_fmts=yuv420p[f3_out0]" -map [f3_out0] -map a:0 -sn -c:v:0 libx264 -maxrate:v:0 5000000 -bufsize:v:0 10000000 -pix_fmt:v:0 yuv420p -force_key_frames:v:0 "expr:if(isnan(prev_forced_t),eq(t,t),gte(t,prev_forced_t+3))" -preset:v:0 veryfast -profile:v:0 high -x264opts:v:0 "subme=0:me_range=4:rc_lookahead=10:partitions=none" -crf:v:0 23 -c:a:0 libmp3lame -ab:a:0 192000 -ac:a:0 2 -disposition:a:0 default -fflags +discardcorruptts+fillwallclockdts -max_delay 5000000 -avoid_negative_ts disabled -f segment -map_metadata -1 -map_chapters -1 -segment_format mpegts -segment_list "D:\Recorded TV\TempRec\transcoding-temp\41625B\41625B.m3u8" -segment_list_type m3u8 -segment_time 00:00:03.000 -segment_list_entry_prefix hls/41625B/ -segment_start_number 0 -individual_header_trailer 0 -write_header_trailer 0 -segment_write_temp 1 "D:\Recorded TV\TempRec\transcoding-temp\41625B\41625B_%d.ts" 2024-02-08 20:22:57.970 Info Server: http/1.1 GET http://127.0.0.1:8096/LiveTv/LiveStreamFiles/c285b4599ba54c8192d77278fd354b8a/stream.ts. Accept=*/*, Connection=close, Host=host3, User-Agent=Lavf/59.27.100, Range=bytes=0-, Icy-MetaData=1 2024-02-08 20:22:57.971 Info SharedHttpPipelineSource: Live Stream ended. 2024-02-08 20:22:57.971 Info Server: http/1.1 Response 200 to 127.0.0.1. Time: 0ms. GET http://127.0.0.1:8096/LiveTv/LiveStreamFiles/c285b4599ba54c8192d77278fd354b8a/stream.ts 2024-02-08 20:22:57.976 Info App: AppendExtraLogData - Read graph file: C:\Emby-server\programdata\logs\ffmpeg-transcode-9d8b71b2-d575-44fc-8707-20e8335309d1_1graph.txt 2024-02-08 20:22:57.978 Info App: AppendExtraLogData - Deserialized GraphData fileStream: 392.000 bytes Graph Count: 1 2024-02-08 20:22:57.979 Info App: AppendExtraLogData - File Deleted 2024-02-08 20:22:57.979 Info App: ProcessRun 'StreamTranscode 9d8b71' Process exited with code 1 - Failed 2024-02-08 20:22:58.035 Error Server: Error processing request *** Error Report *** Version: 4.8.1.0 Command line: C:\Emby-server\system\EmbyServer.dll Operating system: Microsoft Windows 10.0.22631 Framework: .NET 6.0.26 OS/Process: x64/x64 Runtime: C:/Emby-server/system/System.Private.CoreLib.dll Processor count: 24 Data path: C:\Emby-server\programdata Application path: C:\Emby-server\system Emby.Server.MediaEncoding.Unified.Ffmpeg.FfRunException: Emby.Server.MediaEncoding.Unified.Ffmpeg.FfRunException: Error starting ffmpeg -loglevel +timing -y -print_graphs_file "C:\Emby-server\programdata\logs\ffmpeg-transcode-9d8b71b2-d575-44fc-8707-20e8335309d1_1graph.txt" -copyts -start_at_zero -analyzeduration 3000000 -f mpegts -noautorotate -i "http://127.0.0.1:8096/LiveTv/LiveStreamFiles/c285b4599ba54c8192d77278fd354b8a/stream.ts" -filter_complex "[v:0]yadif@f1=mode=send_frame:parity=auto:deint=all,scale@f2=width='trunc(min(max(iw,ih*dar),3840)/2)*2':height=trunc(ow/dar/2)*2,format@f3=pix_fmts=yuv420p[f3_out0]" -map [f3_out0] -map a:0 -sn -c:v:0 libx264 -maxrate:v:0 5000000 -bufsize:v:0 10000000 -pix_fmt:v:0 yuv420p -force_key_frames:v:0 "expr:if(isnan(prev_forced_t),eq(t,t),gte(t,prev_forced_t+3))" -preset:v:0 veryfast -profile:v:0 high -x264opts:v:0 "subme=0:me_range=4:rc_lookahead=10:partitions=none" -crf:v:0 23 -c:a:0 libmp3lame -ab:a:0 192000 -ac:a:0 2 -disposition:a:0 default -fflags +discardcorruptts+fillwallclockdts -max_delay 5000000 -avoid_negative_ts disabled -f segment -map_metadata -1 -map_chapters -1 -segment_format mpegts -segment_list "D:\Recorded TV\TempRec\transcoding-temp\41625B\41625B.m3u8" -segment_list_type m3u8 -segment_time 00:00:03.000 -segment_list_entry_prefix hls/41625B/ -segment_start_number 0 -individual_header_trailer 0 -write_header_trailer 0 -segment_write_temp 1 "D:\Recorded TV\TempRec\transcoding-temp\41625B\41625B_%d.ts" 20:22:57.945 ffmpeg version 5.1-emby_2023_06_25 Copyright (c) 2000-2022 the FFmpeg developers and softworkz for Emby LLC 20:22:57.947 built with gcc 12.2.0 (Rev10, Built by MSYS2 project) 20:22:57.947 Execution Date: 2024-02-08 20:22:57 20:22:57.971 [mpegts @ 000002bad142b480] Could not detect TS packet size, defaulting to non-FEC/DVHS 20:22:57.971 Input #0, mpegts, from 'http://127.0.0.1:8096/LiveTv/LiveStreamFiles/c285b4599ba54c8192d77278fd354b8a/stream.ts': 20:22:57.971 Duration: N/A, bitrate: N/A 20:22:57.971 Stream specifier 'v:0' in filtergraph description [v:0]yadif@f1=mode=send_frame:parity=auto:deint=all,scale@f2=width='trunc(min(max(iw,ih*dar),3840)/2)*2':height=trunc(ow/dar/2)*2,format@f3=pix_fmts=yuv420p[f3_out0] matches no streams. 20:22:57.972 EXIT at Emby.Server.MediaEncoding.Api.BaseStreamingService.StartFfMpeg(StreamState state, String outputPath, CancellationToken cancellationToken, Boolean acquireResources) at Emby.Server.MediaEncoding.Api.Hls.BaseHlsService.ProcessRequest(StreamState state, StreamRequest request) at Emby.Server.MediaEncoding.Api.Hls.DynamicHlsService.Get(GetLiveHlsStream request) at Emby.Server.Implementations.Services.ServiceController.GetTaskResult(Task task) at Emby.Server.Implementations.Services.ServiceHandler.ProcessRequestAsync(HttpListenerHost httpHost, IServerApplicationHost appHost, IRequest httpReq, IResponse httpRes, IStreamHelper streamHelper, RestPath restPath, String responseContentType, CancellationToken cancellationToken) at Emby.Server.Implementations.HttpServer.HttpListenerHost.RequestHandler(IRequest httpReq, ReadOnlyMemory`1 urlString, ReadOnlyMemory`1 localPath, CancellationToken cancellationToken) Source: Emby.Server.MediaEncoding TargetSite: Void MoveNext() 2024-02-08 20:22:58.035 Info Server: http/1.1 Response 500 to 192.168.1.4. Time: 167ms. GET