fcimeson 11 Posted November 16, 2023 Posted November 16, 2023 (edited) I don't think it happens all of the time but often my tv goes to the next episode despite my preference to not automatically play the next episode. Edited November 16, 2023 by fcimeson 1
fcimeson 11 Posted November 16, 2023 Author Posted November 16, 2023 I think this only happens when playing from the library, not continue watching.
Luke 42234 Posted November 16, 2023 Posted November 16, 2023 Hi there, where exactly did you play from?
fcimeson 11 Posted November 16, 2023 Author Posted November 16, 2023 I go to the library cartons, scroll down to minions, and click play. Then it will play episode after episode, season after season.
unisoft 355 Posted November 18, 2023 Posted November 18, 2023 (edited) +1 Its a bug for sure. I'm pretty sure I reported on here as this bug been around a few versions, just like AUTOMATIC speed detection when over a WAN - that has never worked properly either; at least on cable broadband detection. You have to set a specific mbps value for it to work and not transcode media when it should direct play, as supported format and speed way above the mbps of the media file. Edited November 18, 2023 by unisoft
Luke 42234 Posted February 13, 2024 Posted February 13, 2024 HI, can you please try Emby for LG 1.0.41? thanks !
fcimeson 11 Posted February 15, 2024 Author Posted February 15, 2024 Yup that worked bit this new version takes longer to start up.
Luke 42234 Posted February 15, 2024 Posted February 15, 2024 5 hours ago, fcimeson said: Yup that worked bit this new version takes longer to start up. Hi, where exactly does it take longer?
fcimeson 11 Posted February 15, 2024 Author Posted February 15, 2024 The startup screen, the one just before the homescreen. 1
unisoft 355 Posted February 16, 2024 Posted February 16, 2024 FYI. On two TVs (2016OLED and 2017LED models, it just sat on the Emby start-up logo after upgrade. Kill Emby off and all is fine from the second launch.
fcimeson 11 Posted February 16, 2024 Author Posted February 16, 2024 I've upgraded the server but no change. I think it will hang indefinitely, I'm not sure. If I switch to another app and back again it kind of solves the problem. It still hangs longer than it use to but it gets to the home screen. Should I create another issue? PS. There are no performance issues when using the web interface.
Luke 42234 Posted February 16, 2024 Posted February 16, 2024 OK we'll take a look at it. Thanks for reporting.
fcimeson 11 Posted March 14, 2024 Author Posted March 14, 2024 After the latest upgrade, the server no longer hangs. Thanks for the support! 1
