makin__ 0 Posted November 4, 2023 Posted November 4, 2023 Hi everyone, I just switched from Kodi and MPV as the external player to Emby as I really love the concept. However, I would like to use my own mpv.conf so I can set certain shaders and picture quality settings such as the hdr->sdr dynamic tone mapping (using spline) etc. I tried to set up the mpv.conf at %appdata%\mpv\mpv.conf but it is ignored. Can you guys help me? Thanks a lot
Guest Posted November 4, 2023 Posted November 4, 2023 The mpv.conf should be in the mpv folder, not its own folder
makin__ 0 Posted November 4, 2023 Author Posted November 4, 2023 Thanks for answering. The config I use for mpv is stored at mpv/portable_config/mpv.conf <- this one is not used by Emby Theater.
Guest Posted November 4, 2023 Posted November 4, 2023 It has to be in the mpv folder. The portable folder will isolate it from Theater,.
makin__ 0 Posted November 4, 2023 Author Posted November 4, 2023 Ok cool! Anything else to keep in mind regarding what can be set up in the config to not interfere with Theater?
Guest Posted November 4, 2023 Posted November 4, 2023 Some options will be overridden by the options in Theater. Such as the gpu-api and hardware acceleration. But for hardware acceleration, there is an option to let the conf set it.
makin__ 0 Posted November 4, 2023 Author Posted November 4, 2023 Ok, great. It's mainly HDR settings like: [HDR-Spline] profile-desc="HDR ST2094-10" profile-cond=p["video-params/primaries"]=="bt.2020" tone-mapping=spline target-peak=auto target-trc=auto hdr-compute-peak=yes allow-delayed-peak-detect builtin-scalers deband=no tone-mapping-param=default gamut-mapping-mode=relative target-contrast=auto And: # Scaling scale=ewa_lanczossharp # luma upscale dscale=mitchell # luma downscale cscale=ewa_lanczossharp # chroma up&downscale scale-antiring=0.4 # luma upscale deringing dscale-antiring=0.4 # luma downscale deringing cscale-antiring=0.4 # chroma upscale deringing correct-downscaling=yes linear-downscaling=yes #sigmoid-upscaling=yes gpu-shader-cache-dir="C:\Program Files\mpv-x86_64\portable_config\shaders_cache" glsl-shader="C:\Program Files\mpv-x86_64\portable_config\shaders\KrigBilateral.glsl" glsl-shader="C:\Program Files\mpv-x86_64\portable_config\shaders\SSimDownscaler.glsl" #glsl-shader="C:\Program Files\mpv-x86_64\portable_config\shaders\adaptive-sharpen.glsl" See any problems?
Guest Posted November 4, 2023 Posted November 4, 2023 Most of that should be fine, just make sure that corresponding options in Theater are disabled, and leave everything else on auto except for video output. Choose gpu-next.
