Gilgamesh_48 1244 Posted September 23, 2025 Posted September 23, 2025 2 hours ago, Luke said: You should be able to delete many in bulk using the multi-select tool. That is exactly what I did fairly recently when I set up a new server. I simply forgot to turn that off during the setup process and I had way too many meaningless and useless collections. ex. There were 5 different collections for Godzilla. There should be only one and now there is. It should be noted that the default for automatic collections should be off but Emby seems to really think that on is the correct setting. But it was my fault and I know better so I cannot "blame" Emby for my stupidity, as much as I want to. But don't worry Emby I am quite sure I will find other things to blame you for so you need not feel left out. 1
IcedTea123 3 Posted September 24, 2025 Posted September 24, 2025 Using the multi-select on collections says it will delete them from my file system? Uhhhhh, no? Why would I want that? Is the wording bad, meaning it will just delete the pointers to the collection, or will it delete the underlying movies, which would be a BAD thing? At the least, the wording is not optimal. 1
Luke 42289 Posted September 24, 2025 Posted September 24, 2025 31 minutes ago, IcedTea123 said: Using the multi-select on collections says it will delete them from my file system? Uhhhhh, no? Why would I want that? Is the wording bad, meaning it will just delete the pointers to the collection, or will it delete the underlying movies, which would be a BAD thing? At the least, the wording is not optimal. it's just a generic delete message that is used for everything.
IcedTea123 3 Posted September 24, 2025 Posted September 24, 2025 I would throw in a message like "Delete Collections? No actual video files on disk will be deleted." Etc. 1
Luke 42289 Posted September 24, 2025 Posted September 24, 2025 18 minutes ago, IcedTea123 said: I would throw in a message like "Delete Collections? No actual video files on disk will be deleted." Etc. Yes it makes sense. Thanks.
ZanderKeen 73 Posted September 24, 2025 Posted September 24, 2025 10 hours ago, Luke said: Being able to pin a playlist of collection to the homescreen and turn it into a section is something we plan to do. This would be great!!!! 1 1
