tree2369 16 Posted November 15, 2023 Posted November 15, 2023 Been getting a bug recently where if I scroll down in the Live TV guide it scrolls fine. But then when I scroll back up, the guide can get stuck or skip up to the top menu. Seems to mainly happen if I’m scrolling up and it moves backwards to a previous tv show instead of the currently playing tv show. It’s like it will only scroll up consistently if the currently live show is highlighted? Hopefully I’ve explained that okay. Thanks
tree2369 16 Posted November 15, 2023 Author Posted November 15, 2023 Yep spot on that’s the same issue I’m having. Hopefully will be resolved at some stage, makes navigating the guide a slow process at times haha.
Luke 42240 Posted November 19, 2023 Posted November 19, 2023 HI, yes we are looking into this. Thanks.
