easez88 16 Posted November 28, 2023 Posted November 28, 2023 Did anyone find a fix for this? I basically have to put the volume to max to hear anything on my lg tv. Playing the same media in a Sony tv plays normally with no issues. I've seen a few threads about this but none have a solution. 1
Luke 42233 Posted December 2, 2023 Posted December 2, 2023 @easez88 Hi there, let's look at an example. Please attach the information requested in how to report a media playback issue. Thanks!
easez88 16 Posted December 2, 2023 Author Posted December 2, 2023 @LukeHow do I send logs from the LG app? I don't see an option for it. Here are the server logs. The issue is that media on my LG tv from Emby is at a really low volume. So I have to raise the volume really high 75 to hear anything. Every other app plays volume normally at about 30. This includes a Jellyfin instance I stood up just to test. I've been running emby on this TV for some time. So something has changed recently. My other TV also plays emby fine. embyserver.txt
Luke 42233 Posted December 20, 2023 Posted December 20, 2023 On 12/2/2023 at 3:12 PM, easez88 said: @LukeHow do I send logs from the LG app? I don't see an option for it. Here are the server logs. The issue is that media on my LG tv from Emby is at a really low volume. So I have to raise the volume really high 75 to hear anything. Every other app plays volume normally at about 30. This includes a Jellyfin instance I stood up just to test. I've been running emby on this TV for some time. So something has changed recently. My other TV also plays emby fine. embyserver.txt 495.88 kB · 0 downloads Can you try clearing app data in the Emby LG app, or uninstalling/reinstalling the app?
Techium 3 Posted August 18, 2025 Posted August 18, 2025 I've found something interesting, but I don't know what it means... With the TV (soundbar via HDMI ARC in my case) volume set OK (i.e. audible) for other sources (Xbox) and then starting a movie in the LG TV Emby app the volume is inaudible. If I then press the LG TV Guide button, wait for it to load and then exit the TV Guide, Emby starts playing at a louder, audible volume. Nothing else changed. I'm using: LG TV 55UK6470PLC LG TV Emby app v1.0.47 Emby for Synology V4.8.11.0
Luke 42233 Posted September 1, 2025 Posted September 1, 2025 On 12/19/2023 at 10:41 PM, Luke said: Can you try clearing app data in the Emby LG app, or uninstalling/reinstalling the app? @Techiumdid you try this?
Techium 3 Posted September 1, 2025 Posted September 1, 2025 I can't find any way to clear cache, but I've uninstalled (deleted) and reinstalled. On first test it seems fixed, but I'll report back in a few days to confirm 1
Techium 3 Posted September 2, 2025 Posted September 2, 2025 On 01/09/2025 at 01:21, Luke said: @Techiumdid you try this? Ok, just tried again now and the volume has stayed up (audible) with me switching sources etc. Looks like that's fixed it, thanks! 1
