AngryMob 1 Posted November 17 Posted November 17 I do have the same issue with the Fire TV 4K Max directly connected to a Samsung Soundbar. The English DTS-HD MA 5.1 stream is silent. The German DTS 5.1 is working.. My phone can play it both. That's sad. I tried both apps, Emby and Emby for Fire TV. Don't know which one I should use in general. Playback Correction (Wiedergabekorrektur) solves the issue. What is the downside of that?
ebr 17088 Posted November 18 Posted November 18 17 hours ago, AngryMob said: Emby for Fire TV. In that app, have you tried un-checking the DTS-HD option in playback settings?
N1N1 4 Posted November 18 Posted November 18 Hi As I'm facing the same issue, you can install Kodi and use it as external player it works like a charm you can also use emby integration in KODI, I do not like all this stuff to only read a movie, but it seems this cannot be fixed at all
BalthazarBux 19 Posted November 18 Posted November 18 5 hours ago, ebr said: In that app, have you tried un-checking the DTS-HD option in playback settings? But then it is transcoded?
ebr 17088 Posted November 18 Posted November 18 1 hour ago, BalthazarBux said: But then it is transcoded? In most cases it would just convert the audio to something that actually works.
BalthazarBux 19 Posted November 18 Posted November 18 9 minutes ago, ebr said: In most cases it would just convert the audio to something that actually works. Understand, but the problem is that Emby is not playing something that it should?
Luke 43680 Posted November 19 Posted November 19 Can you please try this latest build: We just updated exoplayer. If there's still an issue, then I'll have you grab an app log. Thanks.
N1N1 4 Posted Thursday at 07:20 PM Posted Thursday at 07:20 PM Hi Luke Just installed and try this new release. Unfortunately issue remains I tried another movie with several DTS-HD MA tracks, including mono. whereas all DTS-HD MA 5.1 still has no sound, strangely the DTS-HD MA mono works You can find below log file from my fire stick including both plays: - at first the 5.1 track with no sound - then starting timestamp 20:11:07 the mono track emby_android_1795114952498.txt
ebr 17088 Posted Thursday at 07:58 PM Posted Thursday at 07:58 PM 35 minutes ago, N1N1 said: whereas all DTS-HD MA 5.1 still has no sound The device and player are reporting this track is supported and it is being sent out. However, it doesn't appear to actually be supported if no audio is being heard. I will say that the whole reason these specific audio options were added to the TV app was due to this very type of thing and usually on Amazon devices - where they reported support for the audio but it didn't actually work. 37 minutes ago, N1N1 said: strangely the DTS-HD MA mono works This one "works" because the player actually throws an error when we try to initialize this track (even though it also is reported as supported) so the app falls back to software decoding it and that's why you end up with audio on that one.
ebr 17088 Posted Thursday at 08:16 PM Posted Thursday at 08:16 PM Also, according to this: https://developer.amazon.com/docs/device-specs/device-specifications-fire-tv-streaming-media-player.html?v=ftvstick4kmax_gen2_16# The device supports "DTS-HD (basic profile)". I don't think that necessarily translates into DTS-HD MA 5.1...
N1N1 4 Posted Thursday at 08:28 PM Posted Thursday at 08:28 PM yes but it works on fire stick with Kodi so it's supported
AngryMob 1 Posted Thursday at 09:38 PM Posted Thursday at 09:38 PM 1 hour ago, ebr said: Also, according to this: https://developer.amazon.com/docs/device-specs/device-specifications-fire-tv-streaming-media-player.html?v=ftvstick4kmax_gen2_16# The device supports "DTS-HD (basic profile)". I don't think that necessarily translates into DTS-HD MA 5.1... So you think Kodi is also just somehow converting? Because there it works.
ebr 17088 Posted Thursday at 10:19 PM Posted Thursday at 10:19 PM 1 hour ago, N1N1 said: yes but it works on fire stick with Kodi so it's supported 42 minutes ago, AngryMob said: So you think Kodi is also just somehow converting? Because there it works. Correct. Kodi is working a bit of magic under the covers... in the same way that made you think that the mono track "worked". But, there is also something else at play here. Either the equipment chain is not reporting exactly correctly, or Exo/our app is not asking specifically enough about the support to react automatically.
N1N1 4 Posted Thursday at 10:43 PM Posted Thursday at 10:43 PM With KODI my MARANTZ amplifier displays correctly DTS HD Master with all DTS HD MA 5.1 or even 7.1 So if Kodi transcodes, it transcodes into DTS-HD MA, and it works on the fire stick I need to go to bed right now, but tomorrow I can provide a snapshot of input audio from my amplifier.
rbjtech 5416 Posted Friday at 11:10 AM Posted Friday at 11:10 AM We've seen this many times on the forum - the specification "DTS-HD (basic profile)" basically means that the device - with it's current implementation for this audio codec, simply extracts the DTS Core (the 1.5Mbit lossy 5.1) that is part of every DTS-HD stream. The device should be telling emby this (ie DTS only) and emby should be extracting the core only. From my understanding, KODI (and possibly others) are adding an extraction layer to bypass the default for DTS-HD and are extracting the full bitstream - thus they can play DTS-HD just fine. I suspect this is a DTS licensing issue with Amazon more than a device capability issue. On the file that does not play - see if you can do a basic DTS core extract (ideally with ffmpeg) - name it audio.dts - and see if the 'core' plays with vlc etc. If it doesn't, then that is your problem - the source Core is not workng/corrupt. If it does, then it needs further investigation as to why Emby is playing silence.
N1N1 4 Posted Friday at 02:42 PM Posted Friday at 02:42 PM Hello @rbjtech Thanks for the tip. I extracted DTS HD MA track from my movie with ffmpeg and I can read it very well, even with emby ! That's pretty weird. I create a new library dedicated for audio and I put the dts file here. Then I played it throughout emby, and it was well played in DTS HD format via my amplifier as below. this very same DTS content inside the movie mkv and the signal is then displayed to none with no sound at all
ebr 17088 Posted Friday at 02:42 PM Posted Friday at 02:42 PM 15 hours ago, N1N1 said: So if Kodi transcodes, it transcodes into DTS-HD MA It isn't transcoding it per se. It is re-packaging it. We are looking into whether it is possible to do the same within Exo. 1
rbjtech 5416 Posted Friday at 05:54 PM Posted Friday at 05:54 PM 3 hours ago, N1N1 said: Then I played it throughout emby, and it was well played in DTS HD format via my amplifier as below. ok cool - so that's a DTS core track - your AVR says its DTS - which is correct (5.1 lossy, it's not DTS HD) If you just want to play it while it gets looked into, then you can simply mux that DTS track into the MKV as a separate track (use mkvtoolnix etc) and then you'll be able to play it as normal DTS. As Eric/ebr has said above, there is something in the chain that is not correct - but at least you have verified the source file is good and now have a few options.
BalthazarBux 19 Posted Saturday at 06:51 PM Posted Saturday at 06:51 PM On 11/19/2026 at 1:26 AM, Luke said: Can you please try this latest build: We just updated exoplayer. If there's still an issue, then I'll have you grab an app log. Thanks. In GitHub, you can use the google armeabi v7? There is one named Amazon armeabi v7, but not updated.
