dustbro 5 Posted November 4, 2023 Posted November 4, 2023 Is there a way to change the playback speed via remote? I often switch between speeds and using the menu is cumbersome.
ebr 16335 Posted November 4, 2023 Posted November 4, 2023 Hi. Not at this time. Most modern device remotes have very few buttons on them so menus are the norm.
dustbro 5 Posted November 4, 2023 Author Posted November 4, 2023 Thanks for the reply! Could the menu commands be mapped to a keyboard? 1
dustbro 5 Posted November 4, 2023 Author Posted November 4, 2023 Or maybe place it in the transport section?
Luke 42243 Posted November 5, 2023 Posted November 5, 2023 9 hours ago, dustbro said: Or maybe place it in the transport section? Realistically, I don't see this being added directly to the transport bar, at least not as default behavior. It's just not something that most people use.
Luke 42243 Posted November 5, 2023 Posted November 5, 2023 Hi. Can you try sideloading our standard android app on the same device and see how that compares? https://emby.media/emby-for-android.html I'd like to know if you find this quicker to get to. Keyboard shortcuts are easily doable as well. Thanks.
leftcausedit 3 Posted January 9, 2025 Posted January 9, 2025 On 11/5/2023 at 1:23 PM, Luke said: Hi. Can you try sideloading our standard android app on the same device and see how that compares? https://emby.media/emby-for-android.html I'd like to know if you find this quicker to get to. Keyboard shortcuts are easily doable as well. Thanks. not easy-to-use enough, I think "long press dpad ok" is an acceptable way, for it's causing lags now (the video will play and pause repeatedly and interfaces will stutter).
Luke 42243 Posted January 9, 2025 Posted January 9, 2025 15 minutes ago, leftcausedit said: not easy-to-use enough, I think "long press dpad ok" is an acceptable way, for it's causing lags now (the video will play and pause repeatedly and interfaces will stutter). Hi, what exactly lags?
leftcausedit 3 Posted January 10, 2025 Posted January 10, 2025 12 hours ago, Luke said: Hi, what exactly lags? The interface will have no response or respond very slow for a few seconds, and the video will not play, I release the button, and have no idea the video is paused or not eventually, cuz the app is still loading or dealing with the play-pause-play-pause instructions. By the way, I use android standard app 3.4.20 tv mode on CCWGTV. And I think when dpad ok is pressed, the app is supposed to take action after I release it, instead of play and pause repeatedly when I’m still holding the button.
Luke 42243 Posted January 15, 2025 Posted January 15, 2025 On 1/10/2025 at 1:12 AM, leftcausedit said: The interface will have no response or respond very slow for a few seconds, and the video will not play, I release the button, and have no idea the video is paused or not eventually, cuz the app is still loading or dealing with the play-pause-play-pause instructions. By the way, I use android standard app 3.4.20 tv mode on CCWGTV. And I think when dpad ok is pressed, the app is supposed to take action after I release it, instead of play and pause repeatedly when I’m still holding the button. HI, we'll take a look at it. Thanks.
Luke 42243 Posted January 19 Posted January 19 For video stuttering, please try Emby for Android 3.5.25 and let us know how that compares: https://emby.media/emby-for-android.html Thanks.
