lyphix 0 Posted December 3, 2023 Posted December 3, 2023 Hi guys, I am having trouble with the hardware acceleration in docker. I'm using the integrated graphics card of the Intel N100 and the system is Ubuntu server 22.04 LTS. My emby is 4.7.14.0 With the commands: getent group video | cut -d: -f3, I got 44 getent group render | cut -d: -f3, I got 109 So Here is my docker compose: emby: image: emby/embyserver:latest container_name: emby environment: - UID=1000 - GID=100 - GIDLIST=44,109 - TZ=Asia/Shanghai volumes: - /root/emby/config:/config - /root/emby/cache:/cache - /root/media:/media devices: - /dev/dri:/dev/dri ports: - 8096:8096 restart: unless-stopped After emby started, I found several errors in hardware_detection: Devices": [ { "DeviceIndex": 0, "DeviceInfo": { "VendorName": "Intel Corporation", "DeviceName": "Alder Lake-N [UHD Graphics]", "SubsytemVendorName": "Intel Corporation", "VendorId": 32902, "DeviceId": 18129, "SubsytemVendorId": 32902, "SubsytemDeviceId": 29296, "DevPath": "/sys/bus/pci/devices/0000:00:02.0", "DrmCard": "/dev/dri/card0", "DrmRender": "/dev/dri/renderD128", "IsEnabled": 1, "IsBootVga": 1, "Error": { "Number": -1, "Message": "Failed to initialize VA /dev/dri/renderD128. Error -1" } } } ], I also tried: ffmpeg -hwaccel vaapi -hwaccel_output_format vaapi -i input.mp4 -vf 'format=nv12|vaapi,hwupload' -c:v h264_vaapi output_VAAPI.mp4 It works in Ubuntu but not in Docker: Could you give me any advice? hardware_detection-63837216517.txt
Solution Luke 42244 Posted December 5, 2023 Solution Posted December 5, 2023 Hi, are you able to try the 4.8 beta server and see how that compares? Thanks.
alturismo 37 Posted January 21, 2024 Posted January 21, 2024 On 12/5/2023 at 7:53 PM, Luke said: Hi, are you able to try the 4.8 beta server and see how that compares? Thanks. i can confirm, updating to the beta solved here the issue with an n100 1
