hawk223 9 Posted November 2, 2023 Posted November 2, 2023 Is there a way to configure something other than Opensubtitles. Opensubtitles sucks. They are embedding ads in the subtitles. I don't want this garbage and I don't want to manually edit them to remove.
GrimReaper 4844 Posted November 2, 2023 Posted November 2, 2023 (edited) There are several subtitle plugins in the Catalogue (though OpenSubtitles is by far the best source), you're not forced to use OpenSubtitles. And not sure if it's still the case, but VIP members shouldn't have ads inserted. Nor should subs manually downloaded from their web site. You can also post-process the files to remove unwanted lines of text. Edit: https://forum.opensubtitles.org/viewtopic.php?t=17459 Edited November 2, 2023 by GrimReaper Link
Luke 42185 Posted December 13, 2023 Posted December 13, 2023 Support for opensubtitles.com has been added on the 4.8 beta channel:
