PlutoIsAPlanet 2 Posted November 30, 2023 Posted November 30, 2023 Hi, I'd like to wipe the external URL links from songs contained in a certain folder, as some are invalid (here's an example with a fake link): In the metadata: and reassign them after retrieving the correct data. It seems, that the data is not getting updated and it doesn't matter if I post an emtpy array or modified data. The item itself is getting updated, see the name of the song before: and after posting the JSON (with the modified name and empty ExternalURLs array) using the method PostItemsByItemid the result: The external URL is still there. I tried modifying the existing URL: The original link is unchanged. Any ideas?
Solution Luke 42234 Posted November 30, 2023 Solution Posted November 30, 2023 Hi, try updating the providerids instead. 1
PlutoIsAPlanet 2 Posted December 1, 2023 Author Posted December 1, 2023 14 hours ago, Luke said: Hi, try updating the providerids instead. Good morning Luke, that did the trick. Thank you It seems, like the ExternalURLs property is set, based on the ProviderIds content. As the ExternalURLs also had a setter, I assumed that I could assign as such - I didn't see the connection between the two properties. Have yourself a great weekend! 1
Luke 42234 Posted December 1, 2023 Posted December 1, 2023 Quote It seems, like the ExternalURLs property is set, based on the ProviderIds content. Yes that is correct.