http://192.168.1.4:8096/emby/videos/17804842/live.m3u8?DeviceId=ece699cb-abe6-4ffa-98f1-7b81b4c0de40&MediaSourceId=native_57c9a92498ecd5858f960120f6e8a572_f8f181232418314d1bc8239f1eabc416&PlaySessionId=913ce158d9304b17813f44be87752631&api_key=x_secret2_x&LiveStreamId=06044cf0e6f93cdae5f285c9ecfaaeb4_01413a525b3a9622ce6fdf19f7dde354_native_57c9a92498ecd5858f960120f6e8a572_f8f181232418314d1bc8239f1eabc416&VideoCodec=h264,h265,hevc,av1&AudioCodec=mp3,aac&VideoBitrate=159808000&AudioBitrate=192000&MaxWidth=3840&TranscodingMaxAudioChannels=2&SegmentContainer=m4s,ts&MinSegments=1&BreakOnNonKeyFrames=True&SubtitleStreamIndexes=-1&ManifestSubtitles=vtt&h264-profile=high,main,baseline,constrainedbaseline,high10&h264-level=62&hevc-codectag=hvc1,hev1,hevc,hdmv&TranscodeReasons=ContainerNotSupported 2024-02-08 20:22:58.041 Info Server: http/1.1 POST http://192.168.1.4:8096/emby/Sessions/Playing?X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome Windows&X-Emby-Device-Id=ece699cb-abe6-4ffa-98f1-7b81b4c0de40&X-Emby-Client-Version=4.8.1.0&X-Emby-Token=x_secret2_x&X-Emby-Language=en-us&reqformat=json. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/121.0.0.0 Safari/537.36 2024-02-08 20:22:58.042 Info SessionManager: Playback start reported by app Emby Web 4.8.1.0 playing CNN HD. Started at 0 ms 2024-02-08 20:22:58.042 Info Server: http/1.1 Response 204 to 192.168.1.4. Time: 1ms. POST http://192.168.1.4:8096/emby/Sessions/Playing?X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome Windows&X-Emby-Device-Id=ece699cb-abe6-4ffa-98f1-7b81b4c0de40&X-Emby-Client-Version=4.8.1.0&X-Emby-Token=x_secret2_x&X-Emby-Language=en-us&reqformat=json 2024-02-08 20:22:58.050 Info Server: http/1.1 POST http://192.168.1.4:8096/emby/Items/17804842/PlaybackInfo?UserId=c187086aa78d48339215740cc3bf1cde&StartTimeTicks=0&IsPlayback=true&AutoOpenLiveStream=true&AudioStreamIndex=-1&SubtitleStreamIndex=-1&EnableDirectPlay=false&EnableDirectStream=false&AllowVideoStreamCopy=false&MediaSourceId=native_57c9a92498ecd5858f960120f6e8a572_f8f181232418314d1bc8239f1eabc416&LiveStreamId=06044cf0e6f93cdae5f285c9ecfaaeb4_01413a525b3a9622ce6fdf19f7dde354_native_57c9a92498ecd5858f960120f6e8a572_f8f181232418314d1bc8239f1eabc416&MaxStreamingBitrate=160000000&CurrentPlaySessionId=913ce158d9304b17813f44be87752631&X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome Windows&X-Emby-Device-Id=ece699cb-abe6-4ffa-98f1-7b81b4c0de40&X-Emby-Client-Version=4.8.1.0&X-Emby-Token=x_secret2_x&X-Emby-Language=en-us&reqformat=json. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/121.0.0.0 Safari/537.36 2024-02-08 20:22:58.051 Info App: User policy for sward. EnablePlaybackRemuxing: True EnableVideoPlaybackTranscoding: True EnableAudioPlaybackTranscoding: True 2024-02-08 20:22:58.051 Info SessionManager: Removing playSession 913ce158d9304b17813f44be87752631 from session c21560fc005e5b7fca081b1a8d99b88d 2024-02-08 20:22:58.051 Info SessionManager: Adding playSession 9dd5b00acb5e425ab97d3d5dd800ac74 to session c21560fc005e5b7fca081b1a8d99b88d 2024-02-08 20:22:58.051 Info Server: http/1.1 Response 200 to 192.168.1.4. Time: 1ms. POST http://192.168.1.4:8096/emby/Items/17804842/PlaybackInfo?UserId=c187086aa78d48339215740cc3bf1cde&StartTimeTicks=0&IsPlayback=true&AutoOpenLiveStream=true&AudioStreamIndex=-1&SubtitleStreamIndex=-1&EnableDirectPlay=false&EnableDirectStream=false&AllowVideoStreamCopy=false&MediaSourceId=native_57c9a92498ecd5858f960120f6e8a572_f8f181232418314d1bc8239f1eabc416&LiveStreamId=06044cf0e6f93cdae5f285c9ecfaaeb4_01413a525b3a9622ce6fdf19f7dde354_native_57c9a92498ecd5858f960120f6e8a572_f8f181232418314d1bc8239f1eabc416&MaxStreamingBitrate=160000000&CurrentPlaySessionId=913ce158d9304b17813f44be87752631&X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome Windows&X-Emby-Device-Id=ece699cb-abe6-4ffa-98f1-7b81b4c0de40&X-Emby-Client-Version=4.8.1.0&X-Emby-Token=x_secret2_x&X-Emby-Language=en-us&reqformat=json 2024-02-08 20:22:58.053 Info Server: http/1.1 POST http://192.168.1.4:8096/emby/Videos/ActiveEncodings/Delete?deviceId=ece699cb-abe6-4ffa-98f1-7b81b4c0de40&PlaySessionId=913ce158d9304b17813f44be87752631&X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome Windows&X-Emby-Device-Id=ece699cb-abe6-4ffa-98f1-7b81b4c0de40&X-Emby-Client-Version=4.8.1.0&X-Emby-Token=x_secret2_x&X-Emby-Language=en-us. Accept=*/*, Connection=keep-alive, Host=host4, User-Agent=Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/121.0.0.0 Safari/537.36, Accept-Encoding=gzip, deflate, Accept-Language=en-US,en;q=0.9,fr;q=0.8, Origin=host5, Referer=http://192.168.1.4:8096/web/index.html, Content-Length=0 2024-02-08 20:22:58.053 Info Server: http/1.1 Response 204 to 192.168.1.4. Time: 0ms. POST http://192.168.1.4:8096/emby/Videos/ActiveEncodings/Delete?deviceId=ece699cb-abe6-4ffa-98f1-7b81b4c0de40&PlaySessionId=913ce158d9304b17813f44be87752631&X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome Windows&X-Emby-Device-Id=ece699cb-abe6-4ffa-98f1-7b81b4c0de40&X-Emby-Client-Version=4.8.1.0&X-Emby-Token=x_secret2_x&X-Emby-Language=en-us 2024-02-08 20:22:58.059 Info Server: http/1.1 GET http://192.168.1.4:8096/emby/videos/17804842/master.m3u8?DeviceId=ece699cb-abe6-4ffa-98f1-7b81b4c0de40&MediaSourceId=native_57c9a92498ecd5858f960120f6e8a572_f8f181232418314d1bc8239f1eabc416&PlaySessionId=9dd5b00acb5e425ab97d3d5dd800ac74&api_key=x_secret2_x&LiveStreamId=06044cf0e6f93cdae5f285c9ecfaaeb4_01413a525b3a9622ce6fdf19f7dde354_native_57c9a92498ecd5858f960120f6e8a572_f8f181232418314d1bc8239f1eabc416&VideoCodec=h264,h265,hevc,av1&AudioCodec=mp3,aac&VideoBitrate=159808000&AudioBitrate=192000&MaxWidth=3840&TranscodingMaxAudioChannels=2&SegmentContainer=m4s,ts&MinSegments=1&BreakOnNonKeyFrames=True&SubtitleStreamIndexes=-1&ManifestSubtitles=vtt&h264-profile=high,main,baseline,constrainedbaseline,high10&h264-level=62&hevc-codectag=hvc1,hev1,hevc,hdmv&TranscodeReasons=ContainerNotSupported,DirectPlayError&allowVideoStreamCopy=false. Accept=*/*, Connection=keep-alive, Host=host4, User-Agent=Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/121.0.0.0 