jatobi 2 Posted November 19, 2023 Author Posted November 19, 2023 3 hours ago, Luke said: What version of dsm are you on? What beta file did you try to install? Please see these posts for answers. I’m assuming that’s the latest beta Carlo linked and asked me to install. To which it wouldn’t as my last reply screenshot shows.
Luke 42241 Posted November 19, 2023 Posted November 19, 2023 13 hours ago, jatobi said: Please see these posts for answers. I’m assuming that’s the latest beta Carlo linked and asked me to install. To which it wouldn’t as my last reply screenshot shows. But can you please tell us the exact file name that you tried to install? Thanks.
jatobi 2 Posted November 19, 2023 Author Posted November 19, 2023 15 minutes ago, Luke said: But can you please tell us the exact file name that you tried to install? Thanks. emby-server-synology7-mono_4.8.0.59_armv7_legacy
jatobi 2 Posted November 20, 2023 Author Posted November 20, 2023 6 minutes ago, Luke said: What model do you have? i have a DS1515+. I am currently upgraded to the limit until they release another build for this model. See above.
Solution Luke 42241 Posted December 30, 2023 Solution Posted December 30, 2023 Can you try installing the latest build and see if anything changes? Thanks.
jatobi 2 Posted December 30, 2023 Author Posted December 30, 2023 (edited) 27 minutes ago, Luke said: Can you try installing the latest build and see if anything changes? Thanks. This seems to work, I no longer get that error in any of the logs. TV in the living room works flawlessly now. TV in my room is having troubles but I think that's my TV and not Emby. Odd that this happened like this, wonder what broke it. Thanks Edited December 30, 2023 by jatobi 1
jatobi 2 Posted December 31, 2023 Author Posted December 31, 2023 Wanted to report back: Since my bedroom TV was still having issues, and unsure why because no errors were throwing, you could see the transcode folder being written to temp files during the transcode, but it simply wouldn't play, I decided to nuke the TV. Factory reset and now the bedroom TV works flawlessly as well. So it seems like the latest beta version fixed whatever issue the Roku 12.5 update back in September caused, and this TV simply needed a factory reset to clear all data and start fresh to work. Hope this helps someone else. Thanks all! 1
