Solution Rudolphie 2 Posted December 11, 2023 Author Solution Posted December 11, 2023 Sorry for the late reply, but I was away for the weekend. In the meantime I have made the adjustments and it works! I only entered Dutch and Netherlands in the libraries tab, "advanced". So In summary : In the library tab " advanced": "desired metadata language" "Language" Dutch "Country" Netherlands In the library folder : "desired metadata download language " all fields are left blank. " country" all fields are left blank. "desired download language for images": all fields are left blank. In the movie itself "change metadata" "desired metadata download language " all fields are left blank. " country" all fields are left blank. "lock this item...." unchecked Everything works fine now! To everyone who helped, many thanks for your time and patience! 1
Dibbes 515 Posted February 13, 2024 Posted February 13, 2024 On 12/9/2023 at 7:22 PM, Luke said: I wouldn't change the language settings per film because that's going to get very tedious. I would just leave it blank there and then change it using the library options. As grimpreaper has mentioned, it seems moviedb has the most data available with nl-NL. I've been playing around with this quite a bit over the last two weeks or so, but, while there is some metadata in NL-NL on the sites that the metadata plugins use, it's about 60% at max, the rest will be downloaded in English... For the users that want a closer to 100% experience, a plugin for the moviemeter.nl api would have to be written...