Safari/537.36, Accept-Encoding=gzip, deflate, Accept-Language=en-US,en;q=0.9,fr;q=0.8, Referer=http://192.168.1.4:8096/web/index.html 2024-02-08 20:22:58.060 Info Server: http/1.1 Response 200 to 192.168.1.4. Time: 1ms. GET http://192.168.1.4:8096/emby/videos/17804842/master.m3u8?DeviceId=ece699cb-abe6-4ffa-98f1-7b81b4c0de40&MediaSourceId=native_57c9a92498ecd5858f960120f6e8a572_f8f181232418314d1bc8239f1eabc416&PlaySessionId=9dd5b00acb5e425ab97d3d5dd800ac74&api_key=x_secret2_x&LiveStreamId=06044cf0e6f93cdae5f285c9ecfaaeb4_01413a525b3a9622ce6fdf19f7dde354_native_57c9a92498ecd5858f960120f6e8a572_f8f181232418314d1bc8239f1eabc416&VideoCodec=h264,h265,hevc,av1&AudioCodec=mp3,aac&VideoBitrate=159808000&AudioBitrate=192000&MaxWidth=3840&TranscodingMaxAudioChannels=2&SegmentContainer=m4s,ts&MinSegments=1&BreakOnNonKeyFrames=True&SubtitleStreamIndexes=-1&ManifestSubtitles=vtt&h264-profile=high,main,baseline,constrainedbaseline,high10&h264-level=62&hevc-codectag=hvc1,hev1,hevc,hdmv&TranscodeReasons=ContainerNotSupported,DirectPlayError&allowVideoStreamCopy=false 2024-02-08 20:22:58.062 Info Server: http/1.1 GET http://192.168.1.4:8096/emby/videos/17804842/live.m3u8?DeviceId=ece699cb-abe6-4ffa-98f1-7b81b4c0de40&MediaSourceId=native_57c9a92498ecd5858f960120f6e8a572_f8f181232418314d1bc8239f1eabc416&PlaySessionId=9dd5b00acb5e425ab97d3d5dd800ac74&api_key=x_secret2_x&LiveStreamId=06044cf0e6f93cdae5f285c9ecfaaeb4_01413a525b3a9622ce6fdf19f7dde354_native_57c9a92498ecd5858f960120f6e8a572_f8f181232418314d1bc8239f1eabc416&VideoCodec=h264,h265,hevc,av1&AudioCodec=mp3,aac&VideoBitrate=159808000&AudioBitrate=192000&MaxWidth=3840&TranscodingMaxAudioChannels=2&SegmentContainer=m4s,ts&MinSegments=1&BreakOnNonKeyFrames=True&SubtitleStreamIndexes=-1&ManifestSubtitles=vtt&h264-profile=high,main,baseline,constrainedbaseline,high10&h264-level=62&hevc-codectag=hvc1,hev1,hevc,hdmv&TranscodeReasons=ContainerNotSupported,DirectPlayError&allowVideoStreamCopy=false. Accept=*/*, Connection=keep-alive, Host=host4, User-Agent=Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/121.0.0.0 Safari/537.36, Accept-Encoding=gzip, deflate, Accept-Language=en-US,en;q=0.9,fr;q=0.8, Referer=http://192.168.1.4:8096/web/index.html 2024-02-08 20:22:58.066 Info App: ProcessRun 'StreamTranscode 290e04' Execute: C:\Emby-server\system\ffmpeg.exe -loglevel +timing -y -print_graphs_file "C:\Emby-server\programdata\logs\ffmpeg-transcode-290e0489-757b-49ac-8bc4-955a256e99c5_1graph.txt" -copyts -start_at_zero -analyzeduration 3000000 -f mpegts -noautorotate -i "http://127.0.0.1:8096/LiveTv/LiveStreamFiles/c285b4599ba54c8192d77278fd354b8a/stream.ts" -filter_complex "[v:0]yadif@f1=mode=send_frame:parity=auto:deint=all,scale@f2=width='trunc(min(max(iw,ih*dar),3840)/2)*2':height=trunc(ow/dar/2)*2,format@f3=pix_fmts=yuv420p[f3_out0]" -map [f3_out0] -map a:0 -sn -c:v:0 libx264 -maxrate:v:0 5000000 -bufsize:v:0 10000000 -pix_fmt:v:0 yuv420p -force_key_frames:v:0 "expr:if(isnan(prev_forced_t),eq(t,t),gte(t,prev_forced_t+3))" -preset:v:0 veryfast -profile:v:0 high -x264opts:v:0 "subme=0:me_range=4:rc_lookahead=10:partitions=none" -crf:v:0 23 -c:a:0 libmp3lame -ab:a:0 192000 -ac:a:0 2 -disposition:a:0 default -fflags +discardcorruptts+fillwallclockdts -max_delay 5000000 -avoid_negative_ts disabled -f segment -map_metadata -1 -map_chapters -1 -segment_format mpegts -segment_list "D:\Recorded TV\TempRec\transcoding-temp\244B78\244B78.m3u8" -segment_list_type m3u8 -segment_time 00:00:03.000 -segment_list_entry_prefix hls/244B78/ -segment_start_number 0 -individual_header_trailer 0 -write_header_trailer 0 -segment_write_temp 1 "D:\Recorded TV\TempRec\transcoding-temp\244B78\244B78_%d.ts" 2024-02-08 20:22:58.143 Info Server: http/1.1 GET http://127.0.0.1:8096/LiveTv/LiveStreamFiles/c285b4599ba54c8192d77278fd354b8a/stream.ts. Accept=*/*, Connection=close, Host=host3, User-Agent=Lavf/59.27.100, Range=bytes=0-, Icy-MetaData=1 2024-02-08 20:22:58.143 Info SharedHttpPipelineSource: Live Stream ended. 2024-02-08 20:22:58.143 Info Server: http/1.1 Response 200 to 127.0.0.1. Time: 0ms. GET http://127.0.0.1:8096/LiveTv/LiveStreamFiles/c285b4599ba54c8192d77278fd354b8a/stream.ts 2024-02-08 20:22:58.149 Info App: AppendExtraLogData - Read graph file: C:\Emby-server\programdata\logs\ffmpeg-transcode-290e0489-757b-49ac-8bc4-955a256e99c5_1graph.txt 2024-02-08 20:22:58.149 Info App: AppendExtraLogData - Deserialized GraphData fileStream: 392.000 bytes Graph Count: 1 2024-02-08 20:22:58.150 Info App: AppendExtraLogData - File Deleted 2024-02-08 20:22:58.150 Info App: ProcessRun 'StreamTranscode 290e04' Process exited with code 1 - Failed 2024-02-08 20:22:58.208 Error Server: Error processing request *** Error Report *** Version: 4.8.1.0 Command line: C:\Emby-server\system\EmbyServer.dll Operating system: Microsoft Windows 10.0.22631 Framework: .NET 6.0.26 OS/Process: x64/x64 Runtime: C:/Emby-server/system/System.Private.CoreLib.dll Processor count: 24 Data path: C:\Emby-server\programdata Application path: C:\Emby-server\system Emby.Server.MediaEncoding.Unified.Ffmpeg.FfRunException: Emby.Server.MediaEncoding.Unified.Ffmpeg.FfRunException: Error