Luke 42237 Posted October 1, 2025 Posted October 1, 2025 2 hours ago, GiGo said: Any else having issue with the SMB in the latest beta `4.9.1.36-beta` I can connect via a SMB browser without authentication but with Emby it fails, even if I do add credentials it still fails. HI there, can you please provide a specific example? How to Report a Problem Thanks !
GiGo 108 Posted October 4, 2025 Posted October 4, 2025 On 01/10/2025 at 16:42, Luke said: HI there, can you please provide a specific example? How to Report a Problem Thanks ! All sorted. I got the issue after the latest update, rebooted the device and all is good. 1
GiGo 108 Posted October 5, 2025 Posted October 5, 2025 (edited) On 01/10/2025 at 16:42, Luke said: HI there, can you please provide a specific example? How to Report a Problem Thanks ! Not sure if it's an issue with Emby or if it's my device, but every few hours if I'm accessing a SMB it fails. Local plugged in devices are accessed fine. I have to restart Emby for the SMB link to work, SMB's work fine in file apps. Log attached: Relevant part here: OS/Process: Arm64/Arm64 Framework: .NET 8.0.20 Runtime: System.Private.CoreLib.dll Processor count: 8 Data path: /storage/emulated/0/Android/data/com.emby.embyserver/files Application path: /data/user/0/com.emby.embyserver Fingerprint: Xiaomi/umi_eea/umi:13/TKQ1.221114.001/V816.0.1.0.TJBEUXM:user/release-keys Model: Mi 10 - Xiaomi/Xiaomi Hardware: umi/umi_eea/qcom/umi SupportedAbis: arm64-v8a, armeabi-v7a, armeabi System.IO.IOException: System.IO.IOException: Authentication Failed. at EzSmb.Transports.Connection..ctor(PathSet pathSet, ParamSet paramSet) at EzSmb.Node.GetNode(String path, ParamSet paramSet, Nullable`1 isDirectory) at Emby.Server.Implementations.IO.SmbFileSystem.GetNode(String path, FileSystemCredentials credentials, Nullable`1 isDirectory) at Emby.Server.Implementations.IO.SmbFileSystem.CreateSmbDirectoryForListFiles(String path, FileSystemCredentials credentials) at Emby.Server.Implementations.IO.SmbFileSystem.GetFileSystemEntries(String path, FileSystemCredentials credentials, Boolean recursive) at Emby.Server.Implementations.IO.ManagedFileSystem.GetFileSystemEntries(String path, Boolean recursive, FileSystemCredentials credentials) at MediaBrowser.Controller.Providers.DirectoryService.GetFileSystemEntriesInternal(String path) at System.Collections.Concurrent.ConcurrentDictionary`2[[System.String, System.Private.CoreLib, Version=8.0.0.0, Culture=neutral, PublicKeyToken=7cec85d7bea7798e],[MediaBrowser.Model.IO.FileSystemMetadata[], MediaBrowser.Model, Version=4.9.1.36, Culture=neutral, PublicKeyToken=null]].GetOrAdd(String key, Func`2 valueFactory) at MediaBrowser.Controller.Providers.DirectoryService.GetFileSystemEntries(String path, Boolean clearCache) at MediaBrowser.Controller.Providers.DirectoryService.GetFileSystemEntries(String path) at MediaBrowser.Controller.Entities.Video.GetBifsFromFolder(IDirectoryService directoryService, String folder, String requiredPrefix) at MediaBrowser.Controller.Entities.Video.GetLocalBifs(String videoPath, IDirectoryService directoryService) at MediaBrowser.Controller.Entities.Video.GetLocalThumbnailSetInfos(String videoPath, Guid itemGuid, Boolean enableCache, IDirectoryService directoryService) at MediaBrowser.Controller.Entities.Video.GetThumbnailSetInfos(String videoPath, Guid itemGuid, Boolean enableCache, IDirectoryService directoryService) at MediaBrowser.Controller.Entities.Video.GetThumbnailSetInfos(String videoPath, Guid itemGuid, IDirectoryService directoryService, Int32 maxWidth, Boolean enableStrictWidthRequirement) at RokuMetadata.Api.BifService.Get(GetThumbnails request) at System.Object.lambda_method576(Closure , Object , Object ) at Emby.Server.Implementations.Services.ServiceController.Execute(HttpListenerHost appHost, Object requestDto, IRequest req, Type serviceType) at Emby.Server.Implementations.Services.ServiceHandler.ProcessRequestAsync(HttpListenerHost