Guest Sahx11 Posted November 1, 2023 Posted November 1, 2023 Hi, I already signed up to this application and subscribed but I cannot add a local user nor using the key number what shall I do?
Abobader 3485 Posted November 1, 2023 Posted November 1, 2023 Hello Sahx11, ** This is an auto reply ** Please wait for someone from staff support or our members to reply to you. It's recommended to provide more info, as it explain in this thread: Thank you. Emby Team
pwhodges 2023 Posted November 1, 2023 Posted November 1, 2023 3 minutes ago, Sahx11 said: Hi, I already signed up to this application and subscribed Subscribed to what? Paul
Guest Sahx11 Posted November 1, 2023 Posted November 1, 2023 1 minute ago, pwhodges said: Subscribed to what? Paul To empy premiere
pwhodges 2023 Posted November 1, 2023 Posted November 1, 2023 Emby Premiere is an optional facility which adds features to your server; when you have installed your server, you can add your Premiere key to it, and a range of additional facilities becomes available. If you don't need those facilities, you can run your server without Premiere. If you are not running your own server, Premiere is doing nothing for you. Paul
Guest Sahx11 Posted November 1, 2023 Posted November 1, 2023 Just now, pwhodges said: Emby Premiere is an optional facility which adds features to your server; when you have installed your server, you can add your Premiere key to it, and a range of additional facilities becomes available. If you don't need those facilities, you can run your server without Premiere. If you are not running your own server, Premiere is doing nothing for you. Paul How to install my own server?
pwhodges 2023 Posted November 1, 2023 Posted November 1, 2023 3 minutes ago, Sahx11 said: How to install my own server? https://emby.media/support/articles/Quick-Start.html When you have installed your server, then you add your media to it, and maybe link it to live TV sources (requires Premiere). Emby does not provide any media - you supply that yourself. Paul
