tomassasovsky 2 Posted November 21, 2023 Posted November 21, 2023 (edited) Lookup works inconsistently. My setup is: - Emby Server running on TrueNas Scale. - Emby Theater is connected to the server, running on Windows 11. Lookup also doesn't work consistently if I pause the video. It's really buggy. Recording 2023-11-21 221811.mp4 Edited November 21, 2023 by tomassasovsky
tomassasovsky 2 Posted November 21, 2023 Author Posted November 21, 2023 I'm using version 4.7.14.0 of the Emby Server and version 3.0.20 of Emby Theater. If I also hit "Resume" it starts from the beginning, even if the movie was already started. See the attached video for evidence. Recording 2023-11-21 225005.mp4
Luke 42237 Posted November 21, 2023 Posted November 21, 2023 Hi there, let's look at an example. Please attach the information requested in how to report a media playback issue. Thanks! Also, what do you mean by lookup?
tomassasovsky 2 Posted November 21, 2023 Author Posted November 21, 2023 By lookup, I mean moving to another point in the movie's timeline. Sorry, here's the logfile! And thank you for the quick response! embyserver.txt
tomassasovsky 2 Posted November 23, 2023 Author Posted November 23, 2023 Any updates on this? It's pretty worrying that, as a paying customer, I can't even rely on the most basic funtionality that is resuming playback on a video or moving to another point in the video's timeline.
tomassasovsky 2 Posted November 23, 2023 Author Posted November 23, 2023 (edited) Another thing to note is, I was not able to reproduce this with Emby for Android. It does happen on both the web app and Emby Theater (Windows 11) @Luke Edited November 23, 2023 by tomassasovsky
tomassasovsky 2 Posted November 23, 2023 Author Posted November 23, 2023 I've identified the issue: This error occurs if I connect through my domain where I host my Emby server. However, I don't encounter this issue if I connect directly to the local IP address on my network where the server is. I think it may have something to do with the networking configuration. Here's my current config on the Network section in the Emby server: I also have a Raspberry Pi running Nginx as a reversed proxy. Its config is pretty simple: server { server_name mydomain.com; location / { proxy_pass http://192.168.50.55:10079/; proxy_http_version 1.1; proxy_set_header Upgrade $http_upgrade; proxy_set_header Connection 'upgrade'; proxy_set_header Host $host; proxy_cache_bypass $http_upgrade; } listen [::]:443 ssl; # managed by Certbot listen 443 ssl; # managed by Certbot ssl_certificate /etc/letsencrypt/live/mydomain.com/fullchain.pem; # managed by Certbot ssl_certificate_key /etc/letsencrypt/live/mydomain.com/privkey.pem; # managed by Certbot include /etc/letsencrypt/options-ssl-nginx.conf; # managed by Certbot ssl_dhparam /etc/letsencrypt/ssl-dhparams.pem; # managed by Certbot } server { if ($host = mydomain.com) { return 301 https://$host$request_uri; } # managed by Certbot server_name mydomain.com; listen 80; listen [::]:80; return 404; # managed by Certbot }
Solution Luke 42237 Posted November 23, 2023 Solution Posted November 23, 2023 Hi, please try comparing your nginx setup to this and see if it helps:
tomassasovsky 2 Posted November 23, 2023 Author Posted November 23, 2023 Thank you so much! That, and disabling Cloudflare Proxy worked! 1
