StarWing 0 Posted November 26, 2023 Posted November 26, 2023 I have setup a complete new instance of Emby on a virtual Ubuntu machine, please see my other topic for info I've created some audio streams from local radio stations that I would like to have in our Chromecasts. These streams are setup individually within the IPTV plugin, and they are working well on a desktop with Firefox and on our Android phones. However, they do not seem to work on a Chromecast. I c embyserver.txt
StarWing 0 Posted November 26, 2023 Author Posted November 26, 2023 Sorry, something went wrong whilst editing the post. ==> I can open the stream, but after some seconds, the message appears "too many errors". I've tried fiddling around in the app settings available, but this does not solve the issue.
Solution ebr 16337 Posted November 26, 2023 Solution Posted November 26, 2023 Hi. Can you try sideloading our standard android app on the same device and see how that compares? https://emby.media/emby-for-android.html Thanks.
StarWing 0 Posted November 26, 2023 Author Posted November 26, 2023 (edited) Which APK should I use for google TV ? I've tried the ARM64, but it states "app not suited for your tv" //Edit, took the ARM7 one, after installing it seems to work. Edited November 26, 2023 by StarWing
Luke 42243 Posted November 26, 2023 Posted November 26, 2023 4 hours ago, StarWing said: Which APK should I use for google TV ? I've tried the ARM64, but it states "app not suited for your tv" //Edit, took the ARM7 one, after installing it seems to work. Hi, sounds like you got the right one.
StarWing 0 Posted November 27, 2023 Author Posted November 27, 2023 Whats the difference between the sideloaded app and the official one in the play store ?
Luke 42243 Posted November 27, 2023 Posted November 27, 2023 14 hours ago, StarWing said: Whats the difference between the sideloaded app and the official one in the play store ? The sideloaded app is the direction we are moving towards. We are working on getting it into the store for TV devices. 1
StarWing 0 Posted October 12, 2024 Author Posted October 12, 2024 @Luke Kick for this old topic. Been using Emby for almost a year now, primarily through the Chromecast. Kodi/osmc integration on a vero4k+ does not add more benefits for me. Since the sideloading of the app on Chromecast all works 95% of the time. Whats the status on the sideloading of the app? Is the sideloaded app now the same version as the one we can find in the appstore and does the sideloaded app auto-updates ?
ebr 16337 Posted October 12, 2024 Posted October 12, 2024 4 hours ago, StarWing said: Whats the status on the sideloading of the app? Is the sideloaded app now the same version as the one we can find in the appstore and does the sideloaded app auto-updates ? Hi. Yes, that app is available in the store now. You should install "Emby for Android" from the store. 1
