GrimReaper 4931 Posted November 27, 2023 Posted November 27, 2023 7 minutes ago, _CAP_ said: To try and find a close direct mode I connected over LAN, maxed the quality out and opened up Stats for Nerds. It says the source content is 84 mbps. 22 minutes ago, GrimReaper said: You should increase that as you're playing 80+ Mbps item 7 minutes ago, _CAP_ said: So on the WAN connection I set the client playback to 100 Mbps and stats for nerds then reports its doing Direct play If it's DirectPlaying then your server machine capabilities don't come into play, it's all about your network connection quality.
_CAP_ 0 Posted November 27, 2023 Author Posted November 27, 2023 That's interesting, as CPU direct play with the same video works over the same network connection just fine.
GrimReaper 4931 Posted November 27, 2023 Posted November 27, 2023 (edited) 9 minutes ago, _CAP_ said: That's interesting, as CPU direct play with the same video works over the same network connection just fine. There's no CPU or GPU direct play - an item is either direct playing (being delivered as-is) or it's not, so it's transcoded (via CPU or GPU). You need to find optimal scenario for your setup. https://emby.media/support/articles/DirectPlay-Stream-Transcoding.html https://emby.media/support/articles/Transcoding.html Edited November 27, 2023 by GrimReaper
_CAP_ 0 Posted November 27, 2023 Author Posted November 27, 2023 Okay, ill keep working on this. Thank you very much for your time and help!
Luke 42310 Posted November 27, 2023 Posted November 27, 2023 15 hours ago, _CAP_ said: Okay, ill keep working on this. Thank you very much for your time and help! Please let us know what you find. Thanks.
