davedick 19 Posted November 4, 2023 Posted November 4, 2023 How does Emby Theater (remote access) determine the auto quality setting? I have the server set to 25 Mbps for the account, but ET keep using 5 Mbps for auto
Luke 42237 Posted November 7, 2023 Posted November 7, 2023 Hi, what version of Emby Theater are you using?
davedick 19 Posted November 10, 2023 Author Posted November 10, 2023 When I look at the Emby server admin summary page, it shows "Emby for Windows 1.1.517.70", but the device is an Xbox One
Luke 42237 Posted November 11, 2023 Posted November 11, 2023 21 hours ago, davedick said: When I look at the Emby server admin summary page, it shows "Emby for Windows 1.1.517.70", but the device is an Xbox One Right. Xbox runs windows. anyway to answer the question, we haven’t implemented this on Xbox so it’s using a default value. If that default is too conservative for you then you may want to raise it. We are working on a new windows app and getting this function implemented is on our checklist for it. Thanks.
