itzak 0 Posted November 13, 2023 Posted November 13, 2023 I use the IPTV plugin on Emby. I have the following problem: On the web-based display, I can turn off the display of logos and channel numbers, and it only shows the channel name in the left column in bold. This is very readable at a distance, and that is what I prefer. On the Android TV app, I cannot turn off the display of logos and channel numbers in the left column. When seated in a chair, it's not possible to see the channel logo as it is made smaller to display the channel number, which is very large and bold. For me, channel numbers are useless anyway, since I have so many channels. I use favorites to keep the channels I want listed first. What I want is for the channel name only to be displayed in the left column. That would be readable across the room and USEFUL. Thanks
ebr 16331 Posted November 13, 2023 Posted November 13, 2023 Hi. Can you try sideloading our standard android app on the same device and see how that compares? https://emby.media/emby-for-android.html Thanks.
