AnSniper 19 Posted October 30, 2023 Posted October 30, 2023 (edited) I must now run two Emby servers simultaneously. Because if you use a media library, some images of private videos will appear in the thumbnails of collections/Genres/tags, even if different users are restricted from accessing the media library permissions. If generation cannot be disabled, perhaps the user has a way to customize the switches for these items: Collections/Genes/tags By default, when turned off by the user, these three options will not be displayed in the media library. Just like a Collections media library, users can customize whether to open it on the homepage or not. One or more of them will display XXX images, and the images are only hypothetical. Since I separated them, there are no instances. Edited October 30, 2023 by AnSniper
Solution Luke 42185 Posted October 30, 2023 Solution Posted October 30, 2023 Hi, there is no way to avoid this. In the future we might generate those images separately for each user in order to resolve this issue. What you could do right now is assign your own image to the genre and that will prevent the automatic image from being created. 1