httpHost, IServerApplicationHost appHost, IRequest httpReq, IResponse httpRes, IStreamHelper streamHelper, RestPath restPath, String responseContentType, CancellationToken cancellationToken) at Emby.Server.Implementations.HttpServer.HttpListenerHost.RequestHandler(IRequest httpReq, RestPath restPath, String urlString, String localPath, String contentTypeInPath, CancellationToken cancellationToken) Source: Emby.Server.Implementations TargetSite: Void .ctor(EzSmb.Paths.PathSet, EzSmb.Params.ParamSet) 2025-10-05 20:21:08.942 Info BifService-0HNG3RP0UM1DR:00000006: http/1.1 Response 500 to host3. Time: 59ms. GET http://192.168.68.108:8096/emby/items/7762/ThumbnailSet?MediaSourceId=mediasource_7762. 2025-10-05 20:21:08.983 Info PlaystateService-0HNG3RP0UM1DQ:00000025: http/1.1 Response 204 to host3. Time: 103ms. POST http://192.168.68.108:8096/emby/Sessions/Playing. 2025-10-05 20:21:08.994 Info Trakt: Playback Started 2025-10-05 20:21:09.101 Info HttpClient: POST https://api.trakt.tv/oauth/token 2025-10-05 20:21:09.244 Info HttpClient: Http response 200 from https://api.trakt.tv/oauth/token after 142ms 2025-10-05 20:21:09.282 Info Trakt: New trakt token info: {"access_token":"675eea35ee47a488569fd7e6f73f87b259d90b9b80b706d5beb69be2b310b874","token_type":"Bearer","expires_in":86400,"refresh_token":"60f75d1735eb33698e5757affc84024d4da66183a8a28fe9d14e76c71e8805f0","scope":"public","created_at":1759692069}. 2025-10-05 20:21:09.283 Info BaseItem: Updating trakt user, reset pin info: False embyserver.txt Edited October 5, 2025 by GiGo attachment added as it didn't upload
Luke 42237 Posted October 5, 2025 Posted October 5, 2025 1 hour ago, GiGo said: Not sure if it's an issue with Emby or if it's my device, but every few hours if I'm accessing a SMB it fails. Local plugged in devices are accessed fine. I have to restart Emby for the SMB link to work, SMB's work fine in file apps. Log attached: Relevant part here: OS/Process: Arm64/Arm64 Framework: .NET 8.0.20 Runtime: System.Private.CoreLib.dll Processor count: 8 Data path: /storage/emulated/0/Android/data/com.emby.embyserver/files Application path: /data/user/0/com.emby.embyserver Fingerprint: Xiaomi/umi_eea/umi:13/TKQ1.221114.001/V816.0.1.0.TJBEUXM:user/release-keys Model: Mi 10 - Xiaomi/Xiaomi Hardware: umi/umi_eea/qcom/umi SupportedAbis: arm64-v8a, armeabi-v7a, armeabi System.IO.IOException: System.IO.IOException: Authentication Failed. at EzSmb.Transports.Connection..ctor(PathSet pathSet, ParamSet paramSet) at EzSmb.Node.GetNode(String path, ParamSet paramSet, Nullable`1 isDirectory) at Emby.Server.Implementations.IO.SmbFileSystem.GetNode(String path, FileSystemCredentials credentials, Nullable`1 isDirectory) at Emby.Server.Implementations.IO.SmbFileSystem.CreateSmbDirectoryForListFiles(String path, FileSystemCredentials credentials) at Emby.Server.Implementations.IO.SmbFileSystem.GetFileSystemEntries(String path, FileSystemCredentials credentials, Boolean recursive) at Emby.Server.Implementations.IO.ManagedFileSystem.GetFileSystemEntries(String path, Boolean recursive, FileSystemCredentials credentials) at MediaBrowser.Controller.Providers.DirectoryService.GetFileSystemEntriesInternal(String path) at System.Collections.Concurrent.ConcurrentDictionary`2[[System.String, System.Private.CoreLib, Version=8.0.0.0, Culture=neutral, PublicKeyToken=7cec85d7bea7798e],[MediaBrowser.Model.IO.FileSystemMetadata[], MediaBrowser.Model, Version=4.9.1.36, Culture=neutral, PublicKeyToken=null]].GetOrAdd(String key, Func`2 valueFactory) at MediaBrowser.Controller.Providers.DirectoryService.GetFileSystemEntries(String path, Boolean clearCache) at MediaBrowser.Controller.Providers.DirectoryService.GetFileSystemEntries(String path) at MediaBrowser.Controller.Entities.Video.GetBifsFromFolder(IDirectoryService directoryService, String folder, String requiredPrefix) at MediaBrowser.Controller.Entities.Video.GetLocalBifs(String