ThePhantom79 0 Posted November 9, 2023 Posted November 9, 2023 Hello, I installed emby on a remote Fire TV stick (via Amazon Appstore on web - automatic installation). If I open Emby and I enter for the first time the User / Password - emby dont ask again for the password. If I log out from emby, the App closes completly, but the user is not logged out --> If I open Emby again, the user is logged in without any interaction. As this should prevent kids from using emby, its very important, that there is an validation when starting the app ... Any hints?
GrimReaper 4898 Posted November 9, 2023 Posted November 9, 2023 What is your Start Up Behavior set to in app Startup settings?
ThePhantom79 0 Posted November 9, 2023 Author Posted November 9, 2023 Which setting? In Fire TV settings or in Emby App settings? Or on Emby Server?
GrimReaper 4898 Posted November 9, 2023 Posted November 9, 2023 58 minutes ago, GrimReaper said: in app Startup settings Fire TV app, cog icon top right on Home Screen, Startup tab.
ThePhantom79 0 Posted November 9, 2023 Author Posted November 9, 2023 I have only 'Settings' on the upper right corner. In the settings, I can't find a startup settings. In App settings I can only manage delete cache, deinstall and so on...
GrimReaper 4898 Posted November 10, 2023 Posted November 10, 2023 In your Emby for Fire TV app, client app you're having issues with, log-in and once on Home Screen press cog icon/go to in-app Settings.
rbjtech 5344 Posted November 10, 2023 Posted November 10, 2023 (edited) FYI - Depending on the Server Version (Beta or Stable) and the AndroidTV/FireTV App version - the introduction of an optional 'PIN' has also now been added. The saving of multiple accounts/passwords to the local device is now allowed and thus, as you have witnessed - this potentially means users can access content by just selecting that user from the 'user list' (another option in the Android TV startup options). To 'protect' admin or adult accounts from being used by children, the PIN feature is a great addition for use on shared devices. The PIN is stored on the server, linked to the account - and is the same for each device in use. When first logging in on that new device - you will be asked if you want it protected by the same account PIN. If you do, then each time you select to use that account on that device - it will auto log you in - but it will now also ask for the PIN. Edited November 11, 2023 by rbjtech
ThePhantom79 0 Posted November 13, 2023 Author Posted November 13, 2023 Hi, yes, I didnt know about this menu - so now I get asked about a password each time. More interesting is th "additional" PIN feature. I cant find it- which version do I need for this ? My Server Version is 4.7.11.0
ebr 16337 Posted November 13, 2023 Posted November 13, 2023 5 hours ago, ThePhantom79 said: More interesting is th "additional" PIN feature Hi. That is a new feature in the upcoming 4.8 server and has not been implemented in the TV app at this time. 1
dodgercunt 0 Posted November 19, 2023 Posted November 19, 2023 Does this site actually work as you are making it very difficult
GrimReaper 4898 Posted November 19, 2023 Posted November 19, 2023 28 minutes ago, dodgercunt said: Does this site actually work Which site?
Luke 42244 Posted November 19, 2023 Posted November 19, 2023 9 hours ago, dodgercunt said: Does this site actually work as you are making it very difficult Hi, can you please describe your issue in more detail? thanks.
