Peter Nent 71 Posted December 2, 2023 Posted December 2, 2023 Choosing (pressing the button) EPG during live-TV gives always channel-1 (=the first channel) instead of the current channel.....as the current channel is far more logical ! Example: I'm looking to channel-17 Pressing the EPG button on the Remote Control (or keyboard) gives the 'small' (and pressing twice the 'big') EPG from always channel-1 (=the first channel) Why doesn't it give the EPG of the current (= channel 17 in this example) please change this if possible as it is far more userfriendly. Other, related matter: Last seen: just as it is/was in MCE as far as I remember, why not ALWAYS return back to the last seen live-TV channel, also after a system reboot or return from standby or.... or make it at least possible that users can choose (in some menu settings) to chose wether they like to start always with channel-1, or 'the last seen'. Thnx, Peter
Luke 42241 Posted December 2, 2023 Posted December 2, 2023 Hi, what button exactly do you mean? Can you show a screenshot example? Thanks.
pünktchen 1411 Posted December 27, 2023 Posted December 27, 2023 He means if you open the (osd) epg while playing a live tv channel, it always highlights a program cell in exactly one line above the currently playing channel/program.
Luke 42241 Posted December 27, 2023 Posted December 27, 2023 21 minutes ago, pünktchen said: He means if you open the (osd) epg while playing a live tv channel, it always highlights a program cell in exactly one line above the currently playing channel/program. OK, this should no longer be the case, so please give it another try. Thanks.
pünktchen 1411 Posted December 28, 2023 Posted December 28, 2023 4 hours ago, Luke said: OK, this should no longer be the case, so please give it another try. Thanks. Android 3.3.56 -> not working
Luke 42241 Posted December 28, 2023 Posted December 28, 2023 Sorry, my mistake. It requires the 4.8 server, which will be in the stable channel soon.
