gene0915 42 Posted October 30, 2023 Posted October 30, 2023 (edited) Using Debian 12 and Emby server 4.7.14.0 A few months ago, I moved my Emby server to a new box. Before doing so, I could have sworn that in the 'Advanced' Transcoding section, I saw entries for VAAPI -and- QuickSync. On this new system, I only see VAAPI and, it's detecting my CPU as a Xeon? .... but it's an i3-4370: lscpu Architecture: x86_64 CPU op-mode(s): 32-bit, 64-bit Address sizes: 39 bits physical, 48 bits virtual Byte Order: Little Endian CPU(s): 4 On-line CPU(s) list: 0-3 Vendor ID: GenuineIntel Model name: Intel(R) Core(TM) i3-4370 CPU @ 3.80GHz /opt/emby-server/bin/emby-ffmpeg -hwaccels ffmpeg version 5.0.0-emby_2022_05_27-u1 Copyright (c) 2000-2022 the FFmpeg developers and softworkz for Emby LLC built with gcc 8.3.0 (crosstool-NG 1.24.0) Execution Date: 2023-10-30 11:42:40 Hardware acceleration methods: cuda vaapi qsv drm opencl vulkan ls -la /dev/dri/ total 0 drwxr-xr-x 3 root root 100 Oct 30 06:15 . drwxr-xr-x 20 root root 3980 Oct 30 06:15 .. drwxr-xr-x 2 root root 80 Oct 30 06:15 by-path crw-rw----+ 1 root video 226, 0 Oct 30 06:15 card0 crw-rw----+ 1 root render 226, 128 Oct 30 06:15 renderD128 id emby uid=998(emby) gid=998(emby) groups=998(emby),44(video),106(render) This a bug or nothing to worry about? hardware_detection-63834243342.txt Edited October 30, 2023 by gene0915
Luke 42245 Posted October 30, 2023 Posted October 30, 2023 Hi, you'll be fine with vaapi. For the latest intel hardware you may need to use the 4.8 beta server for QuickSync to show up.
gene0915 42 Posted October 30, 2023 Author Posted October 30, 2023 2 hours ago, Luke said: Hi, you'll be fine with vaapi. For the latest intel hardware you may need to use the 4.8 beta server for QuickSync to show up. Sounds good and as always, thanks Luke! 1
