dma_k 2 Posted November 19, 2023 Posted November 19, 2023 When viewing the media library in browser in Windows, playback button does no work. However: Video is playing on the "background" when media metadata is opened. Video is playing fine in a window mode (which ca be then switch to a full-screen mode). Emby server error: 2023-11-19 01:40:32.561 Error Server: Error processing request *** Error Report *** Version: 4.8.0.59 Command line: /opt/emby-server/system/EmbyServer.dll -programdata /var/lib/emby -ffdetect /opt/emby-server/bin/ffdetect -ffmpeg /opt/emby-server/bin/ffmpeg -ffprobe /opt/emby-server/bin/ffprobe -restartexitcode 3 -updatepackage emby-server-deb_{version}_amd64.deb Operating system: Linux version 6.1.0-10-amd64 (debian-kernel@lists.debian.org) (gcc-12 (Debian 12.2.0-14) 12.2.0, GNU ld (GNU Binutils for Debian) 2.40) #1 SMP PREEMPT Framework: .NET 6.0.20 OS/Process: x64/x64 Runtime: opt/emby-server/system/System.Private.CoreLib.dll Processor count: 8 Data path: /var/lib/emby Application path: /opt/emby-server/system System.IO.FileNotFoundException: System.IO.FileNotFoundException: Could not find file '/opt/emby-server/system/dashboard-ui/videoosd/videoosd_view.js'. File name: '/opt/emby-server/system/dashboard-ui/videoosd/videoosd_view.js' at Interop.ThrowExceptionForIoErrno(ErrorInfo errorInfo, String path, Boolean isDirectory, Func`2 errorRewriter) at Interop.CheckIo(Error error, String path, Boolean isDirectory, Func`2 errorRewriter) at Microsoft.Win32.SafeHandles.SafeFileHandle.Open(String path, OpenFlags flags, Int32 mode) at Microsoft.Win32.SafeHandles.SafeFileHandle.Open(String fullPath, FileMode mode, FileAccess access, FileShare share, FileOptions options, Int64 preallocationSize) at System.IO.Strategies.OSFileStreamStrategy..ctor(String path, FileMode mode, FileAccess access, FileShare share, FileOptions options, Int64 preallocationSize) at System.IO.Strategies.FileStreamHelpers.ChooseStrategy(FileStream fileStream, String path, FileMode mode, FileAccess access, FileShare share, Int32 bufferSize, FileOptions options, Int64 preallocationSize) at System.IO.FileStream..ctor(String path, FileStreamOptions options) at Emby.Server.Implementations.IO.ManagedFileSystem.GetFileStream(String path, FileOpenMode mode, FileAccessMode access, FileShareMode share, Int32 bufferSize, FileOpenOptions fileOpenOptions, Int64 preAllocationSize) at Emby.Server.Implementations.IO.ManagedFileSystem.GetFileStream(String path, FileOpenMode mode, FileAccessMode access, FileShareMode share, Int32 bufferSize, FileOpenOptions fileOpenOptions) at Emby.Server.Implementations.IO.IOManager.GetResponse(HttpRequestOptions options, MediaProtocol protocol) at Emby.Server.Implementations.IO.IOManager.GetResponse(HttpRequestOptions options) at Emby.Server.Implementations.HttpServer.HttpResultFactory.GetContent(StaticFileResultOptions options, Int64 offset, Int64 length, CancellationToken cancellationToken) at Emby.Server.Implementations.HttpServer.FileWriter.SetContentResponseHeaders(Nullable`1 reportedTotalContentLength, CancellationToken cancellationToken) at Emby.Server.Implementations.HttpServer.HttpResultFactory.GetStaticResult(IRequest requestContext, StaticResultOptions options) at Emby.Web.Api.WebAppService.Get(GetDashboardResource request) at Emby.Server.Implementations.Services.ServiceController.GetTaskResult(Task task) at Emby.Server.Implementations.Services.ServiceHandler.ProcessRequestAsync(HttpListenerHost httpHost, IServerApplicationHost appHost, IRequest httpReq, IResponse httpRes, IStreamHelper streamHelper, RestPath restPath, String responseContentType, CancellationToken cancellationToken) at Emby.Server.Implementations.HttpServer.HttpListenerHost.RequestHandler(IRequest httpReq, ReadOnlyMemory`1 urlString, ReadOnlyMemory`1 localPath, CancellationToken cancellationToken) Source: System.Private.CoreLib TargetSite: Void ThrowExceptionForIoErrno(ErrorInfo, System.String, Boolean, System.Func`2[Interop+ErrorInfo,Interop+ErrorInfo])
Luke 42245 Posted November 19, 2023 Posted November 19, 2023 Hi, please try clearing browsing data and seeing if that helps.