makin__ 0 Posted November 4, 2023 Author Posted November 4, 2023 (edited) Just tried it and with the mpv.conf in C:\Program Files (x86)\mpv, it still does not work. Where can I find the logs to see whether Theater is at least trying to? Is there another mpv folder? What would have been if mpv wasn't installed in the first place? Theater must have mpv integrated somehow doesn't it? What about C:\Users\makin\AppData\Roaming\Emby-Theater\system\electronapp\libmpv\x64? I just stumbled upon this post here. In my initial post I mentioned that I tried C:\Users\makin\AppData\Roaming\mpv\mpv.conf at first. Edited November 4, 2023 by makin__
makin__ 0 Posted November 4, 2023 Author Posted November 4, 2023 The logs: 2023-11-04 18:46:10.505 Info Main: Application path: C:\Users\kodi\AppData\Roaming\Emby-Theater\system\Emby.Theater.exe 2023-11-04 18:46:10.507 Info Main: Emby Command line: C:\Users\kodi\AppData\Roaming\Emby-Theater\system\Emby.Theater.exe Operating system: Microsoft Windows NT 10.0.19045.0 64-Bit OS: True 64-Bit Process: False User Interactive: True Processor count: 6 Program data path: C:\Users\kodi\AppData\Roaming\Emby-Theater Application directory: C:\Users\kodi\AppData\Roaming\Emby-Theater\system 2023-11-04 18:46:10.546 Info Main: C:\Users\kodi\AppData\Roaming\Emby-Theater\system\x64\electron\electron.exe "C:\Users\kodi\AppData\Roaming\Emby-Theater\system\electronapp" "C:\Users\kodi\AppData\Roaming\Emby-Theater\data\electron" "C:\Users\kodi\AppData\Roaming\Emby-Theater\system\cec\cec-client.x64.exe" "C:\Users\kodi\AppData\Roaming\Emby-Theater\system\x64\mpv\mpv.exe" 2023-11-04 18:46:10.633 Info App: Application version: 3.0.20.0 2023-11-04 18:46:10.668 Info App: Application configuration: {"EnableDebugLevelLogging":false,"EnableAutoUpdate":true,"LogFileRetentionDays":3,"RunAtStartup":false,"IsStartupWizardCompleted":false} 2023-11-04 18:46:10.670 Info App: Loading MediaBrowser.Model, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null 2023-11-04 18:46:10.670 Info App: Loading MediaBrowser.Common, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null 2023-11-04 18:46:10.670 Info App: Loading Emby.Theater, Version=3.0.20.0, Culture=neutral, PublicKeyToken=null 2023-11-04 18:46:10.725 Info Main: HDMI CEC driver installation was previously cancelled. 2023-11-04 18:46:10.895 Info App: Core startup complete 2023-11-04 18:46:13.898 Info TaskManager: StartupTrigger fired for task: Check for application updates 2023-11-04 18:46:13.899 Info TaskManager: Queueing task SystemUpdateTask 2023-11-04 18:46:13.902 Info TaskManager: Executing Check for application updates 2023-11-04 18:46:13.925 Info HttpClient: HttpClientManager GET: https://api.github.com/repos/MediaBrowser/Emby.Theater.Windows/releases 2023-11-04 18:46:14.659 Info TaskManager: Check for application updates Completed after 0 minute(s) and 0 seconds 2023-11-04 18:46:14.687 Info TaskManager: ExecuteQueuedTasks 2023-11-04 18:47:36.941 Info Main: Http POST fileexists 2023-11-04 18:47:36.947 Info Main: Http Completed POST fileexists 2023-11-04 18:47:40.080 Info Main: Http POST fileexists 2023-11-04 18:47:40.080 Info Main: Http Completed POST fileexists 2023-11-04 18:48:44.291 Info App: Disposing ApplicationHost 2023-11-04 18:48:44.292 Info App: Disposing TaskManager 2023-11-04 18:48:44.293 Info App: Disposing InstallationManager 2023-11-04 18:48:44.294 Info Main: Releasing mutex 2023-11-04 18:48:44.294 Info Main: Releasing mutex
makin__ 0 Posted November 4, 2023 Author Posted November 4, 2023 I created the mpv.log file and it gets filled: mpv.log
Guest Posted November 4, 2023 Posted November 4, 2023 It looks like you've installed Theater here: C:\Users\kodi\AppData\Roaming So your mpv folder should be there, under that username
Guest Posted November 4, 2023 Posted November 4, 2023 It's reading auto profiles from somewhere [ 0.866][v][cplayer] Applying profile 'HDR'... [ 0.866][v][cplayer] Setting option 'target-trc' = 'auto' (flags = 4) [ 0.866][v][cplayer] Setting option 'target-peak' = '120' (flags = 4)
Guest Posted November 4, 2023 Posted November 4, 2023 (edited) Make sure you don't have conflicting mpv.conf files. You should have one in your mpv folder for one user and one in your portable. No others Edited November 4, 2023 by generiq
makin__ 0 Posted November 4, 2023 Author Posted November 4, 2023 Sorry, my user is „Kodi“, I did not want to confuse so that’s why I posted another user name (makin). I guess input.conf does not work and the info in the nerd menu is not altered right?