videoPath, IDirectoryService directoryService) at MediaBrowser.Controller.Entities.Video.GetLocalThumbnailSetInfos(String videoPath, Guid itemGuid, Boolean enableCache, IDirectoryService directoryService) at MediaBrowser.Controller.Entities.Video.GetThumbnailSetInfos(String videoPath, Guid itemGuid, Boolean enableCache, IDirectoryService directoryService) at MediaBrowser.Controller.Entities.Video.GetThumbnailSetInfos(String videoPath, Guid itemGuid, IDirectoryService directoryService, Int32 maxWidth, Boolean enableStrictWidthRequirement) at RokuMetadata.Api.BifService.Get(GetThumbnails request) at System.Object.lambda_method576(Closure , Object , Object ) at Emby.Server.Implementations.Services.ServiceController.Execute(HttpListenerHost appHost, Object requestDto, IRequest req, Type serviceType) at Emby.Server.Implementations.Services.ServiceHandler.ProcessRequestAsync(HttpListenerHost httpHost, IServerApplicationHost appHost, IRequest httpReq, IResponse httpRes, IStreamHelper streamHelper, RestPath restPath, String responseContentType, CancellationToken cancellationToken) at Emby.Server.Implementations.HttpServer.HttpListenerHost.RequestHandler(IRequest httpReq, RestPath restPath, String urlString, String localPath, String contentTypeInPath, CancellationToken cancellationToken) Source: Emby.Server.Implementations TargetSite: Void .ctor(EzSmb.Paths.PathSet, EzSmb.Params.ParamSet) 2025-10-05 20:21:08.942 Info BifService-0HNG3RP0UM1DR:00000006: http/1.1 Response 500 to host3. Time: 59ms. GET http://192.168.68.108:8096/emby/items/7762/ThumbnailSet?MediaSourceId=mediasource_7762. 2025-10-05 20:21:08.983 Info PlaystateService-0HNG3RP0UM1DQ:00000025: http/1.1 Response 204 to host3. Time: 103ms. POST http://192.168.68.108:8096/emby/Sessions/Playing. 2025-10-05 20:21:08.994 Info Trakt: Playback Started 2025-10-05 20:21:09.101 Info HttpClient: POST https://api.trakt.tv/oauth/token 2025-10-05 20:21:09.244 Info HttpClient: Http response 200 from https://api.trakt.tv/oauth/token after 142ms 2025-10-05 20:21:09.282 Info Trakt: New trakt token info: {"access_token":"675eea35ee47a488569fd7e6f73f87b259d90b9b80b706d5beb69be2b310b874","token_type":"Bearer","expires_in":86400,"refresh_token":"60f75d1735eb33698e5757affc84024d4da66183a8a28fe9d14e76c71e8805f0","scope":"public","created_at":1759692069}. 2025-10-05 20:21:09.283 Info BaseItem: Updating trakt user, reset pin info: False embyserver.txt 17.96 MB · 0 downloads Hi, are you sure you configured your smb credentials in the options for the library?
GiGo 108 Posted October 6, 2025 Posted October 6, 2025 6 hours ago, Luke said: Hi, are you sure you configured your smb credentials in the options for the library? Yes, 100% did and it has connected and played perfectly fine before. I've done it again and saved so I'll monitor it and see what happens. Could it possibly loose the credentials causing the issue?
Luke 42237 Posted October 6, 2025 Posted October 6, 2025 I don't think so but please let us know how that goes. Thanks.
GiGo 108 Posted October 7, 2025 Posted October 7, 2025 On 06/10/2025 at 04:53, Luke said: I don't think so but please let us know how that goes. Thanks. Seems I have an the same issue again, a restart of the server solved the issue, ie I can then stream from my SMB mount. The device was still connected to the network, it could still access my SMB mounts in other apps. Logged attached. embyserver.txt
Luke 42237 Posted October 7, 2025 Posted October 7, 2025 Hi, that log looks OK. what exactly happened?
GiGo 108 Posted October 8, 2025 Posted October 8, 2025 10 hours ago, Luke said: Hi, that log looks OK. what exactly happened? It fails to play anything from my SMB mount point. I get the usual 'no valid streams available' and it skips to the next file, which of course then fails too. I have to restart the server app for it to stream again.
Luke 42237 Posted October 13, 2025 Posted October 13, 2025 OK that’s odd. We’ll take a look at it. Thanks.
