MarinaxFaya 0 Posted November 27, 2023 Posted November 27, 2023 Hello I’m completely going crazy ! I’m trying to log in on my account to go on a server that I’ve joined earlier this year but it’s not possible because every time I try it says to me that it’s not the right username or password but it’s the right one sorry for my English I’m French best regards it’s been a week or so that it’s doing that ! Earlier it was working well either I try on the app or the site it saying the same thing It’s only doing that when I tried to used it on my iPad i dona know what too do anymore , i have changed me password múltiple time but no
Luke 42241 Posted November 27, 2023 Posted November 27, 2023 Hi, so this is someone else's server? You'll need to contact them for instructions on how to login. 1
MarinaxFaya 0 Posted November 27, 2023 Author Posted November 27, 2023 Yes this is someone else server they said they said it was not a server issue and I’ve done what they said to connect myself but it’s not working Do you know how I can’t log ….. thank you for your answer
Luke 42241 Posted November 27, 2023 Posted November 27, 2023 OK let's put it this way. What login instructions did they give you? Did you ask them if they tested those instructions themselves?