starting ffmpeg -loglevel +timing -y -print_graphs_file "C:\Emby-server\programdata\logs\ffmpeg-transcode-290e0489-757b-49ac-8bc4-955a256e99c5_1graph.txt" -copyts -start_at_zero -analyzeduration 3000000 -f mpegts -noautorotate -i "http://127.0.0.1:8096/LiveTv/LiveStreamFiles/c285b4599ba54c8192d77278fd354b8a/stream.ts" -filter_complex "[v:0]yadif@f1=mode=send_frame:parity=auto:deint=all,scale@f2=width='trunc(min(max(iw,ih*dar),3840)/2)*2':height=trunc(ow/dar/2)*2,format@f3=pix_fmts=yuv420p[f3_out0]" -map [f3_out0] -map a:0 -sn -c:v:0 libx264 -maxrate:v:0 5000000 -bufsize:v:0 10000000 -pix_fmt:v:0 yuv420p -force_key_frames:v:0 "expr:if(isnan(prev_forced_t),eq(t,t),gte(t,prev_forced_t+3))" -preset:v:0 veryfast -profile:v:0 high -x264opts:v:0 "subme=0:me_range=4:rc_lookahead=10:partitions=none" -crf:v:0 23 -c:a:0 libmp3lame -ab:a:0 192000 -ac:a:0 2 -disposition:a:0 default -fflags +discardcorruptts+fillwallclockdts -max_delay 5000000 -avoid_negative_ts disabled -f segment -map_metadata -1 -map_chapters -1 -segment_format mpegts -segment_list "D:\Recorded TV\TempRec\transcoding-temp\244B78\244B78.m3u8" -segment_list_type m3u8 -segment_time 00:00:03.000 -segment_list_entry_prefix hls/244B78/ -segment_start_number 0 -individual_header_trailer 0 -write_header_trailer 0 -segment_write_temp 1 "D:\Recorded TV\TempRec\transcoding-temp\244B78\244B78_%d.ts" 20:22:58.111 ffmpeg version 5.1-emby_2023_06_25 Copyright (c) 2000-2022 the FFmpeg developers and softworkz for Emby LLC 20:22:58.112 built with gcc 12.2.0 (Rev10, Built by MSYS2 project) 20:22:58.112 Execution Date: 2024-02-08 20:22:58 20:22:58.144 [mpegts @ 00000163cbddb480] Could not detect TS packet size, defaulting to non-FEC/DVHS 20:22:58.144 Input #0, mpegts, from 'http://127.0.0.1:8096/LiveTv/LiveStreamFiles/c285b4599ba54c8192d77278fd354b8a/stream.ts': 20:22:58.144 Duration: N/A, bitrate: N/A 20:22:58.144 Stream specifier 'v:0' in filtergraph description [v:0]yadif@f1=mode=send_frame:parity=auto:deint=all,scale@f2=width='trunc(min(max(iw,ih*dar),3840)/2)*2':height=trunc(ow/dar/2)*2,format@f3=pix_fmts=yuv420p[f3_out0] matches no streams. 20:22:58.145 EXIT at Emby.Server.MediaEncoding.Api.BaseStreamingService.StartFfMpeg(StreamState state, String outputPath, CancellationToken cancellationToken, Boolean acquireResources) at Emby.Server.MediaEncoding.Api.Hls.BaseHlsService.ProcessRequest(StreamState state, StreamRequest request) at Emby.Server.MediaEncoding.Api.Hls.DynamicHlsService.Get(GetLiveHlsStream request) at Emby.Server.Implementations.Services.ServiceController.GetTaskResult(Task task) at Emby.Server.Implementations.Services.ServiceHandler.ProcessRequestAsync(HttpListenerHost httpHost, IServerApplicationHost appHost, IRequest httpReq, IResponse httpRes, IStreamHelper streamHelper, RestPath restPath, String responseContentType, CancellationToken cancellationToken) at Emby.Server.Implementations.HttpServer.HttpListenerHost.RequestHandler(IRequest httpReq, ReadOnlyMemory`1 urlString, ReadOnlyMemory`1 localPath, CancellationToken cancellationToken) Source: Emby.Server.MediaEncoding TargetSite: Void MoveNext() 2024-02-08 20:22:58.208 Info Server: http/1.1 Response 500 to 192.168.1.4. Time: 146ms. GET http://192.168.1.4:8096/emby/videos/17804842/live.m3u8?DeviceId=ece699cb-abe6-4ffa-98f1-7b81b4c0de40&MediaSourceId=native_57c9a92498ecd5858f960120f6e8a572_f8f181232418314d1bc8239f1eabc416&PlaySessionId=9dd5b00acb5e425ab97d3d5dd800ac74&api_key=x_secret2_x&LiveStreamId=06044cf0e6f93cdae5f285c9ecfaaeb4_01413a525b3a9622ce6fdf19f7dde354_native_57c9a92498ecd5858f960120f6e8a572_f8f181232418314d1bc8239f1eabc416&VideoCodec=h264,h265,hevc,av1&AudioCodec=mp3,aac&VideoBitrate=159808000&AudioBitrate=192000&MaxWidth=3840&TranscodingMaxAudioChannels=2&SegmentContainer=m4s,ts&MinSegments=1&BreakOnNonKeyFrames=True&SubtitleStreamIndexes=-1&ManifestSubtitles=vtt&h264-profile=high,main,baseline,constrainedbaseline,high10&h264-level=62&hevc-codectag=hvc1,hev1,hevc,hdmv&TranscodeReasons=ContainerNotSupported,DirectPlayError&allowVideoStreamCopy=false 2024-02-08 20:22:58.211 Info Server: http/1.1 POST http://192.168.1.4:8096/emby/Videos/ActiveEncodings/Delete?deviceId=ece699cb-abe6-4ffa-98f1-7b81b4c0de40&PlaySessionId=913ce158d9304b17813f44be87752631&X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome Windows&X-Emby-Device-Id=ece699cb-abe6-4ffa-98f1-7b81b4c0de40&X-Emby-Client-Version=4.8.1.0&X-Emby-Token=x_secret2_x&X-Emby-Language=en-us. Accept=*/*, Connection=keep-alive, Host=host4, User-Agent=Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/121.0.0.0 Safari/537.36, Accept-Encoding=gzip, deflate, Accept-Language=en-US,en;q=0.9,fr;q=0.8, Origin=host5, Referer=http://192.168.1.4:8096/web/index.html, Content-Length=0 2024-02-08 20:22:58.212 Info Server: http/1.1 Response 204 to 192.168.1.4. Time: 1ms. POST http://192.168.1.4:8096/emby/Videos/ActiveEncodings/Delete?deviceId=ece699cb-abe6-4ffa-98f1-7b81b4c0de40&PlaySessionId=913ce158d9304b17813f44be87752631&X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome Windows&X-Emby-Device-Id=ece699cb-abe6-4ffa-98f1-7b81b4c0de40&X-Emby-Client-Version=4.8.1.0&X-Emby-Token=x_secret2_x&X-Emby-Language=en-us 2024-02-08 20:22:58.213 Info Server: http/1.1 POST http://192.168.1.4:8096/emby/Items/17804842/PlaybackInfo?UserId=c187086aa78d48339215740cc3bf1cde&StartTimeTicks=0&IsPlayback=true&AutoOpenLiveStream=true&AudioStreamIndex=-1&SubtitleStreamIndex=-1&EnableDirectPlay=false&EnableDirectStream=false&AllowVideoStreamCopy=false&AllowAudioStreamCopy=false&MediaSourceId=native_57c9a92498ecd5858f960120f6e8a572_f8f181232418314d1bc8239f1eabc416&LiveStreamId=06044cf0e6f93cdae5f285c9ecfaaeb4_01413a525b3a9622ce6fdf19f7dde354_native_57c9a92498ecd5858f960120f6e8a572_f8f181232418314d1bc8239f1eabc416&MaxStreamingBitrate=160000000&CurrentPlaySessionId=9dd5b00acb5e425ab97d3d5dd800ac74&X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome Windows&X-Emby-Device-Id=ece699cb-abe6-4ffa-98f1-7b81b4c0de40&X-Emby-Client-Version=4.8.1.0&X-Emby-Token=x_secret2_x&X-Emby-Language=en-us&reqformat=json. