ITGuy1024 18 Posted November 16, 2023 Posted November 16, 2023 I tried enabling and disabling "allow hardware transcoding" (If enabled, allow the tuner to transcode streams on the fly. This may help reduce transcoding required by Emby Server) and that didn't seem to make any difference. It can be fine for a bit (20 minutes) then freeze up. Or just freeze up every ~minute or so. Tuner: HDHR5 GPU: P400 CPU: E5-1607 These don't seem to be doing much resource wise during when playing. Playback via local or emby.mydomain.com seems about the same. A little more stutter playing remotely. https://app.emby.media/ seems a little better vs my server. Seems like a similar issue to this thread
Q-Droid 1011 Posted November 17, 2023 Posted November 17, 2023 What happens if you skip back once after around 15 seconds of play or pause playback for a bit?