Guest Posted November 4, 2023 Posted November 4, 2023 Inputs are handled by electron. And the Theater stats won't show shader activity or any profiles. You'll need to look at your mpv logs
makin__ 0 Posted November 4, 2023 Author Posted November 4, 2023 (edited) Thank you so much. I got a plan for tomorrow then. Any feedback regarding shaders? Edited November 4, 2023 by makin__
Guest Posted November 4, 2023 Posted November 4, 2023 What were you wanting to know? There are a multitude of shaders that have different functionality. Example: https://github.com/natural-harmonia-gropius/hdr-toys/blob/master/gamut-mapping/clip.glsl
makin__ 0 Posted November 4, 2023 Author Posted November 4, 2023 Mainly whether I can use the same shaders and the spline tone mapping settings that I use in my Kodi+MPV setup.
Guest Posted November 4, 2023 Posted November 4, 2023 You should be able to. You just need to keep up to date with developments. Not only with the shaders but also with what hassn is developing with libplacebo and the renderers. There's no simple answer to that. You're going to have to manage what you use and read a lot. There is so much development in this area right now.
makin__ 0 Posted November 5, 2023 Author Posted November 5, 2023 (edited) Short update after tweaking the mpv.conf. My current mpv.conf: log-file="C:\Users\kodi\AppData\Roaming\mpv\mpv.log" save-position-on-quit=yes # certain scripts load-scripts=yes hwdec=d3d11va gpu-api=d3d11 gpu-context=d3d11 video-output-levels=full fbo-format=auto # fbo-format=rgba16f alternative deband=yes dither-depth=auto dither=fruit scale=ewa_lanczossharp dscale=mitchell cscale=ewa_lanczossharp scale-antiring=0.4 dscale-antiring=0.4 cscale-antiring=0.4 correct-downscaling=yes linear-downscaling=yes gpu-shader-cache-dir="C:\Users\kodi\AppData\Roaming\mpv\shaders_cache" glsl-shaders="C:\Users\kodi\AppData\Roaming\mpv\shaders\FSRCNNX_x2_8-0-4-1.glsl" glsl-shaders-append="C:\Users\kodi\AppData\Roaming\mpv\shaders\adaptive-sharpen.glsl" glsl-shaders-append="C:\Users\kodi\AppData\Roaming\mpv\shaders\KrigBilateral.glsl" [HDR] profile-desc="HDR" profile-cond=p["video-params/gamma"]=="pq" target-trc=auto target-peak=120 tone-mapping=spline hdr-compute-peak=yes gamut-mapping-mode=relative target-prim=bt.2020 [HDR-Old] profile-desc="HDR-Old" target-trc=auto target-peak=120 target-prim=bt.2020 tone-mapping=bt.2390 hdr-compute-peak=yes [SDR] profile-desc="SDR" profile-cond=p["video-params/primaries"]~=nil and p["video-params/primaries"]~="bt.2020" glsl-shaders="C:\Users\kodi\AppData\Roaming\mpv\shaders\FSRCNNX_x2_8-0-4-1.glsl" [25fps] profile-cond=get("estimated-vf-fps", -math.huge)==25 speed=0.95 mpv.log I attached the mpv.log created after starting and playing back a movie (4K). It looks good so far. What do you think? See any issues in the log? Thanks again for guiding me through everything, I really appreciate it. Edited November 5, 2023 by makin__
Guest Posted November 6, 2023 Posted November 6, 2023 Some of that won't have any effect, but shouldn't cause a problem. Post screenshots of the settings in Theater.
makin__ 0 Posted November 7, 2023 Author Posted November 7, 2023 Also, I could have sworn that before restarting the Emby Server, my Safari, Chrome ans iOS apps did not have to transcode (Audio), any idea what might cause this? ET does not have to...