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/121.0.0.0 Safari/537.36 2024-02-08 20:22:58.214 Info App: User policy for sward. EnablePlaybackRemuxing: True EnableVideoPlaybackTranscoding: True EnableAudioPlaybackTranscoding: True 2024-02-08 20:22:58.214 Info SessionManager: Removing playSession 9dd5b00acb5e425ab97d3d5dd800ac74 from session c21560fc005e5b7fca081b1a8d99b88d 2024-02-08 20:22:58.214 Info SessionManager: Adding playSession 1ba38ab52b904208b64a2ebc294eef69 to session c21560fc005e5b7fca081b1a8d99b88d 2024-02-08 20:22:58.214 Info Server: http/1.1 Response 200 to 192.168.1.4. Time: 1ms. POST http://192.168.1.4:8096/emby/Items/17804842/PlaybackInfo?UserId=c187086aa78d48339215740cc3bf1cde&StartTimeTicks=0&IsPlayback=true&AutoOpenLiveStream=true&AudioStreamIndex=-1&SubtitleStreamIndex=-1&EnableDirectPlay=false&EnableDirectStream=false&AllowVideoStreamCopy=false&AllowAudioStreamCopy=false&MediaSourceId=native_57c9a92498ecd5858f960120f6e8a572_f8f181232418314d1bc8239f1eabc416&LiveStreamId=06044cf0e6f93cdae5f285c9ecfaaeb4_01413a525b3a9622ce6fdf19f7dde354_native_57c9a92498ecd5858f960120f6e8a572_f8f181232418314d1bc8239f1eabc416&MaxStreamingBitrate=160000000&CurrentPlaySessionId=9dd5b00acb5e425ab97d3d5dd800ac74&X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome Windows&X-Emby-Device-Id=ece699cb-abe6-4ffa-98f1-7b81b4c0de40&X-Emby-Client-Version=4.8.1.0&X-Emby-Token=x_secret2_x&X-Emby-Language=en-us&reqformat=json 2024-02-08 20:22:58.216 Info Server: http/1.1 POST http://192.168.1.4:8096/emby/Videos/ActiveEncodings/Delete?deviceId=ece699cb-abe6-4ffa-98f1-7b81b4c0de40&PlaySessionId=9dd5b00acb5e425ab97d3d5dd800ac74&X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome Windows&X-Emby-Device-Id=ece699cb-abe6-4ffa-98f1-7b81b4c0de40&X-Emby-Client-Version=4.8.1.0&X-Emby-Token=x_secret2_x&X-Emby-Language=en-us. Accept=*/*, Connection=keep-alive, Host=host4, User-Agent=Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/121.0.0.0 Safari/537.36, Accept-Encoding=gzip, deflate, Accept-Language=en-US,en;q=0.9,fr;q=0.8, Origin=host5, Referer=http://192.168.1.4:8096/web/index.html, Content-Length=0 2024-02-08 20:22:58.216 Info Server: http/1.1 Response 204 to 192.168.1.4. Time: 0ms. POST http://192.168.1.4:8096/emby/Videos/ActiveEncodings/Delete?deviceId=ece699cb-abe6-4ffa-98f1-7b81b4c0de40&PlaySessionId=9dd5b00acb5e425ab97d3d5dd800ac74&X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome Windows&X-Emby-Device-Id=ece699cb-abe6-4ffa-98f1-7b81b4c0de40&X-Emby-Client-Version=4.8.1.0&X-Emby-Token=x_secret2_x&X-Emby-Language=en-us 2024-02-08 20:22:58.221 Info Server: http/1.1 GET http://192.168.1.4:8096/emby/videos/17804842/master.m3u8?DeviceId=ece699cb-abe6-4ffa-98f1-7b81b4c0de40&MediaSourceId=native_57c9a92498ecd5858f960120f6e8a572_f8f181232418314d1bc8239f1eabc416&PlaySessionId=1ba38ab52b904208b64a2ebc294eef69&api_key=x_secret2_x&LiveStreamId=06044cf0e6f93cdae5f285c9ecfaaeb4_01413a525b3a9622ce6fdf19f7dde354_native_57c9a92498ecd5858f960120f6e8a572_f8f181232418314d1bc8239f1eabc416&VideoCodec=h264,h265,hevc,av1&AudioCodec=mp3,aac&VideoBitrate=159808000&AudioBitrate=192000&MaxWidth=3840&TranscodingMaxAudioChannels=2&SegmentContainer=m4s,ts&MinSegments=1&BreakOnNonKeyFrames=True&SubtitleStreamIndexes=-1&ManifestSubtitles=vtt&h264-profile=high,main,baseline,constrainedbaseline,high10&h264-level=62&hevc-codectag=hvc1,hev1,hevc,hdmv&TranscodeReasons=ContainerNotSupported,DirectPlayError&allowVideoStreamCopy=false&allowAudioStreamCopy=false. Accept=*/*, Connection=keep-alive, Host=host4, User-Agent=Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/121.0.0.0 Safari/537.36, Accept-Encoding=gzip, deflate, Accept-Language=en-US,en;q=0.9,fr;q=0.8, Referer=http://192.168.1.4:8096/web/index.html 2024-02-08 20:22:58.221 Info Server: http/1.1 Response 200 to 192.168.1.4. Time: 1ms. GET http://192.168.1.4:8096/emby/videos/17804842/master.m3u8?DeviceId=ece699cb-abe6-4ffa-98f1-7b81b4c0de40&MediaSourceId=native_57c9a92498ecd5858f960120f6e8a572_f8f181232418314d1bc8239f1eabc416&PlaySessionId=1ba38ab52b904208b64a2ebc294eef69&api_key=x_secret2_x&LiveStreamId=06044cf0e6f93cdae5f285c9ecfaaeb4_01413a525b3a9622ce6fdf19f7dde354_native_57c9a92498ecd5858f960120f6e8a572_f8f181232418314d1bc8239f1eabc416&VideoCodec=h264,h265,hevc,av1&AudioCodec=mp3,aac&VideoBitrate=159808000&AudioBitrate=192000&MaxWidth=3840&TranscodingMaxAudioChannels=2&SegmentContainer=m4s,ts&MinSegments=1&BreakOnNonKeyFrames=True&SubtitleStreamIndexes=-1&ManifestSubtitles=vtt&h264-profile=high,main,baseline,constrainedbaseline,high10&h264-level=62&hevc-codectag=hvc1,hev1,hevc,hdmv&TranscodeReasons=ContainerNotSupported,DirectPlayError&allowVideoStreamCopy=false&allowAudioStreamCopy=false 2024-02-08 20:22:58.225 Info Server: http/1.1 GET