MarioPerathoner 0 Posted December 5, 2023 Posted December 5, 2023 I have installed Elby on a Dreambox 920. When playing a movie, the pause and stop buttons do not work. Can somebody help?
Luke 42245 Posted December 5, 2023 Posted December 5, 2023 Hi there, how did you install Emby Server on this? What Emby app are you playing from?
MarioPerathoner 0 Posted December 5, 2023 Author Posted December 5, 2023 Hi Luke, thanks for the response. I installed the server from the Boxpirates Forum via Console. The app is named Emby Dream. The only thing that does not work is that the played movie does not react if I press the pause, start or stop button - instead, in the right upper corner a icon is displayed that these buttons cannot be used. Playing the same movie with different players work without any probles. Greeting from Austria. Mario
Luke 42245 Posted December 6, 2023 Posted December 6, 2023 What buttons are you referring to exactly? Are they on screen? Are you using the Emby web app?
pünktchen 1411 Posted December 6, 2023 Posted December 6, 2023 2 hours ago, Luke said: Are you using the Emby web app? He's talking about an app named "Emby Dream" that someone has developed for linux based Set-Top-Boxes. Maybe you remember this:
pünktchen 1411 Posted December 6, 2023 Posted December 6, 2023 @MarioPerathonerif you have problems with Emby Dream then you should ask for help in the Boxpirates forum, because that app isn't developed by Emby.
