linesma 4 Posted November 30, 2023 Posted November 30, 2023 I have to replace one of my drives due to a lack of space. If I copy the media over to the new drive while keeping its folder layout the same, and mount the new drive in the same place, will Emby have issues? Thank you.
Solution Q-Droid 1011 Posted November 30, 2023 Solution Posted November 30, 2023 (edited) If you keep everything the same including file and directory attributes like ownership, permissions, etc then it would be fine, not even noticed. edit: added directory Edited November 30, 2023 by Q-Droid
linesma 4 Posted December 2, 2023 Author Posted December 2, 2023 @Q-DroidThank you. I will make sure to keep everything the same on the new drive.