http://192.168.1.4:8096/emby/videos/17804842/live.m3u8?DeviceId=ece699cb-abe6-4ffa-98f1-7b81b4c0de40&MediaSourceId=native_57c9a92498ecd5858f960120f6e8a572_f8f181232418314d1bc8239f1eabc416&PlaySessionId=1ba38ab52b904208b64a2ebc294eef69&api_key=x_secret2_x&LiveStreamId=06044cf0e6f93cdae5f285c9ecfaaeb4_01413a525b3a9622ce6fdf19f7dde354_native_57c9a92498ecd5858f960120f6e8a572_f8f181232418314d1bc8239f1eabc416&VideoCodec=h264,h265,hevc,av1&AudioCodec=mp3,aac&VideoBitrate=159808000&AudioBitrate=192000&MaxWidth=3840&TranscodingMaxAudioChannels=2&SegmentContainer=m4s,ts&MinSegments=1&BreakOnNonKeyFrames=True&SubtitleStreamIndexes=-1&ManifestSubtitles=vtt&h264-profile=high,main,baseline,constrainedbaseline,high10&h264-level=62&hevc-codectag=hvc1,hev1,hevc,hdmv&TranscodeReasons=ContainerNotSupported,DirectPlayError&allowVideoStreamCopy=false&allowAudioStreamCopy=false. Accept=*/*, Connection=keep-alive, Host=host4, User-Agent=Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/121.0.0.0 Safari/537.36, Accept-Encoding=gzip, deflate, Accept-Language=en-US,en;q=0.9,fr;q=0.8, Referer=http://192.168.1.4:8096/web/index.html 2024-02-08 20:22:58.230 Info App: ProcessRun 'StreamTranscode f5d0ec' Execute: C:\Emby-server\system\ffmpeg.exe -loglevel +timing -y -print_graphs_file "C:\Emby-server\programdata\logs\ffmpeg-transcode-f5d0ec6a-56a7-4193-b18f-0e3e5ca36dcd_1graph.txt" -copyts -start_at_zero -analyzeduration 3000000 -f mpegts -noautorotate -i "http://127.0.0.1:8096/LiveTv/LiveStreamFiles/c285b4599ba54c8192d77278fd354b8a/stream.ts" -filter_complex "[v:0]yadif@f1=mode=send_frame:parity=auto:deint=all,scale@f2=width='trunc(min(max(iw,ih*dar),3840)/2)*2':height=trunc(ow/dar/2)*2,format@f3=pix_fmts=yuv420p[f3_out0]" -map [f3_out0] -map a:0 -sn -c:v:0 libx264 -maxrate:v:0 5000000 -bufsize:v:0 10000000 -pix_fmt:v:0 yuv420p -force_key_frames:v:0 "expr:if(isnan(prev_forced_t),eq(t,t),gte(t,prev_forced_t+3))" -preset:v:0 veryfast -profile:v:0 high -x264opts:v:0 "subme=0:me_range=4:rc_lookahead=10:partitions=none" -crf:v:0 23 -c:a:0 libmp3lame -ab:a:0 192000 -ac:a:0 2 -disposition:a:0 default -fflags +discardcorruptts+fillwallclockdts -max_delay 5000000 -avoid_negative_ts disabled -f segment -map_metadata -1 -map_chapters -1 -segment_format mpegts -segment_list "D:\Recorded TV\TempRec\transcoding-temp\99EAC9\99EAC9.m3u8" -segment_list_type m3u8 -segment_time 00:00:03.000 -segment_list_entry_prefix hls/99EAC9/ -segment_start_number 0 -individual_header_trailer 0 -write_header_trailer 0 -segment_write_temp 1 "D:\Recorded TV\TempRec\transcoding-temp\99EAC9\99EAC9_%d.ts" 2024-02-08 20:22:58.282 Info Server: http/1.1 GET http://127.0.0.1:8096/LiveTv/LiveStreamFiles/c285b4599ba54c8192d77278fd354b8a/stream.ts. Accept=*/*, Connection=close, Host=host3, User-Agent=Lavf/59.27.100, Range=bytes=0-, Icy-MetaData=1 2024-02-08 20:22:58.282 Info SharedHttpPipelineSource: Live Stream ended. 2024-02-08 20:22:58.282 Info Server: http/1.1 Response 200 to 127.0.0.1. Time: 0ms. GET http://127.0.0.1:8096/LiveTv/LiveStreamFiles/c285b4599ba54c8192d77278fd354b8a/stream.ts 2024-02-08 20:22:58.288 Info App: AppendExtraLogData - Read graph file: C:\Emby-server\programdata\logs\ffmpeg-transcode-f5d0ec6a-56a7-4193-b18f-0e3e5ca36dcd_1graph.txt 2024-02-08 20:22:58.288 Info App: AppendExtraLogData - Deserialized GraphData fileStream: 392.000 bytes Graph Count: 1 2024-02-08 20:22:58.289 Info App: AppendExtraLogData - File Deleted 2024-02-08 20:22:58.289 Info App: ProcessRun 'StreamTranscode f5d0ec' Process exited with code 1 - Failed 2024-02-08 20:22:58.302 Error Server: Error processing request *** Error Report *** Version: 4.8.1.0 Command line: C:\Emby-server\system\EmbyServer.dll Operating system: Microsoft Windows 10.0.22631 Framework: .NET 6.0.26 OS/Process: x64/x64 Runtime: C:/Emby-server/system/System.Private.CoreLib.dll Processor count: 24 Data path: C:\Emby-server\programdata Application path: C:\Emby-server\system Emby.Server.MediaEncoding.Unified.Ffmpeg.FfRunException: Emby.Server.MediaEncoding.Unified.Ffmpeg.FfRunException: Error starting ffmpeg -loglevel +timing -y -print_graphs_file "C:\Emby-server\programdata\logs\ffmpeg-transcode-f5d0ec6a-56a7-4193-b18f-0e3e5ca36dcd_1graph.txt" -copyts -start_at_zero -analyzeduration 3000000 -f mpegts -noautorotate -i "http://127.0.0.1:8096/LiveTv/LiveStreamFiles/c285b4599ba54c8192d77278fd354b8a/stream.ts" -filter_complex "[v:0]yadif@f1=mode=send_frame:parity=auto:deint=all,scale@f2=width='trunc(min(max(iw,ih*dar),3840)/2)*2':height=trunc(ow/dar/2)*2,format@f3=pix_fmts=yuv420p[f3_out0]" -map [f3_out0] -map a:0 -sn -c:v:0 libx264 -maxrate:v:0 5000000 -bufsize:v:0 10000000 -pix_fmt:v:0 yuv420p -force_key_frames:v:0 "expr:if(isnan(prev_forced_t),eq(t,t),gte(t,prev_forced_t+3))" -preset:v:0 veryfast -profile:v:0 high -x264opts:v:0 "subme=0:me_range=4:rc_lookahead=10:partitions=none" -crf:v:0 23 -c:a:0 libmp3lame -ab:a:0 192000 -ac:a:0 2 -disposition:a:0 default -fflags +discardcorruptts+fillwallclockdts -max_delay 5000000 -avoid_negative_ts disabled -f segment -map_metadata -1 -map_chapters -1 -segment_format mpegts -segment_list "D:\Recorded TV\TempRec\transcoding-temp\99EAC9\99EAC9.m3u8" -segment_list_type m3u8 -segment_time 00:00:03.000 -segment_list_entry_prefix hls/99EAC9/ -segment_start_number 0 -individual_header_trailer 0 -write_header_trailer 0 -segment_write_temp 1 "D:\Recorded TV\TempRec\transcoding-temp\99EAC9\99EAC9_%d.ts" 20:22:58.275 ffmpeg version 5.1-emby_2023_06_25 Copyright (c) 2000-2022 the FFmpeg developers and softworkz for Emby LLC 20:22:58.276 built with gcc 12.2.0 (Rev10, Built by MSYS2 project) 20:22:58.276 Execution Date: 2024-02-08 20:22:58 20:22:58.283 [mpegts @ 0000027847c9b480] Could not detect TS packet size, defaulting to non-FEC/DVHS 20:22:58.283 Input #0, mpegts, from 'http://127.0.0.1:8096/LiveTv/LiveStreamFiles/c285b4599ba54c8192d77278fd354b8a/stream.ts': 20:22:58.283 Duration: N/A, bitrate: N/A 20:22:58.283 Stream specifier 'v:0' in filtergraph description [v:0]yadif@f1=mode=send_frame:parity=auto:deint=all,scale@f2=width='trunc(min(max(iw,ih*dar),3840)/2)*2':height=trunc(ow/dar/2)*2,format@f3=pix_fmts=yuv420p[f3_out0] matches no streams. 