Jen25 34 Posted November 13, 2023 Posted November 13, 2023 (edited) Going into movies folder, coverart quality is low compared to recently added movies area. Same situation - once I enter a movie, the quality of the image is fine. Movies --> all images are low quality Enter a movie --> main image quality is fine Recently added movies --> image quality is fine The images below don't show as well the difference in quality I see, but it gives you an idea of the difference. all movies details page recently added Edited November 13, 2023 by dnicks
Luke 42185 Posted November 13, 2023 Posted November 13, 2023 Hi, please attach the emby server log from when the problem occurred: How to Report a Problem Thanks.
tedfroop21 89 Posted November 13, 2023 Posted November 13, 2023 You need to log in as ADMIN so you are allowed to change stuff. (This is also assuming you are a Premier member.) Go to a movie you want a better image or different image for. When you hover the cursor over the movie you will see 4 icons. Play in the centre, a check mark on the lower left, a heart in the lower centre and three dots on the lower right. Click on the three dots. From the menu that opens pick Edit Images. On the next screen you can see all the associated images for the file. Clicking on the magnifying glass will bring up available images for your movie/tv show/whatever and you can usually pick a high quality image from the available images as they show the pixel size below each image. If you would rather add your own image - hover the mouse over any image section and the three dots appear on the right of the image. From that menu you can pick your own image from a url or upload an image.
Jen25 34 Posted November 14, 2023 Author Posted November 14, 2023 (edited) 21 hours ago, Luke said: Hi, please attach the emby server log from when the problem occurred: How to Report a Problem Thanks. @LukeIt occurs everywhere, all the time, on roku, desktop, apple tv thanks embyserver.txt Edited November 14, 2023 by dnicks
Jen25 34 Posted November 14, 2023 Author Posted November 14, 2023 20 hours ago, tedfroop21@gmail.com said: You need to log in as ADMIN so you are allowed to change stuff. (This is also assuming you are a Premier member.) Go to a movie you want a better image or different image for. When you hover the cursor over the movie you will see 4 icons. Play in the centre, a check mark on the lower left, a heart in the lower centre and three dots on the lower right. Click on the three dots. From the menu that opens pick Edit Images. On the next screen you can see all the associated images for the file. Clicking on the magnifying glass will bring up available images for your movie/tv show/whatever and you can usually pick a high quality image from the available images as they show the pixel size below each image. If you would rather add your own image - hover the mouse over any image section and the three dots appear on the right of the image. From that menu you can pick your own image from a url or upload an image. yeah, I've done that. Every movie or tv show image on the main screen is low quality, but that same image looks much better once I click into the movie details page. It's the same image.
Luke 42185 Posted November 24, 2023 Posted November 24, 2023 Hi, we'll take a look at this. Thanks for reporting.
