embyben 6 Posted November 24, 2023 Posted November 24, 2023 I tried to play a 82GB movie for the first time tonight but it buffers every 20-30 seconds inconsistently. The stream is DirectPlay. Emby Server Version 4.7.14.0 HP Gen8 Microserver - Docker Container - networked using MACVLAN (current setup) Intel(R) Xeon(R) CPU E3-1265L V2 @ 2.50GHz - 16GB RAM Player Sony Bravia A80J 65" Android TV / Emby App Network 8 Port Unmanaged Gigabit Switch I can't see anything obvious in the logs. Can anyone else help? I'm suspecting a networking issue perhaps. How can I stop the buffering please? Title4K HEVC HDR10 CodecHEVC ProfileMain 10 Level153 Resolution3840x2160 Aspect Ratio16:9 InterlacedNo Framerate23.976 Bitrate66 mbps Video RangeHDR10 Colour Primariesbt2020 Colour Spacebt2020nc Colour Transfersmpte2084 Bit Depth10 bit Pixel Formatyuv420p10le Reference Frames1 embyserver.txt
Luke 42185 Posted November 24, 2023 Posted November 24, 2023 Hi, have you tried lowering the in-app quality setting to transcode to a lower bitrate? It's possible the bitrate is just too high for the connection.
embyben 6 Posted November 24, 2023 Author Posted November 24, 2023 (edited) Hi @Luke, thank you for your reply. I haven't tried transcribing, but yes that would probably work. I'd like to find the bottle neck and get my network running at optimal. I'm going to "dumb down" my over engineered network to remove all the sub-interfaces, routing and put my server on the same subnet today and try that. (big project).. Failing that, is there any reason why the A80J TV could not handle 66mpbs? (I even added a gigabit USB NIC to tv) Edited November 24, 2023 by embyben
embyben 6 Posted November 24, 2023 Author Posted November 24, 2023 Not a remote connection. Same house. My Network
ebr 16307 Posted November 24, 2023 Posted November 24, 2023 1 hour ago, embyben said: is there any reason why the A80J TV could not handle 66mpbs? (I even added a gigabit USB NIC to tv) Hi. The TV may only be designed for 100Mb/s network over its network interface. Many TV manufacturers skimp on this hardware because most people don't use it anymore. Have you tried using wireless? It also could just be that the TV's processor has trouble with content that has a bitrate that high.
embyben 6 Posted November 24, 2023 Author Posted November 24, 2023 (edited) I just took apart my network. It wasn't the sub interfaces. It still buffered when being routed. I put emby server on the same Subnet as the TV and there was NO BUFFERING!! very happy. However, now my server is not in a DMZ and I want to find why routing caused the lag?? The firewall is a Intel(R) Core(TM) i3-5005U CPU @ 2.00GHz 4 CPUs with 4MB RAM which should be fine. I'll keep troubleshooting. Thanks for your help. Edited November 24, 2023 by embyben 1
ebr 16307 Posted November 24, 2023 Posted November 24, 2023 Glad you chased it down. Thanks for reporting back.
embyben 6 Posted November 25, 2023 Author Posted November 25, 2023 Turns out my pfSense had a "Traffic Shaper" on as the culprit. All sorted now. 1 1
