StanEXE 0 Posted November 19, 2023 Posted November 19, 2023 Hi there, I recently got a 4K LG TV (50UR78006LK (2023)) and I'm aware it doesn't support TrueHD audio, which isn't a problem for me. Some of the media I have only has a TrueHD audio track and no AC3. On some days, Emby will choose to transcode the track to AC3, in which case the playback works perfectly. Other times it will try to direct play the TrueHD track, which won't work and the screen will stay black with no audio. Is there a way to force transcoding of TrueHD tracks to AC3 on my tv, because direct playing TrueHD always causes the media to not play. I've attached the transcoding log, which shows an error message at the bottom, I suspect this may be the problem but I am not sure. Yesterday it worked fine with transcoding this audiotrack but today it doesn't seem to be working. ffmpeg-remux-3f9fa183-6c1a-452e-8686-bd1fb6452b57_1.txt
StanEXE 0 Posted November 19, 2023 Author Posted November 19, 2023 I installed it using the documentation provided by my server host: https://whatbox.ca/wiki/Emby
SamES 1084 Posted November 23, 2023 Posted November 23, 2023 @Luke, this looks like the same issue with them not packaging our ffmpeg Quote ffmpeg version 6.0.1 Copyright (c) 2000-2023 the FFmpeg developers built with gcc 13 (Gentoo Hardened 13.2.1_p20230826 p7) 1
StanEXE 0 Posted November 26, 2023 Author Posted November 26, 2023 Is there a way for me to resolve this myself or does the issue lie with Whatbox / Emby?
Luke 42237 Posted November 26, 2023 Posted November 26, 2023 12 minutes ago, StanEXE said: Is there a way for me to resolve this myself or does the issue lie with Whatbox / Emby? The issue relates to the way whatbox has packaged embyserver. They'll need to collaborate with us to find a better way. 1
