nunu22 2 Posted October 30, 2023 Posted October 30, 2023 Hello ! i have notice a problem while rewind/forward during video play: after some rewind/forward a big lag between video & audio appears. most of the time, the first fast-forward/rewind works without a hitch, but suddenly a big lag appears. Have you already met this issue ? regards
Luke 42185 Posted October 31, 2023 Posted October 31, 2023 Hi there, let's look at an example. Please attach the information requested in how to report a media playback issue. Thanks!
nunu22 2 Posted October 31, 2023 Author Posted October 31, 2023 hi ! thanks for your answer unfortunatly (or not ), i have not reproduce the issue .... maybe it is because i have installed last android apk version and not used the android tv one ? regards
nunu22 2 Posted October 31, 2023 Author Posted October 31, 2023 (edited) problem reproduced. On movie "First man" in logs. problem appears (last minutes of the logs) on a forward and in same time the movie has became degraded (not smooth). embyserver (1).txt Edited October 31, 2023 by nunu22
nunu22 2 Posted November 1, 2023 Author Posted November 1, 2023 (edited) yes ! no transcoding. I just need to go back to menu and to restart the movie playbacl (from where i leaved), and all is ok (playback ok, and sound well synchronized) Edited November 1, 2023 by nunu22
visproduction 328 Posted November 2, 2023 Posted November 2, 2023 Try a test video that is known to be correct with a proper video index. Quite often video found online has errors that don't show up with dedicated player software because these apps check for problems and fix them on the fly. Where as direct playback in browsers can fail if the video has index errors. So, just because it plays back elsewhere, does not mean the video is free from problems. You can also try remuxing the video with a video editor or app that fixes issues. The easiest way is to use a proper test video and if that works, you know it's pretty much your video that has problems. Hope that helps. 1
nunu22 2 Posted November 2, 2023 Author Posted November 2, 2023 thanks for your answer ! i wasn't aware of this king of problem .
