LittleWizard 31 Posted November 12, 2023 Posted November 12, 2023 I have link to an xmltv epg which seems not to work in emby. It has xz compression. Inside the compressed file the epg has not file extension (don't know if this matter). If I open it in windows with winrar and notepad++ is a perfect xmltv file. I use it in Tv headend with a specific python script. My emby server is on a SynologyNas. Is it due to the xz compression? other epg sources with gz compression do work Thanks!
LittleWizard 31 Posted November 12, 2023 Author Posted November 12, 2023 This is the link http://rytecepg.epgspot.com/epg_data/rytecIT_Basic.xz
Luke 42237 Posted November 12, 2023 Posted November 12, 2023 HI there, please try refreshing the guide data in emby server and then attach the emby server log: How to Report a Problem Thanks.
LittleWizard 31 Posted November 12, 2023 Author Posted November 12, 2023 Ok. I'll do it tomorrow. Also with xz file the epg update takes no time and when I go in the "edit metadata" of a channel to check if it has the new guide as an option for epg source, emby keeps on showing a spinning wheel. In the meanwhile I have done a simple bash that download the xz file, unxz it and add xml extension. I set that downloaded file as local epg source and it works. Running the script in synology scheduler every day, should work.
LittleWizard 31 Posted November 13, 2023 Author Posted November 13, 2023 Here is the LOG. I removed every EPG source, waited the server to end updating, than at time 11:01 added http://rytecepg.epgspot.com/epg_data/rytecIT_Basic.xz as source epg (ITALY>XMLTV) As I told, unzippig (un-xz) the file and adding the .xml extension, does work as local source. embyserver.txt
Luke 42237 Posted November 16, 2023 Posted November 16, 2023 Hi @LittleWizardcan you please attach a copy of the .xz file for testing? Maybe zip it up to make sure the forum compression software doesn't mess with it. Thanks.
LittleWizard 31 Posted November 17, 2023 Author Posted November 17, 2023 Don't you are able to download it from the link http://rytecepg.epgspot.com/epg_data/rytecIT_Basic.xz ? Do you prefer I attach it?
LittleWizard 31 Posted November 17, 2023 Author Posted November 17, 2023 Here it is. rytecIT_Basic.xz
Luke 42237 Posted November 19, 2023 Posted November 19, 2023 Thanks! This has been resolved as part of the upcoming 4.8 server release.