20:22:58.284 EXIT at Emby.Server.MediaEncoding.Api.BaseStreamingService.StartFfMpeg(StreamState state, String outputPath, CancellationToken cancellationToken, Boolean acquireResources) at Emby.Server.MediaEncoding.Api.Hls.BaseHlsService.ProcessRequest(StreamState state, StreamRequest request) at Emby.Server.MediaEncoding.Api.Hls.DynamicHlsService.Get(GetLiveHlsStream request) at Emby.Server.Implementations.Services.ServiceController.GetTaskResult(Task task) at Emby.Server.Implementations.Services.ServiceHandler.ProcessRequestAsync(HttpListenerHost httpHost, IServerApplicationHost appHost, IRequest httpReq, IResponse httpRes, IStreamHelper streamHelper, RestPath restPath, String responseContentType, CancellationToken cancellationToken) at Emby.Server.Implementations.HttpServer.HttpListenerHost.RequestHandler(IRequest httpReq, ReadOnlyMemory`1 urlString, ReadOnlyMemory`1 localPath, CancellationToken cancellationToken) Source: Emby.Server.MediaEncoding TargetSite: Void MoveNext() 2024-02-08 20:22:58.302 Info Server: http/1.1 Response 500 to 192.168.1.4. Time: 77ms. GET http://192.168.1.4:8096/emby/videos/17804842/live.m3u8?DeviceId=ece699cb-abe6-4ffa-98f1-7b81b4c0de40&MediaSourceId=native_57c9a92498ecd5858f960120f6e8a572_f8f181232418314d1bc8239f1eabc416&PlaySessionId=1ba38ab52b904208b64a2ebc294eef69&api_key=x_secret2_x&LiveStreamId=06044cf0e6f93cdae5f285c9ecfaaeb4_01413a525b3a9622ce6fdf19f7dde354_native_57c9a92498ecd5858f960120f6e8a572_f8f181232418314d1bc8239f1eabc416&VideoCodec=h264,h265,hevc,av1&AudioCodec=mp3,aac&VideoBitrate=159808000&AudioBitrate=192000&MaxWidth=3840&TranscodingMaxAudioChannels=2&SegmentContainer=m4s,ts&MinSegments=1&BreakOnNonKeyFrames=True&SubtitleStreamIndexes=-1&ManifestSubtitles=vtt&h264-profile=high,main,baseline,constrainedbaseline,high10&h264-level=62&hevc-codectag=hvc1,hev1,hevc,hdmv&TranscodeReasons=ContainerNotSupported,DirectPlayError&allowVideoStreamCopy=false&allowAudioStreamCopy=false 2024-02-08 20:22:58.305 Info Server: http/1.1 POST http://192.168.1.4:8096/emby/Videos/ActiveEncodings/Delete?deviceId=ece699cb-abe6-4ffa-98f1-7b81b4c0de40&PlaySessionId=9dd5b00acb5e425ab97d3d5dd800ac74&X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome Windows&X-Emby-Device-Id=ece699cb-abe6-4ffa-98f1-7b81b4c0de40&X-Emby-Client-Version=4.8.1.0&X-Emby-Token=x_secret2_x&X-Emby-Language=en-us. Accept=*/*, Connection=keep-alive, Host=host4, User-Agent=Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/121.0.0.0 Safari/537.36, Accept-Encoding=gzip, deflate, Accept-Language=en-US,en;q=0.9,fr;q=0.8, Origin=host5, Referer=http://192.168.1.4:8096/web/index.html, Content-Length=0 2024-02-08 20:22:58.305 Info Server: http/1.1 Response 204 to 192.168.1.4. Time: 0ms. POST http://192.168.1.4:8096/emby/Videos/ActiveEncodings/Delete?deviceId=ece699cb-abe6-4ffa-98f1-7b81b4c0de40&PlaySessionId=9dd5b00acb5e425ab97d3d5dd800ac74&X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome Windows&X-Emby-Device-Id=ece699cb-abe6-4ffa-98f1-7b81b4c0de40&X-Emby-Client-Version=4.8.1.0&X-Emby-Token=x_secret2_x&X-Emby-Language=en-us 2024-02-08 20:22:58.305 Info Server: http/1.1 POST http://192.168.1.4:8096/emby/Sessions/Playing/Stopped?X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome Windows&X-Emby-Device-Id=ece699cb-abe6-4ffa-98f1-7b81b4c0de40&X-Emby-Client-Version=4.8.1.0&X-Emby-Token=x_secret2_x&X-Emby-Language=en-us&reqformat=json. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/121.0.0.0 Safari/537.36 2024-02-08 20:22:58.306 Info SessionManager: Playback stopped reported by app Emby Web 4.8.1.0 on Chrome Windows playing CNN HD. Stopped at 0 ms 2024-02-08 20:22:58.306 Info MediaSourceManager: Live stream native_57c9a92498ecd5858f960120f6e8a572_f8f181232418314d1bc8239f1eabc416 consumer count is now 0 2024-02-08 20:22:58.306 Info MediaSourceManager: Closing live stream 06044cf0e6f93cdae5f285c9ecfaaeb4_01413a525b3a9622ce6fdf19f7dde354_native_57c9a92498ecd5858f960120f6e8a572_f8f181232418314d1bc8239f1eabc416 2024-02-08 20:22:58.306 Info SharedHttpPipelineSource: Closing SharedHttpPipelineSource 2024-02-08 20:22:58.306 Info SharedHttpPipelineSource: Deleting temp files 2024-02-08 20:22:58.307 Info SharedHttpPipelineSource: SharedHttpPipelineSource is done streaming. 2024-02-08 20:22:58.307 Info MediaSourceManager: Live stream 06044cf0e6f93cdae5f285c9ecfaaeb4_01413a525b3a9622ce6fdf19f7dde354_native_57c9a92498ecd5858f960120f6e8a572_f8f181232418314d1bc8239f1eabc416 closed successfully 2024-02-08 20:22:58.307 Info SessionManager: Removing playSession 1ba38ab52b904208b64a2ebc294eef69 from session c21560fc005e5b7fca081b1a8d99b88d 2024-02-08 20:22:58.307 Info Server: http/1.1 Response 204 to 192.168.1.4. Time: 2ms. POST http://192.168.1.4:8096/emby/Sessions/Playing/Stopped?X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome Windows&X-Emby-Device-Id=ece699cb-abe6-4ffa-98f1-7b81b4c0de40&X-Emby-Client-Version=4.8.1.0&X-Emby-Token=x_secret2_x&X-Emby-Language=en-us&reqformat=json embyserver.txt
