moozart 3 Posted March 11, 2024 Author Posted March 11, 2024 15 hours ago, signde said: I am seeing no improvement with 3.3.73 for Android installed on the AFTV 4K Max 2023. DTS-HD/DTS-X all still get no audio. You are completely right, it is not working. Misleading conclusion from my side, because before it was muted and now it is transcoding. So the issue remains.. It is not working without transcoding on Emby or Plex, but works on Kodi. I'm using this demo as reference. 1 1
denysfontaine 0 Posted July 13, 2024 Posted July 13, 2024 (edited) Hi, First, sorry for my bad english ! But, i found a temporary solution ! - Fire Cube 3rg Gen connected to Denon receiver When playing a video (original dvd file) 480i / DTS 5.1 the audio file is playing, but the video freeze for some seconds, play again and freeze again. No audio freeze. What i did is : (when playing the video) click on the gear icon and change the video (originally 480 5mbps) to 480 1mbps. And then, click again on the gear icon to Auto. The video and audio are now playing normally 5mbps and DTS 5.1 without freeze. No problem when using an external player like VLC No problem with PLEX No problem when I convert the audio to Opus 5.1 Running Emby Premiere Version 4.9.0.26 beta Edited July 13, 2024 by denysfontaine
Luke 42243 Posted August 17, 2024 Posted August 17, 2024 On 7/13/2024 at 10:38 AM, denysfontaine said: Hi, First, sorry for my bad english ! But, i found a temporary solution ! - Fire Cube 3rg Gen connected to Denon receiver When playing a video (original dvd file) 480i / DTS 5.1 the audio file is playing, but the video freeze for some seconds, play again and freeze again. No audio freeze. What i did is : (when playing the video) click on the gear icon and change the video (originally 480 5mbps) to 480 1mbps. And then, click again on the gear icon to Auto. The video and audio are now playing normally 5mbps and DTS 5.1 without freeze. No problem when using an external player like VLC No problem with PLEX No problem when I convert the audio to Opus 5.1 Running Emby Premiere Version 4.9.0.26 beta @denysfontaine Hi. Can you try searching for our standard android app (Just "Emby" on Amazon and "Emby for Android on Google) on the same device's app store and see how that compares? Thanks.
BalthazarBux 19 Posted February 28 Posted February 28 (edited) I don't get audio when playing DTS HD-MA either on my Fire Stick 4K Max. (The newest gen, with Wifi6E) Not with 3.5.29 or 2.1.36 Edited February 28 by BalthazarBux
ebr 16335 Posted February 28 Posted February 28 3 hours ago, BalthazarBux said: or 2.1.36 Is there an option in the settings in that app of whether or not to pass-thru DTS-HD?
BalthazarBux 19 Posted February 28 Posted February 28 8 minutes ago, ebr said: Is there an option in the settings in that app of whether or not to pass-thru DTS-HD? Yes, it even has two of them, (maybe one is DTS and one is DTS-HD according to the text below option, both are checked
BalthazarBux 19 Posted February 28 Posted February 28 42 minutes ago, ebr said: Try un-checking the DTS-HD one. Yes, that gave sound with (software decode) in nerd info instead of (direct) 1
