harrybi 1 Posted November 28, 2023 Posted November 28, 2023 Hi, ich habe mir letztes WE Emby Premiere geleistet. Seitdem ich den Key eingetragen habe, starten keine Filme/Serien-Folgen mehr auf meinen LG-TVs. Per Andriod App, Chromecast oder WebBrowser geht noch alles, aber auf den Fernsehern kommt ein endlosen Spinner. Eine Idee woran das liegen kann? (Emby läuft auf einem Raspi4) Gruß Harry
ebr 16333 Posted November 28, 2023 Posted November 28, 2023 Hi there, let's look at an example. Please attach the information requested in how to report a media playback issue. Thanks! 1
harrybi 1 Posted November 28, 2023 Author Posted November 28, 2023 Hi, sorry, missed that... Attached the log of the media to be played. One from yesterday when the premiere key is active, failing. And one I just tried again after removing the premiere key, succeeding again. So for now it looks like I can't use the primiere with my current setup. Which setting do I need to change to make it work with primierekey like without? Greetings, Harry ffmpeg-transcode-c38f1e10-876b-4009-8f49-34a11d87f73f_1.txt ffmpeg-transcode-5f3bf8e5-cc98-47c1-8a0d-fa980e4b9a51_1_with-primiere.txt
Solution harrybi 1 Posted November 28, 2023 Author Solution Posted November 28, 2023 (edited) hm... I guess I found a solution. I changed the Transcoding option from "yes" to "advanced" and checked all supported HW en-/decoders. Now it works again. (with primiere key) Edited November 28, 2023 by harrybi