sward 28 Posted February 9, 2024 Author Posted February 9, 2024 After noticing what look like transcoding errors in the logs I just shared, I tried disabling "Allow Hardware Transcoding" on the Ceton tuner, and suddenly I was able to launch live streams from multiple channels, although it wasn't 100% consistent. I then enabled all the hardware acceleration options under the Transcoding menu (which I had never explored before), which included both QuickSync and DX11VA for Intel UHD Graphics 770. Now I was able to consistently and repeatedly launch live streams of all channels. I was furthermore able to go back and re-enable "Allow Hardware Transcoding" on the Ceton tuner without affecting stability. I'm attaching a couple of logs of all this testing in case it helps. Before declaring victory I will need to test this some more particularly with some recordings, but this is a huge improvement. I've noticed an increase in CPU usage which is now in the 8-10% range as I assume it transcodes on my CPU, whereas before CPU utilization was 1-3% as I'm assuming it was using the Ceton. Has something changed in 4.8.1 in terms of how transcoding takes place? transcoding.txt ffmpeg-transcode-32b5c928-7c8e-4de3-aab0-c5f4fa8cc62a_1.txt 1
Luke 42241 Posted February 9, 2024 Posted February 9, 2024 Does cetonproxy actually have a transcoding feature? Because if not then that setting makes no difference.
Ronstang 294 Posted February 10, 2024 Posted February 10, 2024 12 hours ago, Luke said: Does cetonproxy actually have a transcoding feature? Because if not then that setting makes no difference. No, it simply acts as a link between the tuner and the application that doesn't have native support for Ceton cards. The Ceton is a network tuner so although it has an IP address the proxy listens on the IP of the computer it is installed in for tuner calls. The biggest problem is you take a double network resource hit from my testing, once for the proxy and once for the actual stream.
sward 28 Posted February 10, 2024 Author Posted February 10, 2024 The CetonProxy SW makes the Ceton look like an HDHomeRun tuner, so maybe the Ceton can't transcode in HW but the HDHomeRun can, I don't really know but I observed that with ""Allow Hardware Transcoding" enabled I can only stream live TV to the web app, whereas with it disabled I can stream to both the web app and Emby Theater. Recall that I can't launch ANY live streams without enabling the hardware acceleration options under the Transcoding menu, which include both QuickSync and DX11VA for my Intel UHD Graphics 770. Unfortunately I don't use Emby to watch live TV, but to record shows, as it's my DVR, and with Emby 4.8.1 it's not recording ANY Ceton-based shows despite the following: - I can now launch live TV channels through both the web app and Emby Theater - I can launch a manual recording of a live TV show that I'm currently watching, and yet a scheduled recording of the same show cannot launch The attached log shows that I scheduled DraftKings to launch at 8AM which failed, but later on I was able to launch a live stream of DraftKings both through the web app and Emby Theater, and finally that I was able to launch a manual recording of DraftKings while watching it. What's so different between a manual recording and a scheduled recording, that one succeeds while the other fails? Not sure there's more that I can do, but I'm willing to conduct additional testing and provide logs if it helps you track down this bizarre discrepancy. I've brought this to the 1 yard line, but I cannot get it into the endzone without your assistance. DraftKings.txt
Luke 42241 Posted February 11, 2024 Posted February 11, 2024 16 hours ago, sward said: The CetonProxy SW makes the Ceton look like an HDHomeRun tuner, so maybe the Ceton can't transcode in HW but the HDHomeRun can, I don't really know but I observed that with ""Allow Hardware Transcoding" enabled I can only stream live TV to the web app, whereas with it disabled I can stream to both the web app and Emby Theater. Recall that I can't launch ANY live streams without enabling the hardware acceleration options under the Transcoding menu, which include both QuickSync and DX11VA for my Intel UHD Graphics 770. Unfortunately I don't use Emby to watch live TV, but to record shows, as it's my DVR, and with Emby 4.8.1 it's not recording ANY Ceton-based shows despite the following: - I can now launch live TV channels through both the web app and Emby Theater - I can launch a manual recording of a live TV show that I'm currently watching, and yet a scheduled recording of the same show cannot launch The attached log shows that I scheduled DraftKings to launch at 8AM which failed, but later on I was able to launch a live stream of DraftKings both through the web app and Emby Theater, and finally that I was able to launch a manual recording of DraftKings while watching it. What's so different between a manual recording and a scheduled recording, that one succeeds while the other fails? Not sure there's more that I can do, but I'm willing to conduct additional testing and provide logs if it helps you track down this bizarre discrepancy. I've brought this to the 1 yard line, but I cannot get it into the endzone without your assistance. DraftKings.txt 976.54 kB · 0 downloads OK I think I see the issue here. Thanks.
sward 28 Posted February 14, 2024 Author Posted February 14, 2024 Luke - were you planning to release a fix? I haven't heard anything in a few days now.
sward 28 Posted February 14, 2024 Author Posted February 14, 2024 I would appreciate some kind of feedback before I start making changes to my system that are difficult to reverse. When I hear nothing I am forced to assume the worst, as in "there is no fix coming."
Luke 42241 Posted February 14, 2024 Posted February 14, 2024 OK I did find an issue where if a stream takes more than a few seconds to open, the server will end up closing it instead of waiting. So that's resolved in 4.8.2.
