Stargrazer82301 4 Posted November 23, 2023 Posted November 23, 2023 Had this problem for a few months now, and it's very very vexing! I have a Windows PC as my Emby server, and use a Roku stick as our main way of watching media from that server, over our LAN. Both the Roku and the PC are connected to the same router over the same WiFi network. However, when I have a VPN enabled on the PC, the Emby app on the Roku struggles with playback (I also get this same problem when trying to play over Chromecast, too). Media will often play for a few seconds, then hang for a period, then play a few more seconds. Sometimes media won't play at all. Often, the Roku app won't even be able to view the Emby library at all; I'll just see the loading wheel. This doesn't happen all the time when the VPN is enabled. Sometimes media plays fine. Sometimes playback struggles, but works okay if I lower the playback quality considerably. It seems to act as though like the network speed is just very very slow. But it isn't; the WiFi is fast, and the problem persists even if nothing else is using the network at all (ie, no downloads, no streaming, no anything on any other device). I have port forwarding set up on my router, as per the standard Emby instructions. However, if I disable the VPN, it works fine! I find this very confusing, given that Emby should be operating purely over the LAN. I have tried two different VPN services (NordVPN and ExpressVPN), and get the exact same problem with each. I have tried enabling split tunnelling, etc, in the VPN apps, so that Emby should even be able to use the VPN, but this makes no difference. I have attached logs for a particular occasion when I had the problem this morning, at about 10:53. In this instance, the Roku app wasn't even able to load the Emby library to browse my media. embyserver.txt embyserver-63836330832.txt hardware_detection-63836330850.txt
ebr 16307 Posted November 24, 2023 Posted November 24, 2023 Hi. You say you have these issues on the other apps too, not just the Roku?
Stargrazer82301 4 Posted November 25, 2023 Author Posted November 25, 2023 Hi! Yes, I also have this problem when trying to play to Chomecast (from both the Android and iOS apps for Emby) when the VPN is on.
Stargrazer82301 4 Posted November 25, 2023 Author Posted November 25, 2023 To update: I have attached below the log from an attempt to connect to Emby just now, via Roku and via android app, and in both cases it wasn't even able to load the library when the server was connected to VPN. This happened at about 17:02-17:05. Then, when I disconnected the VPN, the Roku was immediately able to connect, no problems, at 17:06-17:07 (ish). Another note: Often, when the connection issues arise, the Roku app forces us to re-log-in to the server. embyserver.txt
Luke 42185 Posted November 26, 2023 Posted November 26, 2023 Hi, maybe you need to connect using a different address when the vpn is active?
Stargrazer82301 4 Posted November 27, 2023 Author Posted November 27, 2023 According to the dashboard page on my Emby server, the LAN IP address (192.168.1.24:8096) is identical, regardless of whether the VPN is on or not when I check.
ebr 16307 Posted November 27, 2023 Posted November 27, 2023 10 hours ago, Stargrazer82301 said: According to the dashboard page on my Emby server Right, but maybe the server is not able to discover the IP needed for your VPN...
rbjtech 5335 Posted November 27, 2023 Posted November 27, 2023 (edited) Detected local ip addresses: 192.168.1.24, 2601:14d:4a00:1b70:110f:617c:e03a:558a, 2601:14d:4a00:1b70:7566:83a7:1ab7:6423, fe80::4df2:cc55:fe28:cfe7%5, 100.64.100.6, 127.0.0.1, fe80::6562:d309:1db:7a78%24, ::1 Force emby to use only your local IP - dashboard > server > network > local ip address Enter 192.168.1.24 then restart emby Emby should then only 'listen' on 192.168.1.24 - (it will ignore the VPN - 100.64.100.6 - which is the local VPN adapter) -- If you want emby to actually use the VPN itself - then you probably need to start messing with routing/metrics to give routing priority to the LAN (as there is no routing on a lan on the same network/subnet) but generally out the box, that is how it should be anyway. try a 'route print' from a command box - a lower value means it has preference. Edited November 27, 2023 by rbjtech 1
Stargrazer82301 4 Posted November 28, 2023 Author Posted November 28, 2023 I'll let you know. I implemented the change, and a quick test playback worked smoothy. However, the problem is intermittent, and only happens ~50% of the time. If we go a few days without the problem coming back, then I'll post here to update. 1 1
Stargrazer82301 4 Posted December 5, 2023 Author Posted December 5, 2023 Okay, time for an update. The problem still persists. After some trial and error, it seems that it's qBittorrent that's causing the problem. When it's running, the connection has the problems. When I quit it, the problems go away. Oddly, even if there are no downloads of any kind in progress, the problems still happen. 1
pwhodges 2023 Posted December 5, 2023 Posted December 5, 2023 Is qBittorrent using a port which conflicts with Emby? Paul
Stargrazer82301 4 Posted December 7, 2023 Author Posted December 7, 2023 Not as far as I can tell. Both Emby and qBittorrent has ports explicitly assigned, and they are different ports. I have tried changing Emby to use different ports, to no effect. I have tried enabling and disabling port forwarding on my router, and it makes no difference.
speechles 2061 Posted December 8, 2023 Posted December 8, 2023 2023-11-23 10:54:46.445 Info MediaProbeManager: ProcessRun 'ffprobe' Process exited with code 1 - Failed 2023-11-23 10:54:46.445 Error App: Error in ffprobe You have these errors all over in your server log. Is one of your Emby library pointed towards your downloads folder? Where it can get fed incomplete downloads and stumble over the broken files? It almost appears like your problem is the fact Emby is transcoding these and when the VPN is running it takes resources away from the transcoding causing your issue? Are all your libraries working? I would think the reason Emby is appearing broken isn't really because of the bandwidth but the CPU cycles. If you fix the problems noted in your LOG and move the once completed files from your download folder into the appropriate library you will not have incomplete files messing up your library. That is likely the cause of all your problems.
Stargrazer82301 4 Posted December 16, 2023 Author Posted December 16, 2023 Sorry, I'm travelling for work ATM and haven't had a chance to test. But one of the folders Emby monitors is indeed one that partial downloads go into. I will remove it as soon as I return, and see if that helps! Because I never try to watch partially-downloaded files, it (perhaps foolishly) hadn't occurred to me that that might cause a problem.
Luke 42185 Posted December 17, 2023 Posted December 17, 2023 Please let us know if this helps. Thanks.
