Dickydodah! 154 Posted November 28, 2023 Posted November 28, 2023 App version: 1.6.7 TV Model: UE43KU6510 App version: 1.2.6 TV Model: UE32M5500 I'm not sure if this ever worked the way I thought it did but here goes  When the background image of a series, episode or movie is predominatly a light colour the overview is hard/impossible to read. If the overview has more text than what would fit in the space available it is possible to highlight it and it changes to black on a white background, pressing select opens the whole overview in its own window. However if there is no text overflow it cannot be selected. It would be nice if the selection and open in a new window was available for all overviews as it would definitly help those with less than perfect eyesight.
SamES 1084 Posted November 28, 2023 Posted November 28, 2023 Are you only seeing this on the KU model? It's a known issue. If you also see it on the M-series, try updating it to the latest USB Beta version.
Dickydodah! 154 Posted November 28, 2023 Author Posted November 28, 2023 I've updated the M-series and get the same symptoms. I did try searching for any known issues but didn't find any. Can you give me a link please?
