Guest PutzJimmy Posted December 4, 2023 Posted December 4, 2023 Server 4.8.0.61 Android Tv 2.0.98g & 2.0.99g On several different android tv devices we are unable to connect to my emby server using synology's reverse proxy with a valid certificate. Works perfectly on every other app, browser we tried so far. Had no problems with the same setup on Jellyfin. When you get to the first screen in Emby and hit skip and enter ip adress, enter in the correct info and hit ok you go back to the first screen again with no errors at all so i have no clue what is wrong.
ebr 16337 Posted December 4, 2023 Posted December 4, 2023 3 hours ago, Guest PutzJimmy said: enter in the correct info Hi. Exactly what are you entering? 3 hours ago, Guest PutzJimmy said: you go back to the first screen again Is there a "Send Logs" button on that screen?
PutzJimmy 6 Posted December 5, 2023 Posted December 5, 2023 Fake adress here but thats how we enter it, exactly as we do in web or ios/android apps https://media.something.myds.me 443 Nope after entering the server info it just goes back to that first screen with no errors which is super annoying IMG_20231204_195325.HEIC IMG_20231204_195317.HEIC
ebr 16337 Posted December 6, 2023 Posted December 6, 2023 How long have you waited after entering that address? Try waiting about 60 seconds (watch for any messages) then hit the cancel button. Does that give you a screen with a "Send Logs" button on it?
PutzJimmy 6 Posted December 6, 2023 Posted December 6, 2023 We have and there is no "connecting" you can click cancel on or anything that would indicate its doing something, it just goes back to that first screen. Clicking cancel there just exits Emby.
PutzJimmy 6 Posted December 8, 2023 Posted December 8, 2023 2x Nvidia Shield no problems. 1x "Boxer" tv channel providers android box no problems. 2x Mi box 4 gen 2 no problems. 3x Mi box 3 no luck 4x Mi box 4 gen 1 no luck 3x TCL tv's no luck Tested some more, funny thing is Emby android phone app has no problems so far nor has casting to the devices that cant get into the app No one has seen a error yet
ebr 16337 Posted December 8, 2023 Posted December 8, 2023 Have you tried testing with http to see if this is those devices refusing to accept the cert?
PutzJimmy 6 Posted December 8, 2023 Posted December 8, 2023 Exactly the same thing happens with http and we also tried setting the port to 0, 00, 000 from a forum post I saw, still just goes to the first screen with zero errors/info on whats going on
GrimReaper 4898 Posted December 8, 2023 Posted December 8, 2023 18 minutes ago, PutzJimmy said: we also tried setting the port to 0, 00, 000 from a forum post I saw Could you pls post a link to that post?
PutzJimmy 6 Posted December 8, 2023 Posted December 8, 2023 Cant find that post and i don't remember who wrote that either, but the idea was that setting the port to "null" would use 443 anyway from the https or something like that. But it didn't do anything different then entering it correctly
speechles 2062 Posted December 8, 2023 Posted December 8, 2023 44 minutes ago, GrimReaper said: Could you pls post a link to that post? 30 minutes ago, PutzJimmy said: Cant find that post and i don't remember who wrote that either, but the idea was that setting the port to "null" would use 443 anyway from the https or something like that. But it didn't do anything different then entering it correctly This is that post. But it was in regards to the Roku where to use an empty port the value must equate to zero. We will be improving this so you can also just leave it blank. 1
PutzJimmy 6 Posted December 8, 2023 Posted December 8, 2023 Yes that's the one! Yeh I tried it anyway, cant hurt and this is so odd and really annoying with no errors to go on, and that some devices work and some dont driving me nuts
PutzJimmy 6 Posted December 9, 2023 Posted December 9, 2023 Tried a hard reset on one mi box now, no luck
ebr 16337 Posted December 9, 2023 Posted December 9, 2023 Hi. Can you try sideloading our standard android app on the same device and see how that compares? https://emby.media/emby-for-android.html Thanks.
PutzJimmy 6 Posted December 9, 2023 Posted December 9, 2023 (edited) That one connected instantly on two not working devices and casting to all of them works so it has to be something wrong with the android tv app Edited December 9, 2023 by PutzJimmy
Luke 42244 Posted December 10, 2023 Posted December 10, 2023 On 12/9/2023 at 4:03 PM, PutzJimmy said: That one connected instantly on two not working devices and casting to all of them works so it has to be something wrong with the android tv app HI, thanks for confirming. Are you happy continuing to use that? It fully supports TV devices.
PutzJimmy 6 Posted December 11, 2023 Posted December 11, 2023 Well casting sucks both for users and for server that constantly have to do unnecessary transcodes. The Android app I don't mind who knows how to do it, my family & friends tho is a different story
Luke 42244 Posted December 11, 2023 Posted December 11, 2023 We are working on getting it into the store for TV devices, so that will make it easier for your friends and family to install.
PutzJimmy 6 Posted December 11, 2023 Posted December 11, 2023 That would be great, any estimated time frame on that?
PutzJimmy 6 Posted December 19, 2023 Posted December 19, 2023 (edited) Two users on boxes that didn't work with the Android Tv app but now works with the Android phone app is now getting this trying to play anything, trailers do play tho and everything works on phones and windows emby player at their place Edited December 19, 2023 by PutzJimmy
Luke 42244 Posted December 19, 2023 Posted December 19, 2023 @PutzJimmy Hi there, let's look at an example. Please attach the information requested in how to report a media playback issue. Thanks!
PutzJimmy 6 Posted December 22, 2023 Posted December 22, 2023 (edited) I went threw all the menus there is no "Debug Options". This is what server logs show https://pastebin.com/Ti1DG0SV the "Android 9; MIBOX3" IMG_20231222_071101.HEIC IMG_20231222_071050.HEIC Edited December 22, 2023 by PutzJimmy
Luke 42244 Posted December 26, 2023 Posted December 26, 2023 On 12/22/2023 at 1:35 AM, PutzJimmy said: I went threw all the menus there is no "Debug Options". This is what server logs show https://pastebin.com/Ti1DG0SV the "Android 9; MIBOX3" IMG_20231222_071101.HEIC 988.57 kB · 1 download IMG_20231222_071050.HEIC 640.6 kB · 0 downloads @PutzJimmycan you please attach the complete emby server log? Also was an ffmpeg log generated? Please attach that as well. Thanks.
PutzJimmy 6 Posted December 26, 2023 Posted December 26, 2023 (edited) All it generated was the embyserver.txt and hardware_detection-63839204230.txt https://pastebin.com/Y3Fi2Gia but here you have what happens when we tried from a mi box 3 and 4. Was at my sister over the Christmas "God Jul " and was able to experiment around myself and found that her LG webOS tv had the Emby app but it had the same problem as the Android Tv app, would not connect to server whatsoever. Her Android Phones, Android tablets, web browsers, Windows Emby app and casting to her mi box 4 works "crappy as fuck tho ala chromecast " but the Android phone app on mi box wont play anything no matter what settings ive tried Edited December 26, 2023 by PutzJimmy
