Caryuan 1 Posted November 15, 2023 Posted November 15, 2023 Emby for android TV cannot keep playback records when using kodi as an external player,Is there any solution? Thank you.
Luke 42233 Posted November 16, 2023 Posted November 16, 2023 Hi, when you use an external player, there is no standardized way to get this information from the player that you're launching. That means in order for Emby for Android TV to do this, it would have to support each external player individually. Why not just use the internal player?
Caryuan 1 Posted November 17, 2023 Author Posted November 17, 2023 I use emby for android TV on Zidoo media player, but it cannot output TrueHd and DTS HDMA audio tracks, so I use Kodi instead.
Caryuan 1 Posted November 17, 2023 Author Posted November 17, 2023 Kodi is the most powerful playback software on the Android platform, just like Infuse on Apple TV. You can consider adding this function. I admire you. 1
TeamB 2440 Posted November 21, 2023 Posted November 21, 2023 (edited) On 11/17/2023 at 6:28 PM, Caryuan said: Kodi is the most powerful playback software on the Android platform, just like Infuse on Apple TV. You can consider adding this function. I admire you. why not use one of the kodi plugins like embycon or emby nextt gen and just run kodi only. Edited November 21, 2023 by TeamB
