Peter Nent 71 Posted November 27, 2023 Posted November 27, 2023 Using 'app settings', 'start screen' gives a user some kind of possibility to change the menu, but not as I need: is there any way to change an entry to another main menu entry ? Background: The current Live TV menu - recorded, is not to my expectations: when showing the recorded Live-TV, it is not grouped by serie (or any other way), but all shown....thats not what MCE did and what I expect: it should show the series, and if you choose a certain serie, it should show the sorted (from new-to-old or...) list of episodes and let you choose... As I made a Emby library myself called TV-recordings, exactly this way, I've created an alternative....but: Question: how to set this 'mixed- type' into the Live-TV menu ? OR better: is there an initiative to improve the current Live-TV recording this way ? Thanks & best regards, Peter
softworkz 5133 Posted November 28, 2023 Posted November 28, 2023 17 hours ago, Peter Nent said: OR better: is there an initiative to improve the current Live-TV recording this way ? Yes, this is being tracked already here: https://github.com/EmbySupport/Emby.WMC.UI/issues/12
