axelsl 19 Posted November 1, 2023 Posted November 1, 2023 (edited) Hello, I would love to be able to multi select live tv channels in the set up screen and drag and drop several channels at the same time to modify the sort order. For example: Original list of channels: Channel A Channel B Channel C Channel D Channel E Channel F Channel G Ability to select channels D, E and G at the same time and drag and drop them after channel B for the following result: Channel A Channel B Channel D Channel E Channel G Channel C Channel F Thanks for your consideration! Edited November 1, 2023 by axelsl added tags 2
Luke 42246 Posted November 1, 2023 Posted November 1, 2023 Hi, yes it's planned for future updates. Thanks. 1 1
