justinrh 266 Posted December 2, 2023 Posted December 2, 2023 (edited) Is it possible to make the channel guide in the web app to be more compact (vertically)? I don't like having to scroll up and down the screen to see all the channels. EDIT: I just saw the option to turn off the channel image, which did shrink it a lot, but the rows are still overly tall causing the list to be tall. Edited December 2, 2023 by justinrh 1
Luke 42239 Posted December 2, 2023 Posted December 2, 2023 HI, what does it look like after doing that?
justinrh 266 Posted December 2, 2023 Author Posted December 2, 2023 (edited) Luke, you have used the product, right? Now I get to ask you 'exactly what do you mean'? Edited December 2, 2023 by justinrh
arrbee99 1836 Posted December 2, 2023 Posted December 2, 2023 As a matter of interest, or not, in the NextPVR web page I can fit 22 rows while in Emby I can fit 17 (without the logo and I think I used css to make the rows narrower as well). And just to blatantly take the opportunity, in the new Android app, the mini guide in the OSD while playing a channel has a pathetic 3 rows(vs 6 for the Android TV app). 1
justinrh 266 Posted December 2, 2023 Author Posted December 2, 2023 Good data point, arrbee. I can get 16 rows on my 1080 monitor.
Luke 42239 Posted December 2, 2023 Posted December 2, 2023 17 minutes ago, justinrh said: Luke, you have used the product, right? Now I get to ask you 'exactly what do you mean'? Right, i was hoping you'd post a screenshot so that I could follow-up and say, are these really overly tall? You need a little vertical breathing room, so what are we talking here, a couple pixels?
arrbee99 1836 Posted December 2, 2023 Posted December 2, 2023 The 17 I have drops to 15 if I get rid of my css. Just thought I'd mention that cos I don't like to be left out...
justinrh 266 Posted December 2, 2023 Author Posted December 2, 2023 Yes, they are. Way more than a couple of pixels could comfortably be removed. For the few shows that have a second row of text, that text could be moved to be in-line or just hidden in the 'compact mode'. arrbee, I would never want you to be left out!
Luke 42239 Posted December 2, 2023 Posted December 2, 2023 28 minutes ago, justinrh said: Luke, you have used the product, right? Now I get to ask you 'exactly what do you mean'? I guess I disagree. So if it's not a couple pixels, it can't be more than 10 right? At which point, big whoop ? I mean you could shave a couple pixels off but not much more than that. Again you need spacing and breathing room to make things easy to read. The goal isn't just to cram as much as we possibly can onto one screen.
justinrh 266 Posted December 2, 2023 Author Posted December 2, 2023 I just experimented with 2.5em height - it looks good. That would double the rows. Yep, that would be a big whoop. Round up to 3em and call it done.
Luke 42239 Posted December 2, 2023 Posted December 2, 2023 2 minutes ago, justinrh said: I just experimented with 2.5em height - it looks good. That would double the rows. Yep, that would be a big whoop. Round up to 3em and call it done. That's a little excessive. I guess it's fine if your goal maximum rows at any cost. First of all it cuts off the second row. Second, even if there's only one row, you need breathing room. I think 3.5em is the minimum i would go.
arrbee99 1836 Posted December 2, 2023 Posted December 2, 2023 Also you get more horizontally. For me, at the moment Nextpvr fits in from 2pm to 6.30pm, Emby is 2pm to 4pm.
arrbee99 1836 Posted December 2, 2023 Posted December 2, 2023 And in NextPVR you can scroll all the way back to the beginning of the day.
Luke 42239 Posted December 2, 2023 Posted December 2, 2023 14 minutes ago, arrbee99 said: Also you get more horizontally. For me, at the moment Nextpvr fits in from 2pm to 6.30pm, Emby is 2pm to 4pm. Yea but when I look at screenshots of nextpvr I see a lot of truncated text due to that.
arrbee99 1836 Posted December 2, 2023 Posted December 2, 2023 Well, I wouldn't say a lot. It could possibly be said in Emby I see a lot of empty space. But hopefully, If you shrink things a bit vertically, you can do a bit horizontally as well. 1
justinrh 266 Posted December 3, 2023 Author Posted December 3, 2023 @arrbee99how do you apply CSS overrides? I did this but there is no effect in the web app guide:
Solution arrbee99 1836 Posted December 3, 2023 Solution Posted December 3, 2023 I think its something like - div.virtualScrollItem.epgRow {height: 60px;} or similar but using em ? 1
justinrh 266 Posted December 3, 2023 Author Posted December 3, 2023 (edited) Luke, what is wrong with 3em? This has plenty of 'breathing room'. (Yeah, 3.5 would be good, too.) I already address second-line text. Think about the purpose/goal of this; think user-focused! Now, why does the CSS have to have the whole chain for it to take effect? I modified the class, yet that is not enough? Well, I learned how to use the CSS override stuff. Thanks, arrbee99! Edited December 3, 2023 by justinrh
arrbee99 1836 Posted December 4, 2023 Posted December 4, 2023 Don't forget, while you actually know what you're talking about, I'm just the trial and error type...
justinrh 266 Posted December 4, 2023 Author Posted December 4, 2023 Well, now I'm going to ask you for help on every Emby issue I have so you can trial and error a solution 1
